Like Tree104Likes
 Old 01-30-2017, 04:22 PM   #1
MunkieJunkie's Avatar
Posts: 51   (View Stats)
MunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud ofMunkieJunkie has much to be proud of
Default CTS-V Brake Swap
So I've seen that a bunch of different platforms can do a CTS-V brake swap fairly easy, and its a very good bang for your buck than just about any other brake mod.
Does anyone know if this is possible on an MS3? Obviously it wouldn't be a straight plug and play mod, but maybe with a little bracket fabrication it would be possible.
sarm1084 likes this.
MunkieJunkie is offline   Reply With Quote
The Following User Says Thank You to MunkieJunkie For This Useful Post:
[R]usty (01-31-2017)
 Old 01-30-2017, 04:36 PM   #2
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
BobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the world
I'd like to see where this goes even for a 6, since I'm putting MZ6 rear calipers on mine.
2006 Mazdaspeed 6 GT-unDISI swap in progress
1969 Nova-540BBC-S400's-TH400-sitting on 29.5x10.5
Skreets be calling...
BobtailedSnail is offline   Reply With Quote
 Old 01-30-2017, 04:41 PM   #3
ryguy 3's Avatar
Posts: 353   (View Stats)
ryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond reputeryguy 3 has a reputation beyond repute
Did you message the company that makes the brackets for the subaru?
ctsvbrakeswap@outlook.com
Sent from my SM-G920P using Tapatalk
ryguy 3 is offline   Reply With Quote
The Following User Says Thank You to ryguy 3 For This Useful Post:
Tokay444 (05-13-2017)
 Old 01-31-2017, 06:22 AM   #4
I'll email them right now
sarm1084 (11-09-2018)
 Old 01-31-2017, 01:16 PM   #5
Nailedit187's Avatar
Posts: 153   (View Stats)
Nailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond reputeNailedit187 has a reputation beyond repute
I so would!
2007 MS3: CORKSPORT SRI, BS CBE, RED ROKBLOKZ, CAR SEAT MOD, EBAY TP, TURBOFART BPV
1995 CHEVY K1500
1968 CHEVY C20
2015 FZ09
CRF250R BUILT
Nailedit187 is offline   Reply With Quote
 Old 01-31-2017, 01:32 PM   #6
MoMS3's Avatar
Posts: 235   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
I'd be interested as well...perhaps get a group buy in order to help convince these guys to design one for Mazdaspeeds? I would imagine there is interest in the FoST community too (I'm assuming the same setup would work for both focus and MS3?)
verbalparachute and sarm1084 like this.
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
 Old 01-31-2017, 01:55 PM   #7
Just hang tight guys, I emailed them and waiting on a response.
sharksinspace and sarm1084 like this.
 Old 02-01-2017, 09:20 AM   #8
Djohns's Avatar
Posts: 3,944   (View Stats)
Groans: 112
Would be a good option, anyone know how small of a wheel you can run with these?
2010 black mica speed3
Soon:built motor
 Old 02-01-2017, 09:31 AM   #9
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Why?
I don't really know anything about the brake setup you are referencing, but why? What is the benefit?
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 02-01-2017, 09:34 AM   #10
Djohns's Avatar
Groans: 112
Originally Posted by WetzMS3 View Post
Why?
Would be a decent option for those who need/want big brakes. I believe they are a 4 piston design, and can be had for relatively cheap compared to other big brake kits.
Soon:built motor
The Following User Says Thank You to Djohns For This Useful Post:
 Old 02-01-2017, 09:39 AM   #11
Why?
It would essentially be a BBK for cheap. But a BBK is beneficial for many reasons, and based off the picture alone you can see the differences.
The Following 3 Users Say Thank You to MunkieJunkie For This Useful Post:
impossible (02-01-2017), sarm1084 (11-09-2018), WetzMS3 (02-01-2017)
 Old 02-01-2017, 05:53 PM   #12
MoMS3's Avatar
Keep in mind our rotors are 12.6" from factory and the CTS-V calipers from what I can tell get used with 12.75", so basically not a huge difference there (someone else can do the math to figure out the difference in surface area). The big difference for us is in the unsprung weight, as the stock caliper is ~20lbs I believe and these CTS-V's are about 9lbs per side.
The fact these calipers can be had for $150 new for a brembo 4pot is icing on the cake. Now to see if they've got any interest in "braking" into the Mazdaspeed/FoST market...crossing all my fingers and toes
The Following 3 Users Say Thank You to MoMS3 For This Useful Post:
AnimalMother (02-01-2017), impossible (02-01-2017), sarm1084 (11-09-2018)
 Old 02-01-2017, 06:30 PM   #13
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Already contacted the ctsvbrakeswap.com in June 2016 about it and they never replied.
2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning
The Following 2 Users Say Thank You to impossible For This Useful Post:
sarm1084 (11-09-2018), WetzMS3 (02-02-2017)
 Old 02-01-2017, 09:21 PM   #14
Police - Grammarhead
Vansquish's Avatar
Groans: 1,911
For what it's worth, we'd have to run different rotors than what was OE for the CTS-V. The OE CTS-V rotors are 5x120, and ours are obviously 5x114.3. Furthermore, we would likely run into clearance issues with the calipers much like what the few EVO Brembo swappers have discovered.
The Following 3 Users Say Thank You to Vansquish For This Useful Post:
Djohns (02-01-2017), MoMS3 (02-01-2017), WetzMS3 (02-02-2017)
 Old 02-01-2017, 10:24 PM   #15
impossible's Avatar
Groans: 30
No. Visit ctsvbrakeswap.com and you'll see all those supported platforms with brackets available are 5x114.3 aside from the older WRX's which were 5x100
The Following User Says Thank You to impossible For This Useful Post:
 Old 02-01-2017, 10:26 PM   #16
MoMS3's Avatar
They are running 350z track pkg on nissans and sti rotors on the subies, just need to figure out what works with these...we'd just need to figure out a 5x114.3 rotor that has the proper dimensions. But I didn't think of clearance issues...wonder if calipers off of the Focus RS would be able to be adapted to our platform since they work for FoST
 Old 02-01-2017, 10:27 PM   #17
impossible's Avatar
Groans: 30
misread your comment
deltapsik0 likes this.
MoMS3 (02-01-2017)
 Old 02-01-2017, 10:33 PM   #18
MoMS3's Avatar
I was about to say no shit, Mr knows-every-lug-pattern-off-the-top-of-their-head haha
The Following User Says Thank You to MoMS3 For This Useful Post:
 Old 02-02-2017, 05:36 AM   #19
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
I think the Focus RS brakes would be a killer upgrade for the ms3 if they bolt up properly. Looks like the calipers are ~$180ea, rotors are $80 each and pads are $135ish. If that's a bolt on affair I wouldn't even think twice about it.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post:
Djohns (02-02-2017), MD1032 (05-12-2017), sarm1084 (11-09-2018)
 Old 02-02-2017, 06:30 AM   #20
GroceryGtr's Avatar
Posts: 472   (View Stats)
You aren't going to pick up much on the surface area side, but you'd see a clear increase in clamp strength(possibly a reduction in fade scenerios). My concerns would be loss of modulation(you can certainly overbrake a car) and bias changes with the rear brakes. Part of the benefit of a bbk is knowing it was designed with the aforementioned aspects in mind, well with a quality kits anyways. Unsprung weight reduction is great, but lets be practical here; 90% of people would never notice the difference. Hell outside of a competition track setup I doubt anyone has ever said "Gee I really notice the reduced unsprung weight you have on yours vs. mine". I'm being facetious/douchey, but my point is valid.
 Old 02-02-2017, 06:40 AM   #21
Agreed, for the daily driver application this would be 99% aesthetic. It'd be beneficial for those of us that track/autox our cars, though.
 Old 02-02-2017, 06:49 AM   #22
Vansquish's Avatar
Groans: 1,911
The supported platforms may be, but the CTS-V brake rotors are still 5x120. We'd need some other rotor.
Focus RS rotors are 5x108. We'd need a different solution for rotors even if the calipers are a "bolt on".
Mazdazilla6 (02-02-2017), sarm1084 (11-09-2018), WetzMS3 (02-02-2017)
 Old 02-02-2017, 07:06 AM   #23
ryguy 3's Avatar
Why not just use the STI rotors if they are 5x114.3? If this does go thru the custom caliper bracket could compensate for any minor difference in the rotor hat.
 Old 02-02-2017, 07:41 AM   #24
Are these V1 or V2 calipers we talking about?
 Old 02-02-2017, 08:07 AM   #25
Personal preference really, depending on how much you want to spend. I've seen people swap the regular CTS calipers all the way up to the CTS-V 6 piston.
 Old 02-02-2017, 09:11 AM   #26
Voltwings's Avatar
Posts: 3,713   (View Stats)
Not sure i agree with this. Hydraulic force = Hydraulic pressure x area. Since the master cylinder is the same, the pressure part is constant, and the only change would be piston surface area.
It's slow at work, so i did some googling, and it looks like the CTS-v calipers have a surface area of 5554 sq mm. That works out to a single piston with a radius of 42mm, or 1.6". I am fairly certain the MS3 single piston is larger than 2.2" across (cant find the spec), so i am not sure there will really be any increase in clamping force. At least, not any appreciable increase.
Fixed calipers will help with brake fade and caliper flex, but they really do not increase brake "strength."
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following User Says Thank You to Voltwings For This Useful Post:
 Old 02-02-2017, 09:24 AM   #27
Djohns's Avatar
Groans: 112
Not to derail the subject here but what about ats v calipers?
Soon:built motor
 Old 02-02-2017, 09:32 AM   #28
MoMS3's Avatar
They use those with one of their Subaru kits.
 Old 02-02-2017, 09:52 AM   #29
MoMS3's Avatar
Donny you're out of your element! Dude, the rotors are not the issue here...
Rotors are the easy part. Just need to find another platform's rotors which have the proper offset and whatnot (e.g. STI). We would probably have a wider range of choices for pads (potentially cheaper due to more on the market as well) with a 4-pot vs our oddball calipers. Plus changing pads out on a fixed caliper is generally much quicker in my experience.
The Following 2 Users Say Thank You to MoMS3 For This Useful Post:
ThOrZwAr (02-02-2017), Vansquish (02-02-2017)
 Old 02-02-2017, 09:54 AM   #30
Voltwings's Avatar
Why offset the rotor? I keep seeing everyone say this, if we're having to machine an adapter anyways, offset the frikkin caliper to work with stock rotors...
Past:
-Sold-
-Sold-
Current:
The Following 3 Users Say Thank You to Voltwings For This Useful Post:
Djohns (02-02-2017), impossible (02-02-2017), Vansquish (02-02-2017)
 Old 02-02-2017, 09:59 AM   #31
MoMS3's Avatar
Sorry I'm being unclear, I meant that we need to find a rotor in our lug pattern that has a close enough offset. Ideally we wouldn't need an adapter bracket, which is why I suggested the Focus RS brakes given the possibility that their mounting setup is likely similar to the MS3.
Voltwings (02-02-2017)
 Old 02-02-2017, 10:23 AM   #32
UPDATE:
Here's what they replied to my email.
"Do you have a link to a thread on the forum we could take a look at? Or start a thread to gain interest? If there is enough interest we could start looking into making a Mazda kit."
I'll link them this thread, and I'm sure the more people that see this/the more interest we get the higher chance we have of getting a kit made.
The Following 7 Users Say Thank You to MunkieJunkie For This Useful Post:
impossible (02-02-2017), JSmith (02-02-2017), NC-MS3Rob (02-06-2017), sarm1084 (11-09-2018), sharksinspace (02-02-2017), ThOrZwAr (02-02-2017), [R]usty (02-02-2017)
 Old 02-02-2017, 10:24 AM   #33
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
I'd be interested in a low cost BBK setup.
Genpoo stuff
 Old 02-02-2017, 10:33 AM   #34
Omega's Avatar
Posts: 441   (View Stats)
Omega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the worldOmega is the leader of the world
I'd also be interested in a low cost BBK setup as well on the 6...
2006 Super Clean BCM MS6
Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module
Waiting to be installed: Diff Braces - TMM Insert
Omega is offline   Reply With Quote
 Old 02-02-2017, 10:35 AM   #35
[R]usty's Avatar
Posts: 2,204   (View Stats)
[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world
Groans: 79
I'm 100% interested.
2010 Mazdaspeed3 w/tech
Cobb AP V3JBR Tru 3" Wide PathJBR Boost Tubes & BPV HoseCobb XLE BPVCP-E TMIC ║ UR Racepipe ║ Magnaflow CBEAutoTech InternalsGrimmSpeed EBCS ║ JBR RSBSPC Camber ArmsKW V3 CoiloversJBR IM+TB TIGs & TB BypassJBR SSPE - Focus RMMStopTech Slotted Rotors and EBC Yellow Stuff PadsTechna-Fit SS Brake Lines
[R]usty is offline   Reply With Quote
 Old 02-02-2017, 11:16 AM   #36
Djohns's Avatar
Groans: 112
I wish them the best of luck on this forum we are very unusual people, but I too am interested.
Soon:built motor
 Old 02-02-2017, 11:19 AM   #37
AnimalMother's Avatar
Posts: 366   (View Stats)
AnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the world
Definitely interested.
Juan on meth
AnimalMother is offline   Reply With Quote
 Old 02-02-2017, 11:29 AM   #38
Omega's Avatar
It may also be wise to solicit MSO and see if there's interest there.... The more interest from the community as a whole the better chance this will have of coming to fruition.
 Old 02-02-2017, 11:44 AM   #39
Djohns's Avatar
Groans: 112
I can check with them if OP doesn't have an account. Maybe even the facialbook homos? I don't have a Facebook so someone else would need to check with them.
Soon:built motor
 Old 02-02-2017, 11:49 AM   #40
Yeah I don't have an account there, you could pop on over and see if there's any interest.
Miata v8 swap vs rx7 v8 swap blake0521 Miata - General Questions 13 01-21-2015 07:05 PM
GREEK MAZDA 3 MPS XYZ 6-POT BRAKE KIT SERVICE - NEW BRAKE PADS FERODO DS 2500 & NEW CASTROL REACT SRF RACING BRAKE FLUID dgiannitakis MazdaSpeed 3/6 - Suspension & Brakes 5 05-05-2014 01:30 PM
New big brake possibilities? We share front brake calipers with audis/vws breakfasteatre MazdaSpeed 3/6 - Suspension & Brakes 15 11-03-2012 09:18 PM
Hawk HPS brake pads & Goodridge brake lines in stock for the 07-11 MS3. Chris@Xtreme Mazdaspeed3/6 General Discussion 3 08-06-2011 08:56 PM
Hawk Pads, Racing Brake Lines, and ATE Brake Fluid! Race Roots Mazdaspeed3/6 General Discussion 11 09-25-2009 02:04 PM
Page generated in 0.64784 seconds with 36 queries
