Like Tree102Likes
 Old 08-03-2017, 11:16 AM   #121
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Originally Posted by MoMS3 View Post
If DM is going to be designing a bracket for the MS3 then I'd say absolutely go that route, but if they're only designing brackets for the MS6, then us MS3 guys are SOL.
For something that popular I feel like DM would make them for both. At least we had better hope so !
Well if you're talking about the yellow 6-piston calipers, those are $310 apiece vs $100-150...that said, most of the 4-piston come bare metal, so that means you can powder coat them as you see fit.
The 6 pistons are sick. But 4 pistons can probably do the job just fine for what I'm shooting for. Much more clean than painting stock calipers
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
 Old 08-03-2017, 11:23 AM   #122
MoMS3's Avatar
Posts: 232   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
Yeah, I'd be surprised if DM didn't go ahead and make the brackets for us MS3 folks given the interest, I'd also think the MS3 version would be interchangeable with FoST which would make it a more worthwhile venture.
An issue with the 6 piston versions is that their combined piston area is too far off our stock calipers, which throws off brake bias in an undesirable manner. Granted there are ways to adjust the bias to account for this, but at that point you're getting into the realm of why bother, since there are plenty of other options that would fall within the same price range that are engineered to maintain factory brake bias.
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
 Old 08-10-2017, 01:28 PM   #123
Bexar's Avatar
Another week gone by...wish there was an update on the brake brackets!
JBR:
The Following User Says Thank You to Bexar For This Useful Post:
impossible (08-14-2017)
 Old 08-18-2017, 09:15 AM   #124
Bexar's Avatar
Still no update? Can't wait to get some on my car. Just saw a photo on instagram of someone putting yellow Cadillac calipers on their speed. Looks amazing
JBR:
 Old 08-18-2017, 09:41 AM   #125
mituc's Avatar
Posts: 3,504   (View Stats)
Groans: 111
Yeah, I'm done waiting, my pot with patience is empty. I will phoken order a set of CS front calipers and paint the rears. I wish I could fit some OEMs of any kind (FoRS, CTS-V, whatever) but some good aftermarket will work. Or I will get new OEMs, the ones I have are baked after 9+ years of hooning around.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 08-18-2017, 10:30 AM   #126
Bexar's Avatar
Just something about painting stocks looks horrible. Guy I know in town has a black pu with calipers he painted a year or two ago. They look light red and the paint is flaking.
Those GM calipers look great tho
If nothing happens, later this year I will seriously look at designing and possibly producing my own brackets to fit the aforementioned calipers on an off the shelf rotor. I'm a stickler for beautiful brakes
JBR:
 Old 08-18-2017, 11:42 AM   #127
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,895   (View Stats)
Groans: 539
it looks bad because most people don't do it correctly, because it's a fuckload of work.
94 M
06 MS6
 Old 08-18-2017, 03:26 PM   #128
aackthpt's Avatar
Posts: 1,450   (View Stats)
aackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the world
I don't want the flash. So if I were to paint my stock ones, it'd be mostly so it is easier to keep them clean and to make every look less grimy. As such I would paint them gray.
So, for me the gray painted V calipers would do exactly what I want.
Front: https://www.amazon.com/ACDelco-172-2.../dp/B0010G0HP6
Rear: https://www.amazon.com/ACDelco-172-2.../dp/B000S2Q5O0
I'd strongly consider this in the future even though I have new rotors and RedStuff on deck...
2013 'speed3, silver
Stage Bro
aackthpt is offline   Reply With Quote
 Old 09-12-2017, 12:16 PM   #129
HardCruise's Avatar
Posts: 5   (View Stats)
HardCruise is an unknown quantity at this point
Still nothing?
HardCruise is offline   Reply With Quote
 Old 09-12-2017, 12:24 PM   #130
MoMS3's Avatar
Originally Posted by HardCruise View Post
Still nothing?
Two weeks...
monkey.bones.007 likes this.
 Old 09-13-2017, 09:43 AM   #131
Bexar's Avatar
Waiting game
JBR:
 Old 09-19-2017, 09:13 PM   #132
rik881's Avatar
Posts: 14   (View Stats)
rik881 will become famous soon enough
I want big brakes for small bucks. Painted stock calipers are dumb.
rik881 is offline   Reply With Quote
 Old 10-02-2017, 08:09 PM   #133
Atomic41's Avatar
Posts: 1,167   (View Stats)
Atomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond repute
Groaned at 38 Times in 26 Posts
news here ...
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
Atomic41 is offline   Reply With Quote
 Old 10-02-2017, 10:03 PM   #134
mituc's Avatar
Groans: 111
Nah... was a good idea but it looks like it's dead.
 Old 10-03-2017, 05:32 AM   #135
Atomic41's Avatar
Someone must keep the project alive ... it's really a good idea
 Old 10-15-2017, 04:46 PM   #136
Juschiln19's Avatar
Posts: 157   (View Stats)
Juschiln19 is a jewel in the roughJuschiln19 is a jewel in the roughJuschiln19 is a jewel in the roughJuschiln19 is a jewel in the rough
Bumped interested....
06 MS6 GT / Black \ Moonroof - Sure Torq Motor Mounts All(Aggressive) - Sure Diff Mounts - Sure Thermal Gaskets - DM Stage 3 Dual OCC'S - DM Pcv Vent Plate - Magnetic Oil Plug - BNR S4 V2 - Speed Proformence Tranfer Case Bearing Caps - Guardian Angel - Grimmspeed EBCS - JBR Egr Delete - Turbosmart Dual Port BOV(100% To Air) - HTP 3.5" Full Intake W/Recir. Hose Blocked - Strut Tower Bar Front - Whiteline Rear Sway Bar W/Adjustable Links - EBC Stage 4 Brake Kit F&B - Bosch 3.5 Bar Map -Autotech HPFP - CX Racing FMIC Pipe Kit W/ Tr6 Core FMIC - South Bend /Stage 2 Daily Clutch W/ Lightweight Flywheel - Continental Extreme Contact DWS06 - Block8Head Custom Triple Vent Gauge Pod - 3in1 Glow Shift Gauge (Boost/Oil Temp/Oil Pressure) - Glow Shift Gauge (Oil Pressure W/Alarm) - One Step Colder Denso Plugs - Escort Max Radar Detector - Mazda 3(S6 Oil Cooler Delete) Oil Filter Housing - Rev 5 Front Mount Oil Cooler - Thermostatic Controlled Oil Filter Sandwich Plate W/Sensor and Oil Cooler Connections - Rotella T6 Oil - Versatuner w/Tablet - Reinforced Clutch Pedal Assembly
Juschiln19 is offline   Reply With Quote
The Following User Says Thank You to Juschiln19 For This Useful Post:
Atomic41 (10-16-2017)
 Old 10-16-2017, 02:49 PM   #137
macdiesel's Avatar
Posts: 824   (View Stats)
macdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the world
If I was a betting man I’d say this is dead in the water.
2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts//
Coming up: Corksport injector seals
macdiesel is offline   Reply With Quote
 Old 10-19-2017, 11:14 AM   #138
Bexar's Avatar
Still interested, this isn't dead
Atomic41 likes this.
JBR:
 Old 10-25-2017, 12:51 AM   #139
SpeedyTurd's Avatar
Posts: 35   (View Stats)
SpeedyTurd has a spectacular aura aboutSpeedyTurd has a spectacular aura aboutSpeedyTurd has a spectacular aura about
Interested! I really hope this happens soon.
SpeedyTurd is offline   Reply With Quote
 Old 11-13-2017, 08:47 AM   #140
Bexar's Avatar
Been a minute but I have faith that someone. somewhere, still cares a little about this idea
JBR:
 Old 11-13-2017, 08:57 AM   #141
MoMS3's Avatar
I definitely am still interested now I'm running 17x9 rpf1's and the RS brakes are a no-go.
 Old 11-13-2017, 04:40 PM   #142
JakeMS3's Avatar
Posts: 1,160   (View Stats)
JakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the worldJakeMS3 is the leader of the world
Groaned at 7 Times in 5 Posts
I picked up a Wilwood BBK 6 Piston from edge, came with the 2 piece rotors, stainless lines, pads and calipers and of course the brackets needed to make it work. It’s a bolt on kit as well. It was $1050 shipped to the door.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
Corksport Catted DP/HPFP Internals
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
JakeMS3 is offline   Reply With Quote
 Old 11-13-2017, 04:46 PM   #143
JakeMS3's Avatar
Posted that above for the guys who still want a BBK for a good price. They’re out there, just have to search on the net. I almost went with the CS calipers but once I priced them along with new rotors and pads stainless lies, I was in the $1200 range.
2013 LSM w/tech
Cobb AP V3, CBE
DM OCC/TMM
Forge V2 BPV
Wilwood 6 pot BBK
 Old 11-15-2017, 10:25 AM   #144
Bexar's Avatar
I'm not about it. What I do see myself doing is picking up some used calipers on the cheap off eBay or something. Not looking to dish out that much for a BBK, although a price like that is to be expected. Pair the used calipers with some hopefully relatively inexpensive brackets and hopefully we can see a more affordable kit
JBR:
 Old 11-15-2017, 12:26 PM   #145
Djohns's Avatar
Posts: 3,945   (View Stats)
Groans: 112
I think at this point it wouldn’t be a bad idea to just get a list of cars that have the same hub pattern as we do and start looking into their brakes.
2010 black mica speed3
Soon:built motor
 Old 11-20-2017, 09:58 AM   #146
Bexar's Avatar
https://www.wheel-size.com/pcd/5x114.3/
So we did confirm at least that the Focus RS caliper will bolt up directly? As in the brake lines will just bolt in? So the challenge is to find the correct rotors and pads?
JBR:
 Old 11-20-2017, 10:39 AM   #147
MoMS3's Avatar
I don't think the brake line subject was broached per se, however I'd imagine brake lines for a FoRS should in theory mate up to the Mazda connections without issue (correct me if I'm wrong).
The caliper bolts up to the existing caliper mount per Matt@Damond, however it sounds like the holes in the knuckle that the caliper mounting bolts go through will have to be bored out to accommodate the FoRS caliper bolts (unsure how much bigger holes need to be).
Pads will should just be stock FoRS sizing, no need to adapt anything there, and as for the rotors, the stock FoRS rotors will work with a bit of machine work. The hub center bore will need to be increased from 63.4mm to 67.1mm dia. and the lug pattern will have to be adapted from 5x108 to 5x114.3, which will essentially make the holes a bit oblong (each will be drilled out roughly 3mm further from hub center, if that makes sense).
In other words, doable with some adaptation, should be pretty straight forward though. The only other thing to consider is the wheel size needed to run the FoRS brakes, Matt mentioned that you need a minimum of 18" wheels to clear calipers, not sure on offset but I figure going off the RS specs would be a good start there.
The Following 2 Users Say Thank You to MoMS3 For This Useful Post:
Bexar (11-22-2017), macdiesel (11-20-2017)
 Old 11-22-2017, 09:12 AM   #148
Bexar's Avatar
It would be awesome to find a drop in rotor ..... all that extra work is extra $ .... surely there exists a 5x114 rotor off the shelf for some other car. Just would need to do alot of test fitting
JBR:
 Old 11-22-2017, 09:30 AM   #149
JamesHansenDTD's Avatar
JamesHansenDTD will become famous soon enough
Damond motorsports has a CTS-V brackets under development right now. I don't know what the eta is on them.
JamesHansenDTD is offline   Reply With Quote
 Old 11-22-2017, 10:37 AM   #150
MoMS3's Avatar
That is going to be tough to track down methinks, the FoRS rotors have an oddball thickness (25mm) and everything I'm seeing which is going to be similar diameter and offset are anywhere between 30-32mm thick.
Our stock rotors fit the bill aside from the fact they're 320mm vs 350mm in diameter.
 Old 01-04-2018, 04:29 PM   #151
Wp.Chris's Avatar
Posts: 17   (View Stats)
Wp.Chris will become famous soon enoughWp.Chris will become famous soon enough
Bump, still crossing fingers
Bexar likes this.
2008.5 CWP | JBR RMM | JBR TMM | JBR PMM | COBB SRI | COBB TIP | AUTOTECH HPFP | CORKSPORT ADJUSTABLE STRUT | H&R SPRINGS |
Wp.Chris is offline   Reply With Quote
 Old 01-11-2018, 01:37 PM   #152
Bexar's Avatar
Same, hoping to hear something on this
JBR:
 Old 08-08-2018, 01:18 PM   #153
MichaelAress's Avatar
Posts: 8   (View Stats)
MichaelAress can only hope to improve
Groaned at 6 Times in 2 Posts
Default CTS V Brake Swap
Hi guys
Im swapping out a power brake system from one 1971 LeMans into another. Im taking the power booster, pedal rod and master cylinder off the car with the power brakes and dropping them into the non-power one. Do I need to swap the proportioning valve as well?
Thanks
MichaelAress is offline   Reply With Quote
The Following 2 Users Say NO Thank You to MichaelAress For This Un-useful Post:
Db09ms3 (08-08-2018), Vansquish (08-08-2018)
 Old 08-08-2018, 03:54 PM   #154
Db09ms3's Avatar
Posts: 281   (View Stats)
Groans: 65
Originally Posted by MichaelAress View Post
Hi guys
Thanks
Wrong topic doober. BUT yes, you should. Doesn't the GM A-body have a forum? Peep that shit son.
Stockish
 Old 11-09-2018, 03:21 AM   #155
sarm1084's Avatar
Posts: 11   (View Stats)
sarm1084 is on a distinguished road
Groaned at 5 Times in 2 Posts
Originally Posted by KingKhan View Post
Would also be interested if they made a kit for the speed 6
Evo front brembo calipers have already been proven to fit the MS6 with little modification and no bracket. I've seen it on YouTube and I'm sure its on the forums.
Sent from my VS835 using Tapatalk
Future
Gen1 Owner,... Hopefully! lol
sarm1084 is offline   Reply With Quote
 Old 11-11-2018, 12:08 PM   #156
Fstrnyou's Avatar
Posts: 2,148   (View Stats)
Good job quoting an 18 month old post and thinking you're contributing.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
Miata v8 swap vs rx7 v8 swap blake0521 Miata - General Questions 13 01-21-2015 07:05 PM
GREEK MAZDA 3 MPS XYZ 6-POT BRAKE KIT SERVICE - NEW BRAKE PADS FERODO DS 2500 & NEW CASTROL REACT SRF RACING BRAKE FLUID dgiannitakis MazdaSpeed 3/6 - Suspension & Brakes 5 05-05-2014 01:30 PM
New big brake possibilities? We share front brake calipers with audis/vws breakfasteatre MazdaSpeed 3/6 - Suspension & Brakes 15 11-03-2012 09:18 PM
Hawk HPS brake pads & Goodridge brake lines in stock for the 07-11 MS3. Chris@Xtreme Mazdaspeed3/6 General Discussion 3 08-06-2011 08:56 PM
Hawk Pads, Racing Brake Lines, and ATE Brake Fluid! Race Roots Mazdaspeed3/6 General Discussion 11 09-25-2009 02:04 PM
Page generated in 0.54656 seconds with 39 queries
