  • 1 Post By MSMS3
 Old 08-11-2018, 08:33 PM   #1
mgeoffriau's Avatar
Posts: 17   (View Stats)
mgeoffriau has a spectacular aura aboutmgeoffriau has a spectacular aura about
Default Deal Alert: Front End Links w/ Zerks, $3.94 apiece
Just a heads up, was browsing RockAuto's closeout section for the Gen1 MS3 and noticed these:
Granted, these could be crap. But, for $3.94 apiece, I'm willing to take a chance. They look decent, thicker than stock and with Zerk fittings. My total was $15.38 with shipping and a 5% coupon code.
Find them here (listed as API 2700257956, first entry in the Economy section):
https://www.rockauto.com/?carcode=1443711&parttype=7580
2009 MS3 | Pretty Much Stock
mgeoffriau is offline   Reply With Quote
The Following 2 Users Say Thank You to mgeoffriau For This Useful Post:
KiwiFlavor (08-13-2018), Solarsurge (08-15-2018)
 Old 08-12-2018, 06:20 AM   #2
MSMS3's Avatar
Posts: 2,361   (View Stats)
Groans: 133
You are likely to find that the top zerks hit the fenderwell in front. Those on the Moog end links did.
Once they hit they fuck up the threads, so it is best to fill them first (they are likely to be shipped dry) then remove the top zerk and plug the hole with a very short capscrew.
I like zerk fitting end links and use them. But there is a serious clearance issue in front at the top.
KiwiFlavor likes this.
 Old 08-13-2018, 05:16 AM   #3
KiwiFlavor's Avatar
Posts: 2,443   (View Stats)
Can attest. I did that with my moog.
Anyway, still a nice find OP!
2012 NASA Spaceship Gray MS3
MSMS3 (08-13-2018)
 Old 08-13-2018, 08:23 AM   #4
mgeoffriau's Avatar
Yup, saw that in the Moog threads and planned to do the same here.
The Following User Says Thank You to mgeoffriau For This Useful Post:
MSMS3 (08-15-2018)
 Old 08-15-2018, 04:31 PM   #5
MSMS3's Avatar
Groans: 133
That's an amazing deal, though! You can also install the low profile zerks on the upper part. They use a needle grease fitting. They look like this. I'm running them, but don't remember the thread size right now.
 Old 08-15-2018, 07:21 PM   #6
Solarsurge's Avatar
Posts: 570   (View Stats)
I just bought them all. Now available for $10.00 apiece. lol J/K
Good find.
how i finally got my awr front links to stfu! leo766 MazdaSpeed 3/6 - Suspension & Brakes 16 09-25-2015 11:16 AM
Installing front sway bar links buckeyepost MazdaSpeed 3/6 - Suspension & Brakes 7 10-20-2012 09:05 PM
front sway end links ericrapp0507@gmail.com 2010 MS3 - Suspension & Brakes 27 08-25-2011 05:59 AM
Page generated in 0.47876 seconds with 24 queries
