 Old 11-07-2008, 09:09 AM   #1
red07's Avatar
Posts: 290   (View Stats)
red07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant future
Default endlink upgrade needed w/ ASB upgrade?
Hey all,
Looking to buy some Hotchkis ASB's, based on Laloosh's (and others') recommendations.
Do I need to upgrade the endlinks as well? Not too worried about the adjustment factor, but I am concerned whether the bigger, stiffer ASB's may bend or break the stock endlinks.
red07 is offline   Reply With Quote
 Old 11-07-2008, 01:12 PM   #2
Wagonman's Avatar
Posts: 8   (View Stats)
Wagonman is an unknown quantity at this point
I have not heard of people breaking the stock end links. I know some, myself included, installed adjustable endlinks on the front in order to reduce the endlink length. With shorter endlinks there is less chance of the swaybar hitting the frame. Mine are the awr endlinks set to be as short as possible and work fine.
Wagonman is offline   Reply With Quote
 Old 11-07-2008, 01:18 PM   #3
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
bykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the world
Groans: 38
ya it's best to upgrade the endlinks if you can when you do the swaybars, you can use the stock ones but they are not the best, especially when you start upgrading other suspension parts. I work right by AWR and their stuff is really good over there.
bykeryder4life is offline   Reply With Quote
 Old 11-07-2008, 02:35 PM   #4
CHIEFSMS3's Avatar
Posts: 163   (View Stats)
CHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud ofCHIEFSMS3 has much to be proud of
I have the Hotchkis front and rear bars.
When I installed them I also installed the AWR adjustable end links.
I had problems with clunking and the nuts loosening.
So I contacted AWR to find out what torque that they recommended.
When I told them that I had the Hotchkis bars I was told that was my problem.
AWR said that their endlinks were designed for the OEM bars not for bars as thick as the Hotchkis bars.
The threads on the AWR endlinks is not long enough for the lock nuts to thread on completely so they continously loosen.
I went back to the stock endlinks and loctited the nuts and have had no more problems.
Thats my $.02
CHIEFSMS3 is offline   Reply With Quote
 Old 11-07-2008, 02:45 PM   #5
red07's Avatar
Ah, that is very good to know. I'm going w/ the Hotchkis bars, so I am in the same boat. I'll save ~170 bucks and get just the bars.
 Old 11-08-2008, 12:32 AM   #6
MTuning's Avatar
Posts: 362   (View Stats)
MTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond reputeMTuning has a reputation beyond repute
Groaned at 16 Times in 8 Posts
so is that the general opinion? stock end links on aftermarket sway bars?
MTuning is offline   Reply With Quote
 Old 11-11-2008, 05:11 AM   #7
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
AutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond repute
If you are upgrading your sway bar, upgrade the endlinks!!! The stock ones are crap and the ball joint fails... Mine failed on the stock bar...
2008 Stage 3 Roush Mustang
302E 5.0L Stroker 647rwhp-620 rwtq
AutoXRacer is offline   Reply With Quote
 Old 11-11-2008, 08:31 AM   #8
CHIEFSMS3's Avatar
So what did you upgrade to?
The AWR's don't work on Hotchkis bars.
I haven't found any other options!!!
 Old 11-11-2008, 08:40 AM   #9
AutoXRacer's Avatar
I'm still on stock sways... I have the AWRs.
Thats my $.02
Why not just buy longer bolts?
 Old 11-11-2008, 08:52 AM   #10
MTuning's Avatar
how do i upgrade my end links if the aftermarket end links wont work with my RSB. i guess ill have to change the studs on them than.
 Old 11-11-2008, 08:54 AM   #11
CHIEFSMS3's Avatar
It is not longer bolts.
It is the lower threaded heim that is the problem.
It is not long enough to let the lock nut properly
engage the threads to secure the bar to the endlink.
This is because of the added thickness of the Hotchkis bar
and probably the Cobb bars.
 Old 11-11-2008, 01:00 PM   #12
Groans: 38
we should contact AWR and tell them to fix it or make a separate set for peeps with upgraded sways like Hotchkis
 Old 11-26-2008, 12:34 AM   #13
Jackal
Breakdown81's Avatar
Posts: 869   (View Stats)
Breakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the world
Groans: 56
Racing beat also makes a set of upgraded links for the sway bars. The caveat is that they are branded as an MZ3 option. I would suggest contacting Racing Beat and confirming if their product is applicable to the MS3 and hotchkis bars. I believe they may be as they are originally made to be used with Racing Beats own sway bars. Racing beats Front sway bar is 28.5mm in thickness hotchkis' FSB is 29mm, while the RB rear bar is 27.0 mm and the Hotchkis RSB is 32mm. RB only makes upgraded endlinks for the FSB.
Racing Beat can be reached at 714-779-8677
Tom Anderson
We can make you LOOK fast.
www.juicemonkeyinc.com
Breakdown81 is offline   Reply With Quote
CDFP Upgrade ev0nstispanka Mazdaspeed3/6 General Discussion 420 02-15-2009 02:52 PM
Turbo Upgrade ?? ludddwig MazdaSpeed 3/6 - Turbo Induction 5 11-03-2008 11:45 PM
Eee PC gets an upgrade Haltech Computers & Technology News 0 04-15-2008 01:00 PM
Want to upgrade that leaky valve... kneedragger241 MazdaSpeed 3/6 - Turbo Induction 22 03-18-2008 08:13 AM
Page generated in 0.38519 seconds with 26 queries
