 Old 04-16-2011, 05:30 AM   #1
posty's Avatar
Posts: 128   (View Stats)
posty is the leader of the worldposty is the leader of the worldposty is the leader of the worldposty is the leader of the worldposty is the leader of the worldposty is the leader of the worldposty is the leader of the worldposty is the leader of the worldposty is the leader of the worldposty is the leader of the worldposty is the leader of the world
Default Fat Cat Bumpstops Halp
Installing some FSDs today, and I noticed the FatCat rear bumpstops I have are a smaller diameter than the stock bumpstops, so they won't stay in the upper mount.
What have people done to remedy this? I know the FatCats are recommended a lot, so I figure someone has dealt with this.
EDIT: I picked up a 1 1/2" ID "quik pipe" coupler and will try that.
posty is offline   Reply With Quote
The Following 2 Users Say Thank You to posty For This Useful Post:
ak_spray (01-30-2012), S-hendrix (12-27-2011)
 Old 04-16-2011, 02:11 PM   #2
posty's Avatar
Ok so I got the FSDs all installed today without too many problems.
The flexible PVC coupler was an awesome buy, I was able to use the single coupler for all 4 bump stops.
Pic of the coupler (get a 1 /12"):
Here are some pics of using it:
Top mount for rears
Rears mounted
Front bump stop
Front again
Last edited by posty; 06-15-2011 at 08:50 PM. Reason: resized images with less artifacting
The Following 8 Users Say Thank You to posty For This Useful Post:
Design (04-16-2011), dkapetansky (09-17-2011), IMASA (06-15-2011), JTMS3 (04-23-2012), Kawiralph (07-12-2012), macdiesel (02-13-2016), S-hendrix (12-27-2011), Tommy (10-22-2012)
 Old 04-16-2011, 02:21 PM   #3
ScarMS3's Avatar
Posts: 2,088   (View Stats)
ScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the worldScarMS3 is the leader of the world
Groans: 97
Groaned at 31 Times in 25 Posts
That camera doesn't like your skin and fingernails, good job on rigging it up proper
ScarMS3 is offline   Reply With Quote
The Following 2 Users Say Thank You to ScarMS3 For This Useful Post:
karl-hungus (04-16-2011), posty (04-26-2011)
 Old 04-16-2011, 02:22 PM   #4
posty's Avatar
Haha - the camera was awesome, I just used a shitty resizer app.
 Old 04-16-2011, 06:20 PM   #5
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
you fancy moutherfucker.
The Following 3 Users Say Thank You to karl-hungus For This Useful Post:
posty (04-17-2011), RacerX78 (10-05-2011), ScarMS3 (04-16-2011)
 Old 04-16-2011, 07:20 PM   #6
dan7225's Avatar
Posts: 511   (View Stats)
dan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the worlddan7225 is the leader of the world
anybody decide to ditch the rear shock covers in the back and use shock boots instead?
what did you use for a shock boot on the fronts?
i ditched the front yellow thingy because it limits almost a 1/2" of travel.
dan7225 is offline   Reply With Quote
 Old 04-16-2011, 07:43 PM   #7
posty's Avatar
I used the original boot, just zip tied it to the strut at the bottom
The Following User Says Thank You to posty For This Useful Post:
ak_spray (01-24-2012)
 Old 04-16-2011, 09:08 PM   #8
Design's Avatar
Posts: 1,885   (View Stats)
Groaned at 9 Times in 5 Posts
Nice retrofit OP.
09 CWP MS3 GT
Ownership & Build Thread
Design is offline   Reply With Quote
The Following User Says Thank You to Design For This Useful Post:
posty (04-26-2011)
 Old 04-22-2011, 10:13 AM   #9
dan7225's Avatar
I did the same but the oem shock boot is so much bigger around than the strut housing it kind of looks like crap with it all bunched up.
i completely removed the front bump stops, so i might go back in one day and put in some small bump stops and shock boots to clean up the look.
same for the rear, the bilsteins come with a paper thin shock cover that will eventually crack. the oem shock cover is a much sturdier piece but will not fit over the bilstein shock body because it is a larger diameter than oem.
i also dont care too much for the way the oem style shock covers are held up by the bump stops. it eats into the bump stop after a while and wears it out.
 Old 06-14-2011, 12:17 PM   #10
Shaikh@FatCat's Avatar
Posts: 2   (View Stats)
Shaikh@FatCat is an unknown quantity at this point
Great improvement! I'm going to link to this thread on our site.
Shaikh@FatCat is offline   Reply With Quote
 Old 06-15-2011, 02:47 PM   #11
patrick failman
Groans: 74
mine are still holding with the gorilla glue. thanks for taking my call when i was installing them, shaikh.
 Old 06-15-2011, 08:51 PM   #12
posty's Avatar
Awesome! I replaced the images with less-artifacted versions of more reasonable size!
Cheers!
SKiZ0TT (07-22-2011)
 Old 09-17-2011, 07:46 AM   #13
heeltoe's Avatar
Posts: 387   (View Stats)
heeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond reputeheeltoe has a reputation beyond repute
Groaned at 8 Times in 7 Posts
i used the stock front boot and the yellow bottom cover and drilled the hole bigger and everything fitted like stock just straight bolt on.
///KW V2 Coilovers///AWR F&R///HyperTech-Tune///HKS Intake Black Edtion///Bilstein Sport///Eibach Pro-Kit///CP-E Rear Mount///CP-E Passenger Mount 75///CP-E Driver Mount 75///Act Stage 1 Streetlite///Hawks HPS F&R///Goodridge SS Brake Line///Hotchkis F&R///Corksport Front Endlinks///Turbo Smart Dual Port BOV///SPC Rear Camber Arms///Cobb Short Shifter///Cobb Red Knob///Cobb AP V3. Stg-1+Cobb SF+TIH+91///Cobb Downpipe///Cobb Exhaust///Cobb SF///Corksport Cobb SF Cold Air Box///IVT-22,0.028///Corksprort LED///Sure Turbo Inlet///Silicone Boost Hose///J-Speed SSP///Rally Armor Mud Flaps///JDM Window Visor///IR30 Tint///Yellow Fog Light Overlay///CPE-TowPlate///PTP Baffle Plate///MF Magnetic Tans & Oil Bolt///ProClip,GPS,AP,I5///
heeltoe is offline   Reply With Quote
The Following User Says Thank You to heeltoe For This Useful Post:
SKiZ0TT (09-19-2011)
 Old 09-19-2011, 09:07 AM   #14
SKiZ0TT's Avatar
Posts: 542   (View Stats)
SKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the worldSKiZ0TT is the leader of the world
Groans: 33
I did the same for my Koni Yellow / Eibach setup.
2008.5 MAZDASPEED3 GT - SOLD
2004 MAZDASPEED Miata
SKiZ0TT is offline   Reply With Quote
 Old 10-02-2011, 02:31 PM   #15
theurgy's Avatar
Posts: 2,580   (View Stats)
I just wanted to say thanks for the tip, I figure I will post another tip.
Since Canada doesn't have an Ace Hardware, I was still able to find these at my local Home Depot under the Pro-Connect by NCI Marketing brand name.
Got the 1-1/2" x 1-1/2" Flexible Coupling.
I figure this is a pretty generic part but I wanted to post up how easy it was for me to find this piece.
Finally, you say you used one of these for all 4 stops.
I take it you used the ends for the rears... how much did you cut them at?
I also figure you used the inner part of that coupling to put on the front mounts.
It looks like you cut out a 5mm strip, what did you use to cut it?
Just a sharp exacto knife? Hack saw? Dremel?
theurgy is offline   Reply With Quote
 Old 10-02-2011, 02:33 PM   #16
patrick failman
Groans: 74
you may not have ace hardware in canada, but you got tradition.
 Old 10-02-2011, 04:09 PM   #17
theurgy's Avatar
Can't deny it... that's how we roll here in Canada.
 Old 10-02-2011, 07:20 PM   #18
posty's Avatar
Yes I used the ends for the rears, just cut them to fit the depth of the mount, use half of the remainder for the fronts.
A simple razor blade will do nicely.
 Old 10-05-2011, 03:28 PM   #19
theurgy's Avatar
Just installed these yesterday... holy crap I have to say I'm glad I picked up these bumpstops. All 4 of my stock bumpstops were finished. (Pics coming later).
 Old 10-05-2011, 07:05 PM   #20
theurgy's Avatar
As promised:
New FatCat Motorsport bumpstops:
Old completely finished stock bumpstops:
 Old 10-05-2011, 10:02 PM   #21
Manny's Avatar
Posts: 1,185   (View Stats)
Manny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the world
Groans: 320
Groaned at 78 Times in 45 Posts
sweet yellow sock
Manny is offline   Reply With Quote
 Old 10-05-2011, 10:37 PM   #22
theurgy's Avatar
lulz... that's my girl's
 Old 10-06-2011, 07:29 AM   #23
SKiZ0TT's Avatar
Groans: 33
Those bump stops
 Old 12-27-2011, 09:39 PM   #24
S-hendrix's Avatar
Posts: 1,410   (View Stats)
S-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the world
Great post. Will be using this when my fat cats arrive.
BNR S3 . FREEKTUNED . COBB FMIC . COBB CBE . SURE full 3" . CPe Safe Seals . KMD Internals . Grimmspeed EBCS . Guardian Angel . TWM Short Shifter Replacement . MSD DashHawk V2 . Turbo XS DP+RP . Turbosmart Hybrid BOV (full recirc) . JBR SSP+Bushings+Knob/ Rear Sway Bar/ Rear Camber Arms . Sure PMM/TMM . JBR EGR Delete . AWR Adjustable Front/Rear Endlinks . TRZ Dogbone RMM . Denso ITV-22 . Eibach Sport Line . Koni Yellows
S-hendrix is offline   Reply With Quote
 Old 01-07-2012, 12:37 PM   #25
mrdouble99's Avatar
Posts: 256   (View Stats)
mrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the world
Groaned at 4 Times in 2 Posts
Can they be use on stock shock ?
Mazdaspeed3 - sold
- Engine: Cobb AccesPort - Sure Full3 Aeros ID300 - Autotech internal - CP-e 3" cated Downpipe - CP-e xflex RMM 75A - Street: H&R spring - Koni Yellow - SPC camber kit - Team Dynamic Pro Race 1.2 18X8 et50 - BFgoodrich Gefroce KDW2 235/40R18
- Drag : 16x8 et50 FD wheel - Hoosier Quick Time Pro D.O.T. 26x9.5x16 -
- 2010 drag time : 12.737@108.51mph - 259whp@280wtq
- 2013 drag time : 12.432@111.02mph - 28?whp@3??wtq
2014 Black Mazda 6 GT MT
- Corksport Lowering Spring - Corksport LED fog Light Kit - Corksport LED Interior Light Kit - Corksport Shifter bushing
- RX8 R3 19x8 et47 wheels - Michelin PSS 245/40ZR19
- 3M Gloss Black Chrome Wrap
- Autoexe Shifter Knob
mrdouble99 is offline   Reply With Quote
 Old 01-23-2012, 11:55 AM   #26
SKiZ0TT's Avatar
Groans: 33
Question:
I have the FatCat rear bumpstops, and with a larger person in the back seat (225lbs) i get some really nasty rubbing over long / short dips in the rear.
Can this be alleviated by going to the stock length bump stop? I do have rear camber arms...
 Old 01-23-2012, 12:00 PM   #27
patrick failman
Groans: 74
why you making the wife ride in back? jk.
fat cat rear bump stops are shorter than oem so you'd get even more rubbing with the latter.
The Following User Says Thank You to karl-hungus For This Useful Post:
SKiZ0TT (01-23-2012)
 Old 01-23-2012, 12:17 PM   #28
theurgy's Avatar
BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob.
To be installed: SS Brake Lines.
 Old 01-23-2012, 12:42 PM   #29
SKiZ0TT's Avatar
Groans: 33
lol wife..
I was thinking since the OEM bump stops are longer that they would not rub as much since it would be more length to go through before the rubbing..
Last edited by SKiZ0TT; 01-23-2012 at 12:42 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to SKiZ0TT For This Useful Post:
karl-hungus (01-23-2012)
 Old 01-23-2012, 12:47 PM   #30
theurgy's Avatar
I would suggest instead to get your rear fenders rolled.
The Following User Says Thank You to theurgy For This Useful Post:
 Old 01-23-2012, 12:51 PM   #31
SKiZ0TT's Avatar
Groans: 33
Ugh.
 Old 01-23-2012, 12:51 PM   #32
Posts: 9,484   (View Stats)
The oe stops are actually designed as part of the rear spring rate. Shorter stops will reduce said rate and more rear squat will occur
I am assuming OP is rubbing tire in the back. Most guys run oe stops in rear and GC or FCM in the front only which is what I run.
Tappin
kwsmithphoto (01-24-2012), SKiZ0TT (01-23-2012)
 Old 09-02-2012, 02:54 PM   #33
irishking03's Avatar
Posts: 2,136   (View Stats)
irishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the world
Groaned at 6 Times in 6 Posts
Nicely done!
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
irishking03 is offline   Reply With Quote
 Old 09-08-2012, 09:45 PM   #34
MattJackson86's Avatar
Posts: 1,407   (View Stats)
I have bilstein sports with the fatcat stops upfront & OEM in the rear. With even one person in the back and or some luggage I rub over dips in the road. I rolled my rear fenders a tad so I am no long hitting metal, but the tire still hits the plastic fender liner on dips. Sounds terrible when driving, but no damage to tire so far, just some worn down plastic.
 Old 08-26-2013, 04:25 PM   #35
alextheguineapig's Avatar
Posts: 827   (View Stats)
alextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the world
So I don't mean to necro-bump this thread, but I'm ordering Koni Yellows and Swift springs in the future (1 inch drop all around basically) and I'm wondering if I should get the FCM bumpstops for the front and the rear or just reuse the rear, or get new oem rear ones and cut? My car has almost 60k miles and has spent all its life in upstate Ny so I can only image the oem stops are done. I just don't want any rubbing. I'm still running oem wheels and tires, but I don't want any issues next spring when I go bigger.
Current
2013 Ingot Silver Focus ST - ST3
Injen: 3in SES Exhaust TT Tips
SOLD!
2008 Sunlight Silver MS3:
BNR: S3 V2
Cobb: V3 AccessPort
CNT: Catted Downpipe / Cat-Back Exhaust
Damond Motorsports: RMM
Eibach: Prokit
HTP: 3" Intake System (One-piece)
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
Morimoto: HID Kit / The Retrofit Source clear lens swap.
NATOR FMIC: Cx Racing piping / Treadstone TR8
alextheguineapig is offline   Reply With Quote
 Old 08-26-2013, 06:24 PM   #36
theurgy's Avatar
I would suggest replacing them, you can now get Ground Control Bumpstops for way cheaper. As well I'm pretty sure you can also get some KYB Bumpstop kit to work as well.
 Old 08-27-2013, 10:29 AM   #37
Design's Avatar
I wouldn't suggest replacing the rears just yet. Install as designed with the rears in tact. Evaluate the ride and, if too stiff, replace with Fat Cat or trim a couple rings.
09 CWP MS3 GT
 Old 08-27-2013, 10:48 AM   #38
theurgy's Avatar
Depending on mileage, I've found that they are usually destroyed by the time you go and replace your struts, shocks and springs.
You unfortunately can't just buy rear replacement OEM bumpstops from Mazda. They only sell them with a rear shock.
If it was me, and I've already got it all apart, I would rather just replace on the spot than to just hope that it is still intact.
 Old 08-27-2013, 10:57 AM   #39
Ok well to keep dustboot functionality in tact, what would I purchase to replace? Should I buy the GC ones or do I need to spend the money on the Fatcat set, or is there another alternative?
Current
SOLD!
BNR: S3 V2
Cobb: V3 AccessPort
Eibach: Prokit
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
 Old 08-27-2013, 12:17 PM   #40
theurgy's Avatar
Truthfully, I went FatCat cause I didn't know there were cheaper better options.
I would say maybe look at the KYB sets.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f12/fat-cat-bumpstops-halp-78035/
5X Racing Mazdaspeed 3 Bump Stop Kit This thread Refback 04-26-2015 04:46 PM
Fat Cat Motorsports - Koni products - Mazda 3 / Mazdaspeed 3 This thread Refback 06-14-2011 12:37 PM
Newb needs halp with Dual Port Turbosmart BOV BigJeff MazdaSpeed 3/6 - Turbo Induction 8 03-22-2011 06:39 PM
Replaced struts, installed fatcat bumpstops, found broken Hotchkis bracket- fail! red07 MazdaSpeed 3/6 - Suspension & Brakes 6 07-10-2010 12:33 AM
SSR Center Caps - Need Halp martin_nj MazdaSpeed 3/6 - Wheels & Tires 1 02-21-2010 09:34 PM
Fat Cat Motorsports Bumpstops filphil MazdaSpeed 3/6 - Suspension & Brakes 9 04-18-2009 09:25 PM
Page generated in 0.57609 seconds with 35 queries
