-   MazdaSpeed 3/6 - Suspension & Brakes (http://www.mazdaspeedforums.org/forum/f12/)
-   -   Gauging Interest: Big Brake Kit (http://www.mazdaspeedforums.org/forum/f12/gauging-interest-big-brake-kit-1995/)
Cheveyboy 04-24-2009 04:32 PM
The OE brakes on my 02 WRX were 294mm, the car weight was roughly 3100 pounds or less for that year. And in no way would they last 5 laps all out with pads like xp10's, not only would you destroy the pads and rotors from over heating but you would kill a set of bearings and melt tie rod boots after the day was over.
Either the mazda 6 is lighter then you think (if your comparing it to the weight of a speed3), or there is somthing im missing.
I can see you possibly out breaking an STi for a few laps because of the weight diffrence of a mazda6 to a 3600 pound STi, but I cant see it retaining that ability for long.
I mean no harm here, there are so many factors that could be lead any car to out brake any other car IE tires. For how long, who knows. Rotor mass is king for any long haul on a track.
Later man!
Crossbow 04-25-2009 06:24 AM
http://terpconnect.umd.edu/~greghess/east/grandeast.jpg
Average lap's at vir (grand east) is 4-5 a session. Track is 4.2 miles, with two straights that are almost a mile long them selves. (Top speed in stock sti is roughly 130-135 mph, with stage 2's getting to 140ish depending on the temp of the day). My Mazda 6s was governered at 120-126 (depending on who you believe at the time), and I'd hit the gov about 2-3 times on the main straight, if I had a good entrance.
My 6s was 3050 lbs or so, and had 11 inch front rotors, with some generic ford caliper, running GS610 brake fluid, Hankook Ventus Z212 Rubber (245/45/16) on rx7 16x8's, with XP10's (now that i think about it, might have been 11's) front and XP9's rear. Same weight distribution, superior suspension setup to the MS3. (Double wishbone front, multilink rear).
My longest track event was 4 straight days with that setup. Or roughly 4-5 sessions a day, of 4-5 laps a session, or about 5-6 hours of track time.
Only on the last session, of the last day, did I check my pads (Always a routine check after each session) and find the fronts dangerously low. Then I did something stupid and put bobcats on, hoping I'd be able to squeeze one more session out of them...haha that was so stupid. Went to brake on my 2nd lap of turn 1, cooked the brakes, pedal to the floor, almost ran off the track.
Rotor wear was fine, but then of course, I had already used the carbotech deal and paid 50 bucks for a set of new front blanks, to swap in when I changed to the XP10/11's. (Supposedly we can use the same deal for the MS3, only its more like 100, but have to check on that).
The funny thing is, as the mazda6 crew broke up, most of the guy's got sti's, and the first thing they complained about was the braking. Except for hank, he got an rx8 and laughed at everyone's complaints.
This gives you a bit of background of why I feel the MS3's braking system is nuts and only needs pads and fluids. I mean really the only decent upgrade choices would be an expensive 2 piece rotor, or a DBA rotor. You could move to a multi-piston caliper to get improved pad wear, reduced unsprung weight, and better pedal feel/engagement...but it would have little effect on brake performance, and massive effect on your wallet! :)
triplejumper18 04-26-2009 08:28 AM
Brembo's yo!
http://forum.mazda6club.com/index.ph...=post&id=42071
/sarc
http://forum.mazda6club.com/index.ph...pic=112395&hl=
Nliiitend1 04-26-2009 12:49 PM
Is page one of this thread messed up for anyone else??
I can only see the first 25 posts or so...
MZRDISI4 04-26-2009 01:10 PM
It's fine for me.
alwayzamd 05-10-2009 11:11 PM
There a couple reasons why I'm interested in the BBK:
My track pads (Carbotech XP12s) tapered really bad over 4 track days. I probably have to throw away the pads twice as soon as I need to due to the extremely uneven wear. Granted, I'm hard on my brakes -- my DBA slotted front rotors thermal paint indicates I've gotten them at least 1200F.
A well designed multi-piston caliper uses different sized pistons to offset the uneven wear problem. This could save me money in the long run. Those Carbotech pads aren't cheap. They also tend to apply more evenly and consistently since there is no sliding of the caliper.
Also, I got the front left so hot I melted the piston boot in the caliper. I have two rebuild kits on order and hopefully will post what the rebuild process is like.
Changing pads the day before a track event is a bitch with the stock caliper. The design of the stock caliper forces me to take the entire thing off the upright in order to get the pads out instead of taking off the floating piece like the rears. Most BBK's offer convenience of drop-in replacement -- I like this idea... easier from street compound to race.
What I DONT like about the currently available BBK's is that they were designed for the base Mazda 3. I dont know for a fact but I'm willing to bet there is LESS pad area on the current BBK's compared to our stock caliper.
Finally, with respect to the post regarding how much the pads are, Carbotech will put their compound on anyone's pads... they will find the blanks and build them for you at no extra cost. After I got off the phone with them the other day, they recommend that we spend time searching for good cooling options as well. I think I may take off the shield against the back of the rotor unless someone can tell me that's a bad idea.
Crossbow 05-11-2009 10:54 AM
Now that is some valid reasons for a BBK...but it sounds to me you'd benefit more from a replacement caliper for the stock rotors, then an entire replacement rotor/caliper.
The thing that bothers me so much about the BBK's, is the upsized rotors are only 0.4 inches larger in diameter. That's a huge chunk of change for almost no size change.
I do understand that the caliper is the majority of the cost...so why doesn't someone look into having a replacement caliper made for the stock rotors? That way they'd be more rotor options, we wouldn't have to upsize our wheels (from 16 or 17), and we'd get the benefits from a properly designed multi-piston caliper.
So change the thread from BBK to piston kit :).
I mean honestly, a 13 vs 12.6 inch rotor...that should be called a slightly bigger kit...SBK :).
QuickSpool 05-11-2009 03:40 PM
I have a friend that has a track toy STI and a set of Alcon 6 pistons up front and he can consistently brake from 165+ w/o issue. They are fantastic. I did a ride along and the braking performance was outstanding lap after lap. I would LOVE a set of Alcon's that could fit under 17"'s
Cheveyboy 05-11-2009 08:16 PM
Most of the time there is not just a diam. change with a BBK, but a width change also. Most of the time the width increase is better then the diam increase. As long as the whole system is designed corretly as not to induce a bias change. So that half inch in diam. plus at least a quater inch in width is in deed a big change.
Your throwing me for a loop with a few things crossbow, your wheel size info? 16 to 17? You just seem to have it out for BBK's it looks? The pad options will be better if a set of Stoptech's or Wilwood Dynapros were sourced. There are so many benifits that I personal think far outway the cost.
The above poster that torn up boots, thats happening because of the heat im sure you know. Just throwing on a set of better calipers will solve half the problem. A set of 2 piece rotors with that extra diam. and width will be the full solution.
alwayzamd 05-12-2009 11:03 PM
I agree that the larger the rotor, the increased heat sinking capacity, so that will certainly not hurt... but what's the pad area? This is also paramount. Like I said before, I want to know for sure that I'm getting more pad on the rotor than I am with the stock caliper. I don't know for a fact, but I'm willing to bet current BBK's (designed for the base 3) have LESS.
What's important is that we get more pad on the rotor, enlarge the rotor for more heat capacity, use a multi-piston design for even wear, and improve cooling.
Have you guys seen how close that damn shield sits to the rotor? I'm going to yank it.
In reference to the pad options, there may be more with other brands, but I don't really care because Carbotech will be supplying my compound.
I'm interested to see what ends up being produced. Hopefully it's a real MS3 oriented kit.
MZRDISI4 05-12-2009 11:18 PM
With a 4 Piston caliper, you have to have more pad. Unless you've found a way to put a tiny 1 piston pad in a 4 pot caliper.
Crossbow 05-13-2009 07:41 AM
I'll restate my opinoins again since they are a bit confusing.
I don't like BBK's when...
1) The stock system is more sufficient for repeated consistent braking at high speeds for extended lap sessions (with track pads)
2) The BBK's force you to upsize your wheel choices. You can fit 16x8's on the speed3 (as the smallest choice possible), which lowers your tire cost, and can expand on tire choices. If the BBK forced you out of stock wheel selections (having to fit 19's), it would be a huge negative.
3) When the BBK's are thrown together more as a "oooh look at me" and come along side with xdrilled or xdrilled/slotted as the only options, which have no place in a performance solution.
4) When the BBK kit uses a set of rotors/pads that require you to go through a limited choice of manufacturer for replacement components, increasing cost significantly.
*5) When forums drive up the demand for a BBK, a company spends R+D creating a great, properly designed kit, then puts it on the market...and 2 people out of the original 30+ buy it, wasting a huge amount of time and money. (This one is personal, Todd from TCE Performance Products - Producing Winning Results since 1993 designed a kit for the Mazda6 guys back in 04...2 guys bought it from the original 30 or so... :( )
Things I agree on.
I agree on width aspect of the replacement rotors. I had forgotten to include that in my previous statements, and you're right, increasing width is as important as diameter.
I did not know that the stock pad's were a total PITA to change. I had to skip the track this year due to financial reasons, so haven't put the track pads in yet. However if it's the difference of a few minutes vs 30 seconds, I think it still wouldn't be that huge of a deal. But I'll hold final comment back for when I do my pads.
A multi-piston caliper will provide for more even pad engagement and wear. There is however diminishing returns. (6 vs 4 piston, etc)
If the stock braking system is running hot, you'll get increased rotor wear from having to run a more aggressive track pad. You will have to take these costs into consideration (replacing rotors/pads every 4 days or so) against the cost of a BBK which could reduce the replacement times to 8 track days or longer. (Because you could run a less aggressive pad and get the same consistency).
As to my tire/wheel choice, I'm current running Kosei K1-TS 17x8, with 225/45/17 RT615 Falken's. Next tires will probably be Hankook Z212 Ventus 235/40/17, or a more street friendly tire (with a second set of kosei's for the track) 235/45/17 Goodyear F1 Asymetricals.
My pad/rotor choice was most likely going to be the same, DBA front rotors, with Carbotech XP11 or 12's.
spheed3 05-13-2009 07:59 AM
I could see the benefits of a properly designed BBK with extended component life, I'd buy a well desigened kit if it ment saving cash with less pad and rotor replacement. I think I'd rather see an option for a wider, vented rear disc first. I know the rears don't do much work but that didn't seem to stop me from overheating and destroying them my last time out...
alwayzamd 05-13-2009 01:31 PM
spheed3:
Try to remember that the rear rotors cooked the pads due to the stock pad compound which isn't designed to operate in that temperature range, not because the rotors were operating outside of an appropriate temperature range.
I urge everyone that has not read about the common myths of braking systems to read this Stoptech article: StopTech : Balanced Brake Upgrades
This covers more than just the "warped" disc myth, but also compounds and the way the compounds interact with the rotor surface.
To summarize: Simply stated, building a pad comound comes down to a battle between cold and hot performance (there are other concerns, but this is the biggie). Materials that we have today can operate in some given temperature range, and with better engineering, you might increase that range some, but there is a limit inherint in the materials. However, by selecting different amounts of different materials, we can take the entire range and shift it to the "right". In other words, increase the lowest temp operating point in order to increase the highest temp operating point...
So if a street pad is good from roughly ambient to say 800 degrees F before fade and destruction, a race pad may be good from 200 F to 1200 F. Note the increase in cold performance... the pad is considered unsafe until it hits 200 degrees... Some of Carbotech's compounds are good up to 2000 F, but dont expect to use these for daily driving because you will never get the pad into the normal operating zone.
I hope this and the Stoptech article shed some light on braking systems and I also recommend folks read the other Stoptech technical articles as well. Those guys know their stuff!
Nliiitend1 05-13-2009 02:48 PM
Originally Posted by alwayzamd (Post 225092)
...and I also recommend folks read the other Stoptech technical articles as well.
x2
Yes, they do. ;)
spheed3 05-13-2009 04:21 PM
spheed3:
I agree and thank you. I was thinking a vented rotor for the rear purely for increased pad life. I did this on my mustang back in the day and the extra pad life was worth the $100 to upgrade to vented rears.
hyedracyl 05-14-2009 08:55 AM
BBK necessary?
Personally, I'm a Track Junkie. I've probably driven 25-30 racetracks around the country in a number of different vehicles. I'm also a Porsche club driving instructor that has run One Lap of America ten times now. I just bought a MS3, but I will probably start monkeying with the brakes soon. Heck, it's what I do...
Todd at TCE has been helpful to me over the years. The brake line parts that he made available to me on my SRT4 helped me out a lot. At the national SRT meet at Heartland Park in 2006 he told me that I'd be unhappy with the Wilwood SL6 caliper that I was using to upgrade my brakes on the Dodge. He was wrong, they were great. The Carbotech pads (XP8) that were provided for my use during One Lap in 2007 (against my wishes, as I had requested XP10s), were another story. In (8) laps around Miller Motorsports Park (4 on the short course, 4 on the full course) I completely consumed a new set of XP8 pads. I did however reach 147mph on the main straightaway - and successfully slowed down to make turn 1...
The diameter of the rotors on the MS3 looks fine to me. They should work well for a car of this weight - though I do wish that the car was lighter. My Neon's chassis is woefully flexible, but it weighs correspondingly less as well. I haven't changed any pads on the MS3 yet, but the ease by which pads can be changed on the SL6 caliper (for example) couldn't be easier. A 3/16" allen wrench, 7/16" box end wrench, a flathead screwdriver and 5 minutes of your time is all that you need to do a pad change. Very convenient indeed.
My first look at pictures of the MS3 rotors is the reason that I brought up the SRT4. For use on the racetrack, that thing had PITIFUL braking from the factory. They used a 1.1" thick rotor (better than the ~1" used on most cars), but there was almost NO airspace for ventilation/heat dissipation. The extra mass of the rotor allowed the rotors to absorb more heat, but once they got hot your brakes were toast - even with good Carbotech XP10 pads (with extra thick backing plates for rigidity purposes) in place.
The MS3 seems to have taken the same path with their factory brake setup. On the Mazda though, they kept the rotor thickness down to 0.98" - but at a significantly larger overall diameter than that on the SRT4 (12.6 vs. 11.0). If I took my MS3 out onto the track today, I anticipate that I'd be unable to stop it rather quickly. Heat dissipation is critical, and the rotor used on the MS3 doesn't appear to have it. On the street, the stock brakes are probably just fine though.
My first step is going to be to build a new two piece rotor and give that a try. If it's not enough, then I'll add brake ducting to bring in additional cooling air. Then and only then would I consider replacing the caliper and potentially moving up to a larger rotor.
I looked through the Wilwood catalog and they have a rotor and hat combination that should work pretty well for replacing the MS3 stock rotors. The benefit in doing this is that the new rotor will be of a 32 curved cooling vane design. The "fan" effect of the curved vanes will pull air through the rotor to aid in cooling, and the greater air space in the center of the rotor will provide much more surface area for heat dissipation.
I have no idea how much the OEM rotors weigh, but I suspect that there will be a significant reduction in unsprung/rotating mass when the rotors are replaced. I have some "used" Neon rotors hanging around that I'm going to use to make up a sample set. If I'm lucky, I won't have to turn the 12.9" rotor down to 12.6" to make it fit, but maybe I can do that on the auto parts store's rotor turning machine. Otherwise, a trip to a local machine shop for access to a lathe will be required.
The upside to an upgrade like this is that ANY wheel that fits a stock MS3 will fit one with the new 2 piece rotor. Also, the friction surfaces can be changed when necessary at lower cost than buying an entire rotor. Stop Tech charges something like $800 or $900 for new rotors. Who can afford that on a wear item? I know I can't.
I'll keep you posted on how this works, and if I think that going with a BBK is a worthwhile investment. As a builder of these systems, I can assure you that it's tough to get enough customers to justify the expense of designing and building something for any particular vehicle. That's why everyone wants a bulk buy to get the ball rolling. Regardless of the money received from those first kits though, the manufacturer is not going to recover their development costs. That's why there are so few kits out there for you guys to choose from right now.
Greg Hagopian
alwayzamd 05-15-2009 05:35 PM
In response to the last post:
I understand that you have had lots of experience on the track, but it does not seem as though you have had much time on the track with this platform... so I thought I'd chime in.
DBA already makes a great rotor (although not 2 piece design) that really dissipates heat well...
Also, the stock brakes are outstanding. For the occasional track day with track pads, no one really needs an upgrade.
My reasons for wanting an upgrade aren't due to performance at all. Simply put, I want a more reliable, multi-piston caliper that will extend pad life (since pads wont taper), along with the convenience of a fast pad change.
I am excited to follow your 2 piece rotor work, however, to save weight. Keep us posted on this!!
I bet you will find that the stock system is more than enough with good pads for occasional track use.
hyedracyl 05-18-2009 11:37 AM
You would be correct, I have little experience driving an MS3 on the track. My track experience with this particular platform has been limited to instructing students who are driving this particular vehicle.
While no braking issues were noted during those events, students are generally learning how to drive and don't tend to stress the braking system in the same manner as a more experienced track driver would. I believe that you are correct though in stating that most occasional track visitors would not find themselves in need of a BBK, or anything other than good rotors/pads for that matter.
I actually started my "research" on this vehicle out at the DBA website. They are one of the easiest obtainable sources for rotor dimensional information. I did not notice any Kangaroo paw rotors available for this platform in their on-line catalog though. Actually, that surprised me at first. I had hoped to give those a shot first as an off the shelf solution.
Can I interpret from your post that the OEM setup tapers brake pads? The mere heft of the original system would tend to make me think that this wouldn't be a problem, but if it is, I can understand you desiring a stronger caliper.
One thing that I would tend to caution you about though is that not all multi-piston calipers are going to qualify as being significantly better than stock. For example, the Wilwood Dynalite caliper is not strong enough to stand up to the hydraulic pressures present in a power assisted brake system. They tend to flex, making the pedal feel "spongey" and wearing the brake pads in tapered manner. The manufacturer rates them for up to 1500PSI as I recall, and your power braking system can potentially generate as much as 3000PSI in a high speed panic stop situation.
The Superlite caliper is stronger and should experience lower flex levels, but I moved away from even that caliper a while back (the forged ones that they make now are supposed to be stronger than the Billet ones we used to use were, but I have no personal experience with this particular product). I really like the Superlite6 (SL6) myself. Very little taper on the brake pads, and they have good structural integrity. Light weight too. Naturally, as the calipers get stronger, their price goes up correspondingly. I'm not trying to talk you into or out of any particular product, just passing on the benefit of my personal experience.
I'll continue to update folks with information on the potential 2 piece rotor swap. I don't know how much the OEM rotors weigh, but I'll bet the two piece units come in around 12 pounds or so. As I've not had the system apart yet, and the aftermarket rotors were designed for use with Wilwood style brake calipers, I have no idea how the OEM pads will mate up with these friction surfaces. A reduction in swept area may be discovered when I get something put together that I can actually try out. Again, I'll keep you posted.
Nliiitend1 05-18-2009 01:42 PM
Actually, I'm pretty sure DBA does make a "kangaroo paw" rotor for this car (the "standard" option):
Mazdaspeed 3 Front DBA Brake Rotors - 4000 Series
...or maybe it's a mistake. :dunno:
Dabears2k 05-18-2009 02:21 PM
well, the other nice thing is that my company is coming out with a 2-piece rotor that we have worked with Todd on. It's going to be under $450 and will save 11lbs per corner.
hyedracyl 05-18-2009 04:54 PM
Hmm, guess I didn't realize that the 4000 series rotors were of the Kangaroo paw configuration. I hadn't been out to the DBA web site in quite some time, but I thought that I remembered that they were listed as a separate product line. Looks like I was wrong, sorry. I didn't mean to mislead anyone.
As for Todd working with someone to come out with a 2 piece rotor for $450 (pair I assume?), that's great! I'd be interested in trying a set. Would certainly be cheaper than building my own. Any more information on those rotors that you can pass on? I'm hoping for a curved cooling vane design. 11 pounds per rotor is a ton of rotational/unsprung mass. These rotors, along with a lightweight set of rims, would most likely be something that you'd notice during heavy acceleration.
Haltech 05-18-2009 05:00 PM
Ban....
YOUR company is NOT an approved vendor, nor do you meet my standards for business in my community. You have been warned, you have been PM'd, but now you are plain disrespecting the authority of my moderators, who really, dont have to do much. Since you decided to disregard their only enforcement of a rule, you have disrespected me at the same time.
Some people never learn...
MadOzodi 05-18-2009 09:35 PM
While no braking issues were noted during those events, students are generally learning how to drive and don't tend to stress the braking system in the same manner as a more experienced track driver would. I believe that you are correct though in stating that most occasional track visitors would not find themselves in need of a BBK, or anything other than good rotors/pads for that matter...
As I mentioned in another thread, I was fortunate enough to have been one of Greg's students. I'd just like to add that he was very impressed with the size of the MS3's glovebox. At one point, I think we discussed converting it into a mini-fridge while waiting to be let out onto the track.
Greg, I hope your two-piece rotor solution will be available in time for me to have it installed before the PCA this fall. I also hope you decide to bring your MS3 to the track. Good to have you as part of the MS3 community; when I left the track last fall I didn't think you were that serious about picking one up.
-Gary
hyedracyl 05-18-2009 09:47 PM
Thanks Gary, I appreciate the sentiment. If I come up with something that works well, I might just lend you some parts to try them out and see how you feel about them. With the extra rubber that you're sporting these days, you'll find more effective braking even more rewarding than you did last fall on the narrower tires.
You are correct in that I wasn't exactly convinced that the MS3 would be a good car for me in my situation, but when Mazda decided to slap a $2500 rebate on leftover 2008 models recently/currently, I decided that the bang for the buck factor was simply too good to overlook.
How it pans out (for me) out on the racetrack is uncertain at this point, but I'm sure that I'll learn a lot about thrashing it just as soon as I get the chance... My fiancee put enough mileage on the car for me that it's ready for some abuse right now! I suspect that the SCCA will give me plenty of opportunities to explore the MS3's capabilities out at Gateway this summer.
Greg Hagopian
Hye-Dra-Cyl LLC
MadOzodi 05-18-2009 10:16 PM
I need to pull the reigns in a bit because there are so many more questions I want to ask you, heh. Even more after you've put the car through its paces this summer.
I just turned 26,700 miles a couple of days ago and the OEM pads and rotors probably need to be checked out. I'd be more than happy to guinea pig some parts for you if you need a 2nd test car.
alwayzamd 05-19-2009 09:14 PM
hyedracyl:
Thanks for the info...
To answer your question, yes, with race pads the stock caliper tapers the pads pretty bad. But after speaking with a bunch of brake gurus, I dont think the caliper is tapering the pads due to its strength, but rather to the single piston being centered in the caliper. Taper is caused by the front of the pad taking the brunt of the force for slowing the rotor, right? The rear of the pad has less work to do. So the pad tapers...
Multi-piston calipers alleviate this by placing a smaller piston (less force) on the front of the pad than rear (bigger piston).
After looking into it some more, I think I may have found a way to alleviate the tapering by swapping the front pads left to right after each track day (not a session, but say four 20 minute sessions). This would reverse the tapering effect.
I strongly feel that after improving cooling by removing the dust shield (and maybe adding some ducting) and swapping the pads after each track day, that the stock calipers are more than sufficient, even for the heavy enthusiast. This makes a BBK less appealing, since it may not be necessary for our platform, although like I said before, it buys convenience (easy pad change, no worries for tapering).
I'm excited to see your thoughts after you take the car to the track and run it for yourself... I assume you will throw some race pads on the existing calipers and throw on a set of DBA's or some other variant in the mean time? I'm thinking you would want that baseline in order to know if you improved or worsened the braking system after modification. I think you may be in for a surprise.
Finally, yes, the DBA 4000 slotted series are the kangaroo paw design... so far they have been great.
Keep us posted.
hyedracyl 05-19-2009 10:43 PM
So, the pads are tapering from leading to trailing edge then. The original tapering comment had me expecting a vertical taper, not a horizontal one. The SL6 caliper (for example) has two small pistons on the leading edge of the caliper, with the large piston on the trailing end of the caliper. This does indeed help with the tapering of the pads in the horizontal direction by placing more force at the trailing end of the brake pad.
As for swapping pads from L to R (and vice versa), that would indeed serve to compensate for the horizontal tapering effect observed. It would however do nothing to ameliorate the vertical tapering effect. I'll be curious to observe how the wear pattern actually manifests itself with the OEM setup.
As for configuration (to start from), I will upgrade the pads only for a baseline. Using the OEM pads offers me no real data of any value - as I know that the pads are unlikely to hold up under the kind of strain someone like myself will put them under.
With pad wear data in hand, then I'm liable to proceed to the rotor upgrade. After that, brake ducting for greater cooling - though removing the backing plates would probably not be on my agenda. I would tend to modify them to accept the brake duct tubing, so that the high pressure air is forced into the center of the brake rotor. Having something to attach the brake duct tubing to (modified backing plates) would make the ducting setup easier to manage, and more effective as well.
While I will definitely miss the ease with which pad changes can be performed with aftermarket calipers, leaving the car as close as possible to stock has its own benefits as well. I see that folks are having some difficulty with warranty issues when their cars break. Not having to explain (to the dealer) the reason why there are 6 piston calipers mounted to your car will have great value in such a situation. You know that the dealer is going to postulate abuse when they see monster brakes and tires that display heavy outside tread block wear patterns!
I'll do my best to chime in with what I learn as I learn it.
Greg Hagopian
Hye-Dra-Cyl LLC
thanotosq 05-23-2009 10:39 AM
Yeah, your rear rotors look pretty bad....but i guess if those are the original pads...then they should look bad at this point.
I personally think that the prospect of having lighter rotors is exciting. If there is one thing that i feel that this car has too much of (not to bring out the torches and pitchforks) is weight in the front end. After running the Hawk HPS, which i'm not nearly as satisfied with on this car as on my Protege, i would like to explore getting better pads before droping the money for a BBK. However, if i were to drop the money for the BBK, then i would probably want soemthing that is more balanced than BBK/front & OEM/rear....but that is just me....
So, light rotors, more aggressive pads, and lighter wheels (my current wheels are 22 lbs 5zigens and i would like to get something in the 17lbs or less range....17x8 RPF1 @ about 16lbs here i come!)....then if needed BBK.
thanotosq 05-23-2009 10:42 AM
HyeDraCyl-
So, you're the one to blame for the..."well first off you are sitting too far back...blah blah blah"---Gary:smashfreakB:
As if i didnt have to hear enough of that with my last room mate....now i got to here from Gary!:18:
...just jokes....
Maybe i should try to get some lessons!
hyedracyl 05-23-2009 10:54 AM
We all have to start somewhere! It's pretty hard to learn much out on the street - as those other pesky drivers are always in the way! When you feel the need to get some instruction though, there are plenty of guys like me out there willing to help you out. Hopefully, we'll be seeing you soon.
Greg
Jarods7920 05-23-2009 11:17 AM
Greg, if you come up with a better braking solution, i would be willing to test some of them out for you, if you would have me.
JMEngineer 05-27-2009 11:09 AM
I have 2 questions (sorry if the answers are in here somewhere and I missed them)
Do the MS3 and MS6 have the same brakes?
Are there any 2-piece rotors out there?
I'm definitely interested in lighter brake discs. I would like better calipers but I can live without them, so price matters.
Nliiitend1 05-27-2009 12:34 PM
The MS3 and the MS6 do NOT use the exact same brakes (though someone once told me they may use the same pads front pads :dunno: ).
As far as I know, there is still not a direct replacement 2-piece rotor available for either.
MadOzodi 05-27-2009 07:41 PM
Alex, you should attend the StL PCA with me this fall. We won't be in the same group, but it'll be cool just hangin out. Godzilla was on the track this spring; my buddy called me from GIR to let me know but I couldn't make it down there.
I get the feeling your old roommate bugged the crap outta you with unwanted instruction...don't let preconceived notions get in the way of learning if you do decide to have fun getting the point-by from older Boxsters. It'd be sweet if you got Greg as an instructor right off the bat.
Until my brakes are squealing constantly and not just when they're cold, I'm gonna hold off on anything. Additional mods for the car are on hold indefinitely as well.......because I just bought me a motorcycle! :D
wildfrisco 04-20-2011 12:52 PM
Yes. Alcon 2-piece rotors for the Mazdaspeed 3, but price is about $1,400 a pair.
I'm also interested in Ms3 2-piece rotors and tried to participate in a group buy with Girodisc, but ended up being that I was the onlyl one that ponied up the money so the GB fell through.
I've contacted Racing Brake in their forums and the RB person replying in the forums seemed open to the idea of 2-piece Ms3 rotors. They seem to be about half the price of the Alcon units. I also called RB recently and spoke to one of the owners/founders, Warren, but his customer service skills were lacking.
Do you guys know of any other 2-piece brake rotors for the Ms3?
brooks1277 04-20-2011 01:59 PM
Originally Posted by wildfrisco (Post 817819)
Yes. Alcon 2-piece rotors for the Mazdaspeed 3, but price is about $1,300 a pair.
KVR Performance Brakes
wildfrisco 04-21-2011 03:55 AM
Originally Posted by brooks1277 (Post 817914)
Awesome thanks. Found that in the Toronto 3 forums. Also found 1 thread in another forum:
See them here first............
KVR 2 Piece SS Front Rotors for MS3
The weird thing is although the KVR link still works, I called them earlier today and they stated they're no longer in the business of making 2-piece rotors. WTH.
Another thing is that KVR lists this part number (MA883SS) for both the Ms3 and Ms6, but I thought there are slight differences in OEM rotor dimensions for both. Maybe that's why one guy in the Toronto 3 forums stated the hat was thinner and caliper clearance changed by 3-4 mm.
brooks1277 04-21-2011 06:23 AM
The boys over at Freedom Autosport are using 2 piece rotors on the Continental Challenge MS3's. Try contacting Glenn (Long Road Racing) over there and ask if they are available for purchase. I believe he quoted me around $800 for the pair.
wildfrisco 04-21-2011 04:39 PM
Wow I called and he actually has not one but two applications available. Called at the end of the day so he asked me to email him, that way he can send me price, info, pics, etc. I think I'm going to start a new thread and update it as the info comes in. Thanks man!
Page generated in 0.22298 seconds with 11 queries
