| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() | | | LinkBack | Thread Tools | Display Modes | ![]() |
![]() | | #41 | ![]() |
![]() ![]() Join Date: Jan 2009 Location: Venice, CA
Rep Power: 130 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
Groaned at 38 Times in 7 Posts
| Not Ranked : 0 score
It's hard to compare since the TP bar is a different design than, well, everything else out there, but you guys have a decent looking product for a much lower price. Bracing the brackets was a good idea (you're welcome) but the upcoming batch of of TP bars will ship with a thick, black powder coated bracket of much higher strength. Which can be retrofitted to the prior batches, if a user has any legit problems, and most don't. It's not a freebie, they literally just addressed a problem that very few people will ever have with the TP bar, or any others. But Progress has the bang for the buck advantage for sure! Especially with the group buy. The increase in stiffness is palpable and, IMO, solves a very real problem with the OEM setup, which is too soft for skilled drivers. And the u-brakets, while still ugly, look strong! Good idea to run the gusset all the way around, but I hope they put a better welding guy on the job based on the photos you posted. BTW, you sell dampers too, right? The stock ones can't even keep up with the factory springs or RSB, you might want to offer an upgrade package for the rear dampers because they suck, and can't even keep up with the springs, nevermind an uprated RSB. OEM rear dampers, combined with an uprated RSB, is a disaster waiting to happen, IMO, even with the OEM springs. Just my thoughts, and just trying to help! Looks like a good product at a very good price, if it wasn't for the TP bar, I'd most likely be on the list. The TP bar is a lot more expensive, and they only addressed the bracket issue recently because it didn't come up in their testing. Until they sold one to me.
__________________ This car has never been raced, modified, or abused in any way. Maintained as required, only wear items have been replaced with OEM or better parts, in compliance with all warranty terms, and federal and state laws. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | |||||||||
![]() | | #42 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
I wish there were progress springs for the ms3. I had them on my previous lancer and mz3. Best springs I've owned.
![]() | | #43 | ![]() |
![]() ![]() Join Date: Jul 2009 Location: Southern VT
Rep Power: 194 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
Groaned at 22 Times in 15 Posts
Can you throw me on the list? I'll take one.
__________________ 08.5 Mazdaspeed 3 - CP-E Nano SRI, SU Test Pipe, custom FMIC, CP-E RMM, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's 253WHP/274WTQ on a Mustang Dyno 08 Kawasaki Z1000 - Laser X-Treme Exhaust, -1 Front Sprocket, Speedohealer, Renthal Ultra-Low Bar, CRG Bar End Mirrors, Pazzo Levers, Motovation Frame Sliders, Targa Fender Eliminator, OEM Rear Cowl | ||||||||
![]() | | #44 | ![]() |
| Banned ![]() ![]() ![]() Join Date: Jun 2009 Location: Central Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 337
Groaned at 18 Times in 18 Posts
I agree with the stock suspension being less than desirable we are working on something special....very special.
They will do it if I ask and as long as the community participates in the GB. This GB will be a good indication of how we will respond when I ask to have them make Springs SPECIFICALLY for the MS3. One thing I am noticing a lot from manufacturers is that because it fits they will market it instead of designing one specifically for this car. Done! | ||||||||||
![]() | | #45 | ![]() |
![]() Join Date: Dec 2008 Location: Kannapolis NC
Rep Power: 51 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 65
| Not Ranked : 0 score Oh pleeze tell us!!!! I'm so trying to hold out on buying something because I know more time will equal more products for me to chose from (hopefully better).
![]() | | #46 | ![]() |
| I'm a caveman ![]() Join Date: Jun 2008 Location: MEXICO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 135
Groaned at 10 Times in 7 Posts
put me on the list
also interested in this special maybe koni yellows
__________________ look at the cars I have, and what parts are installed on them To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | |||||||||
![]() | | #47 | ![]() |
| Not Ranked : 0 score No and I added you to the list! Thanks! Last edited by Race Roots; 11-06-2009 at 06:18 AM. Reason: MSF Database - Automerged Doublepost | ||||||||
![]() | | #48 | ![]() |
![]() Join Date: May 2009 Location: Warminster, PA
Rep Power: 153 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 465
I would definatley be interested in the progress springs if you can get a tester.
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #49 | ![]() |
| I <3 your mom ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 2622 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,387
Groans: 138
Groaned at 50 Times in 35 Posts
I'll test springs if they decide to do so.
![]() | | #50 | ![]() |
| Not Ranked : 0 score | ||||||||
| The Following User Says Thank You to Race Roots For This Useful Post: | Dash08 (11-09-2009) |
![]() | | #51 | ![]() |
If springs do become an option can we get a set made that will level the car out so it doesnt squat in the rear. I would rather see the car raked out than squat like a civic.
![]() | | #52 | ![]() |
Rep Power: 127 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
Ok ok fine fine add me to your stupid list lol.
![]() | | #53 | ![]() |
Rep Power: 14 ![]() ![]() Thanks: 61
Could you put me on the list please
![]() | | #54 | ![]() |
Done! Done! | |||||||||
| The Following User Says Thank You to Race Roots For This Useful Post: | nyghtryder (11-10-2009) |
![]() | | #55 | ![]() |
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 544 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 906
I see you increased the list to 20. Is the $165 price limited to the first 15?
__________________ 2009 MS3 sport MGM Almost fully semi-bolted
![]() | | #56 | ![]() |
![]() ![]() Join Date: Aug 2009 Location: San Diego
Rep Power: 15 ![]() ![]() ![]() ![]() Thanks: 37
Count me in. Does that make me lucky #15 to get this rolling?
![]() | | #57 | ![]() |
The price will be going up $20 Next week so hop on now! Yes it does so now we need money to start coming in! | |||||||||
![]() | | #58 | ![]() |
| Pay Me The Money I'm Owed ![]() Join Date: Jun 2008 Location: california
Rep Power: 811 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,948
Groans: 60
![]() | Not Ranked : 0 score
so when do payments need to get going and to who? i haz been out the loop
__________________ 1996 200SX SE-R-Injen, JWT, Unorthodox Racing, Progress, GReddy, Nismo, Weapon-R, Prothane 2008.5 Mazdaspeed 3-Cobb, GReddy, AWR, Racing Brake, Street Unit | ||||||||
![]() | | #59 | ![]() |
Screw it, it's only money. Put me on the list. Thanks.
![]() | | #60 | ![]() |
Time for people to send in payments! People can send payments to PayPal account sales@raceroots.com in the following format for the order notes so I can recognize it. "User Name Here" from MSF Progress RSB GB Payment Thanks Brice
Last edited by Race Roots; 11-10-2009 at 06:20 AM. Reason: MSF Database - Automerged Doublepost | |||||||||
![]() | | #61 | ![]() |
![]() Join Date: Sep 2008 Location: Tallahassee, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 59
Very interested if I can still get in for the $165 shipped price. I've read owners having issues with the Cobb and/or Hotchkis squeaking and clunking on them. Will this Progress RSB have the same issues? Or is this common? When will these ship after you receive payment?
__________________ 5% off Redline leather goodies To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Pics of them installed in my Speed3 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #62 | ![]() |
Payment sent.
__________________ 08.5 Mazdaspeed 3 - CP-E Nano SRI, SU Test Pipe, custom FMIC, CP-E RMM, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's 253WHP/274WTQ on a Mustang Dyno 08 Kawasaki Z1000 - Laser X-Treme Exhaust, -1 Front Sprocket, Speedohealer, Renthal Ultra-Low Bar, CRG Bar End Mirrors, Pazzo Levers, Motovation Frame Sliders, Targa Fender Eliminator, OEM Rear Cowl | |||||||||
![]() | | #63 | ![]() |
Free shirts with orders?
![]() | | #64 | ![]() |
![]() Join Date: Jan 2009 Location: Chicago,IL
Rep Power: 67 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
Money sent. Idea when these will ship?
__________________ Black Mica 08.5 GT I'm parting out. Buy my stuff: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #65 | ![]() |
Squeaking and clunking can be attributed to many other things such as installation error as the biggest one. But Proper lubrication of the bushings is important as well. Fedex We might possibly do that we dont have a full set of sizes available currently but when these ship when production is complete we might have some and I will be happy to throw in shirts. ![]() This pre order is to begin production so estimations should be 4 weeks for the complete production run, then they will ship to me from CA (5 days) to FL then out to the customer. ![]() Thanks for participating in the GB! | |||||||||
| The Following User Says Thank You to Race Roots For This Useful Post: | wankular (11-09-2009) |
![]() | | #66 | ![]() |
Groans: 60
![]() | Neutral : +1 score
cant wait just need a car to put it on. but 4 weeks is fine since i dont have one lol. pm sent to finalize us up brice... people should jump all over this deal
![]() | | #67 | ![]() |
Thanks for answering my questions. Please add me to the list. When is the latest we can send payment over?
![]() | | #68 | ![]() |
![]() ![]() Join Date: Apr 2009 Location: Mahopac, NY
Rep Power: 36 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
payment sent | ||||||||
![]() | | #69 | ![]() |
payment also sent yo
![]() | | #70 | ![]() |
The latest? The sooner the better for the community, I would not want to have it held up for more than a week. Unless there are justifiable circumstances and can give me a definitive date otherwise. You can take it to pm if you like to let me know. | |||||||||
![]() | | #71 | ![]() |
![]() ![]() Join Date: Aug 2009 Location: Sweden
Rep Power: 17 ![]() ![]() ![]() ![]() ![]() Thanks: 1
Payment sent here as well! Shipping to Sweden ftl
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #72 | ![]() |
I think you should update the list with who has paid, that way we can get on the ass of those who haven't
![]() | | #73 | ![]() |
So far 9 deposits are in, I am very pleased with how quickly and accurately everyone is following directions...lol | |||||||||
![]() | | #74 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
My payment was sent in earlier.
__________________ 2002 Mazda Protege 5 (Sold) 2009 CWP Mazda 3 GT (Totaled after 5 months) 2009 CWP MazdaSpeed3 (Current) | ||||||||
![]() | | #75 | ![]() |
| i burn your RICE ![]() ![]() Join Date: May 2009 Location: Fayetteville, NC
Rep Power: 332 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 295
Groaned at 30 Times in 21 Posts
you got #19 on your list right here with payment sent!!!
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #76 | ![]() |
Added! And got it! | ||||||||
![]() | | #77 | ![]() |
Groans: 60
payment will be sent in morning... any chance i will see it for christmas my tree is naked without it lol
![]() | | #78 | ![]() |
| The Following User Says Thank You to Race Roots For This Useful Post: | skeeter149 (11-12-2009) |
![]() | | #79 | ![]() |
Can't wait to get this as an early Christmas present ![]() BTW - in that first pic, is that a small pack of grease in the middle? I'm assuming we'll get that too?
__________________ 5% off Redline leather goodies To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Pics of them installed in my Speed3 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | |||||||||
![]() | | #80 | ![]() |
Groans: 60
call it paid my brother can you pm me and lemme know if i did the paypal right?
| Thread Tools | |
| Rear diff mount and rear sway bar | bcmps | MazdaSpeed 6 - Engine, Transmission & Driveline | 7 | 09-20-2009 08:09 AM |
| Help me decide which Rear Sway | Czar Quanovan | MazdaSpeed 3/6 - Suspension & Brakes | 35 | 05-26-2009 09:03 AM |
| FS: OEM MS3 rear sway bar, Cobb sri filter, Corksport rear mm inserts. | 08cosmic3 | MazdaSpeed 3/6 - For Sale / Trade | 1 | 04-16-2009 02:23 PM |
| rear sway bar? | bombdotcom | MazdaSpeed 3/6 - Suspension & Brakes | 22 | 02-18-2009 09:35 AM |
