 Old 02-10-2012, 01:47 PM   #1
kevdog's Avatar
Posts: 2,449   (View Stats)
kevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the worldkevdog is the leader of the world
Groaned at 15 Times in 14 Posts
Default H&R springs / Koni Yellow bumpstop question
Pulled the trigger on a set of H&R springs and Koni Yellows for my 08 MS3. I have been reading bump stop related threads for days now trying to decide what type to put in, and if any cutting is necessary. I know that my rear stops are still in decent condition, but the fronts are destroyed. SO... the main question is;
What are others with the same spring / strut / shock combo running? What stops did you end up using? Did you trim them? etc... I know there are FCM's and ground control, but which is best?
10 years ago i would have just slammed the car and dealt with it, but now I actually want a good ride with my low stance
Any input is appreciated.
gtx3076 and shit
kevdog is offline   Reply With Quote
 Old 02-10-2012, 04:18 PM   #2
Design's Avatar
Posts: 1,885   (View Stats)
Groaned at 9 Times in 5 Posts
Some are reporting the FC and GC are essentially the same height and of the same material. So if it were me I'd go with the cheaper one. I will always suggest leaving the rears untouched. They technically assist the rear springs during jounce.
09 CWP MS3 GT
Ownership & Build Thread
Design is offline   Reply With Quote
The Following 4 Users Say Thank You to Design For This Useful Post:
ant_wailes (03-08-2012), kevdog (02-10-2012), Nliiitend1 (02-10-2012), SKiZ0TT (02-13-2012)
 Old 02-10-2012, 04:20 PM   #3
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
^^This.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 02-10-2012, 05:40 PM   #4
kevdog's Avatar
shit... just dropped cash on the fatcat fronts... oh well! So the rears should remain the same length even with the car lowered?
thanks for the replys!
gtx3076 and shit
 Old 02-10-2012, 06:11 PM   #5
Design's Avatar
Yes. Most manufacturers offset the rear spring rate slightly to compensate.
09 CWP MS3 GT
The Following 2 Users Say Thank You to Design For This Useful Post:
kevdog (02-10-2012), SKiZ0TT (02-13-2012)
 Old 01-29-2013, 09:32 AM   #6
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
thatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the worldthatsmrgimp2u is the leader of the world
Did you wind up cutting the front stops at all? Im going to start ordering parts next month so I want to get all my ducks in a row. I am going with swift R springs and koni yellows, probably with the whiteline WALK as well. Seems like everything im finding of worth is for the FSD's on stock or cobb springs...
| CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline   Reply With Quote
 Old 08-27-2013, 04:36 AM   #7
alextheguineapig's Avatar
Posts: 827   (View Stats)
alextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the worldalextheguineapig is the leader of the world
I hate to bump this thread, but is that right? I'm getting swift Springs on koni Yellows in the next few weeks and I just want to make sure I do it right. I shouldn't cut the rear or change them for the gc ones? This is just the first thread in searching that said that.
Current
2013 Ingot Silver Focus ST - ST3
Injen: 3in SES Exhaust TT Tips
SOLD!
2008 Sunlight Silver MS3:
BNR: S3 V2
Cobb: V3 AccessPort
CNT: Catted Downpipe / Cat-Back Exhaust
Damond Motorsports: RMM
Eibach: Prokit
HTP: 3" Intake System (One-piece)
JBR: Rear Sway Bar
Koni: Yellows
MAC: 3-Port EBCS
Morimoto: HID Kit / The Retrofit Source clear lens swap.
NATOR FMIC: Cx Racing piping / Treadstone TR8
alextheguineapig is offline   Reply With Quote
 Old 08-27-2013, 10:15 AM   #8
Design's Avatar
Most won't recommend replacing the rears. In addition to loss of spring rate under cornering, you'll have to find a way to reattach the dust shields. They are bolt-on plastic cylinders that attach to the third ring of rear jounce bumper.
09 CWP MS3 GT
The Following User Says Thank You to Design For This Useful Post:
Nliiitend1 (08-29-2013)
 Old 08-27-2013, 10:21 AM   #9
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Order the ground control bump stops. They are cheaper and work great. I would say don't cut the rears and see how it feels. I cut approx 1/2" off my rears with no negative effects. You will likely need to pull the rear shocks a time or two, so you can change the settings. You can cut them then if you feel necessary.
 Old 09-30-2013, 12:03 PM   #10
jmen73's Avatar
Posts: 63   (View Stats)
jmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of lightjmen73 is a glorious beacon of light
I have the yellows with Eibach pro springs. I didn't cut anything other than my knuckle when reattaching the rears. I left my original OEM stops on my rear shocks (full soft) and they are fine. The fronts (medium soft) have new OEM stops and pivot bearings. I would order a spare OEM pivot bearing for the front. One of them may go out with the tighter suspension. I have had to replace both after swapping the suspension. Note: the OEM bump stops are longer and softer than the FC stops.
2007 Red MS3: 4" ported PTE 5858, HTP intake, HTP undermount, Treadstone TR8, HKS BOV (VTA), Custom exhaust mani, V-band dp, CNT exhaust, ACT clutch, ACT 6-puck PP, Damond PMM, RMM & TMM, Koni yellows, Eibach prokit springs, Damond OCCs (vented & not).
jmen73 is offline   Reply With Quote
Bilstein vs Koni yellow Atomic41 MazdaSpeed 3/6 - Suspension & Brakes 38 07-08-2017 05:11 AM
Koni Yellow Sport Install Question RussM MazdaSpeed 3 - How-To's 14 04-10-2012 03:54 PM
Coilover VS Koni Yellow+Springs gar_lei 2010 MS3 - Suspension & Brakes 48 04-01-2012 11:51 PM
Koni Yellow install question expoz3d MazdaSpeed 3/6 - Suspension & Brakes 5 04-20-2011 09:57 AM
H&R w/ Koni Yellow demonspeed MazdaSpeed 3/6 - Suspension & Brakes 12 07-22-2009 07:51 PM
Page generated in 0.30605 seconds with 26 queries
