MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() | ![]() | #1 | ![]() |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
(Thread Starter) | ![]() ![]() ![]() Vehicle handles uneven, non-smooth surfaces at high speeds so much better that it makes me want to cry. Also, I've heard that you're supposed to turn dampers on coilovers to full soft for a certain amount of time to break them in. Do I have to do that with these Koni's too? I can't find any info on it. Thanks. P.S. Totally worth the 550 shipped I paid to THMotorsports. Good guys.
__________________ '06 Evo IX MR - 377/320 whp/wtq ETS FMIC | ETS IC Piping | TiAl Bov | SD Tune by ER | Walbro | Blitz SBC i-D Spec-R | Defi Gauges | AMS Shifter Bushings | Blox FMM | Swift Spec R Springs | Agency Power 27mm Rear Sway | '09 MS3 - untuned CP-E SRI | HKS SSQV | Darkstar BSD | SU Shifter Bushings | CP-E Rear MM | Kenwood DNX8120 | CP-E Turbo Inlet | Demon Eyes | CP-E Catless DP | H&R Springs | CP-E FMIC | Screw-on Oil Filter Conversion | Prosport Sandwich Plate | NGK LTR7IX-11 | Koni Yellows | CP-e HPFP | |
The Following 2 Users Say Thank You to demonspeed For This Useful Post: | Addikted To Boost (07-22-2009), gsrtype1 (07-22-2009) |
![]() | ![]() | #2 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4006 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
Groans: 67
| ![]() ![]() ![]() Don't worry about any specific "break-in" procedure. It doesn't surprise me at all that your car feels much more controlled. I just hope the Konis hold up well being forced to operate over a suboptimal range of motion (being as that they were designed for a stock-ride-height Mazda 3). Keep us updated. ![]() |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| ![]() ![]() ![]() did you just get the "shock kit" ? my shocks are fine but ti could be smoother over bumps...
__________________ ![]() |
![]() | ![]() | #4 | ![]() |
Groans: 102
__________________ ![]() | |
![]() | ![]() | #5 | ![]() |
Groans: 67
| ![]() ![]() ![]() They "will work" with the MS3, but they are the same exact part that Koni has been selling for use on the regular Mazda 3 for years. They were designed as a stock replacement for the regular 3, meaning that they are designed to operate at regular Mazda 3 ride height. ![]() |
The Following User Says Thank You to Nliiitend1 For This Useful Post: | gsrtype1 (07-22-2009) |
![]() | ![]() | #6 | ![]() |
![]() Join Date: Nov 2008 Location: Alexandria, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 413
Groans: 40
| ![]() ![]() ![]() From what I understand, Koni Yellows are for drops of more than 1", while the Koni FSD's are the ones that are made for stock ride height. Please correct me if I'm wrong... |
![]() | ![]() | #7 | ![]() |
(Thread Starter) | ![]() ![]() ![]() I've heard both, but no matter what their original design parameters, they are worlds better than stock, and one of our only options, short of coilovers. As for them working outside of their operating range, they are and aren't. They aren't progressive (as far as I know), so their dampening effect is not vehicle height specific. With the 1.2/1.4 inch drop the H&R's provide, they have much less travel to actually work in, but this really doesn't matter to the Koni's, nor should it have a negative effect on them directly. It's just more of a flaw in the suspension in general. gsr, I have my fronts set to full stiff, and rears on the medium setting. The way the stock struts drive is still very fresh in my mind, so it is skewing my impression of the Koni's due to the difference. As for it being smoother over bumps, how fast are you going, and what kind of bumps? Low speed (i.e. parking lots etc...) the dampers really aren't doing anything. If its high speed we're talking about, then yeah.
![]() | ![]() | #8 | ![]() |
rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3155 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,386
Groans: 221
| ![]() ![]() ![]() I think I found them on the site, but they look a little more expensive than 550 for all 4. do you have the link?
__________________ '08 CWP MS3 w/ T3 3071r |
![]() | ![]() | #9 | ![]() |
(Thread Starter) | ![]() ![]() ![]() Call em, 1-800-959-0145. I googled koni yellow's on MS3's, and I found some random (247 I think) thread where they were doing a GB if I remember correctly, I called them, and they had a slightly different price, but still far better than anyone elses.
![]() | ![]() | #10 | ![]() |
Groans: 67
Does this mean that they're ultimately unsuitable for use with shorter springs? No, but the further from stock height you get, the less "optimal" they become... | |
![]() | ![]() | #11 | ![]() |
Groans: 102
![]() | ![]() | #12 | ![]() |
__________________ '06 Evo IX MR - 377/320 whp/wtq ETS FMIC | ETS IC Piping | TiAl Bov | SD Tune by ER | Walbro | Blitz SBC i-D Spec-R | Defi Gauges | AMS Shifter Bushings | Blox FMM | Swift Spec R Springs | Agency Power 27mm Rear Sway | '09 MS3 - untuned CP-E SRI | HKS SSQV | Darkstar BSD | SU Shifter Bushings | CP-E Rear MM | Kenwood DNX8120 | CP-E Turbo Inlet | Demon Eyes | CP-E Catless DP | H&R Springs | CP-E FMIC | Screw-on Oil Filter Conversion | Prosport Sandwich Plate | NGK LTR7IX-11 | Koni Yellows | CP-e HPFP | | |
![]() | ![]() | #13 | ![]() |
Groans: 67
Display Modes | |
Koni Yellow Install this weekend... | thanotosq | MazdaSpeed 3/6 - Suspension & Brakes | 29 | 06-29-2009 09:24 PM |
Koni FSD vs Sport | nyghtryder | MazdaSpeed 3/6 - Suspension & Brakes | 19 | 06-14-2009 03:00 PM |
THE KONI COILOVER FOR THE SPEED3 | hamptotl | MazdaSpeed 3/6 - Suspension & Brakes | 10 | 02-12-2009 10:14 AM |
