 Old 10-05-2014, 04:50 PM   #1
Code Monkey's Avatar
Posts: 7,666   (View Stats)
Default Help with front strut
gen pu, how the fuck do I press the front strut back into the spindle??? We tried securing the top hat first, then jacking up the control arm, the strut is not going in, we only compressed the spring. Now we are trying to wiggle the strut in without bolting the top hat, no dice either. We hammered the strut out, if we need to hammer it back in, there is not enough space to do it from the bottom. Any other ideas? Put some lube on the strut and in the spindle?
@phate;
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
 Old 10-05-2014, 05:02 PM   #2
SaveMelMac's Avatar
Posts: 471   (View Stats)
SaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the worldSaveMelMac is the leader of the world
I had trouble getting it to seat also. One side I was able to simply put a jack under the ball joint and jack the car up. The other side gave me trouble. Basically I had to put the wheel back on and lower the car back down on the wheels a few times, dropping it pretty hard from the floor jack back down. Basically I dropped the car down from a foot off the ground
SaveMelMac is offline   Reply With Quote
The Following User Says Thank You to SaveMelMac For This Useful Post:
Code Monkey (10-05-2014)
 Old 10-05-2014, 05:05 PM   #3
Eth Fiend
phate's Avatar
Posts: 6,932   (View Stats)
Make sure it's going in straight. Sometimes you need to grab the knuckle and move it around a bit until it lines up. If the strut is misaligned at all it just binds.
If you absolutely can't get it, spread the strut holder piece slightly apart. Don't do it much, because it can mess it up.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 10-05-2014, 05:09 PM   #4
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Like is it not going in at all or is the tab not sliding in the right spot. Gen pu still has the tab on RIGHT?
lots of antifreeze
Sent from my gs5
Damond Built Speed 6
Deldran is offline   Reply With Quote
The Following User Says Thank You to Deldran For This Useful Post:
 Old 10-05-2014, 05:14 PM   #5
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
MazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the worldMazdaBoy2.3 is the leader of the world
Groans: 51
Groaned at 29 Times in 22 Posts
You most likely will need to stretch where it goes in to the spindle. I used a fat screwdriver, or a small crow bar, and pounded it in to spread it. Just be careful not to hit the cv boot. ;-)
The other option is to reverse thread the bolt and place some metal in between, which will spread it.
Good luck.
I used to go zoom zoom with my speed....
Now i drive a slow stockish Focus ST...
MazdaBoy2.3 is offline   Reply With Quote
The Following User Says Thank You to MazdaBoy2.3 For This Useful Post:
 Old 10-05-2014, 05:19 PM   #6
The tab is aligned, we are trying the reverse bolt method to spread the mount, the strut went halfway in and is stuck for now, will try to spread some more or maybe we should just lower the car at this point.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 10-05-2014, 05:23 PM   #7
Zoomer1987's Avatar
Posts: 25   (View Stats)
Zoomer1987 has a spectacular aura aboutZoomer1987 has a spectacular aura about
I had some problems too with my H&R coilovers but what I did was secure the strut and top hat, then line up the spindle and bottom of strut, clean inside of the spindle, use ALOT of penetrating oil and then jack up from bottom, i just changed both of my front bushing and top hats last night and that's how I did it, worked like a charm, getting them to release was far harder, long 2x4 and a metal hammer solved that problem
Zoomer1987 is offline   Reply With Quote
The Following User Says Thank You to Zoomer1987 For This Useful Post:
 Old 10-05-2014, 05:36 PM   #8
Ok, the strut is in, it got stuck midway, but we jacked it up high, then dropped real quick and it went in a bit, so we started jacking it up and dropping down, and after several rounds, it went completely in.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 10-09-2014, 08:50 AM   #9
EcKid1974's Avatar
Posts: 34   (View Stats)
EcKid1974 will become famous soon enoughEcKid1974 will become famous soon enough
I had the same exact issue and my car was brand new when I did mine I DP'd the shit out of it then had to hammer it back in with the air impact hammer luckily I was at a garage because there was no way it was going back in
EcKid1974 is offline   Reply With Quote
The Following User Says Thank You to EcKid1974 For This Useful Post:
Code Monkey (10-09-2014)
 Old 10-09-2014, 08:52 AM   #10
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Gr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the world
Groaned at 123 Times in 84 Posts
Just play with it. It will eventually drop in. I got it to what I thought was aligned, it dropped an inch then bound and then I hit the spindle with a mallet a few times and it dropped in.
https://www.youtube.com/user/JustinBieberVEVO
Gr8Speed is offline   Reply With Quote
The Following User Says Thank You to Gr8Speed For This Useful Post:
Front Strut Bearings EvoFire MazdaSpeed 3/6 - Suspension & Brakes 4 05-01-2014 11:19 AM
Front strut bar on MS6????? redboat MazdaSpeed 3/6 - Suspension & Brakes 6 01-27-2014 10:51 AM
Page generated in 0.30117 seconds with 27 queries
