| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() | | #1 | ![]() |
![]() Join Date: Mar 2012
Rep Power: 0 ![]() ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Looking to order my shocks next week. I have H&R springs ready. I am looking at the Tokico Shocks but I possibly now have the budget for Bilsteins/Koni's However for the life of me I cannot seem to get a clear answer on the correct part number for the bilsteins. On the sticky at the top it says BE5-A256 I have since learnt this has changed to 24-102568 but I can't find that part number on the Bilstein catalogue! Parts catalogue I don't want to get the wrong one! Please help. Tokicos are easy as I have their part number. Thanks all |
| Able ![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 3290 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,162
Groans: 125
| Not Ranked : 0 score eshocks.com: Bilstein Shocks and Struts: Mazda 6 http://www.shockwarehouse.com/site/p...6-H1-Bilstein- In short, both are correct.
__________________ ![]() |
![]() Join Date: Apr 2012 Location: Evanston/Chicago ILL
Rep Power: 66 ![]() Thanks: 21
FWIW, Konis are undoubtedly better, but I'm pleased as punch with my Tokicos. They're a tiny bit stiffer then stock MS6. If there was another mod I wanted to pick up (and there's always another mod) that was close to the price difference between Konis and Tokis, I personally would have to think about it pretty hard. I doubt you'll regret either choice.
__________________ |
| The Following User Says Thank You to CaptainCrunch For This Useful Post: | greenespeed (08-13-2012) |
![]() | | #4 | ![]() |
Just an update, went for the Bilstein B8s in the end with H&R springs. Will get them fitted soon and will update you all |
![]() | | #5 | ![]() |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 2251 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,808
Groans: 542
Groaned at 181 Times in 120 Posts
What made you go with a lowering spring vs. a performance spring?
__________________ '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//OEM Hardtop//Bride Gias II//Autokonexion CF Trunk v2 '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line//Spin On Oil Filter Conversion '91 MR2: Planned 1MZ V6 or 3SGTE swap Driver Mod Level: Focus ST Academy So Cal Champion '12 |
![]() | | #6 | ![]() |
![]() Join Date: Nov 2009 Location: Westchester NY
Rep Power: 233 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 561
| Not Ranked : 0 score haulme are you installing yourself?
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge |
![]() | | #7 | ![]() |
![]() Join Date: Nov 2011 Location: Montreal,QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score ??? I dont understand that question.
__________________ 2007 Mazdaspeed 6 - CP-E CAI, KMD Internals, Cobb AP (Custom 91 tune, 17.5psi), Test pipe, JBR RMM, Sure Juggernaught, H&R Coilovers, JBR SSP & Bushings, 17x8 w/245-45-17 tires. |
![]() | | #8 | ![]() |
Groans: 542
| Not Ranked : 0 score The H&R spring is not a performance spring. It would be the equivalent of a BOV in spring form.
![]() | | #9 | ![]() |
Tokicos Suck with a capital S, Bilstien and Koni are a Solid choice As far as Springs go, Eibachs are good, however I'm not sure really what the more preferred porformance springs are available for the Speed6 exactly Basically, you want a Linear Springs vs Progressive, Linear springs compress evenly in one fluid motion as where Progressive springs are like 2 springs in one, designed more for comfort+performance
__________________ ![]() Long Block Built by GPwerks and Loose Screw Motor Sports https://www.gp-werks.com/ http://www.crossoverauto.com ^Any Parts, Great Prices^ |
![]() | | #10 | ![]() |
Groans: 542
The Tokicos are twin tube rubbish. The stock KYB on the MS6 are at least monotube... why anyone would downgrade is beyond me. My experience with the Eibach Prokit is not good. I have considerable seat time on them, and have done back to back comparison vs my car with stock springs. The stock springs are stiffer. I wish RPM still made springs.
![]() | | #11 | ![]() |
![]() Join Date: Aug 2011 Location: Dallas, TX
Rep Power: 244 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 244
Not sure how you can say that the H&R springs are not a performance spring? They greatly improved the handling and ride for myself and everyone I know running it... and that is with stock or aftermarket shocks.
__________________ CLEANED YOUR VALVES? |
![]() | | #12 | ![]() |
Groans: 542
H&R doesnt even call it a performance spring LOL "H&R Mazda Mazdaspeed 6 Sport Lowering Springs offer the handling characteristics and aggressive appearance that you've been looking for, without the harsh ride characteristics of less-advanced spring systems."
![]() | | #13 | ![]() |
H&R springs have been tried and tested. I know one other person running the same setup and they have been fine, in fact quite a few people say H&R are a lot stiffer than the eibachs... Anyhow here they are in all their glory, not going to be installing them myself, get my mechanic buddy to do it... ![]() ![]() |
![]() | | #14 | ![]() |
![]() Join Date: Nov 2010 Location: 93401
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 372
Groaned at 4 Times in 2 Posts
At least for the 6 the H&R springs do not have high enough spring rates in the rear and still soft in the front. They are very smooth with koni yellows. Sent from my ADR6300 using Tapatalk 2
__________________ Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP Stage 2 tune - Koni yellow struts - H&R springs _ (Looking for BT) |
| The Following User Says Thank You to dot584 For This Useful Post: | phate (04-27-2013) |
![]() | | #15 | ![]() |
I would still say they are stiffer than the OEM springs... Although lowering makes things distorted a bit...
![]() | | #16 | ![]() |
![]() Join Date: Jun 2012 Location: mentor, ohio
Rep Power: 28 ![]() Thanks: 52
I feel bad for your mechanic friend putting those rear shocks on is a PITA! I have the H&Rs and love them but i was not allowed to get anything more aggressive. Ride had to remain soft, but i couldn't stand the wheel gap any longer.
![]() | | #17 | ![]() |
I've done 6 rear susp. swaps 3 times this week alone, save your self some head ache and pick up a Swivel 14mm OR a 9/16th if you cant find a 14mm, Swivel adaptor may work to if its not too tall but Lows usually carries them, and an off set 14mm wrench as well, for the shock braket bolts that make the rear shocks such a pain
| The Following User Says Thank You to Coaststarlight For This Useful Post: | mczimer (10-08-2012) |
![]() | | #18 | ![]() |
Ill ask him if he has the sockets also, he restores old ford zephyrs(quite unique in the UK) I had a look at DIY'ing and was in for a shock with some of them saying its easier dropping the subframe out. Fronts look pretty straight forward, I have the strut perches and they almost slot in. Can't wait personally to have them fitted, had to live a 1.5 years with a car that looked like a n offroad car. After this I'll be getting an access port(now they support UK MPS )
![]() | | #19 | ![]() |
![]() Join Date: Jan 2011 Location: Vancouver BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
I'd like to hear how you like them. I have the H&R springs and have a blown rear shock so I need to get an opinion as this is an option.
__________________ 2006 Liquid Platinum Speed6 GT Bought 06.10 w/ 54,543 KM Currently @ 130K KM SURE:R6.Dreadnaught.Juggernaught.Anchors.ShortCut. FlowM6 HT.MS CAI.MSD DH.SU Rear Interior Brace Michelin 235/40/18 Pilot Super Sports on Drag DR-38s Gloss Black w/ Blue Undercut H&R Sport Springs.Hawk HPS.Centric X-D Rotors Pirelli 215/45/18 Sottozero 240 on MS6 Rims __________________________ |
![]() | | #20 | ![]() |
Bilsteins are great. Konis have had leaking issues for some. My opinion: bilstein all the way
| The Following 2 Users Say Thank You to mczimer For This Useful Post: | Coaststarlight (04-29-2013), Marcus (10-22-2012) |
![]() | | #21 | ![]() |
| Not Ranked : 0 score When run daily at full stiff they have been known to leak a bit, I've had Koni yellows DD and a few track days without issues
![]() | | #22 | ![]() |
Well I both daily drive and track my car so I certainly will give a good view of both. Getting them fitted next week so will report then |
![]() | | #23 | ![]() |
![]() Join Date: Mar 2011 Location: Elyria, Ohio
Rep Power: 62 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
I have bilstein hd's from streetunit.com check them out they at the minimum have the correct part numbers.... I like them a lot. I don't track my ms6 but I think they would be very capable... As a dd they are a little stuff, but not rough at all... StreetUnitMark may help ya out with that
__________________ CS LED kit, Aux input, Sure TIP, Sure SRI v2, Sure RMM, Turbosmart BPV, IVT22's, Prosport Boost gauge, JBarone SSP v2 and counterweight, H&R Drop Springs, Bilstein Shocks, Cobb AP, Sure M6, Sure Juggernaught, Sure Dreadnaught, Whiteline RSB, DSS axle, AT internals, Sure Charge Tubes. Currently getting DIZZY tuned! |
![]() | | #24 | ![]() |
Dropped of the car to my buddy today I took some stock photos including measurements and will post later this week once all fitted.At the front, stock bumper incredibly the ride height is a whole 9" of the ground! |
![]() | | #25 | ![]() |
Ok got it fitted First impressions were the looks, the car sits so much better and looks more squat from the back. It has a nice rake to it also. Pretty much exactly what I wanted. Mechanics used alot of the OE for the bump stops as the ones supplied were too small. Despite the advice above he actually found it easier to lower the subframe a bit to take out the rear shocks. Front shocks were easy to install though. Handling is good, I will reserve full judgement until I get the wheel alignment done. you can feel the road alot more but it doesnt seem uncomfortable however. Firm but stock it's like it should have come from the factory like this... Car has been measured and on average its about 2" lower all round but it still clears speed bumps Pics when the car is washed, looks like a dirty bitch at the moment. |
| The Following 2 Users Say Thank You to haulme For This Useful Post: | Coaststarlight (10-20-2012), Marcus (10-22-2012) |
![]() | | #26 | ![]() |
![]() Join Date: Nov 2011 Location: Huntingdon, UK
Rep Power: 0 ![]() Thanks: 0
any updates on this? I am curious to see pics. I have the H&Rs installed now and need new shocks. Interested in seeing how this combo looks.
![]() | | #27 | ![]() |
Hi mate I'm on MPS owners, I'm keeping the car reveal until I've finished completely but what do you need to know, it still feels great and looks good, now its settled its probably gone done another .5" so its a 2.5" drop overall. The Hoff has also gone for the same springs and shock combo and DJJUT is also running it(have a look at his car) Cheers |
![]() | | #28 | ![]() |
![]() Join Date: Mar 2013 Location: CT
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
Where did you order the bilstein B8's from because all i keep finding is the hd's which arent made for pairing lowering springs with
| Bilstein shocks for the ms3 | 18psiWhiteMS3 | MazdaSpeed 3/6 - Suspension & Brakes | 1085 | 05-18-2013 09:45 AM |
| tokico shocks | Joern | MazdaSpeed 3/6 - Suspension & Brakes | 36 | 08-06-2012 11:09 PM |
| how can u tell if your shocks are going/bad | Lvis | MazdaSpeed 3/6 - Suspension & Brakes | 23 | 09-01-2011 10:47 AM |
