MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() | ![]() | #1 | ![]() |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
(Thread Starter) | ![]() ![]() ![]() I'm in the process of overhauling my shocks/struts and bought everything to assemble a new set of shocks, struts and springs. This includes Koni Yellows (8741 1490L,R) and the Eibach ProKit. I also have brand new top hats and strut bearings (Motorcraft DV6Z-18198 and CV6Z-18183-A) I began assembling the fronts (not re-using springs that are on the car) and noticed that spring really did not have to be compressed much at all for the top hat bolt to be tightened all the way until it bottomed out on the shock shaft. I released the tension on the spring after tightening the top bolt and found that there really isn't much load on the spring at all. I can compress the spring by hand and it will stop touching the strut bearing. If you knock the assembled strut on the floor, there is a clunk because there isn't much load on the spring. Am I missing something? Does the sag of the vehicle weight make up for this, or if I install it as is will it be a clunky disaster? I guess what I'm asking is if in the Yellow/ProKit mate up, is there very little load on the spring when in the assembled strut? If you guys have any input, please chime in. I'd like to figure it out before it goes into the car. Cheers!
__________________ 2008 Black Mica MS3 Sport |
![]() | ![]() | #2 | ![]() |
![]() Join Date: Aug 2018
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 14
| ![]() ![]() ![]() Nope you aren't "missing" anything the front springs do not have much if any pre-load in the uncompressed strut. My H&R sports were the same in my yellows. BTW until the springs settle in the front you will get a few pops in the front when turning at low speeds. This usually goes away in a few days
__________________ 2008 True Red Mazdaspeed 3 Mod list: Cobb RMM, TIP, SRI w air box, CBE and AP3 Corksport Short throw plate w/ shifter bushings, TMIC and BPV CPE catted DP Tune done by Will at PD-Tuning (still slow need BT) 150k miles on original motor and turbo H&R sport springs w/ Koni yellows 17x9 +48 6UL with 245/45R17 Flaken Azenis |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 1114 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,452
Groans: 154
| ![]() ![]() ![]() Indeed, the gap will be gone when the vehicle is returned to ride height and the spring and strut compressed. This temporary gap may be exaggerated with shorter springs, and certainly will seem so with the assembled strut, spring, bearing and hat assembled and on the workbench. In that state there is no preload whatsoever. This is normal. Much of that gap goes away once you compress enough to get the bottom of the strut into the bottom of the knuckle and locked down with the cross bolt. You will then be rotating the spring and strut bearing to make sure it is aligned properly, strut bearing tab to the outside, spring base rotated against the stop, and then jacking the bottom of the knuckle up in order to put the sway bar end link back in place. The gap will disappear as you do this. You will probably have to use that jack to press the strut bottom into the knuckle to its resting position, anyway. With the vehicle back on the ground, there will be no gap.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 02-13-2019 at 03:53 PM. |
Display Modes | |
H&R springs / Koni Yellow bumpstop question | kevdog | MazdaSpeed 3/6 - Suspension & Brakes | 9 | 09-30-2013 01:03 PM |
Koni Yellow Sport Install Question | RussM | MazdaSpeed 3 - How-To's | 14 | 04-10-2012 04:54 PM |
Koni Yellow install question | expoz3d | MazdaSpeed 3/6 - Suspension & Brakes | 5 | 04-20-2011 10:57 AM |
H&R w/ Koni Yellow | demonspeed | MazdaSpeed 3/6 - Suspension & Brakes | 12 | 07-22-2009 08:51 PM |
