 Old 07-07-2013, 12:57 PM   #1
0nsp's Avatar
Posts: 143   (View Stats)
0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold0nsp is a splendid one to behold
Groaned at 5 Times in 2 Posts
Default KW v3 rear shock help
Ok, really basic question, but I can't find an answer anywhere.
When installing the rear shocks for the KW v3, do I reuse the stock bump stops?
Right now i have the KW v3, with its yellow foam, then the stock black foam on top, then the OEM top hat and installed. I think I need to go back and remove the stock black bumpstop so that the top hat sits directly on the KW's yellow foam.
Thoughts? Any risks to having the "extended" bumpstops? THanks.
07 BM MS3//
Power//MS CAI/COBB TIP/CP-e DP/CP-e TMIC/TS BPV/Greddy OCC/COBB AP/NGK plugs/Autotech FP
Handling//Hotchkis F+RSB/TRZ RMM + TMM/Enkei RPF1 on Continental Extremecontact DW/solid shifter bushings/custom weighted shift knob/JBR SSP/KW v3 coils
Cosmetic//Tinted tails + windows + side markers/blue led interior/EONON D5102/Heated seats/Speedline tinted+heated mirrors/2tone emblems/painted calipers
0nsp is offline   Reply With Quote
 Old 07-08-2013, 09:59 AM   #2
Design's Avatar
Posts: 1,884   (View Stats)
Groaned at 9 Times in 5 Posts
Correct. The only OEM part reused is the upper shock mount.
If it were me I'd change out right away.
09 CWP MS3 GT
Ownership & Build Thread
Design is offline   Reply With Quote
The Following 2 Users Say Thank You to Design For This Useful Post:
0nsp (07-08-2013), Nliiitend1 (07-13-2013)
 Old 04-19-2017, 02:14 PM   #3
herzloglover's Avatar
Posts: 185   (View Stats)
herzloglover has much to be proud ofherzloglover has much to be proud ofherzloglover has much to be proud ofherzloglover has much to be proud ofherzloglover has much to be proud ofherzloglover has much to be proud ofherzloglover has much to be proud ofherzloglover has much to be proud of
is there any chance you and send a photo to verify?
2011 Velocity Mica Red MS3
Performance
Hypnotic Juice | BNR S3 | Cobb AP v3 | Autotech HPFP | Torx Injector Seals | 3 Bar Bosch Map Sensor | HTP 3.5" Full Aluminum Intake | Turbo XS Downpipe | Corksport Test Pipe | Racing Beat Catback | Grimmspeed EBC | StreetUnit TMIC | Full JBR EGR Delete | Ghetto Rigged Ebay Vented OCC | Corksport Camber Plates | KW v3 Coilovers | CP-e Stage 2 RMM | JBR PMM 80 Duro | JBR Short Shift Plate | JBR Shifter Bushings |
Dem Looks
Rally Armor "2014 Breast Cancer" Mud Flaps | Kensun 6k HID |
herzloglover is offline   Reply With Quote
Blown Rear Shock SPEEDRAC3R MazdaSpeed 3/6 - Suspension & Brakes 19 10-15-2012 02:28 PM
rear shock blown? blakkat 2010 MS3 - Suspension & Brakes 19 06-13-2012 06:25 PM
Page generated in 0.24485 seconds with 22 queries
