 Old 06-29-2017, 09:52 AM   #1
Lex2007's Avatar
Posts: 539   (View Stats)
Default KW V3 rear struts failed after 36,400 miles
I do believe my rear KW struts are failing after only 36,400 miles.
I put in new Moog rear endlinks and new energy suspension bushings on my JBR rear anti-sway bar (max setting is sooo sweet) to make sure the loud clanking I was getting over small bumps wasn't from the sway bar or its components, and in fact it wasn't. The noise persists.
I called KW and they said that it was normal at 36kmiles. sheesh.
Anyone else had KWs fail so quickly? Luckily I didnt get the Mazdaspeed version with no warranty.
Why does this platform chew up rear struts so fast? My OEM shocks only lasted 50k miles and failed in dangerous fashion.
 Old 06-29-2017, 11:10 AM   #2
Oshiguru's Avatar
Posts: 73   (View Stats)
Oshiguru is just really niceOshiguru is just really niceOshiguru is just really niceOshiguru is just really niceOshiguru is just really nice
I have KW v1s, and all 4 are leaking/shot after 1 year and 30k kms. I did put a lot of wear on them (2-3x a month autox and lots of track days). Hopefully they can send you a new set so you can install it and mail back the old ones for warranty. I know bilstein does that but unsure if kw does.
Oshiguru is offline   Reply With Quote
 Old 06-29-2017, 11:16 AM   #3
Lex2007's Avatar
Wow they died fast!
KW makes you send you in the damaged units for warranty repair with 2-3 week turnaround time. You must have receipt of purchase.
I think Ill send all 4 for a check while I'm at it. Glad I didnt buy the Mazdaspeed branded units.
 Old 07-11-2017, 08:22 AM   #4
Lex2007's Avatar
Have you see the warranty RMA form? Its kinda over the top. They ask you to make 8 measurements and get the numbers off of every part. How many horses your car makes, etc etc etc sheesh.
 Old 07-11-2017, 08:43 AM   #5
Djohns's Avatar
Posts: 3,880   (View Stats)
Groans: 105
Yea I had to fill that out when I got my fronts rebuilt. I left a lot of it blank haha
2010 black mica speed3
Soon:built motor
 Old 07-11-2017, 07:53 PM   #6
cyber-ms3's Avatar
Posts: 192   (View Stats)
cyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond reputecyber-ms3 has a reputation beyond repute
Groaned at 6 Times in 2 Posts
From my experience and at Chrysler, local shops and school, shocks generally have to be replaced around the 40k-50k mile range. Of course excessive wear and tear i.e. offroading, high speed over rough terrain will reduce that number.
Honestly, 36k miles is not so far off depending on the road conditions. Regarding the 50k miles of your previous shocks, I'm surprised it even lasted 5k. You might have even been riding on failed shocks the whole time which is why it "failed in dangerous fashion".
cyber-ms3 is offline   Reply With Quote
 Old 07-12-2017, 11:29 AM   #7
Lex2007's Avatar
Wow you have some low expectations. Yes I realize most people expect shocks to last longer then is realistic, but 36k for $1800 suspension. Street use only. That's below my expectations.
60-80k miles of street use as a threshold at which struts starts to misbehave makes sense. Thats what I consider normal.
MAZDA's OEM rears went only 50k before truly catastrophic failure that made the car dangerous to drive. That's unacceptable.
My rear KW V3 struts are dangerous at this point. I can feel the rear floating back and forth now.
Im glad I bought the KWs and not the Mazdaspeed units which have no warranty (although Ive heard KW sometimes honors a warranty). That being said, its still a major PIA to take this all off, ship, wait 3 weeks, and then reinstall.
 Old 07-16-2017, 12:19 AM   #8
SpeedyTurd's Avatar
Posts: 28   (View Stats)
SpeedyTurd will become famous soon enoughSpeedyTurd will become famous soon enough
I think they have recommended height settings And break in period? I could be wrong. I thought I seen that in some paper work that came with my KW v3s.
Also dropping the car on it's nuts maxing it out will even last for ever. More wear and tear.
Shit, just realised my account is back in brownie mode
SpeedyTurd is offline   Reply With Quote
 Old 07-17-2017, 08:22 AM   #9
Lex2007's Avatar
Default Failed KW front struts causing vibration and whirring noise at highway speed
They give you a range of acceptable heights and I was within that normal range.
I took out the KW suspension and put in my old Koni yellows on OEM springs. Holy 4x4. I could conquer Mt. Kilimanjaro with the ground clearance I have. The fender gap is obscene. The steering feels much less responsive compared to the KWs.
But more interesting is that failed KW front struts (and/or KW thin profile strut mounts) were causing or exacerbating a vibration and whirring noise at highway speed (which may be right front bearing.. or my tire).
It was a very loud whirring noise when on the accelerator above 50 MPH and a vibration in the floor pan. I spent many hours tracking down that noise, to no avail.
The rear struts were completely dead. As sin...the piston was compressed and non responsive. When those struts die they die fast.
 Old 07-17-2017, 10:20 AM   #10
sho
sho's Avatar
Posts: 534   (View Stats)
sho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the world
96k miles on my mazdaspeed coilovers (KW v3's). Not a single issue yet.
2007 Mazdaspeed 3 GT
Suspension/Braking/Handling:
-Mazdaspeed Accessory Coilovers/SPC Camber Arms/Hotchkis 32mm Front and Rear Sway Bars/Stoptech Brake Rotors/EBC REDSTUFF Brake Pads/17x9 +42 Enkei RP01's with 255/40/17 Hankook rs3
Engine/exhaust goodies:
-Built bottom end -Manley H-Beams, Manley 88mm platinum series pistons, stock head, stock head studs, ACT 6puck w/ prolite flywheel, cp-e exhaust mani, PTE5862, 6th port w/ Bosch 2200's and aeromotive 325 stealth pump, tr1235 fmic w/ 3" cold side
Tuned by Realgib3
sho is offline   Reply With Quote
 Old 07-17-2017, 11:01 AM   #11
Lex2007's Avatar
That's amazing. And I havent raced my car. Just drive it daily...mixed city/highway. OEM wheels and tires with Barone rear antisway bar.
 Old 08-09-2017, 09:48 AM   #12
Lex2007's Avatar
Got the rebuilt struts back. Took 3 weeks despite next day shipping to them because they ship super slow ground.
Anyway, they cleaned up the struts and added new bump stops and piston bellows (the black covers) with a new design. The original bellows fell apart in a few months. I dont know what else they did other than change the seals as they dont really offer up much info. They also include a new piston nut.
I bought new bearings for the front and new lower spring perches (the ones that you use to adjust height). The plastic threads on mine were kinda worn and the plastic threads for the allen screw which holds the perch in position were toast.
I gotta say the OEM springs with Koni yellow's is so much more reasonable on bad roads. But man do those OEM springs SUCK. Floaty and a total lack of precision. I think having the rear JBR anti-sway bar at its stiffest setting is too much for the stock springs to handle. I experienced some weird body roll and secondary body movements over bumps at highway speed with this temporary set up. Kinda scary frankly.
Here's 2 of the 4.
[IMG]IMG-20170809-WA0005 by xcvx4, on Flickr[/IMG]
Corksport Struts, JBR Rear Sway Bar, JBR Rear Camber Arms Install/Initial Feedback Sinister_Speed3 MazdaSpeed 3/6 - Suspension & Brakes 15 11-25-2015 08:03 AM
Failed rear diff coupling 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 6 08-04-2011 10:27 AM
Page generated in 0.34191 seconds with 25 queries
