 Old 05-03-2018, 08:32 AM   #1
chad38davis's Avatar
Posts: 4   (View Stats)
chad38davis is an unknown quantity at this point
Default MS3 Gen 1 Suspension Issues
First off, let me introduce myself to the forum. This is my first post so I'm sorry if I make a rookie error or show any noob like behavior.
I've read the other threads over suspension issues that sound to have the same problem, but I figured some of you guys would have a little more insight. So my car has been making a slight clunking noise when going over bumps in the road for quite a while. I did a much needed upgrade to the car and installed bc racing coilovers on the car. The clunking seemed to stop for a while after the coilovers, but within the past two weeks its come back and it's way worse!
The best way to describe the problem is when going over any slight bump or pothole or even and uneven surface on the road the car makes a disheartening clunking noise. I can tell the noise sounds to mainly be coming from the left front. I just want to fix the problem soon before it turns into a bigger issue. I read that it could possible be ball joints and that the lower a arm ball joints are the first to go so I just purchased two new lower a arm assembly's and ofcourse the problem is still there. My next thought is front sway bar end links, but I wanted to ask you guys is there is a certain way to diagnose the problem instead of just throwing parts at it, because we're all on budgets. haha. Any suggestions on what else I may need to check out and how to check for the problem.
Thanks guys!!!
chad38davis is offline   Reply With Quote
 Old 05-03-2018, 10:20 AM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,896   (View Stats)
Groans: 539
check front sway bar bushings, if there's play there you can prolly move the sway bar by hand and recreate the noise.
94 M
06 MS6
 Old 05-03-2018, 10:34 AM   #3
Db09ms3's Avatar
Posts: 281   (View Stats)
Groans: 65
What Pu Manchu said. I had the same issue. Before I did them I found a blown strut and my strut bearings were shot. Replaced them but the clunk persisted. Did the sway bar bushings and it is gone. Now the rear is doing it.
Stockish
 Old 05-03-2018, 11:18 AM   #4
Okay, I’ll check for play later on today. Is it a difficult job to replace the front sway bar bushing? Or is it just time consuming? And is yall’s opinion, is it a good idea to go ahead and replace the end links as well?
 Old 05-03-2018, 11:21 AM   #5
Db09ms3's Avatar
Groans: 65
Google it or search for the how to here. The job isn't hard but requires you to get yo' ass underneath the front end of the car. I didn't feel the slop in the sway bar as it only happened under load. I didn't replace my endlinks.
Stockish
 Old 05-03-2018, 11:24 AM   #6
Okay thanks! I’ll update once I figure out what the issue might be.
 Old 05-03-2018, 03:04 PM   #7
MSMS3's Avatar
Posts: 2,327   (View Stats)
Groans: 126
Do the end links at the same time you do the sway bar bushings. End links are easy. For the swaybar bushings, you will need to be under the car with your feet sticking out the front.
The parts are dirt cheap. Some work involved with the bushing sets, but not too bad. I recommend you get the bushing sets with zerk fittings and be sure to fill them full of grease after installing as they are going to be shipped dry. And grease the bar itself first.
These are good. JBR makes lots of good stuff for our cars.
JBR Tru-Torsion Stainless Sway Bar Brackets and Bushings [SB-BSH-BRKT] - $31.99 : James Barone Racing, Aftermarket Performance
 Old 05-03-2018, 03:48 PM   #8
Fstrnyou's Avatar
Posts: 2,149   (View Stats)
There's also a chance it could be a worn ball joint.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 05-03-2018, 03:56 PM   #9
Yeah, I’ve replaced the two lower a-arm ball joints. I’ll defiantly check out those bushings, but do any of you have any recommendations as far as the end links go? Should I go adjustable or what?
 Old 05-03-2018, 03:59 PM   #10
Fstrnyou's Avatar
Endlinks are ALL adjustable. They're used to set your toe-in/out.
Other rides:
History:
 Old 05-03-2018, 04:11 PM   #11
Db09ms3's Avatar
Groans: 65
I'd say go OEM Mazda. Then again I'm stock
Stockish
 Old 05-18-2018, 05:14 PM   #12
Kompleat's Avatar
Posts: 3   (View Stats)
Kompleat will become famous soon enough
I had BAD clunking as well. For me it was an end link. I just replaced both fronts with OEM. When I shook the sway bar by hand I could hear it clunk. With new end links I could not get it to make the sound by shaking the sway bar. No more clunks over bumps. It was driving me nuts.
Kompleat is offline   Reply With Quote
Gen 2 suspension on Gen 1 09Speed MazdaSpeed 3/6 - Suspension & Brakes 8 09-08-2015 01:57 PM
Ford issues six recalls covering 101,000 vehicles for multiple issues Haltech Automotive News 0 07-08-2014 01:50 PM
Venezuela issues its first-ever driver's license suspension Haltech Automotive News 0 05-22-2011 04:40 PM
Ford Windstar recalled again, this time for suspension issues Haltech Automotive News 0 01-27-2011 09:50 AM
Page generated in 0.31640 seconds with 25 queries
