Like Tree304Likes
 Old 08-25-2015, 06:04 PM   #401
Eth Fiend
phate's Avatar
Posts: 6,941   (View Stats)
245/40 Rivals. They're just under the wear bars now so I'll likely need another set to finish out the season. They did really well with the longer sessions. It was a 3.5 mile course and it took them just a few corners to come up to temp and have their typical grip. I never felt them drop off as if they got too hot.
@Nliiitend1; and I were discussing on Sunday how the car would behave at the higher speeds since most everything has been focused on autocross and most recently focused on shifting the roll bias to the rear. I was lucky that Sunday was an autocross day on asphalt, because I set hot temps there and didn't touch them again before Monday. The car felt great, really. I could feel it was still pushy in steady state cornering but was able to get the rear around if I tried. This was just another indicator that the car could use more rear stiffness.
There's more grip available in the rear with pressure and alignment changes, too. If the rear were to respond to LCA bushings as well as the front did, I would probably pick up a little bit of grip from them, also. Hopefully it's enough to offset the stiffer rear bar once it's moved into the stiffer settings. I would love to see the car pick up even more front grip from more rear roll bias.
-06 MS6
-Corn fed 07 MS3 - Sold
Code Monkey (08-25-2015), Deldran (08-25-2015), Easter Bunny (08-26-2015), Funkster777 (08-26-2015), Mauro_Penguin (08-26-2015), Nliiitend1 (08-25-2015), SpeedRebirth (08-26-2015)
 Old 08-26-2015, 04:21 AM   #402
dagrimey1's Avatar
Posts: 1,246   (View Stats)
dagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the world
Groaned at 7 Times in 6 Posts
Love that you continue to make the 6 a true race car. With that said I really got to come to Midwest.
Mobile Forum App Blows
dagrimey1 is offline   Reply With Quote
The Following User Says Thank You to dagrimey1 For This Useful Post:
phate (08-26-2015)
 Old 08-26-2015, 07:15 AM   #403
KevinK2's Avatar
Posts: 903   (View Stats)
.... Nliiitend1 and I were discussing on Sunday how the car would behave at the higher speeds since most everything has been focused on autocross and most recently focused on shifting the roll bias to the rear. I was lucky that Sunday was an autocross day on asphalt, because I set hot temps there and didn't touch them again before Monday. The car felt great, really. I could feel it was still pushy in steady state cornering but was able to get the rear around if I tried. This was just another indicator that the car could use more rear stiffness....
I think you were speaking of the road course showing more rear roll stiffness was need. From my experience when I was both winning my class in autox, and doing well with my old Triumph regularly on the road course, I always ran my fabricated 5 way adjustable rear sway bar in neutral position for the big track, and one step stiff for autox. Be careful when you let the big track suspension behavior influence the autox set-up.
From Delaware
The Following 2 Users Say Thank You to KevinK2 For This Useful Post:
Easter Bunny (08-26-2015), phate (08-26-2015)
 Old 08-26-2015, 08:01 AM   #404
Funkster777's Avatar
Posts: 1,254   (View Stats)
Funkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the world
I had to opportunity to do a ride along with @phate;
In short, it was amazing. His car handles dramatically different than mine. I was very impressed with what he could do with it and how it moves.
Thanks again for the ride.
Funkster777
2010 Black Cherry Metallic Mazda 6 DD (well as needed)
2006 Black Mica Mazdaspeed6 Sport
Originally fixed by IL NATOR. Rear Diff, TC, & PS cooler replaced due to MI NATOR. Rebuilding a MS6 one part at a time.
Performance: GTX3076r~Molnar rods~Wiseco pistons~Grimm EBCS~3-bar MAP~Autotech Internals~HTP 3.5" intake~GFB BPV~TR8 intercooler w/2.5" piping~Cobb AP v3~Freak Tune in progress (need to quit breaking things)~eBay catless DP~CS CBE~JBR RMM~ACT HD 6 puck sprung w/prolite~JBR SSP & weight~TWM Stage 2 SS w/BB & boot~Maisonvi Shift Knob~AE Tower Strut Bar~Rear Interior Brace~CP-e Rear Diff mount~Replacement Rear Diff & TC, MD PS cooler, CS Front & Rear Sway Bar~H&R Springs~Bilstein HD shocks~SS brake lines~FI Grounding Kit~EBC Yellows~Potenza RE970AS
Exterior: 6000k HIDs low beams~8000k HIDs fog lights~Luminics Ultra White Bulb high beams~HD lip~Speedline Emblemless Grill~Blacked out rear emblems~Smoked Rear & Side Markers with LEDs~15% back & windshield top tint~35% front~Sharkfin Antenna~Tower II LEDs for parking lights~CAR-LED tails
Interior: UV & purple LEDs~Blackvue DR400G-HD~Escort Redline up high w/mute~NeoPro Link iPod Connection~ProSport Premium Boost Gauge w/Vent Dual gauge pod
Waiting to Install/ Buy: SS clutch, oil pressure gauge, CP-e EWG setup/ Wheels (likely)?, Summer tires?, EVO Brembos?, Meth setup-5/6th port?
Funkster777 is offline   Reply With Quote
The Following User Says Thank You to Funkster777 For This Useful Post:
phate (08-26-2015)
 Old 08-26-2015, 08:10 AM   #405
KevinK2's Avatar
New sway bar testing ... I found some text results from when I modeled an Eibach sway bar for one of my cars, using a "simple beam theory" program. It reminded me that for a long slender bar like your new one, there is a contribution to lever-end deflection due to torsion bar slope at tube ends. If you transpose the applied point load to a force and a moment on the axis of the torsion rod section, the bending moment in question is based on the distance between the transposed force and the support bushing center (due to the dogleg in the lever arm). This puts the rod in "second mode" bending, with added deflection due to the slope at the ends:
A simple manual dial indicator at the "hump" in the torsion rod position would capture this effect:
http://i21.geccdn.net/site/images/n-.../TLS_53304.jpg
This effect was small in the more typical bar I had modeled, but your bar is much more prone to this, based on geometry.
From Delaware
The Following 5 Users Say Thank You to KevinK2 For This Useful Post:
Code Monkey (08-26-2015), Mauro_Penguin (08-27-2015), Nliiitend1 (08-26-2015), phate (08-26-2015), zenit (08-26-2015)
 Old 08-27-2015, 01:44 PM   #406
Eth Fiend
phate's Avatar
It's fun, man, and epic midwest is an absolute blast. Not as big as some of the other epic meets, but definitely a great down home feel that is really relaxed.
I think you've experienced what I've read about and from what Shaikh told me once on the phone. It was that 'big track' setups tend to need less rear stiffness, whereas autocross can handle more rear stiffness. I've never had experience with this, of course, but Shaikh said the over/understeer bias shifts towards oversteer as the speeds increase.
I've thought for a long time that the car needed more rear stiffness for autocross. I was happy to see that the car was still pushy at Autobahn - I interpreted this as being still far away from having enough rear stiffness to see that shift at higher speeds, based on what Shaikh and you have just said.
Right, it's just an overhanging load of equal and opposite forces at each end of the bar. I've been meaning to revise my theoretical spring rate calcs (not previously posted) for the bar and arms now that I have everything in hand. The shape of the arms was the big unknown, so I should be able to calculate everything now and see how closely it matches the bench rate.
-06 MS6
Code Monkey (08-27-2015), Funkster777 (08-28-2015), KevinK2 (08-27-2015), Mauro_Penguin (08-27-2015), Nliiitend1 (08-27-2015)
 Old 08-27-2015, 03:07 PM   #407
Code Monkey's Avatar
Posts: 7,671   (View Stats)
I can only confirm this with experience. Your rear setup is already so much stiffer relative to the front and my setup, that every time you post about going even stiffer, my first thought is always wtf, lol. My car is now very nicely balanced for dry conditions; in the wet, on Maxxis RC1's and with traction control on, the rear still slides all over the place.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
The Following 4 Users Say Thank You to Code Monkey For This Useful Post:
Funkster777 (08-28-2015), Mauro_Penguin (08-27-2015), Nliiitend1 (08-27-2015), phate (08-27-2015)
 Old 08-27-2015, 04:19 PM   #408
Eth Fiend
phate's Avatar
That could also be shock valving at play. Does it still over steer in steady state cornering?
-06 MS6
 Old 08-27-2015, 06:56 PM   #409
I would say no, but it is very easy for me to lose the rear the moment the track gets just a little bit of rain, or maybe I should try driving the car more like a FWD car.
2006 Mazdaspeed6
2017 Subaru BRZ
phate (08-27-2015)
 Old 08-27-2015, 07:05 PM   #410
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
Higher vehicle speeds definitely need less rear roll stiffness relative to the front than low vehicle speeds do for proper rotation/balance/good "steady state" behavior.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 2 Users Say Thank You to Nliiitend1 For This Useful Post:
Code Monkey (08-27-2015), Mauro_Penguin (08-27-2015)
 Old 08-27-2015, 07:18 PM   #411
aviator79's Avatar
Posts: 3,930   (View Stats)
Groans: 67
Im just going to ask it:
can I run just the rear setup u did? As in just the stiffer springs and perches and adapters on lca. Wish I didnt sell my BC COs for $200 as my rear is too soft on oem springs and koni struts.
phate (08-27-2015)
 Old 08-27-2015, 10:24 PM   #412
Eth Fiend
phate's Avatar
Yep, no reason you can't. The shocks have to be up to whatever you put in or ride quality will suffer. No adapter on LCA is needed with the QA1 or blue springs. Just the upper adjuster and spring.
I sort of do. The two big places I utilize the awd is the launch and corner exit. Otherwise it's very similar to fwd.
-06 MS6
Last edited by phate; 08-27-2015 at 10:24 PM. Reason: MSF Database - Automerged Doublepost
aviator79 (08-28-2015), Code Monkey (08-28-2015), ItsNox (09-11-2015), Mauro_Penguin (08-28-2015), Nliiitend1 (08-28-2015)
 Old 09-11-2015, 07:47 AM   #413
Eth Fiend
phate's Avatar
Lots going on recently. Last weekend we autocrossed and it was HOT! I left the SD card in my laptop the first day, so no video. The second day I did get some video. I still haven't gone through accelerometer data, and not sure that I will do much with it. It's an asphalt surface that we autocross on only twice per year.
My fastest with a cone. It would have landed me second in class, but the cone knocked me back to 4th. That's just how it goes some days.
Johanna's fastest:
Me spinning after pushing way too hard:
I got the rear bar bushings from @zenit; over the weekend, also. I put it all together on Wednesday and rate tested it similar to how I did the stock/whiteline bars:
The company who did the bar and arms stocks a few shapes of the arms, and these were the longest arm they carry. I expected them to be a little short after bending - they're ~2" short of what I need them to be, and they also aren't quite as wide as I'd hoped for. That just means that, for now, I can't get a good rate for the softest setting.
For the stiffest setting, I was expecting 188lb/in. The bar tested at 180lb/in. The "softest" setting at the shorter than expected arm length was 107lb/in. That's a little stiffer than I want it to be, starting out. I'm going to do a test fit on the car in just a few minutes. I have some ideas for extending the arms to achieve the softer rate. [With the outboard extension, all of the rates will be softened just slightly due to some bending in whatever assembly I make.]
xfeejayx, jbbuie, ItsNox and 3 others like this.
-06 MS6
The Following 12 Users Say Thank You to phate For This Useful Post:
aviator79 (09-11-2015), Code Monkey (09-11-2015), Funkster777 (09-11-2015), jbbuie (09-11-2015), Justin@Freektune (09-11-2015), Mauro_Penguin (09-23-2015), Mazdazilla6 (09-11-2015), mxlplx71 (09-11-2015), TiGraySpeed6 (09-11-2015), WetzMS3 (09-11-2015), xfeejayx (09-11-2015), zenit (09-11-2015)
 Old 09-11-2015, 08:04 AM   #414
Fuck those lampposts, you're gonna hit one some day.
2006 Mazdaspeed6
2017 Subaru BRZ
The Following 5 Users Say Thank You to Code Monkey For This Useful Post:
Crarrs (09-12-2015), Deldran (09-11-2015), ItsNox (09-11-2015), Mauro_Penguin (09-23-2015), phate (09-11-2015)
 Old 09-11-2015, 08:40 AM   #415
ItsNox's Avatar
Posts: 3,076   (View Stats)
ItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the world
I was thinking this the entire time!!!
'06 Mazdaspeed 6 GT
Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella
Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings
Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s
Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth
- Miltuned
On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.
Georgia Motherfucking Nator
Originally Posted by Ziggylittles View Post
I hate that you can sleep on suckas and then make rape with your family sedan
ItsNox is offline   Reply With Quote
The Following 3 Users Say Thank You to ItsNox For This Useful Post:
Code Monkey (09-11-2015), Mauro_Penguin (09-23-2015), phate (09-11-2015)
 Old 09-11-2015, 08:57 AM   #416
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Lol, it looks bad from the video. I have never seen anyone hit one of those. I have only seen 2 accidents. One where a wheel popped off. And one where guy got squirly at the end the run and clipped the curb.
Still safer than driving on the road with the hundreds of idiots driving around you.
Sent from my SM-N910V using Tapatalk
Damond Built Speed 6
Deldran is offline   Reply With Quote
The Following 3 Users Say Thank You to Deldran For This Useful Post:
 Old 09-11-2015, 09:57 AM   #417
KevinK2's Avatar
Clint, that run with one cone was impressive ... you were coming so close to several cones. And there is one big left turn about 30 sec into the run where you have a lot of discretion on what line you will use, any comment on your approach there? Was the run in 2nd gear? What rpm were you maxing at ? Rear Bar looks real good!
From Delaware
phate (09-11-2015)
 Old 09-11-2015, 12:10 PM   #418
Eth Fiend
phate's Avatar
Well that didn't take long With pulling the exhaust off, lunch, taking pictures and being really careful double checking everything, it only took about 3 hours. If the exhaust wasn't in the way and I was just throwing it on, I bet it's <1 hour of work.
I stuck these guys up there to make sure the side pieces sit flush with the toe boxes and that the lower brackets were on the correct side.
That all looked good, so I pulled the lower brackets off and lubed up the bushings and the bar. Stuck the lower brackets onto the bar, then set the bar in place. I put the arms on and re-centered the bar, tightened down everything...
Driver side is at normal ride height, here:
Passenger side suspension is at full droop in this pic:
Plenty of clearance with the lower shock bolt:
And with the diff:
Everything turns smoothly, no binding at all. The holes must be aligned pretty closely!
You can sort of tell in this picture how the arms don't extend backward quite far enough.
And in this pic, you can get an idea of how far out the arms need extended:
I think this is going to be easily remedied, and with a better-than-originally thought idea of how to keep the end links vertical at all positions.
The other big question has been the exhaust. I'm going to end up dumping it right before the axle so I can lose weight, but I'm pretty convinced an exhaust shop could loop a section of the exhaust upward in this space:
Seems there's plenty of room, even for a 3" pipe to go through. I may try this first, just to know for sure it could be done.
xfeejayx and ItsNox like this.
-06 MS6
The Following 9 Users Say Thank You to phate For This Useful Post:
Code Monkey (09-11-2015), Crarrs (09-12-2015), Funkster777 (09-14-2015), KevinK2 (09-11-2015), Mauro_Penguin (09-23-2015), mxlplx71 (09-11-2015), Nliiitend1 (09-11-2015), TiGraySpeed6 (09-11-2015), xfeejayx (09-11-2015)
 Old 09-11-2015, 01:32 PM   #419
MSP611's Avatar
Posts: 2,291   (View Stats)
this sway bar and brackets look bad ass!! keep up tht work phate... maybe sell me one too lol... u know wat i would roughly cost for a mocked up 304 stainless short exhaust like ur thinkin?
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
phate (09-11-2015)
 Old 09-11-2015, 07:23 PM   #420
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
Get in line ;-)
-Wetz
QFT
The Following 3 Users Say Thank You to xfeejayx For This Useful Post:
Mauro_Penguin (09-23-2015), phate (09-11-2015), zenit (09-11-2015)
 Old 09-13-2015, 07:47 AM   #421
Eth Fiend
phate's Avatar
It's tough to tell in the video, but there are 4 surface finishes over the entire course. In that second lot after the Chicago box, there's a strip of unsealed pavement that the whole car is on, then it narrows to only a strip at the right at the start of the braking zone that had decent grip, then ending at some pavement where grip majorly fell off. I tried to keep the car's right side tires on the higher grip surface while still turning, then tip toeing through that low grip braking zone to get the car slowed enough to make the next left hander. After that it was an attempt to cut off as much distance as possible, which I wasn't very successful at that.
After the start, we short shifted into 2nd and left it there. In the straight between the first and second lot, I data logged 6400-6500 rpm (I think that's ~55mph). The short straight coming into the finish saw as high as 7300 rpm.
-06 MS6
Funkster777 (09-14-2015), KevinK2 (09-13-2015), Mauro_Penguin (09-23-2015), Nliiitend1 (09-14-2015)
 Old 09-17-2015, 08:19 AM   #422
Eth Fiend
phate's Avatar
I have exhaust work scheduled for next Wednesday. I'm going with a loop above the bar, for now. The big reason is not wanting to change the weight of the car too much, and also just to see if it can be done. I'll ask them about the dumped exhaust while it's in the air.
I have everything on the way for arm extensions and end links. I'll probably machine everything on Monday, retest the bar on Wednesday, then install Friday. That's an autocross weekend, so hopefully everything works out and we'll have this bar on for it. Not sure when I'll pull the whiteline bar...
-06 MS6
ItsNox (09-17-2015), Mauro_Penguin (09-24-2015), xfeejayx (09-17-2015), zenit (09-17-2015)
 Old 09-24-2015, 01:21 PM   #423
Eth Fiend
phate's Avatar
I think everything is ready to go for install, tomorrow. I had a small bend put in the exhaust so the bar would be clear of obstruction. I'll get pics when I'm putting the bar on. @MSP611;, I forgot to ask about a dumped exhaust when it was on the rack. I got distracted trying to explain the situation to the exhaust guy.
Anywho, I made some extension that look something like this:
3 positions for the end link to attach...
Then I made some turnbuckles for the rod ends. These will be my end links:
Did some measuring to make sure I was going to cut the arms to give the same positions relative to the bar:
And I cut some slots into the arms so I can fine tune the lever arm length:
Stuck it all together:
^That end link is attached to the wrong side, lol. They'll be attached to the outboard side of the arms.
The holes are separated by the same distance as the length of the slot. Each hole will overlap with another holes position so it can be adjusted to any length in a 7" range. For now, I can't fully utilize it because the upper attachment points for the end links are in two very narrow ranges. I'm planning to make a rail or something up top so I can slide both ends to keep the end link vertical at all positions.
I rate tested the bar with the new additions.
Softest: 72 lb/in
Stiffest: 190 lb/in
I tested at 4 positions. Graphed together, the stiffness vs lever arm length looks like this:
-06 MS6
Code Monkey (09-24-2015), Funkster777 (09-29-2015), KevinK2 (09-24-2015), Mauro_Penguin (09-24-2015), Nliiitend1 (09-29-2015), xfeejayx (09-25-2015)
 Old 09-24-2015, 01:56 PM   #424
KevinK2's Avatar
Nice work again. With the MR's included, how does your bar rate compare to the Whiteline in the poly bushings? Wheel rate or otherwise.
From Delaware
phate (09-24-2015)
 Old 09-24-2015, 06:06 PM   #425
Eth Fiend
phate's Avatar
Wheel Rates:
WL Soft Setting: 43 lb/in
WL Stiff Setting: 52 lb/in
New Bar Soft: 72 lb/in
New Bar Stiff: 190 lb/in
If I leave the springs the same (850/800), the soft setting shifts the F/R roll bias by 2.4% rearward, and the stiff setting shifts it by 13.6% rearward.
My plan is to go back to a 700 lb/in rear spring. In that case, the soft setting shifts bias by .5% rearward, and the stiff setting by 12.3% rearward.
The soft setting is pretty darn close to what I wanted. I was expecting 73 lb/in for the softest setting.
-06 MS6
KevinK2 (09-24-2015), Mauro_Penguin (09-29-2015), Nliiitend1 (09-29-2015)
 Old 09-24-2015, 09:38 PM   #426
MSP611's Avatar
wow this is cool... now start sellin em!!! i need to figure out my dumped exhaust sitch but its hard not bein home
In progress:
The Following 2 Users Say Thank You to MSP611 For This Useful Post:
Funkster777 (09-29-2015), phate (09-24-2015)
 Old 09-25-2015, 05:17 PM   #427
Eth Fiend
phate's Avatar
Bar is on
Most of the above pics are at full droop; the last couple are at or near ride height. The clearance between the tire and end link is tight, only ~1/8". At normal ride height, it's ~1/2" (plenty!).
I swapped to the 700 lb/in springs while I had everything apart to remove the Whiteline bar. We're driving up right now for an autocross tomorrow and Sunday.
Funkster777, jbbuie and ItsNox like this.
-06 MS6
The Following 11 Users Say Thank You to phate For This Useful Post:
Code Monkey (09-25-2015), Crarrs (09-28-2015), Funkster777 (09-29-2015), KevinK2 (09-25-2015), Mauro_Penguin (09-29-2015), Mazdazilla6 (09-28-2015), nindoja (09-25-2015), Nliiitend1 (09-29-2015), TiGraySpeed6 (09-26-2015), xfeejayx (09-27-2015), zenit (09-25-2015)
 Old 09-25-2015, 05:48 PM   #428
Definitely only a street/autox use, I would bang the shit out of it at the track.
2006 Mazdaspeed6
2017 Subaru BRZ
phate (09-25-2015)
 Old 09-25-2015, 06:56 PM   #429
Eth Fiend
phate's Avatar
On what?
I'll take a picture of this tomorrow, but... If you look at everything in side view, the low part of the arm is within the area of the wheel and tire. Since the arms move with the wheel, any bumps you encounter at the wheel also raise the arms. It would have to be something the tires straddle to make contact with the arms.
Edit: or it would take dropping a wheel off of the road surface where the bar arm will contact the edge. Not good if that happens, anyway.
-06 MS6
Code Monkey (09-25-2015), Funkster777 (09-29-2015), Mauro_Penguin (09-29-2015), zenit (09-25-2015)
 Old 09-25-2015, 07:36 PM   #430
Yeah, spinning out and going over the curbing would do it, the LCA has this metal stripe that goes around the bottom, I already bent it in on one side.
2006 Mazdaspeed6
2017 Subaru BRZ
phate (09-25-2015)
 Old 09-25-2015, 07:58 PM   #431
Eth Fiend
phate's Avatar
It's probably best if you don't do that
-06 MS6
Code Monkey (09-25-2015), Mauro_Penguin (09-29-2015)
 Old 09-25-2015, 07:59 PM   #432
I have special, hmmm, "talents".....
2006 Mazdaspeed6
2017 Subaru BRZ
ItsNox (09-27-2015), Mauro_Penguin (09-29-2015), phate (09-25-2015)
 Old 09-27-2015, 07:59 AM   #433
Eth Fiend
phate's Avatar
So...we found that the car can't be driven the same way, or the back end likes to go around the front. Transitionally, the car is sharper and it turns in better/faster. It turns in with a purpose, now. Steady state is nearly the same, there was a long sweeper and the car still pushed in that section. If we lifted off the throttle too much while the car was transitioning weight the back end would get loose very quickly, which is how the spins started. Before, we were having to lift very suddenly to get any rotation out of the car.
Tires were an issue. We ended up flat spotting and cording a tire in one spin. They were pretty much dead, anyway, and overall grip was down. We ended up mid pack in the class despite everything.
Subjectively, the car is more fun like this. I always compare to the speed 3 in this category and the 6 has always had a more serious and settled demeanor on course. The 6 feels light and agile with it.
It's a new day. We were offered a set of wheels with Dunlop Z2's on them. Going to leave the bar at the softest setting to see if tires were the main culprit. Videos and whatnot later.
Mauro_Penguin, jbbuie and ItsNox like this.
-06 MS6
The Following 8 Users Say Thank You to phate For This Useful Post:
Code Monkey (09-27-2015), Funkster777 (09-29-2015), KevinK2 (09-27-2015), Mauro_Penguin (09-29-2015), Mazdazilla6 (09-28-2015), Nliiitend1 (09-29-2015), TiGraySpeed6 (09-27-2015), xfeejayx (09-27-2015)
 Old 09-27-2015, 08:21 AM   #434
MSP611's Avatar
good info now u have too much rotation lol
In progress:
 Old 09-27-2015, 10:30 AM   #435
Eth Fiend
phate's Avatar
Nah, just gotta get used to it and drive or more effectively. Fresh tires helped immensely. Just got done with our heat and everything was much better.
xfeejayx likes this.
-06 MS6
Mauro_Penguin (09-29-2015), MSP611 (09-27-2015), xfeejayx (09-27-2015)
 Old 09-27-2015, 11:16 AM   #436
MSP611's Avatar
well thts good to know i would like to know how a 6 setup like this drives... i might be a lil bit of a copy cat here soon when i come home...
In progress:
 Old 09-27-2015, 11:53 AM   #437
KevinK2's Avatar
09-24-2015 04:21 PM
... I rate tested the bar with the new additions.
Softest: 72 lb/in
Stiffest: 190 lb/in
09-24-2015 09:06 PM
Phate:
Wheel Rates:
Thanks for the update from the track!
I know you are busy now, but when you can please clarify the new bar rates ... is 72/190 at the wheels?
Thanks
From Delaware
phate (10-26-2015)
 Old 09-28-2015, 07:42 AM   #438
Eth Fiend
phate's Avatar
Thanks
That's single wheel bump at the wheels. Since it's a 1.0 MR, there is no reduction in bench rate except for the loss through the angle of the end links.
-06 MS6
KevinK2 (09-28-2015), Mauro_Penguin (09-29-2015)
 Old 09-28-2015, 08:22 AM   #439
Eth Fiend
phate's Avatar
Here's a couple videos from the weekend I edited quickly. The second video is probably a new favorite of mine...Johanna said not to put the camera there...
Funkster777 and jbbuie like this.
-06 MS6
cocoanton (09-28-2015), Code Monkey (09-28-2015), Crarrs (09-28-2015), Funkster777 (09-29-2015), Mauro_Penguin (09-29-2015), SpeedRebirth (09-28-2015), TiGraySpeed6 (09-28-2015), xfeejayx (09-28-2015)
 Old 09-28-2015, 09:00 AM   #440
KevinK2's Avatar
First, congratulations on some great engineering work, similar to a Tri-Point Engineering product. Very timely since WL's adjustable 24mm bar (23mm oem) is out of production, as is Cork Sports' 25mm, leaving only the $365 24mm non-adjustable Autoxe bar.
I finally plugged in your input numbers for your program, from post # 203, into my old Puhn based calculator, with the Whiteline bar at stiff for starts:
3469 lbs Total Wt
850F/800R springs
24mm OEM front bar
WL rear bar , stiff @ 485 lb/in
MR rear spring = .573
Front Total WT Bias = 58.6%
Front Total WT Transfer Bias = 60.8%
Steady State => Slight Understeer
Front Sprung Wt Bias = 59.4%
16280 Fr Roll Rate, in-lbs/in @ Wheel
7984 Rr Roll Rate, in-lbs/in @ Wheel
Rear end link @ 1G = ~240 lbs
How does this compare? I used your sprung wt central CG location and lever arm to the roll axis, as those were inputs to my program for comparing other variables (to be corrected). I could run your current set-up, if that is more convenient.
From Delaware
Mauro_Penguin (09-29-2015), phate (09-28-2015)
Shocks for a daily driven Mazdaspeed 6 This thread Refback 12-05-2015 09:07 PM
Whats New/General Speed 6 Discussion - Page 296 This thread Refback 11-29-2015 05:42 PM
fe1rx Ohlins Installation - Page 7 This thread Refback 08-23-2015 04:39 AM
fe1rx Ohlins Installation - Page 6 This thread Refback 04-25-2015 01:24 PM
Prepping as dedicated track car - Page 56 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-21-2015 12:36 PM
BC coilovers VS. H&R coilovers - Page 15 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 08-26-2014 07:50 AM
Whats New/General Speed 6 Discussion - Page 297 This thread Refback 07-28-2014 08:03 PM
racing aspirations » Suspension Geometry Calculator This thread Refback 06-21-2014 02:57 AM
Prepping as dedicated track car - Page 50 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #48 Pingback 03-14-2014 12:36 PM
Prepping as dedicated track car - Page 46 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-20-2014 11:02 AM
Suspension/combo or coilovers?? gurusev 2010 MS3 - Suspension & Brakes 35 07-31-2013 10:06 AM
BC Coilovers or Bilstein Dampers/H&R Springs Bleupit80 MazdaSpeed 3/6 - Suspension & Brakes 6 02-12-2013 06:35 AM
BC BR Extreme Low Coilovers vs KSport Kontrol Pro Coilovers Doberman MazdaSpeed 3/6 - Suspension & Brakes 9 07-28-2012 07:35 AM
Suspension Techniques Coilovers? asiandude74 MazdaSpeed 3/6 - Suspension & Brakes 6 02-05-2011 11:15 PM
MSD Dashhawk Data Logger Data Base JimmyMac MazdaSpeed 3/6 - ECU Computer Tuning 2 06-30-2008 09:43 AM
Page generated in 0.69770 seconds with 31 queries
