Like Tree307Likes
 Old 10-27-2015, 09:41 AM   #521
Eth Fiend
phate's Avatar
Posts: 6,943   (View Stats)
Originally Posted by Tomas View Post
Hey when you are ready to order the front poly bushings from the commies let me know. If you could order everything double (including the rear LCA bushings) I can paypal you the money for the bushings and we can split the shipping costs 50/50 + add the shipping costs to send me the bushings from yours to my place after you get them.
Yep. I just emailed them asking for an updated list of available bushings. I was just looking around on their site and it looks like they've added a few with stiffer poly. I was hoping they did.
-06 MS6
-Corn fed 07 MS3 - Sold
Mauro_Penguin (11-01-2015), MS3johanna (10-27-2015), Tomas (10-27-2015)
 Old 11-02-2015, 10:27 AM   #522
Eth Fiend
phate's Avatar
Forever rate testing...
Nliiitend1 and Crarrs like this.
-06 MS6
Code Monkey (11-02-2015), Mauro_Penguin (11-03-2015), Tomas (11-02-2015)
 Old 11-02-2015, 10:46 AM   #523
ItsNox's Avatar
Posts: 3,076   (View Stats)
ItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the world
WTF is happening in that picture? Educate a noob
'06 Mazdaspeed 6 GT
Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella
Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings
Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s
Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth
- Miltuned
On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.
Georgia Motherfucking Nator
Originally Posted by Ziggylittles View Post
I hate that you can sleep on suckas and then make rape with your family sedan
ItsNox is offline   Reply With Quote
The Following 2 Users Say Thank You to ItsNox For This Useful Post:
BLKSTIG (11-04-2015), phate (11-02-2015)
 Old 11-02-2015, 11:02 AM   #524
Eth Fiend
phate's Avatar
Lol, I'm testing the spring rate of the tire. One of my corner scales is up top to measure the applied force. The vise grip snake thing with dial indicator is attached to the bottom plate of the scale which is directly on top of the tire. It's measuring the deflection from that plate to the "ground" surface the tire is resting on. Record force and deflection at different points and you can calculate spring rate (which is just force per deflection).
The calculated rate is half of actual rate since you deflect both the top and bottom of the tire, rather than just one like when it's on the car rolling. [Two springs of the same rate in series yield a spring half of their individual rate.]
Rinse and repeat for different pressures. I started at 50 psi, then went to 25 psi in 5 psi increments.
It's important because the tire acts like a second spring in series with the primary coil spring.
I'll post results in a while after I get back and throw them in excel.
-06 MS6
The Following 11 Users Say Thank You to phate For This Useful Post:
BLKSTIG (11-04-2015), cocoanton (11-02-2015), Code Monkey (11-02-2015), davychronic (11-02-2015), Funkster777 (11-02-2015), ItsNox (11-02-2015), Justin@Freektune (11-03-2015), Mauro_Penguin (11-03-2015), Mazdazilla6 (11-15-2015), silvapain (11-02-2015), wolly6973 (11-03-2015)
 Old 11-02-2015, 11:03 AM   #525
Crarrs's Avatar
Posts: 1,662   (View Stats)
Groans: 98
Load cell and dial indicator to determine the spring rate of his tires. A tire works like a spring the same way the actual springs in your suspension do; they just move less.
2004 MSM TiGrey
The Following 5 Users Say Thank You to Crarrs For This Useful Post:
cocoanton (11-02-2015), ItsNox (11-02-2015), Mauro_Penguin (11-03-2015), phate (11-02-2015), silvapain (11-02-2015)
 Old 11-02-2015, 11:27 AM   #526
ItsNox's Avatar
Knowledge boner achieved. Thanks gents
Sent from my SM-N910T using Tapatalk
'06 Mazdaspeed 6 GT
- Miltuned
 Old 11-02-2015, 11:34 AM   #527
Crarrs's Avatar
Groans: 98
The calculated rate is half of actual rate since you deflect both sides of the tire, rather than just one like when it's on the car rolling. [Two springs of the same rate in series yield a spring half of their individual rate.]
Rather than springs in series, wouldn't this actually be more analagous to springs in parallel with some ratio proportional to the camber/roll angle of the tire? Thinking like a balance bar on a brake balance adjuster.
2004 MSM TiGrey
The Following User Says Thank You to Crarrs For This Useful Post:
phate (11-02-2015)
 Old 11-02-2015, 12:00 PM   #528
Eth Fiend
phate's Avatar
Sort of, but I think we're talking about two different things. I'll draw a diagram in a few, I think I know what you're getting at
-06 MS6
Crarrs (11-02-2015)
 Old 11-02-2015, 12:31 PM   #529
Crarrs's Avatar
Groans: 98
Yeah, I'm thinking of each sidewall acting as an individual spring, with the load path passing through only the rubber. But I think I've just talked myself into realizing that things don't quite work out that way, since some portion of the force passes through the air "spring". Breaking down the relative spring rate contributions into air versus rubber is probably something best left to the tire companies, as they have detailed mechanical/kinematic models of what they're building.
EDIT: And I just re-read your original post, and realized which frame of reference you're speaking within. The vertical displacement needs to be cut in half because you're compressing the sidewalls at both the top and bottom of the tire. I was just jumping ahead to the next analytic step of how it applies to what the tire is doing dynamically when it's on the car. And....nope....I'm definitely not volunteering to help you write that script for your handling/setup spreadsheet.
2004 MSM TiGrey
The Following 4 Users Say Thank You to Crarrs For This Useful Post:
Mauro_Penguin (11-03-2015), Nliiitend1 (11-02-2015), phate (11-02-2015), silvapain (11-02-2015)
 Old 11-02-2015, 03:35 PM   #530
Eth Fiend
phate's Avatar
Yep, exactly right. I was only trying to isolate one side of the tire since that's all that touches the ground.
A diagram for us all to be on the same page:
I think this is what you were getting at (with an addition of horizontal springs):
Where k_v1 and k_v2 are dependent upon tire pressure...but you'll end up with some overall different spring rate as the tire gains or loses camber - which is where the horizontal springs come into play because they will add some stiffness in that vertical direction. I haven't studied tire models enough to know exactly how to model this system. I know there is also some damping in both the vertical and horizontal directions, not shown here. I am working on a side project to measure the non-rotational vertical damping of a tire that I might play with on one of these tires. I'm hoping to find that it's such a small affect that I can continue to ignore it (haha).
__________________________________________________ _______________
Onto the tire testing:
[Hankook RS3 V2 255/40/17 on a 9.5" wide wheel. Might make it easier to find for someone seaching.]
I did 6 tests starting at 50psi, working down to 25psi in ~5psi increments. I only have a 1" dial indicator, so that really limited the testing deflection. The tire pressure gauge I was using wasn't the greatest. I left my nice one at an autocross a while back and haven't gotten it back. These graphs are for the actual rate of the tire as it would be on the car, on the ground.
This first graph shows all of the data points, starting with a zero'd initial reading:
^You can see a high initial deflection that I thought would throw off averages, so I made another chart without that point.
Those lines looked pretty darn linear, so I added some trendlines. The slope of the trendline is the spring rate of the tire at that pressure.
I compared a numerical average of rate (force per unit deflection) to the slope of each tire's trendline:
Fun stuff. The RS3's aren't terribly important for me to do this with, I just wanted to do it for experience. The test rig could probably be set up for more consistent readings. I will definitely use a dial indicator with more travel for the Hoosiers, and repeat some tests for testing consistency.
-06 MS6
Code Monkey (11-02-2015), Crarrs (11-02-2015), Funkster777 (11-02-2015), Mauro_Penguin (11-03-2015), silvapain (11-02-2015), Tomas (11-04-2015)
 Old 11-02-2015, 03:50 PM   #531
KevinK2's Avatar
Posts: 906   (View Stats)
I think the "both sides" of the tire explanation was a confusion point. "Top and bottom" may have been a better description.
I don't think the air pressure changes that much dynamically. I recall setting the pressure, with tire on ground, then reading same pressure when loaded by car.
The sidewall rate does vary with set pressure, as Phate's plots show. But the sidewall structure also has a spring rate, low for all season, high for comp tires. I had a set that looked ok at 10 psi, on the car.
The tread is also an "elastic foundation" type spring, significant with passenger tires. When going from a tire set worn bald, to a new set of all seasons, you notice the smoother ride.
From Delaware
The Following 6 Users Say Thank You to KevinK2 For This Useful Post:
cocoanton (11-03-2015), Code Monkey (11-02-2015), Funkster777 (11-03-2015), ItsNox (11-04-2015), Mauro_Penguin (11-03-2015), phate (11-03-2015)
 Old 11-03-2015, 10:44 AM   #532
CorkSport Vincent's Avatar
Posts: 163   (View Stats)
CorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the worldCorkSport Vincent is the leader of the world
Nice work sir, You are most certainly that 1% of customer that really goes all in to there projects and try's to find every 10th of a second he can. You need to get on a race team somewhere with this kind of follow trough.
I was given the option to edit this. Not sure if it worked or not.
CorkSport Vincent is offline   Reply With Quote
The Following 8 Users Say Thank You to CorkSport Vincent For This Useful Post:
Code Monkey (11-03-2015), Funkster777 (11-03-2015), ItsNox (11-04-2015), Justin@Freektune (11-03-2015), Mauro_Penguin (11-03-2015), Nliiitend1 (11-03-2015), phate (11-03-2015), zenit (11-03-2015)
 Old 11-03-2015, 03:04 PM   #533
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Groaned at 7 Times in 6 Posts
I'll be pit crew for said race team.
The Following 4 Users Say Thank You to zenit For This Useful Post:
Deldran (11-03-2015), Mauro_Penguin (11-03-2015), Nliiitend1 (11-04-2015), phate (11-03-2015)
 Old 11-03-2015, 04:36 PM   #534
KevinK2's Avatar
I agree with Corksport's comments. Phate is writing the book about modifying the suspension on this car.
Once you know the spring rate of the tires, you can fine tune the sprung weight's roll resistance at the front and rear suspensions. Looking at Phate front, with 800 lb/in springs and the oem 23mm front bar, I figured the wheel rate components up front: [ Note, actual OEM front bar is 24mm for MS6, and 23 for the M6. ]
425 lb/in springs
225 lb/in for the bar in a corner
640 total lb/in at the front wheel, while cornering (Phate can correct this)
Now the tire rate is added in series to the prior rate based on just steel stuff. Looking at his most excellent spring rate graph, for 30 psi, a tire rate is about 1350 lb/in. This softens the prior 640 wheel rate to 434 lb/in, or 68% of that value. Likewise at 35 psi and about 1600 lb/in at the tire, the rate drops to 457 lb/in, 71% of that "strictly steel" value.
The net effect is a bit softer suspension, and the tire contribution is a bit variable, as noted depending on camber condition, and how many g's are being held in the corner.
From Delaware
cocoanton (11-03-2015), Funkster777 (11-04-2015), ItsNox (11-04-2015), Mauro_Penguin (11-03-2015), Nliiitend1 (11-04-2015), phate (11-03-2015)
 Old 11-04-2015, 12:55 PM   #535
Eth Fiend
phate's Avatar
425 lb/in springs
That's exactly the idea. I need to incorporate this into my spreadsheet, now.
The numbers I come up with for my current setup, where I typically run ~35psi with the rears being slightly higher:
Front
850lb/in spring @ .73 MR -- 453lb/in WR
205lb/in bar @ .73 MR -- 109lb/in, but doubled in roll, so 218lb/in WR
so 671lb/in wheel rate
1590lb/in tire (typically around 35psi).
Combined rate of 472lb/in.
Rear
700lb/in @ .57 MR -- 227lb/in WR
72lb/in @ 1.0 MR -- 72lb/in, but doubled in roll, so 144lb/in WR
so 371lb/in wheel rate
Combined rate of 301lb/in.
Those are interesting if you go a little further with an assumption that the front and rear track widths are equal. I showed a page or so back that playing with track width up to 1" on one end of the car isn't a huge influence on roll bias, so the .2" difference we're ignoring is mostly negligible. Once you make that assumption, you can directly use the wheel rates to calculate roll bias.
Without Tire Spring Rate
Front WR + Rear WR = 671 + 371 = 1042lb/in
Front Roll Bias = 671/1042 = 64.4%
With Tire Spring Rate
Front WR + Rear WR = 472 + 301 = 773lb/in
Front Roll Bias = 472/773 = 61.1%
Comparing to my 58.1% front weight bias, it shows the car might be much closer to neutral than I thought, when I wasn't including tire spring rate.
jbbuie likes this.
-06 MS6
Funkster777 (11-04-2015), Mauro_Penguin (11-05-2015), Nliiitend1 (11-04-2015)
 Old 11-04-2015, 01:50 PM   #536
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
Front
Rear
Honestly, that jives much better with gut feel. I've never thought this car was a 'big heavy pig' that plows into corners. Also never had a performance car before, so who knows how my butt is calibrated.
Numbers make sense of how 5 psi extra in the rear can make a good difference, and that's ignoring what it does for heat/grip.
The Following 2 Users Say Thank You to xfeejayx For This Useful Post:
Funkster777 (11-06-2015), phate (11-04-2015)
 Old 11-04-2015, 02:12 PM   #537
KevinK2's Avatar
... Those are interesting if you go a little further with an assumption that the front and rear track widths are equal. I showed a page or so back that playing with track width up to 1" on one end of the car isn't a huge influence on roll bias, so the .2" difference we're ignoring is mostly negligible. Once you make that assumption, you can directly use the wheel rates to calculate roll bias.
I'm glad our numbers were close, so my spreadsheet in not too far off, but still needs a tweek.
When I saw you had front and rear tracks as independent variables, I figured I needed to add that to my SS, but when you test the % change in the variable for 1" difference, that's about 1/60.6 or just 1.6% ... not worth worying about on this platform.
From Delaware
The Following 2 Users Say Thank You to KevinK2 For This Useful Post:
Mauro_Penguin (11-05-2015), phate (11-04-2015)
 Old 11-06-2015, 05:01 PM   #538
KevinK2's Avatar
... I went ahead and picked up and installed some poly bushings for the stock front sway bar. Energy Suspension part # 9.5109G. I want to see if this balances out the turn in and lift off oversteer we experienced during the last autocross....
Did you get a chance to test this change on the road?
I had the same issue with my street M6s when I upgraded the rear bar from 18mm to a Steeda 22.5mm with poly rear bushings, and rubber oem fronts ... slowed turn in. I went the "soft " correction by finding Audi RS4 rubber bushings for the rear bar, but they were as hard as poly's! Related chart: elastomer-poly-plastic hardness-scale
From Delaware
MS3johanna (11-10-2015), phate (11-06-2015)
 Old 11-06-2015, 05:29 PM   #539
Eth Fiend
phate's Avatar
Not yet. I've had the front bar unhooked intending to replace the rod ends when I got them in. They're in, and should go on the car tomorrow. I put the rear bar back on tonight. There's an autocross Sunday that we want to go to, otherwise it will be next weekend.
-06 MS6
 Old 11-09-2015, 07:20 AM   #540
Eth Fiend
phate's Avatar
We autocrossed yesterday with this setup. The poly bushings up front helped the turn in oversteer quite a bit.
We had the RS3's on for the first time. They did pretty well. I went as low as 28psi and they never had any sign of rolling over. In hindsight, that was probably too low for max grip and it likely ended up hurting times more than anything.
We were on an asphalt lot and we did two full sessions of 8 runs each (both Johanna and I). It started out cold, around 40° for my first session and I thought the car was dialed in pretty well within a couple runs. The car was totally predictable, was rotating very easily when I wanted it to, and could be controlled and brought back into grip with a little bit of throttle.
Johanna drove the 2nd and 3rd sessions and thought the car was too loose, but ended up beating my time by .040 seconds. I drove the last session where I also thought the car was too loose...so I dropped rear pressures and spun the car...dropped more and didn't go faster...So I was likely on the back end of the grip curve where dropping pressure resulted in less grip. I was too dense to realize it at the time so I ended up just being pissed off for most of my second session.
Lesson learned.
If I have time, I'll throw the Steeda bar on for next weekend.
I also got some MS3 adjustable uppers for the rear suspension from @zenit; that I'm going to test on the 6. The 3 and 6 run different uppers in stock form, but the SPC pieces look like they'll fit ok on the 6. I doubt they go on before next weekend, so it'll be a winter project. I'm hoping that with an adjustable upper there won't be as much cross talk between camber and toe like there is when adjusting the LCA eccentric bolt. That would let me dial in camber very easily for different surfaces. The asphalt likely needed less negative camber and we could have picked up a little rear grip to play with bar settings a little more.
zenit likes this.
-06 MS6
Funkster777 (11-09-2015), KevinK2 (11-09-2015), Mauro_Penguin (11-09-2015), MS3johanna (11-10-2015), Nliiitend1 (11-09-2015), xfeejayx (11-09-2015), zenit (11-09-2015)
 Old 11-09-2015, 09:34 AM   #541
KevinK2's Avatar
.... If I have time, I'll throw the Steeda bar on for next weekend.
With that very versatile rear bar you designed, with the option of buying a stiffer splined bar component, I think you should have options for increasing the front bar size, like the Steeda 26mm.
But, time rolls on, and the demand for front bars has decreased. Steeda used to offer a 28.5mm front bar, but dropped it. It can still be purchased from Racing Beat:
28.5mm front bar
but it's on back order and you must order it.
The point is with all you have done to make this car what it is, I think it's worth the investment in these two bars before they are no longer produced. The reduced price for the Steeda 26 is consistent with clearing inventory. I know the big 28.5 front bar may case too much reduction in the independence of the front corner suspensions, and would likely require a bigger rear bar component, but I figure you could always sell it if you don't use it. But I'd check videos of SCCA solo 1 winners with ~similar sized cars, to compare roll.
Just my $.02 . I have a Progress 24mm rear bar still in the box for my M6, in case when I put softer bushings on the Steeda 22.5 in the rear, the drop in overall stiffness (that you measured on a MS6 front bar) is too much. I bought it because it is likely discontinued, as it is no longer listed on the Progress web site.
From Delaware
Last edited by KevinK2; 11-09-2015 at 11:26 AM. Reason: added M6 Progress rear bar is discontinued
phate (11-09-2015)
 Old 11-10-2015, 04:11 PM   #542
MS3johanna's Avatar
Posts: 689   (View Stats)
MS3johanna is the leader of the worldMS3johanna is the leader of the worldMS3johanna is the leader of the worldMS3johanna is the leader of the worldMS3johanna is the leader of the worldMS3johanna is the leader of the worldMS3johanna is the leader of the worldMS3johanna is the leader of the worldMS3johanna is the leader of the worldMS3johanna is the leader of the worldMS3johanna is the leader of the world
The car was a bit loose, thankfully not in the snap oversteer way, but, loose nonetheless. I admit that a lot of that was just needing to adjust my driving to the different surface. Asphalt is much slicker than concrete, and I was having a hard time figuring out how to use that in the first heat. I did much better in the second heat, when I was more conscious of this change. Then, I could really use the throttle to get around corners. It handled incredibly! Super predictable and rewarding in the use of smooth inputs. The set up got copious compliments from an Evolution driving school instructor, as well as another top competitor that I snagged for a ride-alongs!
Still, I think I've made the biggest improvement to the car out of all...
:p
MS3johanna is offline   Reply With Quote
The Following 10 Users Say Thank You to MS3johanna For This Useful Post:
Code Monkey (11-10-2015), Funkster777 (11-11-2015), KevinK2 (11-10-2015), Mauro_Penguin (11-11-2015), naoandlater (11-11-2015), Nliiitend1 (11-11-2015), phate (11-10-2015), silvapain (11-17-2015), Tomas (11-11-2015), zenit (11-10-2015)
 Old 11-11-2015, 12:29 PM   #543
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,805   (View Stats)
I have the racingbeat FSB. Barely noticeable change from stock. Car still rolls like a mofo.
Not like the Hotchkiss FSB on the MS3 which really tightens down the front end.
Mauro_Penguin (11-11-2015), phate (02-17-2016)
 Old 11-11-2015, 02:16 PM   #544
KevinK2's Avatar
High spring rate reduce the impact on roll with stiffer bars.
Tests by Phate show a 50% loss in stiffness due to poly bushing flex on the oem front bar. On my 90% tracked car, I had split aluminum bushings from ~1" thk plate, on a 1" dia front bar, greased with never seeze paste. No wear, no noise, no 50% loss. I'm sure Phate could come up with something to match his delrin rear bushings. Like a simple split plastic bushing with the top half od smaller than the bottom half, for anti rotation.
From Delaware
 Old 11-11-2015, 02:32 PM   #545
Eth Fiend
phate's Avatar
What is your spring and bar setup now? I remember you had those crazy stiff rear springs, but I think you pulled them since they were ridiculously stiff.
-06 MS6
 Old 11-11-2015, 08:55 PM   #546
Bob Ross Fanclub
Tomas's Avatar
I am running 425 lbs springs in the front on FSDs. And 250/500 progressive springs in the rear on self-valved bills. I need to run higher spring rates in the front.
Yes, the 200/2000 lbs progressive springs were a bit too much. That shit was giving me concussions. Even the 250/500 springs are pretty bouncy. I honestly don't know how you can run those 700 or 800 lbs rear springs on the street and call the ride solid. I tried 500 lbs standard springs and it was still just too bouncy for me. But may be it's my vagina. I do have a higher degree of sensitivity (girlishness) for that sort of thing.
Few more comments.
The RS3s. Those tires don't run very well when cold. You need to heat them up. On road courses they would run ok when cold but they would really start to stick after 2 laps. Also, yes 28 psi is too low for that tire. I run them at 42 psi hot and noticed they gave better feedback and stuck just the same as at 36.
The rear camber arms you want to try from the MS3. If they work, and you still want to eliminate crosstalk between motions, I have these here gusset reinforced arms below with spherical bearings. They are for Ford Focuses but fit perfectly on the MS3. There is of course more ride harshness so I took them off (see aforementioned vagina reference)
If you want them you can hais for cheap.
Oh and by the way. You got beat by a girl DRIVING YOUR OWN CAR. That's why no girl will ever drive my car. I couldn't bear a girl beating me at something. It's my small penis and correspondingly small self esteem.
Code Monkey (11-11-2015), phate (11-11-2015)
 Old 11-12-2015, 03:20 AM   #547
MSP611's Avatar
Posts: 2,291   (View Stats)
are the speed3 and speed6 camber arms interchangeable like tht? or will it take modding?
Few more comments.
In progress:
 Old 11-12-2015, 04:42 AM   #548
Eth Fiend
phate's Avatar
I also got some MS3 adjustable uppers for the rear suspension from zenit that I'm going to test on the 6. The 3 and 6 run different uppers in stock form, but the SPC pieces look like they'll fit ok on the 6.
You're killing me smalls.
-06 MS6
Mauro_Penguin (11-12-2015), MS3johanna (11-12-2015), Nliiitend1 (11-12-2015), silvapain (11-17-2015)
 Old 11-12-2015, 05:36 AM   #549
ItsNox's Avatar
First you put the graham. Then the chocolate. Then you put the mallow on. Then another graham.
Mmmmmm
'06 Mazdaspeed 6 GT
- Miltuned
The Following 3 Users Say Thank You to ItsNox For This Useful Post:
MS3johanna (11-12-2015), phate (11-12-2015), zenit (11-13-2015)
 Old 11-12-2015, 06:41 AM   #550
MS3johanna's Avatar
The 800# hurt a little sometimes. The 700# on the other hand, really aren't bad! Much better now that the sway bars are attached again, haha.
Not the first time!! On the upside of that, this girl is fully indebted to help with improvements/repairs, and provides a garage for said repairs. And she might just win him (us) some times at scca events next year since the ladies class is ~1/6 the size of the open class, and far less competitive! I've been pushing myself hard to get here, and I still have a lot to learn. Also, I've been competing in his car for *almost* as long as he has (but am otherwise many years of autoX experience behind).
There I go again, making off-topic posts in the suspension thread. :screwy:
The Following 7 Users Say Thank You to MS3johanna For This Useful Post:
KevinK2 (11-12-2015), Mauro_Penguin (11-13-2015), Nliiitend1 (11-12-2015), phate (11-12-2015), SpeedRebirth (11-12-2015), Tomas (11-12-2015), zenit (11-13-2015)
 Old 11-12-2015, 06:50 AM   #551
MSP611's Avatar
o...lo siento... i thought u were jst talkin about interchanging camber arms not full upper control arms
In progress:
 Old 11-12-2015, 08:17 AM   #552
Eth Fiend
phate's Avatar
I forgot I hadn't posted this yet. I tested my rear springs
That was an early setup that didn't give great results, but after a few setup revisions, I had a consistent rig.
I can add a few more graphs if you guys are interested, but this is what it boils down to. Rates of the springs over a short displacement range:
You can see that the SSS springs (800lb/in advertised) are increasing rate much more rapidly than the QA1's (700lb/in advertised). In reality, the springs are more like:
QA1: 680 lb/in, gaining rate at ~120lb/in/in (pounds per inch, per inch)
SSS: 815 lb/in, gaining rate at ~220lb/in/in
The QA1's DO level out at near their advertised rate, while the SSS springs consistently increase without leveling off. It's no wonder the "800" lb/in SSS springs felt significantly stiffer than the "700" lb/in QA1's.
Also note that this is displacement at the spring, while the wheel movement is spring displacement multiplied by the inverse of the motion ratio - so 1/0.57 = 1.75. That graph represents ~2.8" of wheel travel from the point of 0 load on the spring, then 2.8" into bump travel. That's probably the extreme of travel over serious bumps.
-06 MS6
Code Monkey (11-12-2015), Funkster777 (11-13-2015), KevinK2 (11-12-2015), Mauro_Penguin (11-13-2015), Mazdazilla6 (09-30-2016), silvapain (11-17-2015)
 Old 11-12-2015, 08:26 AM   #553
xfeejayx's Avatar
Groans: 78
600s were qa1?
-Wetz
QFT
The Following User Says Thank You to xfeejayx For This Useful Post:
phate (11-12-2015)
 Old 11-12-2015, 08:28 AM   #554
Eth Fiend
phate's Avatar
Originally Posted by xfeejayx View Post
600s were qa1?
Yep. I liked the 700's so much more that I sold the 600's...so no testing of those.
-06 MS6
 Old 11-12-2015, 08:52 AM   #555
MSP611's Avatar
the QA1's are the blue coil company springs right?
In progress:
 Old 11-12-2015, 08:55 AM   #556
Eth Fiend
phate's Avatar
SSS = Blue Coils. QA1 is its own company.
-06 MS6
 Old 11-12-2015, 09:20 AM   #557
xfeejayx's Avatar
Groans: 78
Explains why the jump from 700-800 was so much more noticeable, and less liveable, than 600-700 jump.
The Following 4 Users Say Thank You to xfeejayx For This Useful Post:
Mauro_Penguin (11-13-2015), Nliiitend1 (11-12-2015), phate (11-12-2015), silvapain (11-17-2015)
 Old 11-12-2015, 10:15 AM   #558
KevinK2's Avatar
Nice work with the spring rate testing.
We know the rate is based on active coils, and with so few active coils in these high rate springs, especially the 800's, the change in last coil supported at the flat ground spring ends, based on load, appears to give the initial progressive rate (unless it's due to a quirk in the tire scale)
It would be interesting to figure the rates based on load with the car parked, and then look at pic's of the car in a corner and estimate the lean angle. Then figure the change in spring load and rate at the rear inner and outer sides. The outside heavily loaded spring would likely stay near the 700 lb/in, but the inside unloaded spring may drop close to the 600 lb/in rate, providing more lean than calculated with the spreadsheet, even if the tire rates are included.
With softer springs and more active coils, you have less of this coil "seating" effect with the springs.
From Delaware
The Following 3 Users Say Thank You to KevinK2 For This Useful Post:
 Old 11-12-2015, 08:39 PM   #559
Eth Fiend
phate's Avatar
The ride isn't bad at all. The 600's were super comfy just cruising around town, and the 700's aren't much worse. With the 850F/700R, it's about the same ride quality (maybe slightly better) as a stock sprung, stock shock 1st gen MS3. I've been so impressed by these dampers since I got them back. Shaikh just posted this video, I thought it was pretty interesting.
Few more comments.
I'll probably start out around 38psi this weekend, then fine tune from there as they go up in heat and pressure. I'm usually pretty good at finding the ideal pressure, but I think I just started out way too low last weekend and didn't realize it at the time.
No shame here. She's gotten much faster since we started co-driving together regularly, especially in the past 6 months or so. She's helped with the entire process, and probably knows more about the 6 suspension than 99.9% of other people. Friendly competition between us has probably motivated both of us to get better and faster, and that's a good thing!
With the 800's, you can literally see the inactive section move further into the first coil (from each end), which is likely the cause of the 'progressive' spring rate. You can see this effect is even more pronounced on the purple square plot of the SSS 800-B plot. It initially has a very soft rate relative to the rest of its range, and it is due to a very small gap at the tip of the coil to the next lower coil. The rate jumps up as the coil tip contacts the next lower coil.
silvapain and MS3johanna like this.
-06 MS6
KevinK2 (11-13-2015), Mauro_Penguin (11-13-2015), Nliiitend1 (11-13-2015), silvapain (11-17-2015)
 Old 11-13-2015, 10:45 PM   #560
BAT-man's Avatar
Posts: 718   (View Stats)
BAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the world
Groaned at 29 Times in 14 Posts
[QUOTE=phate;2981099]The ride isn't bad at all. The 600's were super comfy just cruising around town, and the 700's aren't much worse. With the 850F/700R, it's about the same ride quality (maybe slightly better) as a stock sprung, stock shock 1st gen MS3. I've been so impressed by these dampers since I got them back. Shaikh just posted this video, I thought it was pretty interesting.
His videos support a theory I've been a proponent of for quite some time - one should not be afraid of body roll, within reason. Mazda's suspension is tuned very well from the factory and its made to lean, in order to provide camber under compression, and traction when not in compression... I see so many folks try to stiffen the hell out of everything and just not let the suspension work... Sometimes, when the suspension is absolute shit, you want to eliminate ANY effect it can have, so 20kg springs all around, pretty much weld the wheels to the chassis, and you rely on tires along to provide "dampening." For the most part, I have been enjoying the autoX/street capabilities of the completely stock MS3 suspension with pretty good results...
Btw, for funsies and slightly relevant to this thread, here is a corner weighed fully loaded genPu, full tank of gas, TRMotorsports C3 17x9 wheels, Hankook V12 255/40-17 tires, and a small 8” ZoomBox-cased sub in the driver side trunk cavity + small 1ch amp in place of stock spare-mounted sub:
Without driver (3311 lbs): https://lh3.googleusercontent.com/-t...4_175351-1.jpg
With 194lbs fat ass driver (3505 lbs): https://lh3.googleusercontent.com/-f...024_175836.jpg
I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems.
"... if u can't find' em - grind 'em"
- old Chinese proverb
http://www.mazdamotorsports.com/
BAT-man is offline   Reply With Quote
The Following 2 Users Say Thank You to BAT-man For This Useful Post:
Mauro_Penguin (11-14-2015), phate (11-16-2015)
« sway bar shifting | - »
Shocks for a daily driven Mazdaspeed 6 This thread Refback 12-05-2015 09:07 PM
Whats New/General Speed 6 Discussion - Page 296 This thread Refback 11-29-2015 05:42 PM
fe1rx Ohlins Installation - Page 7 This thread Refback 08-23-2015 04:39 AM
fe1rx Ohlins Installation - Page 6 This thread Refback 04-25-2015 01:24 PM
Prepping as dedicated track car - Page 56 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-21-2015 12:36 PM
BC coilovers VS. H&R coilovers - Page 15 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 08-26-2014 07:50 AM
Whats New/General Speed 6 Discussion - Page 297 This thread Refback 07-28-2014 08:03 PM
racing aspirations » Suspension Geometry Calculator This thread Refback 06-21-2014 02:57 AM
Prepping as dedicated track car - Page 50 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #48 Pingback 03-14-2014 12:36 PM
Prepping as dedicated track car - Page 46 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-20-2014 11:02 AM
Suspension/combo or coilovers?? gurusev 2010 MS3 - Suspension & Brakes 35 07-31-2013 10:06 AM
BC Coilovers or Bilstein Dampers/H&R Springs Bleupit80 MazdaSpeed 3/6 - Suspension & Brakes 6 02-12-2013 06:35 AM
BC BR Extreme Low Coilovers vs KSport Kontrol Pro Coilovers Doberman MazdaSpeed 3/6 - Suspension & Brakes 9 07-28-2012 07:35 AM
Suspension Techniques Coilovers? asiandude74 MazdaSpeed 3/6 - Suspension & Brakes 6 02-05-2011 11:15 PM
MSD Dashhawk Data Logger Data Base JimmyMac MazdaSpeed 3/6 - ECU Computer Tuning 2 06-30-2008 09:43 AM
Page generated in 0.69939 seconds with 31 queries
