Like Tree300Likes
 Old 05-26-2017, 01:12 AM   #881
MSP611's Avatar
Posts: 2,291   (View Stats)
Just add in an alignment before connecting bars and removing weight.
Sent from my SM-G935V using Tapatalk[/QUOTE]
You really do an alignment before y connect your sway bars? Why is that?
Sent from my SM-G930V using Tapatalk
In progress:
 Old 05-26-2017, 08:18 AM   #882
Eth Fiend
phate's Avatar
Posts: 6,930   (View Stats)
Sent from my SM-G930V using Tapatalk[/QUOTE]
After corner balancing, yes. Just ensures you don't inadvertently add preload since your bar pickup points will move slightly with the alignment.
MSP611 likes this.
-06 MS6
-Corn fed 07 MS3 - Sold
Mauro_Penguin (05-28-2017), MSP611 (05-26-2017), roguemazda (05-27-2017)
 Old 05-26-2017, 12:48 PM   #883
MSP611's Avatar
Good info. I need to see if I can get corner balanced here soon closest guy to me is in South fan Francisco tho. Like 2.5hrs from me so I'd have to trailer it unless I did a rough alignment at home and drove it but prob not the best idea
In progress:
 Old 05-28-2017, 07:51 PM   #884
Eth Fiend
phate's Avatar
Taking it out for the first time this season, tomorrow. Corner balanced and aligned, new wheel and tire setup clears with plenty of room to spare. Water injection is doing work, but more on all that later.
MSP611 likes this.
-06 MS6
aackthpt (05-29-2017), Code Monkey (05-29-2017), KevinK2 (05-28-2017), Mauro_Penguin (05-29-2017), MSP611 (06-03-2017)
 Old 05-31-2017, 11:22 AM   #885
KevinK2's Avatar
Posts: 899   (View Stats)
Taking it out for the first time this season, tomorrow. Corner balanced and aligned, new wheel and tire setup clears with plenty of room to spare. Water injection is doing work, but more on all that later......
How did it go? The handling should be great for sure with those mega tires, did the Water Inj'n better the IC? .. hope it did.
From Delaware
phate (05-31-2017)
 Old 05-31-2017, 07:23 PM   #886
Eth Fiend
phate's Avatar
It went well. Johanna and I took the class, but there weren't any fully prepped cars in our class, so I was just looking at overall results.
159 total drivers:
I was 8th fastest on raw time, and 15th overall on pax.
Johanna was 12th fastest on raw time, and 25th on pax.
I think we did ok considering it's an all new setup. I had a scratch run that was .6s faster than my fastest, but I coned it away. We split the "pro" class (nationals level folks) down the middle, so that's a good sign.
I set up the alignment based on what we were running last year. -2.5°/-3.0° camber front/rear, 0° toe all around. I didn't have the pyrometer out, but I suspect the rear could use a touch more. Tire pressures started at 38 psi all around and was really loose. We went down as far as 35psi in the rear, but grip seemed to fall off again below 35.5 - this will change as we change rear camber.
The rear bar might need backed off a bit, but I want to add a touch of negative camber in the rear first. I didn't have my pyrometer, but the outsides of the contact patch felt a little cooler than the insides on the rear. Front felt pretty even.
The car is a monster. It's making good power and is just incredibly responsive with the flow modifications and lack of intercooler. It made good power without the water injection, actually - I was able to get away with a lot more boost and timing than I thought I would. My tuning didn't go much beyond it calming down the first bit of knock I was seeing - I'm running enough timing at this point that I need on a dyno to really quantify changes. We went through a LOT of water - 10 runs, totaling to ~8 minutes of driving went through 3 liters of water.
The aquamist system ended up being dead simple to tune once I ignored their instructions. It's worthy of a full write up in the near future, it's a very capable system.
Couple pictures. I took video but, for some reason, the sound is extremely faint. I'm still trying to fix that before I upload anything.
Code Monkey likes this.
-06 MS6
Code Monkey (06-01-2017), Mauro_Penguin (06-02-2017)
 Old 05-31-2017, 07:55 PM   #887
KevinK2's Avatar
159 total drivers:
Johanna was 12th fastest on raw time, and 25th on pax. .....
well done! it looks like a handling monster.
"It made good power without the water injection, actually - I was able to get away with a lot more boost and timing than I thought I would. "
without?
From Delaware
phate (06-01-2017)
 Old 06-01-2017, 06:08 PM   #888
Eth Fiend
phate's Avatar
without?
Yes, without. I still run 50% E85 as my regular fuel, so knock protection is very high compared to 93 octane fuel. The latent heat capacity of ethanol is huge, and you inject more of it than you do gasoline = great cooling in cylinder.
After I encountered minor knock, I allowed the water injection system to work. I only added another 2° of timing on top of that and I was at my self imposed street tuning limit. It still seemed to be picking up power, but a dyno is well worth the investment to keep from hurting the engine. I might be able to get some time on the rollers in the next month or two.
-06 MS6
KevinK2 (06-02-2017)
 Old 06-01-2017, 06:44 PM   #889
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Groaned at 7 Times in 6 Posts
I'm curious about how much you anticipate paying for dyno time when dialing in ignition timing, (I have no experience or expectations for how long that might take), and whether you think the WI will effect ignition timing for MBT.
-feejay
-wetzel
 Old 06-01-2017, 06:51 PM   #890
Eth Fiend
phate's Avatar
If i get on the rollers with fuel and boost already dialed in, it takes 1-2 hours to dial in timing.
Changing jets a couple times plus finding new mbt, maybe 4 hours total.
-06 MS6
zenit (06-01-2017)
 Old 06-01-2017, 06:54 PM   #891
zenit's Avatar
Groans: 57
Great. If only we knew someone with an AWD dyno to abuse.
@Mazdazilla6;
-feejay
-wetzel
phate (06-02-2017)
 Old 06-01-2017, 07:01 PM   #892
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Clint if you're going to be in the area soon I can talk to my boss about dyno time. We have tuning sessions mon-wed every other week but the rest of the time the dyno just sits. I don't think it'd be too big of an issue if you paid for the time and came on a non tuning day.
phate likes this.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
phate (06-02-2017)
 Old 06-02-2017, 08:41 AM   #893
Eth Fiend
phate's Avatar
Where at?
-06 MS6
 Old 06-03-2017, 12:39 AM   #894
Where at?
P&L Motorsports in Lisle IL. Talked to my boss, he said it wouldn't be a problem. Dyno rates are $140/hour we'd deal with setting it up an strapping it down.
phate likes this.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 06-03-2017, 06:00 AM   #895
Eth Fiend
phate's Avatar
I'm familiar. If all goes well, from next week on I'll have the 6 with me. Should be easy to get a day for dyno time. Are Fridays or Mondays possible?
-06 MS6
 Old 06-03-2017, 08:32 AM   #896
KevinK2's Avatar
If i get on the rollers with fuel and boost already dialed in, it takes 1-2 hours to dial in timing.....
Do you prefer dynos with brakes & load cells to step through rpm's for tuning, or simple inertial types with rpm sweeps?
phate likes this.
From Delaware
phate (06-03-2017)
 Old 06-03-2017, 09:45 AM   #897
Yes. This coming week is a tuning week so the week after will work any day. The week after that would have to be Thurs or Fri.
phate likes this.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
phate (06-03-2017)
 Old 06-03-2017, 10:40 AM   #898
Eth Fiend
phate's Avatar
Alright, I'll keep in touch.
My preference for dynos are eddy current models of any brand. Inertia drum dynos tend not to simulate road load well enough. Eddy current models can incrementally add load to the point where they will stall out 1k+ hp cars and are typically dead consistent between runs.
I do full throttle, full rpm range sweeps and walk up timing iteratively over the rev range until I see little to no gain in power in a region, then back off 1-2°. I don't use the rpm hold function because we can't 'live flash' the ecu to watch power change in real time. I may spend a few extra minutes and do this at two different boost levels - 1 at wastegate pressure (~10psi) and another at full tilt (20+ psi)m then interpolate between the different load regions. Typically, though, there's not much difference in where MBT lies between high and low boost on a given engine.
-06 MS6
KevinK2 (06-03-2017)
 Old 06-03-2017, 11:13 AM   #899
KevinK2's Avatar
When I bought my 1st turbo, back when dinosaurs roamed the earth, I found that maximizing advance pre-boost, and backing it down as boost started to increase, eliminated the horrific lag and made that 2L-T run like a 3L na.
Looking forward to your real tuning results!
MSP611 likes this.
From Delaware
The Following 3 Users Say Thank You to KevinK2 For This Useful Post:
Mauro_Penguin (06-04-2017), MSP611 (06-03-2017), phate (06-03-2017)
 Old 06-03-2017, 11:20 AM   #900
MSP611's Avatar
Now that's some insider info from a real vet...
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
 Old 06-04-2017, 01:28 PM   #901
MSP611's Avatar
Need updates. I needz moar!!! I'm trying to button up my suspension this weekend (Monday/Tuesday for me) I need to stop slackin so I can drive this horrible investment lol. I wish I had a lift to make things enjoyable, but don't we all.
In progress:
 Old 07-03-2017, 07:50 AM   #902
Eth Fiend
phate's Avatar
Had the car out last weekend. Just now getting to the videos.
Fastest recorded for Johanna. She ended up with a 43.2xx.
Johanna beat my by .4s, and was 2nd fastest raw time at the event. I ended up 4th fastest. There's a lot more out there, I don't think either of us really reached the limits in several sections. We both kept pushing it harder and it just sticks.
A couple of issues that I'm trying to iron out.
#1 is that the braking is really lacking. Last year, I was running the HPS pads in the stock front calipers and was happy with the braking. I changed to the CS calipers and 2 piece rotors this year, but still with HPS pads. When I go to brake, the initial pedal feel is very firm but the braking force is very light. If I ease into the brakes, pedal feel is normal and braking force is fine.
I suspect that I'm pressurizing the brake booster so I'm going to replace the original line with internal check valve with a new line and new check valve. Those parts should be in today.
#2 is that the car is still breaking up on long left handers. I need to do more data logging and get with the VT guys to sort this out.
Probably some more, but those are the big ones. I bought an enclosed trailer a few weeks ago, so the car is officially a trailer queen
-06 MS6
Code Monkey (07-03-2017), KevinK2 (07-03-2017), Mauro_Penguin (07-04-2017), MS3johanna (07-03-2017)
 Old 07-03-2017, 11:48 AM   #903
KevinK2's Avatar
So you suspect some hose or check-valve damage during the swap to new rotors/calipers ?
Fuel slosh possible? Would show up on log for pressure.
Those starts seem easier on the transaxle.
From Delaware
phate (07-03-2017)
 Old 07-03-2017, 12:13 PM   #904
Eth Fiend
phate's Avatar
The check valve may just be a little gummed up after 200k miles. I haven't pulled it, but I suspect it's slow to move or is a little leaky. The issue is worst when I come out of boost and immediately try to jump on the brakes...which is several times during an autocross. If I have some time, I'll pull it tonight for some inspection. I have one coming in with 0.3psi crack pressure that is piston type, for comparison.
After my first autocross this year, I did find a cracked fitting on the braided line going to the caliper. I thought that was the fix, but the issue persists.
Fuel pressure is ok, from what I remember. I've run with as much as a full tank when it's occurred, so I don't think it's slosh. I should probably go back to the basics, first, but some datalogging of fuel pressure will be included.
-06 MS6
 Old 07-03-2017, 09:59 PM   #905
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,768   (View Stats)
Groaned at 33 Times in 19 Posts
I am more and more intrigued by this Johanna driving empress.
My penis wants you to win.
But the girl in me wants lesbian sex with AutoX annihilator Johanna.
MAKE LOVE TO THE CANVAS
Code Monkey (07-04-2017), phate (07-04-2017)
 Old 07-04-2017, 06:17 AM   #906
zenit's Avatar
Groans: 57
She's faster than you.
@MS3johanna;
MS3johanna likes this.
-feejay
-wetzel
The Following 2 Users Say Thank You to zenit For This Useful Post:
 Old 07-04-2017, 09:28 AM   #907
Eth Fiend
phate's Avatar
Check valve holds 50psi and doesn't leak. Going to rework the lines a bit, since I changed them up a little bit for the new intake manifold. I broke an adapter when I pulled the line, last night, anyway...
If not that, I may be looking at a brake booster issue.
-06 MS6
 Old 07-14-2017, 09:09 AM   #908
Eth Fiend
phate's Avatar
Going to try this again tomorrow. Last weekend I pulled the car off the trailer the night before Autocross and found the clutch hydraulic line squirting fluid everywhere. It's been on for 4 years (CS braided steel), so I replaced it with a technical fit steel braided line.
I reworked the vacuum lines a bit, so I'm interested to see if braking is better. I have the next steps in mind if it doesn't work out.
Had the car on the dyno last Friday. Water injection kills power off and I couldn't make it up with tuning. E85 is an incredible fuel. Since it has such a high octane for us, the water injection doesn't pay off. I'll be pulling it soon. Graph, below. Highest line is without water, lowest line is with as much water as possible before it caused blowout, and the middle line is with the 2 smallest nozzles I had.
-06 MS6
Code Monkey (07-14-2017), KevinK2 (07-14-2017), Mauro_Penguin (07-16-2017)
 Old 07-14-2017, 10:43 AM   #909
zenit's Avatar
Groans: 57
@phate; did you get a chance to look at whether water injection caused an overall decrease in airflow?
Also, have you figured out a solution for intercooling with the st Mani or are you keeping it straight piped?
-feejay
-wetzel
phate (07-14-2017)
 Old 07-17-2017, 06:16 PM   #910
Eth Fiend
phate's Avatar
Finally got the car out again this past weekend. The brakes still sucked, but went really dang fast despite that. I took #1 pax, and was 2nd on raw 0.2s behind 1st. Johanna went 6th raw and 6th pax. Other than braking, I'm pretty happy with everything.
I ordered a set of Hawk HP+ as my next step with brakes. I'm a little concerned they'll be too touchy like the yellows, but I'll have to go to a different brand if these don't work out.
Also, the car shoots massive flames now and put on a bit of a show this weekend, lol. Great time, overall. Hopefully someone got decent pictures from the weekend. Really crappy screen cap attached.
Double header this coming weekend
I haven't looked at the logs, yet. This week if I have time. I will probably buy a front mount for testing, but I'm not real willing to give up this response.
-06 MS6
Code Monkey (07-17-2017), Mauro_Penguin (07-18-2017)
 Old 07-17-2017, 08:01 PM   #911
KevinK2's Avatar
Finally got the car out again this past weekend. The brakes still sucked, but went really dang fast despite that. I took #1 pax, and was 2nd on raw 0.2s behind 1st. Johanna went 6th raw and 6th pax. Other than braking, I'm pretty happy with everything .....
Congrats on the fast runs.
Have you data logged the brake booster vacuum? Would also be good to log brake lever motion with a simple motion switch.
Worst case, I think they make brake pressure assist using the steering fluid pump.
From Delaware
Mauro_Penguin (07-18-2017), MS3johanna (07-18-2017), phate (07-18-2017)
 Old 07-20-2017, 04:10 PM   #912
zenit's Avatar
Groans: 57
Just a thought- when I first installed an aftermarket TMIC on my car (as a part of testing super-cheater K04), I didn't notice any difference in power, but there was big difference in transient response, which is probably an effect of much smaller pressure drop across the TMIC at higher-than-stock boost levels.
Obviously, straight pipe restriction < Large TMIC, but I wonder if you couldn't get 90% of the response you see from the straight pipe with a large TMIC, and not have to deal with power loss and the complications of keeping up with a WI system.
Also, re: response- it'd be fun to see one of those dynographs/logs plotted against time (secs), instead of Torque/hp v RPM.
-feejay
-wetzel
 Old 07-20-2017, 07:06 PM   #913
KevinK2's Avatar
I would think a well designed top mount A/L intercooler with an ice tank in the trunk would provide the lowest AIT's. Providing enough ice on a hot day could be a problem.
EDIT: I guess it would be great, if allowed:
2017 Solo Rules SP class, 15.10.3.2&3 :
2. Except for standard parts as defined in these rules, the external use
while on course of liquids, ice, dry ice, refrigeration systems, vaporized
compressed gases, etc. to reduce the temperature of the intake air
charge is prohibited. Wrapping of intakes with liquid-soaked fabric is
not permitted.
3. As utilized only on engines originally equipped with forced induction,
induction charge heat exchangers (also known as “intercoolers” or
“charge air coolers” [CACs]) are unrestricted in size and configuration.
Air-to-air CACs and radiators for air-to-liquid CACs must be cooled only
by the atmosphere except for standard parts. Body panels, fascias, or
structural members may not be cut or altered to facilitate CAC installation.
From Delaware
phate (07-21-2017)
 Old 07-24-2017, 04:12 PM   #914
KevinK2's Avatar
... I will probably buy a front mount for testing, but I'm not real willing to give up this response.
There are some advantages with the FMIC for autoxing, but got to watch the rule book about limitations on what material can be trimmed for clearance. I suspect the AIT's can be much lower with a fmic at the condenser location, and fans driving ambient air through the core. Helps reduce heat soak at staging, as well as on course.
But you would really need a big drop in intake temps to justfy it. Power ratio is based absolute temps, where absolute temp degR = amb degF + 460. So going from 230F AIT to 100F gives a drop of 20%. But in SAE HP formula's for adjusting for variations from standard conditions, they us the sq-rt of this, for a 10% increase in density...... I think?
From Delaware
 Old 07-24-2017, 07:33 PM   #915
Eth Fiend
phate's Avatar
Good weekend. Saturday was pouring rain most of the morning, so we bailed. Sunday turned out to be a pretty nice day.
I ended up with a trifecta - 1st in class, 1st on overall raw time, and 1st on index. My 1st time ever for that.
I was pretty happy with the car - I put in Hawk HP+ brake pads up front and they are on the opposite end of the spectrum. Maybe too touchy, but I want to run them another day or two before I decide on something else. Great braking power at low pedal pressure, so it doesn't seem to be a vacuum or brake booster issue. I got a little more used to them a couple runs in, but still locked up the front tires very briefly once or twice.
Johanna had a rough day mashing cones. She ended up 9th on overall raw time with the cone, and would have been 6th if it was clean.
For future rainy days, I picked up some Hoosier H2O rain tires. These will go on my green XXR's. 245/40/17, but they look gigantic.
If I go with an intercooler, I think it'll be a front mount. The top mounts still heat soak like crazy.
Nliiitend1 and Code Monkey like this.
-06 MS6
Code Monkey (07-25-2017), KevinK2 (07-24-2017), Nliiitend1 (07-28-2017)
 Old 07-24-2017, 08:29 PM   #916
KevinK2's Avatar
Congrat's on FTD. Did you log ait's? Agree about heat soak from a TMIC.
From Delaware
phate (07-26-2017)
 Old 07-25-2017, 07:36 AM   #917
Code Monkey's Avatar
Posts: 7,656   (View Stats)
To minimize piping, you could route the hot side similar to what I did, and with the Ecoboost IM, the cold side could be very short and go under the radiator (ideally with a shorter or angled radiator).
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
phate (07-26-2017)
 Old 07-26-2017, 05:31 PM   #918
Eth Fiend
phate's Avatar
Didn't log them, but they tend to level out around 250°F from the testing I've done.
-06 MS6
KevinK2 (07-26-2017)
 Old 07-26-2017, 06:43 PM   #919
zenit's Avatar
Groans: 57
or the sensor taps out.
-feejay
-wetzel
The Following 3 Users Say Thank You to zenit For This Useful Post:
Code Monkey (07-26-2017), KevinK2 (07-26-2017), phate (07-26-2017)
 Old 08-02-2017, 09:56 AM   #920
KevinK2's Avatar
Looks like you could be competitive at the SCCA Nationals. If you go FMIC for the increased charge density, be careful about alterations to the frame/body:
15. STREET PREPARED CATEGORY
15.10 C 3
“intercoolers” or
From Delaware
Shocks for a daily driven Mazdaspeed 6 This thread Refback 12-05-2015 10:07 PM
Whats New/General Speed 6 Discussion - Page 296 This thread Refback 11-29-2015 06:42 PM
fe1rx Ohlins Installation - Page 7 This thread Refback 08-23-2015 05:39 AM
fe1rx Ohlins Installation - Page 6 This thread Refback 04-25-2015 02:24 PM
Prepping as dedicated track car - Page 56 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-21-2015 01:36 PM
BC coilovers VS. H&R coilovers - Page 15 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 08-26-2014 08:50 AM
Whats New/General Speed 6 Discussion - Page 297 This thread Refback 07-28-2014 09:03 PM
racing aspirations » Suspension Geometry Calculator This thread Refback 06-21-2014 03:57 AM
Prepping as dedicated track car - Page 50 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #48 Pingback 03-14-2014 01:36 PM
Prepping as dedicated track car - Page 46 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-20-2014 12:02 PM
Suspension/combo or coilovers?? gurusev 2010 MS3 - Suspension & Brakes 35 07-31-2013 11:06 AM
BC Coilovers or Bilstein Dampers/H&R Springs Bleupit80 MazdaSpeed 3/6 - Suspension & Brakes 6 02-12-2013 07:35 AM
BC BR Extreme Low Coilovers vs KSport Kontrol Pro Coilovers Doberman MazdaSpeed 3/6 - Suspension & Brakes 9 07-28-2012 08:35 AM
Suspension Techniques Coilovers? asiandude74 MazdaSpeed 3/6 - Suspension & Brakes 6 02-06-2011 12:15 AM
MSD Dashhawk Data Logger Data Base JimmyMac MazdaSpeed 3/6 - ECU Computer Tuning 2 06-30-2008 10:43 AM
Page generated in 0.66491 seconds with 27 queries
