Like Tree302Likes
 Old 11-17-2018, 03:15 PM   #1121
KevinK2's Avatar
Posts: 899   (View Stats)
Default Which Torsen LSD?
I had always assumed this was a popular Type-2 Torsen, but it appears to be a variation of that theme, with the same parallel axis for both the outer gears and the side gears. The original Type-2 has 3 pair of outer gears (6 total), while this one has 12, shorter outer gears, all meshing with each other (no pairs).
Torsen Type-2:
Like Phate? (animation, just 6 short, outer gears):
https://www.youtube.com/watch?v=W96fOdMZnXE
The animation shows wheels spinning in opposite directions. But outer gears would spin slowly when in a corner, with side gears at different speeds, spinning in same direction.
Just a curiosity. Torsen now has many different versions supplied to the OEM car makers.
From Delaware
phate (11-19-2018)
 Old 03-11-2019, 03:27 PM   #1122
aviator79's Avatar
Posts: 3,925   (View Stats)
Groans: 67
Are the Suspension Spring Specialists, aka "Blue Coils" basically a drop in spring? I had been planning on buying BC coilover height adjusters and QA1 springs. I am not finding blue coils for sale anywhere. Guess I can call manufacture.
Also saw some post with what looked like other possible options:
MS6 Suspension Data & DIY Bilstein Coilovers
Driving home from FL to CT in the next few weeks and car will be riding on bump stops whole way home which causes ass to pucker every time I go over a big bump, but made it down here fine. Shipping some stuff home but will still be overweight. Would love to get stiffer springs before that but likely not going to happen. Problem is even empty rear is too heavy for OEM springs so need to fix when I get home.
 Old 03-13-2019, 01:12 PM   #1123
OverBoosted's Avatar
Posts: 1,608   (View Stats)
OverBoosted is the leader of the worldOverBoosted is the leader of the worldOverBoosted is the leader of the worldOverBoosted is the leader of the worldOverBoosted is the leader of the worldOverBoosted is the leader of the worldOverBoosted is the leader of the worldOverBoosted is the leader of the worldOverBoosted is the leader of the worldOverBoosted is the leader of the worldOverBoosted is the leader of the world
Originally Posted by Tomas View Post
Nintendo is on all counts correct.
350 lbs pig tail springs compared to stock. Rear. Best DD set up so far. Much firmer than stock. Minimal squat left. Not bouncy.
MS6 rear 250/500 springs. Gets bouncy. Prepare for light neck injuries.
MS6 front with FSD and 425 springs (hands down best front DD set up ever for MS6)
Filling rattling full homo only set up (for me) with 600 springs, front
I know this is super old post. But what/where did you get the upper mount to turn the bilstein shock into a coilover. I see where to get all the other parts.
OverBoosted is offline   Reply With Quote
 Old 03-13-2019, 01:30 PM   #1124
dagrimey1's Avatar
Posts: 1,245   (View Stats)
dagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the worlddagrimey1 is the leader of the world
Groaned at 7 Times in 6 Posts
My 500lbs aren't bouncy I'm running the QA1s easy to find and fairly cheap on ebay.
Can't believe I using Tapatalk again!
dagrimey1 is offline   Reply With Quote
 Old 03-13-2019, 02:23 PM   #1125
Here is the original design i was going to remake, just using the BC upper spring mount
 Old 03-13-2019, 03:42 PM   #1126
eroler1's Avatar
Posts: 116   (View Stats)
eroler1 has a spectacular aura abouteroler1 has a spectacular aura about
whats up with this new account spammers? the other one copy pasted something about viagra
eroler1 is offline   Reply With Quote
 Old 03-15-2019, 10:50 AM   #1127
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,785   (View Stats)
BC racing
OverBoosted likes this.
MAKE LOVE TO THE CANVAS
OverBoosted (03-15-2019), phate (03-18-2019)
 Old 03-15-2019, 10:52 AM   #1128
BC racing
Thank you! Putting together a set for the rear right now and will be doing the fronts soon.
Sent from my Pixel XL using Tapatalk
 Old 03-15-2019, 11:34 AM   #1129
dagrimey1's Avatar
Every clowns BC as a cheaper option but I love their CS and parts catalog.
Shocks for a daily driven Mazdaspeed 6 This thread Refback 12-05-2015 09:07 PM
Whats New/General Speed 6 Discussion - Page 296 This thread Refback 11-29-2015 05:42 PM
fe1rx Ohlins Installation - Page 7 This thread Refback 08-23-2015 04:39 AM
fe1rx Ohlins Installation - Page 6 This thread Refback 04-25-2015 01:24 PM
Prepping as dedicated track car - Page 56 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-21-2015 12:36 PM
BC coilovers VS. H&R coilovers - Page 15 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 08-26-2014 07:50 AM
Whats New/General Speed 6 Discussion - Page 297 This thread Refback 07-28-2014 08:03 PM
racing aspirations » Suspension Geometry Calculator This thread Refback 06-21-2014 02:57 AM
Prepping as dedicated track car - Page 50 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #48 Pingback 03-14-2014 12:36 PM
Prepping as dedicated track car - Page 46 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-20-2014 11:02 AM
Suspension/combo or coilovers?? gurusev 2010 MS3 - Suspension & Brakes 35 07-31-2013 10:06 AM
BC Coilovers or Bilstein Dampers/H&R Springs Bleupit80 MazdaSpeed 3/6 - Suspension & Brakes 6 02-12-2013 06:35 AM
BC BR Extreme Low Coilovers vs KSport Kontrol Pro Coilovers Doberman MazdaSpeed 3/6 - Suspension & Brakes 9 07-28-2012 07:35 AM
Suspension Techniques Coilovers? asiandude74 MazdaSpeed 3/6 - Suspension & Brakes 6 02-05-2011 11:15 PM
MSD Dashhawk Data Logger Data Base JimmyMac MazdaSpeed 3/6 - ECU Computer Tuning 2 06-30-2008 09:43 AM
Page generated in 0.32981 seconds with 26 queries
