Like Tree305Likes
 Old 03-31-2015, 09:35 AM   #321
Eth Fiend
phate's Avatar
Posts: 6,942   (View Stats)
Originally Posted by MSP611 View Post
I know I will be a lil heavier than you when I do my corner balance becuz I will be full interior with some bracing minus some weight obviously from cats and a couple extra things but prob pretty close to stock, so im thinkin of doin minimum 850sF/900sR or so in the rear....
I would get corner weights first (at race weight) before deciding on rates. I've gone from 600's, to 700's, to 800's in the rear and the 800's can be a little unruly around town. If you plan to DD the car, maybe consider slightly lower rates. Performance wise, I definitely prefer the stiffer spring in the rear, and I think overall the car needs a lot more rear bias - hopefully through a stiffer rear ARB that doesn't exist yet, lol. If I want more spring than what I have now, it will likely require another revalve of the shocks.
Also other than the bump travel measurements I thought u needed a longer spring for the available 12" or so of full travel?... im sure im getting something wrong and my numbers r off, but jw why the choice of the 7" spring exactly
You need height adjusters in the rear for the shorter springs. I have some from BC Racing and they work great. 7" spring only because it's available in decent rates and works with the space we have. An 8" spring would be fine (QA1's are 8"), and they fit great with the same height adjusters.
When you run a significantly stiffer spring, your normal operating range of bump travel is decreased.
The real question is in the extra 30-50mm lowering r u wasting the space just for looks with less actual function?
Sort of. I gave my impressions of bump steer curves a page or two ago when I measured them, and I've put a lot of stock into those when deciding on height. The rear is fine being lower IF you can keep it off of the frame stops and IF you can keep the tires from rubbing, all while running proper camber settings. The front, not so much.
-06 MS6
-Corn fed 07 MS3 - Sold
MSP611 (03-31-2015)
 Old 03-31-2015, 09:40 AM   #322
MSP611's Avatar
Posts: 2,291   (View Stats)
great info @phate; this is some of the most informative suspension shit ive read, included as well the speed6 road racing thread. Ya the car will mostly be street driven but only taken out when I really wanna drive and I have a lot of nice roads and mt. driving around me with wat I grew up on....
As for corner balancing before I order, tht might be slightly hard becuz im gone 11months out of the year and only had limited time when im home... I was tryin to have everything ready when im home... I know corner balancing is ideal first but I don't know if ill have time.
In progress:
 Old 03-31-2015, 10:27 AM   #323
Code Monkey's Avatar
Posts: 7,671   (View Stats)
You just want corner weights first (with you in the car) without any balancing as this will determine valving and spring rates. Once you get all the suspension pieces in, you do proper alignment and corner balancing. If you cannot get all 4 corners, even just the front and rear weight would do.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
Easter Bunny (03-31-2015), Mauro_Penguin (03-31-2015), phate (03-31-2015)
 Old 03-31-2015, 10:38 AM   #324
MSP611's Avatar
hmmm maybe ill have my roommate get it done... What kind of special scales do u use? or do take it somewhere?
In progress:
 Old 03-31-2015, 10:54 AM   #325
KevinK2's Avatar
Posts: 903   (View Stats)
..... so technically @KevinK2; it would give you a lil more low? The real question is in the extra 30-50mm lowering r u wasting the space just for looks with less actual function?
The sprung CG height and track width are the only two things that can reduce the weight transfer for a specific corner speed. But unless you can correct bump steer, and adjust the F & R roll centers to reasonable heights, you can mess up the suspension geometry and degrade the handling with a 50mm drop.
From Delaware
 Old 03-31-2015, 11:52 AM   #326
MSP611's Avatar
gotcha dually noted lol
In progress:
 Old 03-31-2015, 12:39 PM   #327
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
*duly*
WetzMS3 likes this.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 2 Users Say Thank You to Nliiitend1 For This Useful Post:
Easter Bunny (03-31-2015), Tomas (03-31-2015)
 Old 03-31-2015, 12:40 PM   #328
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
*duly*
This guy.
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 03-31-2015, 12:40 PM   #329
MSP611's Avatar
meh tomato, tomatoe
In progress:
 Old 03-31-2015, 01:37 PM   #330
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,800   (View Stats)
*duly*
well may be he meant to note things twice. I mean why not.
Nliiitend1 (03-31-2015)
 Old 03-31-2015, 01:59 PM   #331
KevinK2's Avatar
Right, noted for both the front, and rear suspensions .... twice noted
From Delaware
The Following 2 Users Say Thank You to KevinK2 For This Useful Post:
Easter Bunny (03-31-2015), Nliiitend1 (03-31-2015)
 Old 03-31-2015, 09:14 PM   #332
MSP611's Avatar
U got it @KevinK2;
In progress:
 Old 04-06-2015, 06:03 PM   #333
Eth Fiend
phate's Avatar
Autocrossed on asphalt yesterday. It's a totally different animal than the concrete I'm used to running on. Grip wasn't available like usual. I ran two sessions, one in the morning that consisted of 5 runs, and an afternoon session with 7 runs. I was mostly working tire pressures and taking tire temps and trying to reign in the oversteer that I started out with.
Current setup, as a reminder - 850F/800R springs, stock front bar, WL rear bar on stiff. -2.0° F/-1.8° R camber, 0 toe all around.
I ended up with pressures of 32.5F/33R, which is the closest I've ever had them. That gave me some manageable mid corner oversteer, but the car still has some steady state understeer. Turn in is a little numb, but I attribute that mostly to the Rivals. They weren't crisp the first time around, but the wider/slightly stretched tire this time around is definitely better.
Tire temps were kind of interesting. There was a hard, straight braking zone coming into the finish, so I think inner tire temp readings were a little hotter than they would have been otherwise, so I'm taking that into consideration. Mostly - I need more negative camber most everywhere. The inside region of the tread on the front tires was just slightly hotter than the outside by ~5° on most runs. The rear tires had almost completely even heat across the tread. With the assumption that the inner tread was slightly hotter due to the last braking zone, I want to try more negative camber to see if we can pick up more cornering power.
If that is the case, I think I can still shift more roll bias to the rear and hopefully pick up more front grip. Any additional grip up front and/or loss of grip in the rear should be countered by some added camber in the rear at the very least. On concrete, I have room to bring rear temps down since they were higher to get some rotation out of the car.
On the max camber front, we've been discussing it on our local autocross forum. There are folks running upwards of -3° without any [claimed] reduction in braking power. I have at least that much to play with, and I might be able to add in some caster by rotating the ball joints a bit. I'll work on that next weekend if I can. We have a test and tune, and should have tons of runs.
The car felt pretty good, though. Other than me completely over driving a few runs, including one spin, it was good when I drove it with smoother input. Throttle down before the apex most everywhere without inducing significant understeer, very easy and quick to correct mistakes.
This was my fastest run from the day. Check out the tire rollover, it's amazing how much it has. That's the pressure they seemed to like on that surface, and they weren't actually rolling over onto the sidewalls. They were pretty happy and pretty easy to drive.
I've sent an email to GCDC for a recommendation of accelerometers. I tried using Harry's Lap Timer at this autocross and the last with marginal success. It did record numerous data points (both lineal and lateral) of >1.10g, and a few decel points just over 1.2g. The sampling rate is too slow to be useful, though. There are two GCDC units I'm looking at. One that is +/-2g and another that is +/-16g. The 2g unit seems totally sufficient, but they recommend the 16g one for automotive use. If they say the 2g accelerometer is OK for automotive use (I don't see why it wouldn't be), I'll get it for the higher resolution. Both have faster sampling rates than I need right now, and both look to have sufficient battery life. Maybe I can get that in before the test and tune. The HLT preview is enticing, haha.
-06 MS6
The Following 8 Users Say Thank You to phate For This Useful Post:
aviator79 (04-07-2015), Code Monkey (04-06-2015), ItsNox (04-12-2015), KevinK2 (04-06-2015), Mauro_Penguin (04-06-2015), mxlplx71 (04-07-2015), TiGraySpeed6 (04-07-2015), wolly6973 (04-07-2015)
 Old 04-06-2015, 10:11 PM   #334
KevinK2's Avatar
Even with the stiff spring set-up, it appears to have more body roll than desireable. With your custom rear bar sized to match the Steeda 26mm front bar, bars would be 38% stiffer (100% with RB), roll and edge wear would be reduced. The wear on the front tires really get across the outer edges, lots of slip angle ... great camera work! I know you are going for more camber, but did you try more pressure F & R, like 36+ psi?
On the video, it looks like you were fast and slipping on the asphalt.
From Delaware
 Old 04-07-2015, 04:07 AM   #335
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Groaned at 7 Times in 6 Posts
This was my fastest run from the day. Check out the tire rollover, it's amazing how much it has. That's the pressure they seemed to like on that surface, and they weren't actually rolling over onto the sidewalls. They were pretty happy and pretty easy to drive..
Your tires are definitely moving, but actually less than I expected. I'm used to seeing videos of big floppy race tires or oversized street tires on an undersprung car.
I can relate to the low pressures v tire roll. I was running 32 psi on 255's on 10's and saw roll right at the outer marker for the front tires. However, I'm beginning to wonder if that the tires on the front setup are under cambered and are still overtaxing the outside edge, but due to a lack of body roll essentially scrubs the tire flat vs rolling the tread and scrubbing. I'm not sure how adding pressure would help this.
This is a something that could be looked into with a pyrometer. Didn't happen to record the raw data did you?
-feejay
-wetzel
Mauro_Penguin (04-13-2015)
 Old 04-07-2015, 08:27 AM   #336
Eth Fiend
phate's Avatar
I started around 34/36, they increased to ~36/37 and grip was down and the car was very loose. I dropped it as low as 32/32, but that seemed to be too low as it wasn't as fast or responsive.
I was ~1.7s slower than the fastest door car, so not bad imo.
Sure did, but of course my notebook is with my autocross box, in Johanna's garage. I'll ask her to grab it. I tried to record as much as I could so I have something to look back on.
Are you coming down for the test and tune this weekend? I'll have my pyrometer if you'd like to use it. Might even have an accelerometer by then!
-06 MS6
 Old 04-07-2015, 11:48 AM   #337
KevinK2's Avatar
.... I can relate to the low pressures v tire roll. I was running 32 psi on 255's on 10's and saw roll right at the outer marker for the front tires. However, I'm beginning to wonder if that the tires on the front setup are under cambered and are still overtaxing the outside edge, but due to a lack of body roll essentially scrubs the tire flat vs rolling the tread and scrubbing. I'm not sure how adding pressure would help this.
EDITED:You see a lack of body roll for your car. From Phates video of his car, I see about 5-6 " at the wheel, in terms of max gap and min gap, and also know larger sway bars are the way to reduce roll, but with the oem front bar, and an effectively 2mm larger rear bar where the MR is .56, Phate's not getting much anti-roll from the set-up, imho.
In the tire pressure, I was wrong to suggest raising both front and rear to ~ 36+ psi, and Phates subsequent notes show that made things worse. You are right in that higher pressure would not help the front edge wear on the stetched fit tires.
Originally Posted by Phate
... I started around 34/36, then increased to ~36/37 and grip was down and the car was very loose....
With this info, I read +2 psi up front did increase front grip, and/or +1 psi at the rear decreased rear grip. So 1st logical step would be to change one variable. I'd leave the front at 34, and reduce the rear by ~2 psi. That is 34/34, and we now know Phate was best with 32.5/33. Of course this is after knowing what worked from Phate, but it's a logical path vs my quick suggestion to raise pressures to 36+.
One thing to remember is Phate's control arm bushings are close in stiffness to new oem's, so some neg camber loss is due to bushing flex in the corners, which supports the general agreement to increase neg camber.
From Delaware
 Old 04-07-2015, 12:28 PM   #338
I thought autocrossers ran very high pressures in the front? Like 40-42 psi front/34 psi rear on a car like the speed6?
2006 Mazdaspeed6
2017 Subaru BRZ
phate (04-07-2015)
 Old 04-07-2015, 12:36 PM   #339
Eth Fiend
phate's Avatar
I typically lower one axle's pressure at a time and sort of shimmy down to those pressures. The fronts weren't happy much above 34psi, nor below the 32.5psi; both cases with close to nominal rear pressures.
You can feel it during the course, also. If you start at a decent pressure it feels great for the first segment or two, then as pressures increase as the tire heats up, the grip goes down. The tires never got above 140°F, so I definitely wasn't overheating them.
Most camber limited/softly sprung/heavy cars have to in order to prevent tires from rolling over. If you don't have any of those, then you can lower until you find peak grip (nearly one in the same, if you think about it - you run the pressure that gives max grip). I never rolled the tire over onto the sidewall (even though the video might seem like it), I simply lost grip with lower pressure.
-06 MS6
Last edited by phate; 04-07-2015 at 12:38 PM. Reason: MSF Database - Automerged Doublepost
aviator79 (04-07-2015), Code Monkey (04-07-2015), KevinK2 (04-07-2015), Mauro_Penguin (04-13-2015)
 Old 04-07-2015, 02:27 PM   #340
Crarrs's Avatar
Posts: 1,662   (View Stats)
Groans: 98
Most of the autocrossers on here are running the widest tire they can possibly fit on a given wheel width, so they need the extra pressure to support the sidewall. I was running 245s on an 8-inch wheel, and I know I wasn't the only one. I was running 42-44 psi in the front with slightly over 1 degree of negative camber on stock springs.
With the "proper" setup of a wider wheel for a similar-width tire, you can get away with less pressure, and it will gain you traction overall versus having to run the extra pressure simply to maintain your contact patch. If I had decided to keep developing my MS3 for STX, my next 3 purchases would've been camber plates, 17x9s, and the GC coilover setup; in that order.
2004 MSM TiGrey
The Following 4 Users Say Thank You to Crarrs For This Useful Post:
Code Monkey (04-07-2015), KevinK2 (04-07-2015), Mauro_Penguin (04-13-2015), phate (04-30-2015)
 Old 04-07-2015, 04:42 PM   #341
KevinK2's Avatar
Good point. As I watched the stretch fit tires on Phates wheels, there was very little if any sidewall distortion. I was reminded of a similarly placed camera on a F1 machine, and due to the small wheel dia spec (26" dia on 13" dia rims), the tread would shift back and forth by an inch or two, with zero roll of the tread width! Two images:
Link, 2003/F1/Imola
2004 Imola
From Delaware
 Old 04-10-2015, 05:42 PM   #342
Eth Fiend
phate's Avatar
Going to do testing this weekend with this little guy.
I got the +-2g unit. I don't think I'll ever have the car pulling 2g's unless it's in a wreck lol. This thing is dead simple. Set up a quick config file, save it, then it's one button top start and stop logging.
It will supposedly record 8-10 hours at 512Hz, but I'll be logging at 128 to start out. If it needs more, I'll bump it up for Sunday. I'm just going to log the entire day and trim the data later. Should be pretty easy.
Nliiitend1 and Mauro_Penguin like this.
-06 MS6
aviator79 (04-10-2015), Code Monkey (04-10-2015), Crarrs (06-09-2015), Mauro_Penguin (04-13-2015), Nliiitend1 (04-10-2015), TiGraySpeed6 (04-10-2015)
 Old 04-11-2015, 07:43 AM   #343
KevinK2's Avatar
When you were considering the 2 vs 16 g, I was wondering if the accuracy would be better with the 2g setup. With analog pressure gauges, accuracy is expressed as a % of full scale, but your g accelerometer + digital output board is likely different in acuracy vs scale. So is the 2 g more accurate vs the 16g uspeing a 2g display option?
Also, have you added neg camber for the next run? I know you did not have much time to do it.
From Delaware
phate (04-12-2015)
 Old 04-11-2015, 08:09 AM   #344
Nliiitend1's Avatar
Groans: 67
Considering that both the 16g and 2g accelerometers have rougly the same resolution (16-bit vs. 15-bit, respectively according to the company's website), wouldn't that stand to reason that the accuracy of the 2g model would be better (for the range of 0-2g, that is)?
2008 MS3 GT
2016 MX-5 Club
Mauro_Penguin (04-13-2015), phate (04-12-2015)
 Old 04-12-2015, 07:36 AM   #345
Eth Fiend
phate's Avatar
Yes, the resolution is much better with the 2g unit for the reasons nliiitend1 said. They also said there was less noise with the 2g unit.
I did a rough test of it by putting it inside a box and turning it on all sides. Everything registered near 1g, so the device is working properly (not a perfect test, obviously, just something to make sure it wasn't giving drastically wrong info). We put it on Johanna's MS3 yesterday for ~20 runs, logging at 128Hz. I'll have to write some code to trim the logs, but the data looks good.
Today is test and tune, and I'll do a set with the current -2° camber up front, then change from there. Probably see what full negative does (should be around -3°), and maybe an in between setting if time allows.
Totally accurate, but from -2 to 2, and -16 to 16
-06 MS6
KevinK2 (04-12-2015), Mauro_Penguin (04-13-2015), Nliiitend1 (04-12-2015), wolly6973 (04-12-2015)
 Old 04-13-2015, 05:18 AM   #346
Eth Fiend
phate's Avatar
I have done ZERO analysis on the accelerometer data logs. I had a couple minutes this morning, so I trimmed one and plotted lateral and lineal accel over time. Looks promising.
Axis orientation, for reference:
-06 MS6
Code Monkey (04-13-2015), Crarrs (04-13-2015), KevinK2 (04-13-2015), Mauro_Penguin (04-13-2015), Nliiitend1 (04-13-2015)
 Old 05-09-2015, 04:06 PM   #347
Eth Fiend
phate's Avatar
Wrote a bunch of code for accelerometer data analysis. I'll do a full write up of how I'm generating these graphs if anyone is interested. These are showing the average total acceleration every 5° (+- 2.5° of every 5°, starting at 0°), along with the standard deviation at that angle.
Edit: These are your typical g-g diagrams where braking is +y direction and turning left +x direction.
Prior to changing the alignment:
After adding negative camber in the front end:
Johanna driving the car:
I think my next step is to do some averaging between runs of the same driver/setup and compare from there.
-06 MS6
Code Monkey (05-09-2015), Crarrs (06-09-2015), KevinK2 (05-09-2015), Mauro_Penguin (06-08-2015), Nliiitend1 (05-10-2015), Tomas (06-07-2015), zenit (05-11-2015)
 Old 06-06-2015, 11:23 AM   #348
Eth Fiend
phate's Avatar
I autocrossed the 6 last Sunday without any suspension changes made from the last time. I did, however, realize the week before that when we swapped the turbo a couple months ago that I hooked up the boost controller wrong and I was only getting spring pressure I so rarely go full throttle except at autocross that I never noticed. Needless to say, running double the boost pressure makes the car feel really fast again, haha.
The course was exceptionally fast. I was in third gear probably more than 70% of the course with only 1 downshift to 2nd for a 180° turnaround pivot cone. My driving wasn't the tidiest and I managed to only get 1 clean run - my slowest run of the day. My fastest run was another 1.3s faster than my clean run, and I think it is within reason to say it was achievable had I been driving a little better. But, that 1 clean run was good enough to take the class by a little over .7s.
I ended up 6th overall, and had I driven that fast run cleanly it would have put me 2nd overall. We'll see in a week whether it was a fluke or not (haha).
Accelerometer data showed that I was trail braking slightly more, but I need to work on it more.
It was my nephew's first time at an autocross so I had the camera pointing backwards to get his reaction. It's too bad he had the visor down (he's in runs 1, 2, and 5). Run 3 has a pretty good reaction, but the camera died just a little ways in. Run 4 is our very own @zenit;! It also shows me that I'm still a little choppy with the steering at some points. And take a look at the seat movement!
-06 MS6
Code Monkey (06-06-2015), Funkster777 (06-08-2015), ItsNox (06-08-2015), KevinK2 (06-06-2015), MSP611 (06-08-2015), Nliiitend1 (06-08-2015), TiGraySpeed6 (06-08-2015), zenit (06-07-2015)
 Old 06-08-2015, 04:52 AM   #349
MSP611's Avatar
What are u usually racing against in the class u r in?
Also what is Ur harness mounted to? U have a harness bar?? Is there any harness we can get and mount without a harness bar?? Like something with longer straps we can mount to the floor or something?
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
phate (06-08-2015)
 Old 06-08-2015, 06:51 AM   #350
Crarrs's Avatar
Groans: 98
Schroth Rallye 3 and Rallye 4 are made for exactly that purpose. I just sold mine here last month. It works very well.
2004 MSM TiGrey
The Following 2 Users Say Thank You to Crarrs For This Useful Post:
Mauro_Penguin (06-08-2015), phate (06-08-2015)
 Old 06-08-2015, 07:01 AM   #351
ItsNox's Avatar
Posts: 3,076   (View Stats)
ItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the world
http://youtu.be/y7miouPPn0o
Were his under-titties sweaty after the run? I know how he feels. Except we were on the side of a mountain! Look at his fist all clenched and holding on for dear life to the handle and trying to wedge himself in there in that la-z-boy no-support passenger seat.
OH FUN TIMES CANT WAIT TO DO IT AGAIN
'06 Mazdaspeed 6 GT
Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella
Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings
Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s
Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth
- Miltuned
On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.
Georgia Motherfucking Nator
Originally Posted by Ziggylittles View Post
I hate that you can sleep on suckas and then make rape with your family sedan
ItsNox is offline   Reply With Quote
The Following User Says Thank You to ItsNox For This Useful Post:
phate (06-08-2015)
 Old 06-08-2015, 07:15 AM   #352
Eth Fiend
phate's Avatar
My class typically consists of muscle cars (mustangs - including the new 5.0, camaros). It includes the AWD "boost buggies" - WRX (non-STi) and DSM's - but they rarely run this class in my region. We're allowed to run DOT RComp tires, so the muscle car guys have mostly gone to the 315 or 335 wide Hoosier A6. The competition has gotten pretty serious in this class, locally. 2 years ago when I was considering the switch the class was pretty soft. I think a few of us noticed and made the switch all at once and it's made for some great competition and typically the biggest class to compete in.
The harnesses:
Last year I borrowed @naoandlater;'s Schroth Rallye Cross 4 point harness (this one). I REALLY liked this harness and hated having to give it up. The mounting tabs are bendable and work great.
I'm currently running a Corbeau 4 point harness (this one) that I bought as a replacement for the Schroth. This harness is less than half the price of the Schroth and looked to be a good alternative. The mounting tabs are ~1/8" steel and pretty short, so impossible to bend by hand. They make it a little more of a pain to mount everything, but it's doable.
Both harnesses mount similarly, but like I said the Corbeau tabs make it a pain. For the Schroth I used the two rear seat bracket bolts of the front seat to mount the lap belt (going into the chassis tub). The bendable tabs make this possible. For the Corbeau, I'm using the lower mounting point for the front seat seat belt to mount the lap belt's left side, and the rear seat bracket bolt to mount the right side (same as Schroth). The shoulder harness mounting points are the same between the two - I'm using the rear seat belt lower mounting points directly behind the driver.
Both of the harnesses let you push the belt out of the way onto the rear floor and let you keep the 3 point functionality for DD use. I'm really leery of using 4 points on the street, even though both say they are DOT approved (The Corbeau harness came with a letter stating this, I can't seem to find the approval on their site).
I've looked into the harness bar in conjunction with lighter seats (true racing seats need a mounting point behind the shoulders). I asked a racecar fab shop how they would go about it and what it would weigh and for me it doesn't seem worth it. It would likely end up in a net gain of weight, even with super light racing seats (carbon fiber craziness).
-06 MS6
InkedInspector (06-16-2015), Mauro_Penguin (06-08-2015), MSP611 (06-08-2015), naoandlater (06-08-2015), Nliiitend1 (06-08-2015)
 Old 06-08-2015, 07:27 AM   #353
No freaking way you would gain weight with a harness bar, the driver power seat is like 65 lbs IIRC.
2006 Mazdaspeed6
2017 Subaru BRZ
ItsNox (06-08-2015), Mauro_Penguin (06-08-2015), phate (06-08-2015)
 Old 06-08-2015, 07:35 AM   #354
Eth Fiend
phate's Avatar
The Sport driver seat is 45lb and the passenger seat is 41, total of 86. Figure the lightest carbon fiber seat with padding weighs 10lb each, plus brackets and hardware for 15lb each (guessing on bracket weight). That's 30lb for the two, leaving only 56 lb for a 4 point bar.
Aluminum racing seats weigh more and eat into that margin.
-06 MS6
Code Monkey (06-08-2015), Mauro_Penguin (06-08-2015), xfeejayx (06-11-2015)
 Old 06-08-2015, 07:36 AM   #355
MSP611's Avatar
The harnesses:
Great fuckin info @phate;
I'm really interested in the harnesses for hard canyon driving etc etc plus I kind of like the look. In the current format u have them mounted (corbeaus or rallye), do the belts get in the way of the passengers leg room or make any fuss? Did u change the mount bolts u used for longer ones on the brackets??
In progress:
 Old 06-08-2015, 07:40 AM   #356
Eth Fiend
phate's Avatar
I rarely have back seat passengers, but I can imagine they would be stepping on the harness.
The Schroth doesn't require any new or different hardware. Stock bolts are sufficient because the tabs are pretty thin. The Corbeau harness does require longer bolts, but they are supplied with the harness.
-06 MS6
 Old 06-08-2015, 07:42 AM   #357
MSP611's Avatar
Hmmm well thts shitty lol Damn backseat passengers... I don't really drive with them either and don't like to in a matter of fact. All my friends think I'm weird for having a sedan and not liking to drive people lol.
In progress:
The Following 2 Users Say Thank You to MSP611 For This Useful Post:
 Old 06-08-2015, 07:54 AM   #358
Eth Fiend
phate's Avatar
Here's the usual mess.
-06 MS6
 Old 06-08-2015, 08:12 AM   #359
MSP611's Avatar
Could u tuck it under Ur seat lol??
In progress:
phate (06-08-2015)
 Old 06-08-2015, 09:08 AM   #360
KevinK2's Avatar
Just a brief complement on your smooth driving style, and looking ahead on the course. I can see it from your normal videos, and this one with the camera facing the driver and passenger. Is that an ugraded turbo? It's amazing how you can stay in 3rd and still pull out hard from some slow corners.
Who was the passenger in run 3 ???
Back in history when I competed for class titles, I also had close competition, that I beat by tenths. I had plotted all the time differentials, and found I had a significant gain after spending a day running HSDE's at Summit Point's 2 mile road course.
From Delaware
phate (06-08-2015)
« sway bar shifting | - »
Shocks for a daily driven Mazdaspeed 6 This thread Refback 12-05-2015 09:07 PM
Whats New/General Speed 6 Discussion - Page 296 This thread Refback 11-29-2015 05:42 PM
fe1rx Ohlins Installation - Page 7 This thread Refback 08-23-2015 04:39 AM
fe1rx Ohlins Installation - Page 6 This thread Refback 04-25-2015 01:24 PM
Prepping as dedicated track car - Page 56 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-21-2015 12:36 PM
BC coilovers VS. H&R coilovers - Page 15 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 08-26-2014 07:50 AM
Whats New/General Speed 6 Discussion - Page 297 This thread Refback 07-28-2014 08:03 PM
racing aspirations » Suspension Geometry Calculator This thread Refback 06-21-2014 02:57 AM
Prepping as dedicated track car - Page 50 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum Post #48 Pingback 03-14-2014 12:36 PM
Prepping as dedicated track car - Page 46 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-20-2014 11:02 AM
Suspension/combo or coilovers?? gurusev 2010 MS3 - Suspension & Brakes 35 07-31-2013 10:06 AM
BC Coilovers or Bilstein Dampers/H&R Springs Bleupit80 MazdaSpeed 3/6 - Suspension & Brakes 6 02-12-2013 06:35 AM
BC BR Extreme Low Coilovers vs KSport Kontrol Pro Coilovers Doberman MazdaSpeed 3/6 - Suspension & Brakes 9 07-28-2012 07:35 AM
Suspension Techniques Coilovers? asiandude74 MazdaSpeed 3/6 - Suspension & Brakes 6 02-05-2011 11:15 PM
MSD Dashhawk Data Logger Data Base JimmyMac MazdaSpeed 3/6 - ECU Computer Tuning 2 06-30-2008 09:43 AM
Page generated in 0.76569 seconds with 30 queries
