Like Tree4Likes
  • 2 Post By rymanmazda
  • 1 Post By DVM17
  • 1 Post By Vansquish
 Old 06-10-2014, 12:25 PM   #1
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,798   (View Stats)
Default MS6 Whiteline RSB The Shit It is Not
Although it appears quite a few people have installed Whiteline RSBs on MS6s without issue, this was not the case on mine. This thing must have been bent by an inebriated lesbian or someone with something resembling the true meaning of gross incompetence.
This RSB will hit the opening of the LCA no matter how you position it. It is about 1/2" to 3/4" wider between extension arms than the stock RSB. In addition, it is about a full inch longer on one side than then other. If you think you are going to get something even close to a balanced set up with this thing you might as well ride a lawn mower.
I tried fixing it by drilling holes and grinding away but at the end it's just better I throw the thing in the trash. Shipping it back to vendor on my dime is not worth the money or trouble.
TL Dr. Whiteline is shit don't buy.
Side to side difference in length.
Fail
MAKE LOVE TO THE CANVAS
Code Monkey (06-10-2014), theschrum (06-10-2014)
 Old 06-10-2014, 12:42 PM   #2
Code Monkey's Avatar
Posts: 7,671   (View Stats)
I will be experimenting with disconnecting the RSB at the track, if I like it, the bar will be removed for good.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
Tomas (06-11-2014)
 Old 06-10-2014, 12:50 PM   #3
rymanmazda's Avatar
Posts: 1,531   (View Stats)
rymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the worldrymanmazda is the leader of the world
Groans: 122
Groaned at 4 Times in 2 Posts
The problem is that Whiteline RSB is really the only option for us MS6 guys.
2006 BCM Mazdaspeed 6 GT w/navi
Freektune: 400whp/387awtq
Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18
-Autocross Setup-
17x8 +38, BF Goodrich R1 225/45/17
Other Rides:
2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013)
1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it.
1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father)
1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD)
rymanmazda is offline   Reply With Quote
 Old 06-10-2014, 01:04 PM   #4
Big Dog's Avatar
Posts: 730   (View Stats)
Big Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the world
Groans: 89
This is disappointing. I have one on the shelf to install........Fuck. I guess I'll be inspecting it tonight.
Big Dog is offline   Reply With Quote
 Old 06-10-2014, 01:11 PM   #5
scubasteve711's Avatar
Posts: 1,238   (View Stats)
scubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the world
ugh not pleased to hear this...
@Code Monkey did you change the spring rates in the rear?
07' Speed6 Velocity Red Mica
Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP
Anti break stuff: Upper Rear Diff Brace, RMM
Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod
scubasteve711 is offline   Reply With Quote
 Old 06-10-2014, 01:47 PM   #6
Will be running 1000 lbs in the front, 600 lbs in the rear.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 06-10-2014, 01:53 PM   #7
Police - Grammarhead
Vansquish's Avatar
Groans: 1,869
Strictly speaking, that's not accurate.
Corksport sells one too, but it's not adjustable.
That said, I've got a CP-E rear diff mount, and a Whiteline RSB sitting in my closet waiting for me to work up the chutzpah to install them, and when I get home from work today, I'm going to measure the shit out of the RSB.
 Old 06-10-2014, 02:35 PM   #8
rymanmazda's Avatar
Groans: 122
True!
This was going to be my next purchase but now I don't know what to get.
Also, If you need any help with installing that rear diff mount, HMU and I'll try my best to help over the internet! I've had to install and uninstall one 3 times. It takes me all by myself about 4 hours.
Vansquish and ItsNox like this.
-Autocross Setup-
Other Rides:
The Following User Says Thank You to rymanmazda For This Useful Post:
Vansquish (06-10-2014)
 Old 06-10-2014, 02:58 PM   #9
speedtoz's Avatar
Posts: 453   (View Stats)
speedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the world
I have a white line rsb. Kinda scared now. Lol
^^^My fail boats^^^
2006 mazdaspeed 6: fujita CAI, PG TIP, Turbosmart dual BOV, ITV22, Corksprt TBE, Cobb AP, SURE front/rear diff mounts(FTW), whiteline RSB
1978 280z(s30): currently needs some love....and going turbo o.0
1990 300zx: 850cc injectors, 300degree fuel rail, aeromotive FPR, garrett gt 28's twin turbo upgrade(@19psi), stillen IC's, CZP's 3in dp and mid pipe, Selin dual intakes, GTR R32 brakes, Nismo clutch, HKS hi-power exhaust, megan coil-overs, SPL full titanium suspension parts, z1 boost tubes, 2 AEM AFR's, AEM boost guage
RWHP:???? RWTRQ: 475@4500 rpm. needs new clutch(blown).
2008 350z HR: Greddy dual Ti-C, Carbonetics LSD, Nismo diff, GTM TP's, Stillen CAI's
(waiting on full metal CSC and carbonetic clutch and light wieght flywheel, then it's TT time!) currently on hold due to needing new clutch and flywheel/metal csc and master. wanting skyline manifold.
speedtoz is offline   Reply With Quote
 Old 06-10-2014, 03:05 PM   #10
ms6mil's Avatar
Posts: 4,972   (View Stats)
ms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the world
Groans: 307
Groaned at 6 Times in 6 Posts
I thought Corksport stopped selling the RSB for the MS6. I haven't seen it on their interwebz for a while.
@Tomas; will the lower profile RSB bushings that you chimed make any relevant difference in clearance? Or would the mm's be neglible?
ms6mil Rear Axle Breakdown
"Here am I. Send me!"
____________________________________________
Columbus, GA 2006 MazdaSpeed 6
EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel
GT3076 - 393/380 3/9 e85
GT3076 - 426/400 E85/DO10 Meth
PTE5862 - TBD
ms6mil is offline   Reply With Quote
The Following User Says Thank You to ms6mil For This Useful Post:
Tomas (06-11-2014)
 Old 06-10-2014, 03:44 PM   #11
6erforlife's Avatar
Posts: 48   (View Stats)
6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of6erforlife has much to be proud of
I've got one sitting in my room waiting for install as well. This is the first I've heard of such a problem and I've been perusing the forums for awhile now. On 6club, all the old OG's used to praise the whiteline sway bar for how much of a difference it makes to the car
Liquid Platinum 07 Speed 6 #10177
JBR 80duro RMM, Sure Juggernaut, Sure Dreadnaught
GTX3071, Cobb AP, HTP3.5" Intake, Streetunit TMIC, M2 DP, TurboSmart BOV, Grimmspeed EBCS, AT Internals, GP Werks BSD & Baffle, Denso ITV22, TWM Stage 2, Dashhawk, JBR OCC, JBR TB TIG, SURE IM TIG, VTCS Delete, Ford Transit Oil Filter Conversion, Clean Valves!
LED tail lights, 20% tint, EVO X rims and VG Sharkfin
Big Turbo baby!
6erforlife is offline   Reply With Quote
 Old 06-10-2014, 04:00 PM   #12
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Ah well, at least the stabilizer bars are really easy to take in and out of the rear.
MINI H1 6.0 - CAR LED TAILS
Tomas (06-11-2014)
 Old 06-10-2014, 05:00 PM   #13
aviator79's Avatar
Posts: 3,925   (View Stats)
Groans: 67
Im confused, it has been know that the "adjustablity" does not work, that you have to bolt to the stiffer setting and you have to cut the end off so they do no hit. Did you run it without doing that and that is why it is bent or? if that is the case the thing is junk to bend that easily.
When I got mine I bought the non adjustable one which did not exist but was cheaper so they sent the adjustable one, I cut off ends and it fits. I will have to go back to 6club to find more info but the fact that yours is out of wack I cannot explain as must be a manufacture defect or ??? Do you have it mounted in the bushings w/ brackets on the floor when you are measuring?
Did you buy it new? or off a car that was totaled? (just asking...)
Issue is it is so tight up there after diff mount that making one fit has to be perfect. There is also the issue of keeping it center where someone mentioned xyz hose and hose clamps IDK...
Tomas (06-11-2014)
 Old 06-10-2014, 05:28 PM   #14
LaraS's Avatar
Posts: 1,369   (View Stats)
LaraS is the leader of the worldLaraS is the leader of the worldLaraS is the leader of the worldLaraS is the leader of the worldLaraS is the leader of the worldLaraS is the leader of the worldLaraS is the leader of the worldLaraS is the leader of the worldLaraS is the leader of the worldLaraS is the leader of the worldLaraS is the leader of the world
Groaned at 137 Times in 134 Posts
That's bizarre. I installed a Whiteline RSB on my MS6 only 3 months ago..no issues, no modification needed.
2007 Mazdaspeed6 - SOLD =(
LaraS is offline   Reply With Quote
 Old 06-10-2014, 05:42 PM   #15
aviator79's Avatar
Groans: 67
A new one? They may have finally changed the design as its been 6 years...
rymanmazda (06-10-2014)
 Old 06-10-2014, 06:12 PM   #16
Big Dog's Avatar
Groans: 89
I bought mine from RPM at the end of April. So mine is fairly new. I should have time to install it and the diff mount in a couple weeks.
 Old 06-10-2014, 06:53 PM   #17
aviator79's Avatar
Groans: 67
Just take a pic of it. I do not think they changed the design. But how @LaraS; would not cluck if she had not cut the ends off IDK as she is lowered and that makes it worse.
... Do you have it mounted in the bushings w/ brackets on the floor when you are measuring?
had to look at a pic to see that this would/could not be issue. Did you order nascar version?
Last edited by aviator79; 06-10-2014 at 06:53 PM. Reason: MSF Database - Automerged Doublepost
Tomas (06-11-2014)
 Old 06-11-2014, 05:53 AM   #18
Bob Ross Fanclub
Tomas's Avatar
The bar was bought new.
The measurements were taken with the bar flat on the floor. You don't need to hold it down with brackets in the position the pictures were taken.
Yes, if you just cut the ends of the bar and shave off some of the material on the lower part of the flat spot where the links connect to you can clear the bar hitting the LCA. But even then, at least in my case, the link was so far to the back in the "hard" setting of the bar that the upper hem joint of the link would hit the opening in the LCA. That's due to the much longer (about 1") arm on the driver's side as opposed to the passenger side as pictured in the OP.
The OEM bar does not have stops on it to keep it from moving side ways. I don't think the hose and clamp trick to keep it centered is needed.
Also, I think Racingbeat makes a sway bar combo for the MS6. Not sure if it's a 24,mm bar or what in the rear.
The bushings will help a little bit but not much. The clearance part on the bar is fixable its just a pain in the ass. Just overall shoddy workmanship.
Don't even know what the Nascar version is?
Last edited by Tomas; 06-11-2014 at 05:54 AM. Reason: MSF Database - Automerged Doublepost
ms6mil (06-11-2014)
 Old 06-11-2014, 06:02 AM   #19
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
nascar version is a joke about offset for turning left.....
340hp / 371tq
Tomas (06-11-2014)
 Old 06-11-2014, 07:20 AM   #20
Eth Fiend
phate's Avatar
Posts: 6,935   (View Stats)
That sucks. Guess I should measure mine, because it was installed before I started assuming all parts made for the MS6 are fucked up and it'll either need tweaked, ground down, or I'll just have to make my own version of it.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 06-11-2014, 07:31 AM   #21
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
@jbarone;
stop being a cunt
Monotonous ONE is offline   Reply With Quote
The Following 2 Users Say Thank You to Monotonous ONE For This Useful Post:
Mauro_Penguin (06-11-2014), SpeedRebirth (06-12-2014)
 Old 06-11-2014, 09:01 AM   #22
LaraS's Avatar
Yeah I bought it brand new in January. I'll take photos of it this weekend.
 Old 06-11-2014, 09:06 AM   #23
5LOWMS6's Avatar
Posts: 1,088   (View Stats)
5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world5LOWMS6 is the leader of the world
Groans: 46
Groaned at 37 Times in 19 Posts
I've been getting a weird clunk from the left side only since I've put my coilovers on, I now have a better idea on where it's coming from. The problem is it clears the lca when the car is on jacks. I just hope my rsb isn't completely fucked like yours OP.
On a side note, it did make a huge difference on stock suspension and it wasn't hitting the LCA even on hard bumps.
Is it possible to measure those ends while it's installed? I'll be taking a look at it this weekend and I'll post some pictures for reference.
06 Liquid Platinum GT
COBB AP // 3" ID MAF // 3" HTP TIP // Ebay catless DP // Autotech FPI // DO DVC-30 w/D07 // Grimmspeed EBCS // FORGE V1 BPV // DM OCC // JBR SSP|TIGs|EGR- // SURE RMM|Juggernaught // CP-E TMIC|Rear Diff Mount // Whiteline RSB // ISC N1 Coilovers // 18x8 +45 TSW Nurburgring
MisterSix Tuned..
vdyno: 287hp/335tq Uncorrected (2400ft ASL) 303hp/355tq Corrected
5LOWMS6 is offline   Reply With Quote
The Following User Says Thank You to 5LOWMS6 For This Useful Post:
Tomas (06-11-2014)
 Old 06-11-2014, 10:04 AM   #24
Bob Ross Fanclub
Tomas's Avatar
You can get an idea on difference in arm length by looking at how the rods on the links sit inside the LCA.
Last edited by Tomas; 06-11-2014 at 10:05 AM. Reason: MSF Database - Automerged Doublepost
 Old 06-11-2014, 11:04 AM   #25
Big Dog's Avatar
Groans: 89
I would be interested in your findings. I am going to stick with stock suspension pretty much indefinitely. I only wanted the RSB to even things out. Did you find it did this quite well? I'm wondering if the issue is more common with lowered or heavily modified suspension cars. Keep us posted.
 Old 06-11-2014, 11:15 AM   #26
Big Dog's Avatar
Groans: 89
Double post - stupid phone.
 Old 06-12-2014, 07:12 AM   #27
JBR
JBR's Avatar
Posts: 6,615   (View Stats)
Groans: 28
Originally Posted by Monotonous ONE View Post
@jbarone;
stop being a cunt
What the heck did I do?
JBR is offline   Reply With Quote
 Old 06-12-2014, 07:17 AM   #28
He probably wants you to make us a swaybar?
 Old 06-12-2014, 07:27 AM   #29
JBR
JBR's Avatar
Groans: 28
I kinda figured...lol.
Not going to happen<-----No way to sugar coat it either, sorry.
 Old 06-12-2014, 07:36 AM   #30
SpeedRebirth's Avatar
Posts: 685   (View Stats)
SpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the world
Groans: 33
Billet Aluminium MS6 Swaybar coming soon right? Or we'll pick your bone... Pricetag: 1k
Mazdaspeed6 -06
Tuned with by Alex@Stratified
CP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP
Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation
Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit
JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2
Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025
Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp
Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter
Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
SpeedRebirth is offline   Reply With Quote
The Following User Says Thank You to SpeedRebirth For This Useful Post:
JBR (06-12-2014)
 Old 06-12-2014, 08:14 AM   #31
Groans: 819
You're just being coy.
Its probably in development and you dont want to talk about it. I understand.
The Following User Says Thank You to Monotonous ONE For This Useful Post:
Tomas (06-12-2014)
 Old 06-12-2014, 09:17 AM   #32
Groans: 33
The package you talk about must have an error in the description.
Looked at Racing Beat's website and they have the front bar that fits both M6 and MS6. But the rear is only compatible with FWD.
Sway Bar Package
"Racing Beat - 28.5mm (1.125") Front, 27mm (1.0625") Rear (Both bars utilize solid tubing.)"
Sway Bar - Rear
"This bar is not compatible with the MazdaSpeed6 models, the rear bar for the MazdaSpeed application features a large U-shaped bend in the center of the bar to clear the AWD components."
Mazdaspeed6 -06
290 AWHP / K04
Tomas (06-12-2014)
 Old 06-12-2014, 09:57 AM   #33
DVM17's Avatar
Posts: 1,283   (View Stats)
DVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the world
Groaned at 25 Times in 6 Posts
I think this is the only time I don't blame JBR for not making us a RSB. Have you seen that thing? ugh... bends on bends on bends.
Jamie be like:
On a side note, kind of related, don't try to upgrade your axles without doing at least something to your rear sway bar (stock or not)
My brand new dss axle just tore it's boot. stock swaybar and all
JBR likes this.
2006 Mazdaspeed 6 (Titanium Gray) : Built, gtx2867r Purple Drank tuned
12.07 @ 116 on 205 snow tires
hunting for 11's on 245's
DVM17 is offline   Reply With Quote
The Following User Says Thank You to DVM17 For This Useful Post:
JBR (06-13-2014)
 Old 06-12-2014, 10:03 AM   #34
Vansquish's Avatar
Groans: 1,869
So...SO tempted to groan this, but can't bring myself to do it...
JBR likes this.
The Following 2 Users Say Thank You to Vansquish For This Useful Post:
JBR (06-13-2014), scubasteve711 (06-12-2014)
 Old 06-16-2014, 10:49 AM   #35
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Well you guys could pester @CorkSport; to bring theirs back into production. I love mine and the fitment is 100% on it.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 06-16-2014, 12:50 PM   #36
Big Dog's Avatar
Groans: 89
We have been pestering them about MS6 parts in general. Just about everything they make that is MS6 specific is no longer available and is always out of stock. I'm kind of giving up.......
The Following 2 Users Say Thank You to Big Dog For This Useful Post:
leo766 (11-03-2016), rymanmazda (06-16-2014)
Whiteline RSB + Dreadnaught? LilGator MazdaSpeed 3/6 - Suspension & Brakes 20 12-17-2012 06:22 PM
Whiteline Sway Bar Help! Goldenboy Mazdaspeed3/6 General Discussion 13 09-23-2012 05:27 PM
Page generated in 0.56701 seconds with 39 queries
