 Old 04-14-2017, 09:36 PM   #1
Analytical's Avatar
Posts: 33   (View Stats)
Analytical is on a distinguished road
Groaned at 6 Times in 2 Posts
Default Mazdaspeed coil over in the rear side specific?
Curios if they are & if so should the Mazda speed sticker face the front or rear of car.
Tricks get applause, style gets respect.
Analytical is offline   Reply With Quote
 Old 04-18-2017, 07:41 PM   #2
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
Yes, if you want to be able to easily adjust the compression.
Read the install manual posted in your other thread.
Alignment of the front coil over once seated
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
The Following User Says Thank You to ibcrusn For This Useful Post:
Analytical (04-20-2017)
 Old 04-20-2017, 09:25 PM   #3
Analytical's Avatar
Thank you ibcrusn
 Old 04-21-2017, 12:55 AM   #4
mituc's Avatar
Posts: 3,340   (View Stats)
In the rear you have a spring and a damper. They are not side specific, only the front struts are because of the tabs and eventually the spring seat (which in the rear is built into the low control arm).
2008 Cosmic Blue Mazda 3MPS
Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PSS 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend ENduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit
JBR Tru-3" + CS CAI Box, SU TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071, CS 3.5BAR, Guardian Angel, CoolingMist WMI
StratiVersaTuned FTW
mituc is online now   Reply With Quote
Analytical (04-23-2017)
The ATP Mazdaspeed Specific Exhaust Housing Info socks MazdaSpeed 3/6 - Turbo Induction 16 10-21-2008 02:34 PM
Page generated in 0.27069 seconds with 22 queries
