| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() | | #1 | ![]() |
![]() Join Date: Aug 2011
Rep Power: 0 ![]() ![]() Thanks: 0
Groaned at 13 Times in 5 Posts
(Thread Starter) | Not Ranked : 0 score Okay, everytime I shift from 1 - 2 - 3 I get a clunk noise in between every gear WHEN the clutch is pushed in, it does not happen if I lift of throttle and not push the clutch in. It sounds like it's coming from the front or the middle ish? Very irritating and stopping me from driving hard because I'm scared of something falling out. If I WOT in between these gears, the clunk is EXTRA LOUD!! very noticeable to people that drive beside me. Could this be the transmission mount failing? |
![]() Join Date: Nov 2010 Location: Houston Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,693
Groans: 190
Groaned at 59 Times in 42 Posts
Check the rmm could be that, pull it out and look to make sure
__________________ ~2011 Liquid Silver MS3~ ![]() TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
| The Following User Says Thank You to SWAY For This Useful Post: | Post pwned (09-25-2011) |
| Harvestor of PU ![]() Join Date: Jun 2011 Location: in the snowy mountains of narnia
Rep Power: 919 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,905
Groans: 170
Groaned at 25 Times in 20 Posts
likely your RMM
__________________ 2012 BM MS3 w/ tech. No bolt ons. self tuned. |
| The Following User Says Thank You to Harvey PU For This Useful Post: | Post pwned (09-25-2011) |
![]() | | #4 | ![]() |
Groans: 190
Yup just happened to me my bushing was fucked I had to pull it out to see I'm back on the stocker
![]() | | #5 | ![]() |
![]() Join Date: Jul 2010 Location: Illadelph,PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,199
Groans: 53
Groaned at 16 Times in 12 Posts
In b4 dropped bolt.
__________________ 2010 Mica Black Stock tune !JBR: RMM Shifter bushings RSB CORKSPORT: SRI+TIP. |
![]() | | #6 | ![]() |
RMM and REM is the same thing right? If so, it is fine and it was only installed last week as well. At first it was torqued at 65 ft lb. And I got the clunk, so I was thinking it was the RMM, torqued to 80 ft lb. Still getting the clunk. |
![]() | | #7 | ![]() |
![]() Join Date: Mar 2010 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,981
Groans: 120
Groaned at 154 Times in 77 Posts
RMM is rear motor mount, REM is a shitty band IMO (in my opinion) Can't hurt to pull it off and check it again takes like 15mins. Maybe u need to change ur tranny fluid? No idea what car you're driving or your mileage. Any clunk would be a motor mount like previously said the trannies on these cara are extremely stout I'd highly rule against it being a transmission problem
__________________ 2003 TB Evo VIII Big turbo, injectors, intercooler and stuff. 448whp 373trq 25psi 93oct. Speed Density Converted ![]() Old: 2009 White MS3 GT. Fully bolted and tuned. Sold |
| The Following User Says Thank You to 4G63 For This Useful Post: | karl-hungus (09-26-2011) |
![]() | | #8 | ![]() |
Its a MS6, 59,xxx KM I did just pull it off today, looks like how I bought it except for some small scratches from install. Someone told me it could be the other mounts.. like driver and passenger side that are failing. And I was just asking to see if anyone actually thought so |
![]() | | #9 | ![]() |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2811 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
take out your battery box and inspect the tranny mount. bet the latter is ripped. oh, and have some rem or coldplay playing in the background. Coldplay honors R.E.M. at Music Midtown | Atlanta Music Scene
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
![]() | | #10 | ![]() |
Lol what.... Yeah I'm going to have a look, no idea where it is though... |
![]() | | #11 | ![]() |
![]() Join Date: Mar 2011 Location: Charlotte, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,164
If you are extra sure it's not your RMM (and you really do need to take it out to check the bushing) then I'd suspect the tranny mount (drivers side below the battery box.) It will take a bit to get to it, but there is some good disassembly advice here: How to: Install TRZ Transmission Mount Check the bolt for tightness to torque spec. Check for ripping around the sides of the rubber (there is supposed to be a small gap on each side, but check for tears going away from those points. If possible, take a light and a camera and check the distance and connection from the mount bolt to the mount point, noted in the copied pic below. Ensure there is no gap. You can jack the engine up just a bit from underneath to see if you get movement of the mount or bolt when the weight shifts off the chassis. |
| The Following User Says Thank You to Skipper For This Useful Post: | speedtown (09-27-2011) |
![]() | | #12 | ![]() |
Is that on a 3? It doesn't look like a 6 at all.. And how do I know if the bushing on my RMM is stuffed? Will it be ripped or...? I tried looking for the tranny mount yesterday... don't know where it is |
![]() | | #13 | ![]() |
Groans: 74
![]() | | #14 | ![]() |
| Not Ranked : 0 score |
![]() | | #15 | ![]() |
![]() Join Date: Jul 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
I think my tranny mount is failling also... Any word on your issue? I am a speed 6
__________________ 2006 Mazdaspeed 6 Red - GT3076R - sadly sold and missed LSA supercharged Caddy CTS-V stealth gray-current Waiting for the speed2 to come out for my daily driver |
![]() | | #16 | ![]() |
![]() Join Date: Dec 2009 Location: Chitown
Rep Power: 1463 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,818
Groaned at 66 Times in 49 Posts
Do yourself a favor and get a TT Front Engine Mount to compliment your replaced RMM. They're the only two mounts you'll need on that engine IME. Solid and quite tame on vibes once broken in. If your trans mount happens to be shot from the process, just replace it with a stocker if it's your DD IMHO. Good luck.
__________________ PERM Tuned - EFR 7163 Street Sleeper ![]() |
![]() | | #17 | ![]() |
![]() Join Date: Nov 2010 Location: Cortlandt Manor, New York
Rep Power: 150 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 123
![]() | | #18 | ![]() |
| Not Ranked : 0 score Like I said, it's very mild and the MOST tame solution for the MS6 IME.
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
![]() Join Date: Mar 2008 Location: Jacksonville, NC
Rep Power: 2288 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 797
Groans: 46
Groaned at 16 Times in 11 Posts
| Not Ranked : 0 score I swear I had less vibration with the TT front mount and my CP-E RMM, than I had with just the Cp-E RMM..
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks |
![]() | | #21 | ![]() |
__________________ PERM Tuned - EFR 7163 Street Sleeper ![]() | ||
| TRZ Transmission mount | thenewzolt | 2010 MS3 - Engine, Transmission & Driveline | 20 | 03-20-2011 10:36 PM |
| is transmission mount the same as motor mount? | spoonher | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 08-26-2009 01:21 PM |
| MS3 Transmission Mount Solution!!! NEW MOUNT! | ptperformance | Mazdaspeed3/6 General Discussion | 135 | 01-19-2009 01:41 PM |
| TRZ Transmission Mount Now Available | CaptainKRM | Mazdaspeed3/6 General Discussion | 56 | 12-05-2008 11:09 PM |
| AWR Transmission Mount... | ATE BALLER | MazdaSpeed 6 - Engine, Transmission & Driveline | 17 | 06-26-2008 05:27 PM |
