Notices
 Old 07-01-2012, 12:19 AM   #1
opilot's Avatar
Posts: 1   (View Stats)
opilot is an unknown quantity at this point
Default rear passenger squeak.
ok i own a 06 speed 6. when i bought the care it had a faint squeak on the rear passenger wheel and it had a pattern, it scaled with the speed i was going. it also pulled to the right. so naturally i figured it just needed a brake change. i changed all 4 brake sets and noticed that they still have alot of pad left on them. the car no longer pulls to the right but the squeak is louder then ever.. if i apply the breaks they go away. if i deploy the e brake it goes away. i also washed my car after, the squeak went away for about 20 mins then came right back. i used the special tool for the rear calipers, i didnt change the rotors though. iv heard of many others with this happening to but i didnt hear of a fix for it. please hook me up with a fix haha thanks
opilot is offline   Reply With Quote
 Old 07-06-2012, 10:07 AM   #2
671 grains of reason's Avatar
Posts: 350   (View Stats)
671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world
does this happen on low speed turning as well. if so your rear diff coupler is fubar.
2006 MAZDASPEED6 // SURE R6 // SURE AEROS & TIH // COBB AP // JBR TIG // SURE ANCHORS & SHORTCUT // SURE DREADNAUGHT // WHITELINE RSB // RACING BEAT E.L. // ULTRA GAUGE // AMSOIL FLUIDS
formerly pursuit_special
671 grains of reason is offline   Reply With Quote
 Old 07-06-2012, 10:12 AM   #3
predapio's Avatar
Posts: 7,208   (View Stats)
Groans: 165
Groaned at 139 Times in 88 Posts
I had the same thing happen, my squeak was in the trunk though.
Dumb bitch that was tied up in there was kicking and screaming.
What a lovable bunch we are!!
predapio is online now   Reply With Quote
The Following 3 Users Say Thank You to predapio For This Useful Post:
671 grains of reason (07-06-2012), adlpb (07-06-2012), Raider (07-06-2012)
Squeak from rear passenger wheel hnda etr MazdaSpeed 3/6 - Suspension & Brakes 14 07-14-2012 12:47 AM
Rear brake squeak & burning smell scriccs MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 01-13-2012 10:09 AM
Rear passenger window not working JohnMS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 03-31-2011 05:38 PM
Page generated in 0.26103 seconds with 22 queries
