Like Tree15Likes
 Old 06-23-2014, 04:23 PM   #1
Code Monkey's Avatar
Posts: 7,632   (View Stats)
Default Review of Fat Cat Motorsports coilovers (Mazdaspeed6 road racing setup)
They are finally here! I plan this thread to be an on-going review of my FCM setup. Expect some pictures, some hard data, impressions from the track and street, and long-term evaluation.
First off, big thanks to Shaikh at FCM for even considering taking on this unicorn project and big thanks to @dot584; who provided his car and time to make it happen!
To recap the development process (painful details here):
05may2012 -- initial contact with FCM
06jun2012 -- dot584 brings his Mazdaspeed6 to FCM, many visits follow
20aug2013 -- dot584 gets his setup finished
23jun2014 -- Code Monkey gets his setup finished
So was it worth the wait? To quote someone from the miata.net forum "Original build schedule was 3-4 weeks. Took about 11... Once you ride on these, all will be forgiven." Hoping this will be my experience as well.
I went with the FCM Elite 3140 single-adjustables with racecar-like ride frequencies of 2.2 Hz / 2.45 Hz, which translated to 1000 lbs springs in the front and 600 lbs springs in the rear. The rears have external reservoirs for compression adjustment.
The time and money invested in the setup call for a professional install and I am going with C&C’s Northside Motors in Houston. They are one of the performance shops recommended by the local track junkies and one guy there is an instructor with The Drivers Edge so I can always ask him to drive my car at the track to evaluate the handling and tweak the suspension if needed.
I am dropping my car off tomorrow and if everything goes well I will be picking it up Friday.
But enough talk, now onto some suspension pr0n!
The coilovers arrived in two boxes:
Contents of box 1 with a hand written setup diagram:
Just looking at these springs gives me a chubby:
Another angle:
Contents of box 2:
Another angle:
And another angle:
Closer look at the external reservoirs:
Another angle:
@dot584; @phate;
@06Speed6; @6ixof1; @:: Gusto ::; @aggierandy; @blackmicamps6; @cnyms6; @CorkSport; @dale_gribble; @Easter Bunny @EyeKon; @Ingle; @ItsNox; @Jh8909; @Lakespeed6; @Nliiitend1; @S-hendrix; @sidekick; @Speed_j23; @Spencer@CorkSport; @SpICeZ; @Tomas; @TiGraySpeed6;
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
MCS coilovers|Brembo BBK|6UL 17x9|Nitto NT01|ACE 350|Delicious tuned
2000 E39 M5
2001 MR2 2ZZ
The Following 31 Users Say Thank You to Code Monkey For This Useful Post:
06Speed6 (06-25-2014), aggierandy (06-23-2014), aviator79 (06-23-2014), blackmicamps6 (06-23-2014), CorkSport (06-24-2014), cshunter (06-26-2014), dale_gribble (06-23-2014), EyeKon (06-28-2014), impossible (06-24-2014), Ingle (06-24-2014), ItsNox (06-30-2014), jack_hammer (06-28-2014), jbbuie (06-23-2014), Jh8909 (06-23-2014), Lakespeed6 (06-24-2014), m4tic (06-23-2014), Mazdazilla6 (06-24-2014), Modality14 (07-03-2014), phate (06-23-2014), Poohster (06-23-2014), S-hendrix (06-23-2014), SamiChicago (08-01-2014), sidekick (06-24-2014), stanley0910 (07-06-2014), TiGraySpeed6 (06-24-2014), Tomas (06-24-2014), torquemaniac (06-26-2014), Tyhackman15 (06-24-2014), Vader (06-24-2014), xfeejayx (07-03-2014), [R]usty (06-23-2014)
 Old 06-23-2014, 04:29 PM   #2
S-hendrix's Avatar
Posts: 1,410   (View Stats)
S-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the world
At last!! They look awesome. I cannot wait to hear your impressions once you get it on the track!
Sent from my SCH-I605 using Tapatalk
BNR S3 . FREEKTUNED . COBB FMIC . COBB CBE . SURE full 3" . CPe Safe Seals . KMD Internals . Grimmspeed EBCS . Guardian Angel . TWM Short Shifter Replacement . MSD DashHawk V2 . Turbo XS DP+RP . Turbosmart Hybrid BOV (full recirc) . JBR SSP+Bushings+Knob/ Rear Sway Bar/ Rear Camber Arms . Sure PMM/TMM . JBR EGR Delete . AWR Adjustable Front/Rear Endlinks . TRZ Dogbone RMM . Denso ITV-22 . Eibach Sport Line . Koni Yellows
S-hendrix is offline   Reply With Quote
The Following User Says Thank You to S-hendrix For This Useful Post:
Code Monkey (06-23-2014)
 Old 06-23-2014, 04:31 PM   #3
blackmicamps6's Avatar
Posts: 2,744   (View Stats)
blackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the worldblackmicamps6 is the leader of the world
Groans: 127
couldn't possibly be more jealous right now! Merry christmas to you sir!
2007 BlackMicaMPS6| MDM RMM| Forge V2 BPV|Cobb SRI| M2 Downpipe|Denso ITV22's|Cobb AP| Cobb TiP|AutoTech Internals|CP-E TMIC| MDM SSP| SPC Ball joints |Bilstein Shocks| RPM Sport springs| XCarLink MP3 Adapter| 30% window tint| Powerslot rotors| Hawk HPS Pads| Sharkfin Antenna
FreekTuned
blackmicamps6 is offline   Reply With Quote
The Following User Says Thank You to blackmicamps6 For This Useful Post:
 Old 06-23-2014, 04:33 PM   #4
Eth Fiend
phate's Avatar
Posts: 6,827   (View Stats)
Sweet. What's the top hat assembly consist of for the front?
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 06-23-2014, 04:34 PM   #5
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,458   (View Stats)
Groans: 2,978
Is the hose clamp really all that is holding on the external reservoir?
I hugged rfinkle2
bstover17 (07-04-2014), jack_hammer (06-28-2014)
 Old 06-23-2014, 04:45 PM   #6
Here's a closeup of the hand written note:
From my previous email exchanges with Shaikh I have a note that the "thread pitch is M12 x 1.25 vs the stock M10, so the upper mount will need to be drilled out."
Looks like it. They were supposed to be welded but it is possible that the shop will decide to route them somewhere else for easy access.
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
ItsNox (06-30-2014), phate (06-23-2014), stanley0910 (07-06-2014)
 Old 06-23-2014, 05:21 PM   #7
Eth Fiend
phate's Avatar
Interesting design. Moves the shock rod upward, but doesn't gain any shock travel. [Or maybe I'm looking at something wrong.]
-06 MS6
 Old 06-23-2014, 05:27 PM   #8
cnyms6's Avatar
Posts: 135   (View Stats)
cnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the worldcnyms6 is the leader of the world
looking forward to your impressions on the track
thanks for keeping after this and waiting such along time
I hope that isn't experience for everyone that uses FCM
2006 MS6 BCM
JBR SSP, CP-E RMM, CP-E Rear Diff mount, RSB, AT internals, Full Race Intake, TR8 FMIC, EGR delete, AP V3, Stratified tune, Carbotech pads, TLT springs, Bilsteins
SpeedPerformance rebuild, EFR 7163, Full Race Ex Mani & DP
Street: Conti DWS 225/50-17 on 17x7 et 45, Track: Nitto NT-05 255/40-17 on Enkei RPF1
137,000 miles of driving fun
cnyms6 is offline   Reply With Quote
The Following User Says Thank You to cnyms6 For This Useful Post:
 Old 06-23-2014, 05:32 PM   #9
aviator79's Avatar
Posts: 3,918   (View Stats)
Groans: 67
Wow, these let you catch air off speed bumps (or I guess ideally prevent that from happening). Look nice. Im just happy to be switching to konis...
 Old 06-23-2014, 05:38 PM   #10
Eth Fiend
phate's Avatar
Just the opposite, hopefully. The shock valving is designed to suck up high velocity bumps and not upset the chassis.
I'm anxious to hear your thoughts Code Monkey. I've forgotten since we talked about it - did you get KBO on one or both axles?
-06 MS6
aviator79 (06-24-2014), Code Monkey (06-23-2014), stanley0910 (07-06-2014)
 Old 06-23-2014, 05:43 PM   #11
From my emails:
"Rear will already have a reservoir which essentially has a similar compression behavior to what we can get with KBO (sans reservoir)."
"To clarify, we are not going to be using KBO on your front single adjustables (it won't fit the current hardware)."
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
phate (06-23-2014)
 Old 06-23-2014, 05:52 PM   #12
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Damn, look at those springs! They must be imported from Ireland, because one look at those and I was Dublin.
MINI H1 6.0 - CAR LED TAILS
The Following 4 Users Say Thank You to dale_gribble For This Useful Post:
Code Monkey (06-23-2014), ItsNox (06-30-2014), sidekick (06-24-2014), stanley0910 (07-06-2014)
 Old 06-24-2014, 05:58 AM   #13
Lakespeed6's Avatar
Posts: 2,396   (View Stats)
Lakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the worldLakespeed6 is the leader of the world
Cannot wait to see how these perform!
2006 Black MS6 531HP 486TQ FREEKBUILT -- FreekTune
BW S300sx 62mm -- Twin TIAL 38mm EWG -- Perm Top Mount Twin Scroll Turbo Manifold -- Perm 4" Intake
TR1035FMIC -- JBR TB and IM thermal spacers -- JBR OCC -- Bosch 3.5 Bar MAP -- Greddy BOV-- CP-E Injector seals
Perm Downpipe -- 3" Magnaflow CBE -- Autotech Fuel Pump Internals -- Grimmspeed EBCS -- NGK Iridium
Ported Head and Intake Manifold -- Snow Performance Meth Injection D10 and D12 -- balance shaft delete -- EGR delete
ACT 6 Puck -- ISC Coilovers -- Sure Torq R6 -- Sure Juggernaught -- Sure Dreadnaught -- Sure Anchors -- Sure Shift Knob
2006 CWP MS6 313HP 319TQ FreekTune
ATP GTX3076r -- TIAL 38mm EWG -- HTP 3" Intake System -- CPE Single Exit Exhaust-- ATP Catless Down Pipe
CPE Differential Mount -- CPE Top Mount Intercooler -- JBR 80D Trilogy Mount Package -- Grimmspeed EBCS
Autotech Internals -- Bosch 3 Bar Map Sensor -- Bit Wise Plug n Play -- GFB Hybrid BOV
Bilstein Struts -- H&R Sport Lowering Springs -- Cobb v3 -- e85
1990 Nissan Skyline GTR
1991 White BMW 325ic
Scorpion catback -- Short shifter -- Bilstein HD -- HR Springs -- Intake -- NRG Wheel -- Chassis and strut tower brace -- Sway bars
Lakespeed6 is offline   Reply With Quote
The Following User Says Thank You to Lakespeed6 For This Useful Post:
Code Monkey (06-24-2014)
 Old 06-24-2014, 06:53 AM   #14
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Damn...
my credit card just ran out of the office screaming in fear....
Some gorgeous custom bilstein porn there!
340hp / 371tq
The Following 5 Users Say Thank You to TiGraySpeed6 For This Useful Post:
Code Monkey (06-24-2014), doctavus (06-26-2014), ItsNox (06-30-2014), spd6demon (06-24-2014), trancehead (06-24-2014)
 Old 06-24-2014, 08:38 AM   #15
spd6demon's Avatar
Posts: 164   (View Stats)
spd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the world
Can't wait to see these things in action! I just did an autox event this past weekend and found out quickly how bad I need a new suspension setup. May be needing to whip out my credit card again
06 MS6 GT // PTE 6266 GEN2 // Kozmic 6th Port Inj. 1200cc // Weisco Pistons (0.020 over) // Manley H+ Rods // JDM Sport EM // Tial 38mm EWG // SP63 Keyed & Polished Crank & Sprockets // 4" WPI // P&P IM // Cobb AP // Custom DP
CP-E Safe Seals // CP-E Rear Diff Mount // Bosch 3.5 BAR // Sure ShortCut // TWM Shift Knob // AutoTech HPFP internals // H&R Springs // DRAG DR-34 +35mm // CS2 Front Lip // CX Racing Air to Water IC // Custom Matt Damond Dual OCC
HTP Small Batt Tray // SP63 EBCS // HKS BOV // Kozmic Oil Feed Line // JBR EGR block off // JBR BSD // JBR Counter-weight // NGK // DW 65c ITFP // JBR PMM // JBR SSB // SU RMM // Corksport TMM Insert // FREEK Tune in progress
305/364 (K04) // 367/387 (2871r)
454/417 (PTE6262 R.I.P)
spd6demon is offline   Reply With Quote
The Following User Says Thank You to spd6demon For This Useful Post:
 Old 06-24-2014, 08:40 AM   #16
Tyhackman15's Avatar
Posts: 1,742   (View Stats)
Tyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the worldTyhackman15 is the leader of the world
I have a strong feeling you're going to be very happy. I run FCM coilovers on my miata and they are fantastic. The faster you go, the smoother it is.
SOLD 2008 MS3 17x8 Evo 9's, 235 v12
1995 Miata 1.8L w/ FMII GT2560R @11psi, FM stage 2 clutch/flywheel, FM Frame rail braces, FM high capacity radiator/fans, RB Sway bars, Racing beat exhaust, Fat cat Coilovers, Jongbloed 15x9, Wilwood 4 wheel BBK, Rollbar, Hardtop, TDR Racing seat
2001 Saab 9-3 Viggen 2.3T Stage 3+ bro, SRI, 3" DP, ETS FMIC, 17x8 BBS RK2's, Full chassis bracing / sway bars, Forge BPV, Winter/DD
Tyhackman15 is offline   Reply With Quote
The Following User Says Thank You to Tyhackman15 For This Useful Post:
The Following User Says NO Thank You to Tyhackman15 For This Un-useful Post:
5doorsoffury (07-04-2014)
 Old 06-24-2014, 02:18 PM   #17
Mazdazilla6's Avatar
Posts: 3,655   (View Stats)
Dear lord. 2 years, I'm sure it's definitely worth it though. Can't wait to see how these sweet things work out for you!
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 06-24-2014, 03:42 PM   #18
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,711   (View Stats)
Groaned at 33 Times in 19 Posts
Why do you think you need a professional install?
There is nothing extraordinary about installing this kit. Pretty sure you can do it yourself. In fact, I would recommend you do it yourself. You might need to service certain components later on and you don't want to have to take the car to a shop every time there is something wrong. Better off just learning from the start how everything goes together.
And if you want to get corner weighed, you can do that later on.
If you come down to FL you can do that for free at my place. Well almost. Will cost you a hand job. Just a short one.
Edit: You also want the guy at that shop to tweak your suspension? what the fuck dude. Learn how to do that yourself. Don't be that guy who gets behind the wheel without knowing what the fuck is going on with your set up. The personal reward will be much higher. It might take some time but what's the hurry?
MAKE LOVE TO THE CANVAS
The Following 6 Users Say Thank You to Tomas For This Useful Post:
Code Monkey (06-24-2014), Easter Bunny (06-24-2014), ItsNox (06-30-2014), Mauro_Penguin (06-27-2014), phate (06-24-2014), sidekick (06-29-2014)
 Old 06-24-2014, 03:54 PM   #19
Raider is mah Homie
Groans: 2,978
Which aspect of the hand job is short? The dick or the stamina.
I hugged rfinkle2
The Following 5 Users Say Thank You to Easter Bunny For This Useful Post:
Code Monkey (06-24-2014), doctavus (06-26-2014), ItsNox (06-30-2014), SpeedRebirth (06-25-2014), Tomas (06-25-2014)
 Old 06-25-2014, 08:47 AM   #20
Speeeeeed
06Speed6's Avatar
Posts: 6,519   (View Stats)
Damn those look nice, these took longer to finish than a cpe IM.
2006 Mazdaspeed 6
The Following 7 Users Say Thank You to 06Speed6 For This Useful Post:
Code Monkey (06-25-2014), Easter Bunny (06-25-2014), ItsNox (06-30-2014), Mauro_Penguin (06-27-2014), phate (06-25-2014), TiGraySpeed6 (06-25-2014), Tomas (06-25-2014)
 Old 06-25-2014, 08:56 AM   #21
Bob Ross Fanclub
Tomas's Avatar
Both.
Easter Bunny (06-25-2014), ItsNox (06-30-2014), sidekick (06-29-2014)
 Old 06-25-2014, 02:27 PM   #22
Eth Fiend
phate's Avatar
Just spoke to Shaikh. My shocks *should* (hopefully) be finished next week. It would be nice to have them for 4th of July weekend; I could probably find time to put everything together.
Code Monkey - do you have yours on yet? I'm anxious!
-06 MS6
 Old 06-25-2014, 02:34 PM   #23
I may be able to pick the car up tomorrow evening -- that assumes everything goes ok with the install, all the parts fit, no parts are missing, etc. I am anxious too.
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
phate (06-26-2014)
 Old 06-26-2014, 06:36 PM   #24
Groans: 127
ANTICI
PATION
FreekTuned
The Following 5 Users Say Thank You to blackmicamps6 For This Useful Post:
Code Monkey (06-26-2014), Easter Bunny (06-26-2014), EyeKon (06-28-2014), ItsNox (06-30-2014), phate (06-26-2014)
 Old 06-26-2014, 06:42 PM   #25
The shop called me today around lunch -- they have everything installed but are having a bit of trouble with the external reservoirs on the rear shocks, I emailed Shaikh and this is his response:
"The reservoirs have to be on flexible lines to ensure you can position them out of the way of the suspension arms / drive shaft. It's important the shop know to check the position of the reservoir and watch for potential inferference when articulating the arms up-and-down (no rear spring installed) to be sure everything clears. I really recommend being around for that part of the job unless you TOTALLY trust this shop. It's may not be a full drop-in situation. I wasn't positive on exact clamp position so they will have to check that. The urethane blocks are used on off-road trucks, etc. Check the clamps are secure before your race. We supply constant tension clamps which are higher quality than what you'd get at an auto/hardware store."
The shop was positive I would have the car back by Friday so let's see what happens tomorrow.
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
The Following 4 Users Say Thank You to Code Monkey For This Useful Post:
blackmicamps6 (06-26-2014), EyeKon (06-28-2014), phate (06-26-2014), TiGraySpeed6 (06-26-2014)
 Old 06-26-2014, 07:02 PM   #26
Eth Fiend
phate's Avatar
Can you just mount the shock upside down and move the reservoir to where ever it's easiest to access?
-06 MS6
 Old 06-26-2014, 07:03 PM   #27
No idea, I will give them a call tomorrow morning and see what they say.
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
phate (06-26-2014)
 Old 06-27-2014, 09:00 AM   #28
So I just got a call from the shop, everything is in but there is a problem -- the tapered QA1 spring in the rear is too long according to them, it is 8", should be 7". They already bottomed out the rear shock adjuster and the rear dropped only 1" -- if they are to proceed with the corner balancing, they may have to raise the rear and who the fuck knows what ride height the car will end up with, it could end up higher than the current height.
I told them not to proceed with corner balancing for now -- will need to talk to Shaikh and see what he thinks.
@phate;
Edit: @phate; according to your calculations, they should be able to go 2.5" lower in the rear?
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
Easter Bunny (06-27-2014), ItsNox (06-30-2014)
 Old 06-27-2014, 09:13 AM   #29
Eth Fiend
phate's Avatar
Edit: phate according to your calculations, they should be able to go 2.5" lower in the rear?
Here's my install test for the rear springs.
It might be due to how tall the adjuster is at minimum height, because the QA1 springs only come in one height.. No doubt there's a tiny bit of difference due to the spring rate, but I think it's a seat issue. There were quite a few adapters in your above pics - was one of them intended to go on the rear LCA? The QA1's can sit directly in the LCA. The bottom of this post links to a bunch of pics of the rear setup off of the car.
-06 MS6
Code Monkey (06-27-2014), Easter Bunny (06-27-2014)
 Old 06-27-2014, 09:47 AM   #30
Eth Fiend
phate's Avatar
Taking a second look at the adjustable rear perches from your pics, they look like they would be really tall at minimum height. If you find that's the case, lets compare them to the BC's. I think you'll have more adjustment room with them. If I didn't post their dimensions, I'll dig them out. I know I measured and sketched them.
-06 MS6
 Old 06-27-2014, 09:58 AM   #31
But then I would have no adjusters on the rear spring and no ride height adjustability, which means no corner balancing.
Edit: The shop is saying 6" rear springs would work best.
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
 Old 06-27-2014, 10:02 AM   #32
Eth Fiend
phate's Avatar
No, the adjuster goes up top.
-06 MS6
 Old 06-27-2014, 12:01 PM   #33
Got an update from the shop:
"Talked to Shaikh and we are both on the same page. Everything is done as should be, so right now he is going to contact you and talk about your project."
So I need to order another set of springs -- 7" Tein ST100-01175, the rate is 10k or 560 lbs, they are tapered 70mm-90mm. Shaikh said with the 1000 lbs springs in front, that would give me ride frequencies of 2.2 / 2.35 Hz. He also said he would make me a pair of lower spring perch adapters to fit the new springs as the ones I have now are 65mm. The springs are a special order from Japan, expect up to 90 days for delivery, FLM.
The plan for now is to stick with what I have and make the best of it -- the shop will drop the car in the rear a bit, match the front, and do an alignment. Once I get the Teins, we will swap the springs and corner balance the car. I will be picking up the car Monday.
I also called QA1 as they do custom jobs, they could do the Mustang II springs in 6" but the minimum order is 200 springs, lol.
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
Easter Bunny (06-27-2014), ItsNox (06-30-2014), phate (06-30-2014)
 Old 06-27-2014, 12:20 PM   #34
Eth Fiend
phate's Avatar
Seems a bit ridiculous. All of the QA1 Mustang II springs are 8", mine included. With my setup and 600lb springs, this was the "low" setting with both rings and the rubber seat on the adjuster:
With 700lb springs, it would raise the car another ~.20". We have very similar rear corner weights...
That difference would be offset if you pulled the locking ring and rubber isolator.
-06 MS6
 Old 06-27-2014, 12:31 PM   #35
I need to carefully read through your thread and see what may be going on. I am not ordering springs today, I do not want to rush into things. I will get the car Monday, drive for a few days and see if anythings settles.
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
Easter Bunny (06-27-2014), phate (06-27-2014)
 Old 06-28-2014, 03:55 PM   #36
EyeKon's Avatar
Posts: 240   (View Stats)
EyeKon is the leader of the worldEyeKon is the leader of the worldEyeKon is the leader of the worldEyeKon is the leader of the worldEyeKon is the leader of the worldEyeKon is the leader of the worldEyeKon is the leader of the worldEyeKon is the leader of the worldEyeKon is the leader of the worldEyeKon is the leader of the worldEyeKon is the leader of the world
Read all the above and as you would say FML
'13 MX5 GT PRHT, Supercharged, Dolphin Grey
EyeKon is offline   Reply With Quote
 Old 06-28-2014, 04:24 PM   #37
I would not be so pessimistic. Let's wait when I get the car back, I will post pictures of how the rear spring sits and we will go from there. It is possible switching to BC perches will solve my problem.
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
phate (06-30-2014)
 Old 06-28-2014, 04:53 PM   #38
jbbuie's Avatar
Posts: 17   (View Stats)
jbbuie is a splendid one to beholdjbbuie is a splendid one to beholdjbbuie is a splendid one to beholdjbbuie is a splendid one to beholdjbbuie is a splendid one to beholdjbbuie is a splendid one to behold
I to have been running BC perch with QA-1 mustang springs (softer 375lbs) for about 6 months and have the same adjustability as @phate. Noticed another MS6 at an autocross event last weekend with KW coilovers had height adjustability problems in the rear also.
jbbuie is offline   Reply With Quote
The Following 2 Users Say Thank You to jbbuie For This Useful Post:
Code Monkey (06-28-2014), phate (06-30-2014)
 Old 06-28-2014, 04:56 PM   #39
Do you or @phate; have the part # for the BC perch?
2006 Mazdaspeed6
2017 Subaru BRZ
2000 E39 M5
2001 MR2 2ZZ
phate (06-30-2014)
 Old 06-28-2014, 05:32 PM   #40
jbbuie's Avatar
Once I get home tomorrow I'll look and see.
Code Monkey (06-28-2014), Tomas (06-29-2014)
Mazdaspeed6 for road racing Code Monkey Mazdaspeed3/6 General Discussion 1393 03-17-2018 07:57 AM
MS3 Suspension Setup and Fine Tuning for Autocross and Road Racing Bap 2010 MS3 - Suspension & Brakes 109 04-23-2014 04:57 AM
BC Racing Coilovers 2010 MS3 Review Daddy 2010 MS3 - Suspension & Brakes 26 06-16-2012 07:12 AM
Powdercoated Mazdaspeed6 rims (winter setup) Jon2000 MazdaSpeed 3/6 - Wheels & Tires 28 11-02-2011 03:09 AM
BC Coilovers Setup glocK23 MazdaSpeed 3/6 - Suspension & Brakes 40 12-11-2009 03:21 PM
Page generated in 0.61066 seconds with 37 queries
