| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() | | #1 | ![]() |
![]() Join Date: Mar 2008
Rep Power: 77 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
(Thread Starter) | Not Ranked : 0 score Also, is there a trick to putting the caliper spring back on? I had a hell of a time putting it back on. Thanks
__________________ ![]() Mods: Cobb Tuning Accessport Stage 1+, Cobb Tuning SF Intake, Cobb Tuning Inlet Pipe, Cobb Tuning Springs, Cobb Tuning STS, TRZ Rear Engine Mount, TRZ Transmission Mount (not currently installed), TVM Shifter Bushings, Forge BPV, MSD Dashhawk, 30% Tint |
![]() Join Date: Jul 2008 Location: Tucson, AZ
Rep Power: 593 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 467
Groaned at 6 Times in 6 Posts
Dumb question, but did you bleed the brakes?
__________________ Sitting on jackstands due to ZZB: 2006 LP MS6 Sitting herrafrush in the driveway: 1990 Miata - new track slut PARTING OUT ENTIRE SPEED6. LET ME KNOW IF YOU NEED A PART. |
![]() Join Date: Apr 2010 Location: Columbia, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,747
Groans: 97
Groaned at 31 Times in 25 Posts
Dumber question, if you don't release the brake like from the caliper, you wouldn't need to bleed would you? I never have anyways. Make sure that the brake fluid reservoir cap is tight and the level is correct, could be that the pads need to be broken In a bit, bedded into the rotors I believe is the term, look up proper procedure
| The Following User Says Thank You to ScarMS3 For This Useful Post: | 2008speed3 (01-06-2011) |
![]() | | #4 | ![]() |
![]() Join Date: Jul 2009 Location: Philadelphia Metropolitian Area
Rep Power: 207 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
Its the P.O.S. HAWK HPS pads. They are just squishy like that. Trust me on this one. I've been through bleeding and re-bleeding so have many others on here. I plan on going back to stock pads asap. The hps stop well if you stomp the break, but there is nothing like the perfectly crisp feel of the stockers. If anyone knows where to get the stockers for cheap online lmk please.
__________________ 2008 Mazdaspeed3 GT 2.206 ~ 13.330 @ 107.98 MPH (I & AP only, DSC ON) Cobb SRI | Cobb AP (Stage 2+ v200) | OBX TP | Hankook Ventus V12 Evos | Hawk HPSoftpenis Pads | Duplicolor Black Stock Wheels | 15% Tint | SuperRiceLEDs 9500k | SURE RMM Race | TRZ TMM | JBR PMM 80a | JBR Shifter Bushings | Fidanza Flywheel | Koni Sport Shocks |
| The Following User Says Thank You to JNR5005 For This Useful Post: | kwsmithphoto (03-20-2011) |
![]() | | #5 | ![]() |
![]() Join Date: Jun 2009 Location: Lost Angels, Cali
Rep Power: 5069 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,681
Groans: 78
Groaned at 274 Times in 243 Posts
| Neutral : +1 score
The only characteristic of the hawk hps pad to be aware of, is that they require more pedal effort stopping, when they're cold - like first thing in the morning. Once warmed up, they stop on a dime. I'm guessing it's as someone else mentioned, you haven't bedded in the brakes yet, or did it incorrectly. Read the bedding in procedure on the hawk box and follow it to a "T" Sent from my iPhone using lame ass Tapatalk
__________________ ![]() | |
| The Following User Says Thank You to hnda etr For This Useful Post: | Nliiitend1 (01-08-2011) |
![]() | | #6 | ![]() |
OP; buy the $250 set of oem fronts, that will fix your problem instantly.
__________________ 2008 Mazdaspeed3 GT 2.206 ~ 13.330 @ 107.98 MPH (I & AP only, DSC ON) Cobb SRI | Cobb AP (Stage 2+ v200) | OBX TP | Hankook Ventus V12 Evos | Hawk HPSoftpenis Pads | Duplicolor Black Stock Wheels | 15% Tint | SuperRiceLEDs 9500k | SURE RMM Race | TRZ TMM | JBR PMM 80a | JBR Shifter Bushings | Fidanza Flywheel | Koni Sport Shocks | |
| The Following User Says Thank You to JNR5005 For This Useful Post: | memin (03-15-2011) |
![]() | | #7 | ![]() |
Groans: 78
| Neutral : +1 score
| The Following User Says Thank You to hnda etr For This Useful Post: | btstarcher (06-27-2012) |
![]() | | #8 | ![]() |
I did not bleed the brakes as it was my understanding that it was un-needed with just a pad/rotor install. I supported the caliper with a bucket, so there was no stress on the line. I followed the instructions on the pad box fairly closely, within the confines of the traffic that I was driving in. It was rather cold here when testing (about 30 degrees F) so I am thinking that it just may be the pads warming up. It's not like they are not stopping. I am making 90-100 mile drive tomorrow, so I will get a better feel for them then. I don't think I will be buying new pads any time soon though. I will just wait until these wear out again and I'm sure I will get used to them eventually.
![]() | | #9 | ![]() |
![]() Join Date: Feb 2009 Location: gilbert, az
Rep Power: 1878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,876
Groans: 241
Groaned at 70 Times in 36 Posts
You cheaped out and thought aftermarket would be better is the problem. The hawks don't have the same bite and won't until they reach higher temps. The oem are much better, wider temperature range for optmal coeff of frction, and I've heard little issues with them fading. So if you want your pedal feel back go with the oems.
__________________ 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, hallman pro rx bc, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Turbosmart Hybrid bpv, SURE TIG's + coolant bypass, ITV24's, CP-E 75d RMM, Medefail Tranny mount, DDM 35W 6000K HID's, SURE Counterweight, 18x8 245/40 NT-05's up front, R: 225/45 Sport Maxx TT's 390whp/400wtq |
| The Following User Says Thank You to 86azms3 For This Useful Post: | kwsmithphoto (03-20-2011) |
![]() | | #10 | ![]() |
Groans: 78
The cold is definitely going to impact stopping effort - regardless of pad, but possibly more with the hawks... another thing to consider, is getting stainless steel brake lines... This will also firm up your pedal... Sent from my iPhone using lame ass Tapatalk
![]() | | #11 | ![]() |
![]() | | #12 | ![]() |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 524
Groaned at 39 Times in 30 Posts
i have ebc reds in and i hate the pedal feel. I miss the OE bite.
__________________ ![]() 2008 Cosmic Blue Mazdaspeed3 1986 Mazda RX7 2002.5 Sunlightsilver Protege5 (sold 12/26/09) Hey you should read this: http://www.mazdaspeedforums.org/foru...ler-you-58361/ |
![]() | | #13 | ![]() |
![]() Join Date: May 2009
Rep Power: 425 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 454
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score No there's definitely a difference between increased braking effort and a soft/squishy brake pedal. The latter usually surfaces when the lines/fluid overheat or there is unsufficient pressure in the lines. In the two MS3's I drove with HPS, the pedal "felt" the same but took increased braking force to stop the car. Not necessarily a bad thing but the progressive behavior is not for everyone (including me).
![]() | | #14 | ![]() |
![]() Join Date: Jun 2008 Location: Bowling Green KY
Rep Power: 993 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 435
Groans: 35
Groaned at 45 Times in 37 Posts
I had my front rotor's turned and Hawk HPS installed and had the same issue with soft brakes and a slight grinding sound. Carried it back to the shop and they call the sound "chatter". Manager said they need to be fine turned or something along that line. Now the HPS grab like the stockers did at much less cost. I'm not sure what they did the 2nd time but it was like night and day, very happy now. They checked the rear and said I had plenty of pad left, so I did not change the rear.
__________________ Cobb AP // Stratified 20% E-85 // Cobb SRI Amsoil Dry // Cobb TIH // NGK 1 colder // Custom FMIC // Test Pipe // Forge BPV V1 (red) // Autotech // DCR VVTA // Koni FSD's // ACT 6 puck Prolite Fly // Cobb RSB // Chassis Braced // Sure SSP // JBR 88 RMM // JBR 70 PMM // CorkSport SS lines // Indy Fogs // DDM 6K HID // 6K LED fogs // FD's W/RE-11's // 13.196 @ 110.84 |
![]() | | #15 | ![]() |
![]() Join Date: Mar 2008 Location: 60607
Rep Power: 2144 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,446
Groans: 59
People like to rag on the HPS here but I've been using them for ~25K of the 38K miles that are on my car's odometer (I'm on my second front and first rear sets of HPS pads) and to me, they're about perfect for a DD and they perform pretty admirably on track (with good fresh fluid) during the occasional track day, especially considering their cost (the low dust is just a bonus, as far as I'm concerned). Yes, they give up a bit of initial bite compared to OEM pads, but I really don't believe they give up anything in the areas of longevity, heat resistance, or stopping power. As much as I use my brakes (and as often as I replace them, in kind), I've come to be pretty satisfied with their less-than-OEM price tag and relatively low dust production. Just wanted to throw out my $.02...
__________________ Stance is not a verb. |
![]() | | #16 | ![]() |
Curious, for those doing their own pads/rotors, how many of you are opening the bleeder screw before pushing the caliper piston back into the housing? Seems this could be a $1600 issue if fluid gets pushed back into the ABS control valve.
![]() | | #17 | ![]() |
Rep Power: 4091 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,497
| Not Ranked : 0 score I never do. Though it wouldn't hurt, whenever I am swapping pads I am usually putting fresh fluid in.
![]() | | #18 | ![]() |
![]() Join Date: Jan 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
Yeah even my OEM Pads had to be bedded in. When I got my car back from the dealer they felt a little soft after a brake job but after a few days they where fine.
![]() | | #19 | ![]() |
http://www.cardone.com/english/club/...%2012-0001.pdf | |
![]() | | #20 | ![]() |
![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 631 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,718
Groaned at 8 Times in 5 Posts
hey OP check how you put that spring back in. if you put it in wrong it will give the caliper resistance causing a squishy pedal feeling
![]() | | #21 | ![]() |
Groans: 59
I've also never experienced the "mushy pedal" phenomenon, and I've changed my front brake pads twice and my rear pads once.
__________________ Stance is not a verb. | |
![]() | | #22 | ![]() |
Everyone I know here locally does the same. But my pedal travels downward a little further than I'd like after the OEM pad/rotor install. I opened the reservoir cap and haven't uncorked the lines so I'm confident it's not air in the system. Still holding pressure at the pedal so I don't think it's the master cylinder either. Caliper springs look and feel fine. I noticed the same feel during FFF's test drive. Probably going to have a pro take a look and will report back. |
| 2009 MS3 brakes vs. 2010 MS3 brakes | Driver72 | 2010 MS3 - Suspension & Brakes | 11 | 11-21-2009 09:34 AM |
| Pad/Rotor install how-tos? | AFcadet | MazdaSpeed 3/6 - Suspension & Brakes | 21 | 11-20-2009 02:50 AM |
| Rotor Removal | FantasmoNegro | MazdaSpeed 3/6 - Suspension & Brakes | 18 | 04-17-2009 04:41 PM |
