 Old 04-20-2011, 04:59 PM   #1
:: Gusto ::'s Avatar
Posts: 1,454   (View Stats)
Default -- Stiffer Rear CO springs...?. --
Okay so i picked up a set of USED BC co's for Super cheap...
& i know KW are the preferred CO set up for the $$... but like i said super cheap.. heh...
either way.. i was trying to get some STIFFER rear springs .. for when i load up my trunk on vacations... Or if i just happen to be carrying extra gear in the trunk.
SU said they didn't offer them... any1 have some ideas ...?
yea yea - i know i cant spell
 Old 04-20-2011, 06:40 PM   #2
jroc's Avatar
Posts: 1,482   (View Stats)
jroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the world
Groaned at 6 Times in 6 Posts
Isnt the rears on the bc cos already 10k?
Im trying a 10.5k spring on mine from a e90. Waiting on the shipment to get here.
JDMFresh.com 1990 Mazda Miata
NASA Time Trials/Time Attack, Global Time Attack
A miata may be gay, but its probably faster than your car around a track. That's pretty gay.
jroc is offline   Reply With Quote
 Old 04-22-2011, 01:39 AM   #3
kwsmithphoto's Avatar
Posts: 1,035   (View Stats)
kwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the worldkwsmithphoto is the leader of the world
Groaned at 41 Times in 9 Posts
From your mod list, it already looks like you have a better setup than you can get from BC. I mean shit, you even bought rear trailing arms (why?).
Cheaping out now will just send you backwards. Cobb has stiffer rear springs that are barely lower than stock, I think your main problem is running Bilstein HD's instead of sports. The OEM rear springs/bump stop combo actually works very well with proper dampers; the rear end doesn't have very much travel, so it needs to be controlled properly.
Again, you have already done a lot of expensive stuff so what are you looking to gain from chap shit like BC's?
Besides, some people have dyno'd BC rear dampers and they suck. KW or Mazdaspeed have much better solutions, as do Koni and Bilstein. Rear damping is absolutely critical with these cars, but you won't get it right with any BC product, IMO.
EDIT: Was unintentionally responding to both of you guys. The OP doesn't have your setup but I think my reply was valid for both of you. Gusto, I have carried very high loads a lot of miles on the stock spring and bump stop setup, with Koni FSD's, and it has been good with one exception: the rear springs have developed a few mils of sag. I'm looking at a few solutions to lift them, but the spring rate is just fine. What isn't just fine is the amount of preload on the OEM springs - basically, their static length is a bit lacking for hauling stuff. A member here has the same problem and is experimenting with some heater hose wrapped around the lower end of the spring. So far so good. If I were you, I would simple raise the rear ride height a bit since you already have adjustable perches. I would also toss those BC dampers too, ASAP.
This car has never been raced, modified, or abused in any way. Maintained as required, only wear items have been replaced with OEM or better parts, in compliance with all warranty terms, and federal and state laws.
kwsmithphoto is offline   Reply With Quote
 Old 04-22-2011, 07:09 AM   #4
jroc's Avatar
Fwiw, cobb doesnt have any suspension pieces for the ms6 so no comparison there. As much as I wanted koni yellows the price wasnt in my budget. The bilsteins have made me happy.
I dont think anyone has bought kw2s yet for the ms6 to my knowledge, its been all h&r, bc, and I kniw of one other runni ng kports. Down here the car is pretty competitive against the other cars here, my limiting factor right now is quality of tires. 3 seconds off from 1st place who runs r compounds, im still on street tires. Thatll change after summer.
 Old 04-22-2011, 04:13 PM   #5
nahh.. the BC are 8k... id love some 10k
any ideas..?
 Old 04-22-2011, 07:30 PM   #6
jroc's Avatar
The springs I ordered are from an e90 bmw. The bilsteins actually raised my ride height, at the same time the bmw springs are slightly shorter. So im hoping the difference puts me back to where the height was. Well see when they get here.
 Old 04-22-2011, 10:52 PM   #7
Sorry guys, I keep forgetting that the MS3 and MS6 sections are all muddled together.
 Old 04-28-2011, 06:27 PM   #8
10k springs...!??!??
any1 know anything..?
 Old 05-05-2011, 03:18 PM   #9
Mr_Bill's Avatar
Posts: 182   (View Stats)
Mr_Bill is the leader of the worldMr_Bill is the leader of the worldMr_Bill is the leader of the worldMr_Bill is the leader of the worldMr_Bill is the leader of the worldMr_Bill is the leader of the worldMr_Bill is the leader of the worldMr_Bill is the leader of the worldMr_Bill is the leader of the worldMr_Bill is the leader of the worldMr_Bill is the leader of the world
You can order springs for a straight swap from BC Racing, they typically cost $100 for a set of two. Just call the number on their website...
BC Racing - North America
Mr_Bill is offline   Reply With Quote
 Old 05-10-2011, 06:00 PM   #10
thanks mr. bill .. i had one of the guys @ street.unit look into it.. apparently they dont offer a stiffer spring for the set up.. =0(
 Old 07-02-2012, 10:13 AM   #11
Well ... its been a year..its about time for my yearly trip.. still having the overload issue... BC still doest offer a stiffer spring.
@jroc :
Any luck w/ the bmw springs?
 Old 07-02-2012, 06:42 PM   #12
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
The rear of the ms6 presents some really interesting problems. I'd like to know more about these bmw springs as well.
@jroc
Past Mazdas & Speeds
Stiffer Springs? ManMan MazdaSpeed 3/6 - Suspension & Brakes 23 05-07-2011 10:48 AM
Would a stiffer rear mount cause other mounts to fail? KaiserSoze MazdaSpeed 3 - Engine, Transmission & Driveline 12 06-04-2009 09:07 PM
Page generated in 0.33710 seconds with 24 queries
