 Old 11-02-2018, 09:48 AM   #1
Carskick's Avatar
Posts: 315   (View Stats)
Default Stiffer Springs that do NOT lower
I've searched far and wide for this answer, but haven't had much luck...
Almost everyone wants to lower their car. I want stiffer springs, but do not want to go lower than the rear @ OEM. This is my DD, and I sometimes have to drive down dirt roads, roads with pot holes, etc., and the car is already low enough.
So my suspension is all original OEM (92k miles) except for the Shocks/Struts, which I got Koni STR.T. I regret not getting the yellows, long story, but it is what it is at the point.
I want to get springs that are 5-15% stiffer than stock when they were new to compensate for my wider tires/wheels and get me stiffness close to the OEM setup.
The Eibeichs, Corksports, and most others I see that are stiffer also lower the car. Currently, my front wheel well as about an inch more gap than the rear. I'd prefer them even, and would like them to both fall in the current range. I've attached pictures of where it is right now.
Any suggestions would be greatly appreciated.
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
 Old 11-02-2018, 10:16 AM   #2
Db09ms3's Avatar
Posts: 378   (View Stats)
Groans: 80
Maybe brand new OEM springs is what you need. I plan to do that as I don't want to get it any lower too.
Stockish
 Old 11-02-2018, 10:31 AM   #3
Rose City Speed6's Avatar
Posts: 49   (View Stats)
Rose City Speed6 is a glorious beacon of lightRose City Speed6 is a glorious beacon of lightRose City Speed6 is a glorious beacon of lightRose City Speed6 is a glorious beacon of lightRose City Speed6 is a glorious beacon of lightRose City Speed6 is a glorious beacon of light
Groaned at 3 Times in 1 Post
Coilovers or custom springs are your only hope.
Rose City Speed6 is offline   Reply With Quote
 Old 11-02-2018, 10:53 AM   #4
Carskick's Avatar
Thanks guys.
That's kind of what I was afraid of. Buy new OEM, or go custom.
I believe my wheel's offset is too positive for most coil overs, so I'd need spacers, which I'd prefer not to do.
I haven't researched custom, I wonder how crazy the cost gets...
 Old 11-13-2018, 07:06 AM   #5
Carskick's Avatar
Just a quick update...
I've decided to go all out. I want the suspension to be better than new at this point, so I'm going to start researching all the various options. I plan on replacing the strut/shocks and selling my STR.R's, which are barely used, while also replacing springs, end links, bushings, top hats, bump stops, etc.
I'll just have to start reading through and getting a parts list together. Going to stay at less than a 1 inch drop and hope the stiffer springs offset the drop enough.
Stiffer springs with little to no drop ViperTGB 2010 MS3 - Suspension & Brakes 15 12-29-2014 11:34 AM
I need springs to lower my car falconman17 Gen2 MS3 General Discussion 5 02-16-2013 10:37 AM
Lowering springs without stiffer ride? eugenes18t 2010 MS3 - Suspension & Brakes 38 11-27-2012 03:26 PM
-- Stiffer Rear CO springs...?. -- :: Gusto :: MazdaSpeed 3/6 - Suspension & Brakes 11 07-02-2012 06:42 PM
Stiffer Springs? ManMan MazdaSpeed 3/6 - Suspension & Brakes 23 05-07-2011 10:48 AM
Page generated in 0.25955 seconds with 23 queries
