Like Tree10Likes
 Old 05-01-2009, 04:36 PM   #1
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Default Uhhhhh Air Lift Kit 1000
UPDATE!!!!:
Ok, did some measuring on the Gen2 stock springs. On the Gen1, I think I measured them while uncompressed. (just like a newb ass). Doing that will lift the car alittle without pumping them.
Gen2 compressed are 3.5"x6" from the top inside bolt to the bottom top of the coil spring. The top bolt head comes down lower then the top bottom of the coil spring.
So the lined cavity area is 3.5"x6"
Also have to take into the equation are the support rings and rubber blocks on both ends that come with the kits.
I have gotten the bag dimensions sheet from AirLift and the ones in green are optimal to our cars. The ones in blue will work also with very little lift. The ones in red will lift but still can be used.
Please post Coil Spring sizes from stock compressed Gen1, MS6 and any other after market Coil Spring (compressed) here. So I can make a database on the OP for others. TIA!
Kit# Repl. Kit# Bag# diameter height
60723 60223 46149 3 x 5.5
60793 60293 46149 3 x 5.5
60724 60224 46142 3 x 7
60756 60256 46143 3 x 8
60729 *components only 46144 3 x 9
80754 80254 46166 3.44 x 5.5
60739 60239 46136 3.44 x 7
80777 80277 46136 3.44 x 7
80753 80253 46135 3.44 x 8.75
60713 *components only 48171 3.44 x 10.5
81560 81260 48171 3.44 x 10.5
60789 60289 46125 4 x 4
60776 60276 46091 4 x 5
80702 80202 46091 4 x 5
60727 60227 46141 4 x 6
60795 60295 46141 4 x 6
60806 60306 46141 4 x 6
60774 60274 46137 4 x 7
60785 60285 46137 4 x 7
60751 60251 46129 4 x 8
60797 60297 46129 4 x 8
80590 80290 47162 4 x 8
60783 60283 46130 4 x 9
60788 60288 46130 4 x 9
80765 80265 46130 4 x 9
80545 80245 47078 4 x 10
60736 60236 46131 4 x 11
60738 60238 46131 4 x 11
80531 80231 47039 4 x 11
80537 80237 46131 4 x 11
80539 80239 46131 4 x 11
80523 80223 47027 4 x 13
60748 60248 46165 4.35 x 5.5
60743 60243 46172 4.35 x 6.5
60732 60232 46173 4.35 x 7
60763 60263 46161 4.35 x 8
60702 60202 46159 4.35 x 9
60779 60279 46159 4.35 x 9
60798 60298 46159 4.35 x 9
60799 60299 46159 4.35 x 9
61741 61241 46159 4.35 x 9
60740 60240 46160 4.9 x 4.25
60752 60252 46160 4.9 x 4.25
60754 60254 46160 4.9 x 4.25
60796 60296 46160 4.9 x 4.5
60742 60242 46127 4.9 x 6
60792 60292 46128 4.9 x 8
60810 60310 46164 4.9 x 9
60769 60269 46123 4.9 x 10
60807 60307 46123 4.9 x 10
61792 61292 46123 4.9 x 10
60759 60259 46147 5.38 x 4.5
60777 60277 46147 5.38 x 4.5
60811 60311 46147 5.38 x 4.5
60809 60309 46151 5.38 x 6.5
60812 60312 46151 5.38 x 6.5
60813 60313 46151 5.38 x 6.5
60744 60244 46150 5.38 x 7.5
60728 60228 46133 5.38 x 8.5
60733 60233 46133 5.38 x 8.5
60747 60247 46134 5.38 x 9.5
60750 60250 46134 5.38 x 9.5
60786 60286 46134 5.38 x 9.5
60808 60308 46134 5.38 x 9.5
60755 60255 46132 5.38 x 10.5
I'll be getting the 80754 for my Gen2.
Gen1 - ?
Gen2 - 3.5" x 6"
MS6 - ?
Others - ?
Original Post Below for reference:
While I'm waiting on these group buys to end or take money (mummbling) I got bored and had to find something to do lol.
Previously I put PRC Spacers on the rear coils to help with lauching and/or extra grocery and stuff overload in the back. I know it's ghetto but it helped alittle.
http://www.mazdaspeedforums.org/foru...y-out-lol.html
This Air Lift Kit is a step up between spacers and air shocks but not by much lol. These will have to be modified alittle since they don't make one for our cars. I got the closest to the rear coil inside dimensions 3"x9" air bag #60756 , the next one closest would be 3.44"x8.75" #80753 .
Cut the top at the marks with hand saw or saw saw.
Drill about half way down with a 1" paddle bit.
Squeeze the air out of the bladders and put the black cap back on so it will keep the shape.
Removed the PRC Spacers.
Stick the upper block in cuz it will be harder if you do it after you put the bladder in.
Fold and push in the bladder.
Fold and insert the lower doughnut waffer in.
Start adjusting everything.
Start putting the hoses together (USE WD-40 cuz these are very hard to put on).
Drilled a 5/16" hole in rear lower bumper lip.
I put silicone vacuum hose on the lines where they might/would rub and zip tied them up.
At about 27psi it really picks the car up lol.
This is 15psi will test drive it tomorrow.
Minimum air should be at 5psi and a maximum of 35psi for these air bladders. I will probably use 10-15psi daily and 20-25psi with a load. Drag strip will be 35psi to help with launch lol. Enjoy.
Update:
I had to go bigger on the upper block hole from 1" to 1.5". The 1" was sitting on the coil plate bolt washer and cocking off center. 1.5" lets it sit more flush now, wider balance surface.
Jhornbrook likes this.
The Following 25 Users Say Thank You to bioevolve For This Useful Post:
802MS3 (05-08-2009), AmillieMS6 (03-19-2011), Boosted Beluga (06-13-2013), breakfstincluded (12-20-2012), Dano (03-26-2011), darkcherry (08-07-2013), Dash08 (04-10-2011), Easter Bunny (03-19-2014), Fail_6 (12-12-2013), fishin53 (01-18-2013), Hectik1 (03-19-2011), labikesrcool (05-01-2009), miguelbates (05-02-2009), mouse0330 (05-02-2009), Outlaw4shrt (12-02-2012), PapaSmurf (03-07-2014), redboat (06-13-2013), RichieRichness (10-24-2012), rigor (06-11-2011), Speed3eak (03-26-2011), Sport6 (03-24-2011), Tomas (03-14-2011), toprock (11-05-2009), TWOptSL0W (04-29-2012), wolly6973 (10-25-2011)
 Old 05-01-2009, 04:38 PM   #2
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
I used to use one of these in my left spring on my mustangs to help launch the car at the track.
bioevolve (05-01-2009)
 Old 05-01-2009, 04:45 PM   #3
Alittle Faster
bioevolve's Avatar
LMAO, to help with that twist and corner squat eh lol.
 Old 05-01-2009, 05:19 PM   #4
boosted3's Avatar
Posts: 855   (View Stats)
boosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the world
Groans: 49
wtf good write up.So these arent liek air bags to raise and drop a car.is this for performance and ride quality...
boosted3 is offline   Reply With Quote
The Following User Says Thank You to boosted3 For This Useful Post:
 Old 05-01-2009, 05:37 PM   #5
Alittle Faster
bioevolve's Avatar
Yeah just for raising and performance for launch, also for keep from bottoming out when you have a load. Besides I have tall tires on so this will help me alot lol. 245/45/18.
 Old 05-01-2009, 06:48 PM   #6
boosted3's Avatar
Groans: 49
i see i see.nice job
bioevolve (05-04-2009)
 Old 05-03-2009, 05:58 PM   #7
Alittle Faster
bioevolve's Avatar
Welp, drove it around. OH MAN! Talk about a solid feeling launch. On stock suspension when you shift, before the car tends to rock back and forth when shifting or launching. Now you just shift and it goes no rock, just a little up and down on the front. At 15psi it's a little bouncy in the rear, but not to bad. It seemed to help with cornering giving the front tires more bite, since the weight is now more on the outside front corner of a turn. Feels like less understeer (until you brake traction), abit more oversteer.
All in all this is an great single mod that does more than one thing! I think so anyways.:phillyb:
 Old 05-03-2009, 06:27 PM   #8
rofl this is awesome. congrats u have the first clown car MS3 haha. sry im just being an idiot as i have never seen this before and it just looks hilarious.
2007speed3 (03-20-2011), bioevolve (05-04-2009), TexasSpeed3 (08-16-2011)
 Old 05-03-2009, 06:57 PM   #9
silverspd3's Avatar
Posts: 298   (View Stats)
silverspd3 is a splendid one to beholdsilverspd3 is a splendid one to beholdsilverspd3 is a splendid one to beholdsilverspd3 is a splendid one to beholdsilverspd3 is a splendid one to beholdsilverspd3 is a splendid one to beholdsilverspd3 is a splendid one to behold
Groans: 43
can i see a pick of the lowest u can go?
forge bpv, cp-e cai
silverspd3 is offline   Reply With Quote
 Old 05-03-2009, 07:23 PM   #10
lol the lowest he can go is if it was never installed.
2007speed3 (03-20-2011), bioevolve (05-04-2009), wolly6973 (10-25-2011)
 Old 05-03-2009, 07:52 PM   #11
I<3Groceries's Avatar
Posts: 1,988   (View Stats)
That's crazy. I've never seen such a thing.
The Following 2 Users Say Thank You to I<3Groceries For This Useful Post:
bioevolve (05-04-2009), tddvrrn (11-02-2011)
 Old 05-04-2009, 04:49 PM   #12
Alittle Faster
bioevolve's Avatar
Update:
 Old 05-04-2009, 05:02 PM   #13
danesti's Avatar
Posts: 4,186   (View Stats)
danesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the worlddanesti is the leader of the world
Groans: 137
so this is what people do in cape snoral?
i want 60 ft times.
and your avatar for weird sex things.
2008 STi
Intake
Turboback
AP
danesti is offline   Reply With Quote
The Following User Says Thank You to danesti For This Useful Post:
 Old 05-08-2009, 05:26 AM   #14
Alittle Faster
bioevolve's Avatar
i want 60 ft times.
Yeah, when we get bored lol.
I want times also, someone do this and take it to the track. Record 5psi (which will be like stock) and 35psi consistent launches, should be a decrease in time anywhere from .2-.4 sec in the 60ft mark.
The Following 2 Users Say Thank You to bioevolve For This Useful Post:
danesti (05-08-2009), wolly6973 (10-25-2011)
 Old 11-05-2009, 07:55 AM   #15
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
.2 to .4 seconds?!?!
I think thats a lofty goal, especially for those running track tires and already running 1.90's. I think a half a tenth to a tenth is more likely.
The Following 2 Users Say Thank You to socks For This Useful Post:
bioevolve (11-05-2009), wolly6973 (10-25-2011)
 Old 11-05-2009, 02:46 PM   #16
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
hah i've never heard of these either. they look like a great idea though, i could definitely see how it would help. haha the car lifted up like that looks hilarious though, people will think you're taking your cx-7 down the quarter.
The Following 2 Users Say Thank You to madvillain For This Useful Post:
 Old 11-05-2009, 06:17 PM   #17
reddeerspeed3's Avatar
Posts: 689   (View Stats)
reddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the world
i had thought about doing this for the track and also for possibly towing a little tent trailer. keep us updated
reddeerspeed3 is offline   Reply With Quote
The Following 2 Users Say Thank You to reddeerspeed3 For This Useful Post:
 Old 11-06-2009, 06:44 PM   #18
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
i thought about this for my wifes fat friends, probably be sitting at 35psi most of the time.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
The Following 4 Users Say Thank You to nyghtryder For This Useful Post:
bioevolve (11-06-2009), brandonlee (12-12-2013), redboat (06-13-2013), wolly6973 (10-25-2011)
 Old 03-13-2011, 07:49 PM   #19
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,785   (View Stats)
I am gonna resuscitate this bitch.
If the OP pr someone else who did this is still around I got a few questions.
How often do you need to re-inflate the bags, or how long does a 5-10 psi pump on the bags last before a re-inflating?
Any reliability issues? Hoses kinking or bags rubbing against spring causing them to rupture?
MAKE LOVE TO THE CANVAS
bioevolve (03-09-2014), RichieRichness (10-24-2012), wolly6973 (10-25-2011)
 Old 03-19-2011, 05:32 AM   #20
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Groaned at 9 Times in 6 Posts
Interesting.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
Hectik1 is offline   Reply With Quote
The Following User Says Thank You to Hectik1 For This Useful Post:
 Old 03-19-2011, 11:11 AM   #21
nyghtryder's Avatar
i dont have these since im going coilovers but ive used them on other vehicles. they are designed to rub on the spring and not wear very much. they will have to be replaced every few years though since they are a wear part. environment conditions contribute the most to their life span ie, on the west coast smogs going to eat them and on the east coast the cold is going to make them brittle over time. lines wont rupture or break unless you did a poor install initially. if you want to go crazy you could always use ss braided lines but with such low pressures its really not necessary.
your going to loose about 2psi a week depending on oat.
when i was considering doing this i was going to get an onboard compressor with a guage in the cabin so i could monitor and change pressure on the go. it was only going to cost about 100 extra.
NATOR PA
bioevolve (03-09-2014), RichieRichness (10-24-2012), Tomas (03-24-2011), wolly6973 (10-25-2011)
 Old 03-19-2011, 09:36 PM   #22
Bob Ross Fanclub
Tomas's Avatar
I installed them last week end. So far I like it. I am running 7-8 psi and its just the right amount of pressure so the car doesn't squat anymore and not too much so it's not bouncy.
An onboard compressor is certainly an option but I change tires to go to the track about once a month and with that of course I check pressures. Don't want to lay cables all over the place to monitor pressure and power the compressor - yet. May be in the future.
For 90 dorrah I think this is a great mod.
Outlaw4shrt likes this.
bioevolve (03-09-2014), Sport6 (03-24-2011), wolly6973 (10-25-2011)
 Old 03-23-2011, 06:25 PM   #23
nyghtryder's Avatar
biggest plus of onboard compressor is being able to change tire pressures while at the track.
NATOR PA
The Following User Says Thank You to nyghtryder For This Useful Post:
 Old 03-23-2011, 09:02 PM   #24
rigor's Avatar
Posts: 2,397   (View Stats)
rigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the worldrigor is the leader of the world
Groans: 40
i was thinking of this also! it will work well, if i get hooked up good out of the hole, it will bang on the rear bump stops, and screw your traction this will stop that
good job man!
the only thing i would of done different, is after they are filled, have a small isolation valve to keep the air from going from one bag to the other..
but that will only be noticed in cornering
BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw
472 hp 461tq virtual dyno and ran out of fuel!
nishan said theirs a easy 550 in the setup if i had the fuel but meh...
54,000 miles big turbo! stock block
at 104000 2 bent rods
current miles 113000 and runs perfect! no hiccups!
tuned by nishan
rigor is offline   Reply With Quote
The Following 3 Users Say Thank You to rigor For This Useful Post:
bioevolve (03-09-2014), Tomas (03-24-2011), wolly6973 (10-25-2011)
 Old 03-24-2011, 06:36 AM   #25
Bob Ross Fanclub
Tomas's Avatar
holly shit. that's a good point.
The kit comes with two valves so one could just inflate the bags separately.
What kinda isolation valve are you thinking of? I guess one could use two check valves after the tee or just any type of valves.
Inflate bags, close valves. go.
edit: check valves wouldn't work.
bioevolve (03-09-2014), wolly6973 (10-25-2011)
 Old 03-24-2011, 06:44 AM   #26
nyghtryder's Avatar
you could get two air check vavles, they auto close so theres no need to get under the car.
NATOR PA
The Following 2 Users Say Thank You to nyghtryder For This Useful Post:
 Old 03-24-2011, 10:11 AM   #27
rabble rabble
802MS3's Avatar
Posts: 5,315   (View Stats)
Groans: 221
Tomas, did you get them to use at the track, or just when the car is loaded? whats your suspension setup?
'08 CWP MS3 w/ T3 3071r
The Following 2 Users Say Thank You to 802MS3 For This Useful Post:
 Old 03-25-2011, 06:54 PM   #28
Bob Ross Fanclub
Tomas's Avatar
You are right. It would. But if one side for whatever reason either gets more air while inflating or looses air faster than the other you are going to have pressure imbalance. You also wouldn't know how much pressure is in the actual bag if the lines going to the bag loose pressure faster than the line+bag after the check valve.
What I did is buy a volume control valve. You can set it so there is barely any air moving through it so that the pressure stabilizes but doesn't go from one side to the other while cornering. Or at least just barely.
In retrospect I am actually thinking if you use separate tire valves for each side that one might be able to sort of use it to corner weigh the car?
I am running Koni FSD 4045 with the front knuckle stops trimmed to lower the front. Rear bump stops are also trimmed. I also haz tri point RSB and hotchkiss FSB. Was on h&R springs but ride was too tough for my sissy ass so I went back to stock springs.
Next track day for me is APR 9.
I'll post some impressions soon thereafter.
Edit: BTW. I went to school at Saint Mikes. Best time of my life. I fucking love VT.
 Old 04-06-2011, 05:16 AM   #29
rigor's Avatar
Groans: 40
do you like them so far?
tuned by nishan
The Following 2 Users Say Thank You to rigor For This Useful Post:
 Old 04-06-2011, 03:13 PM   #30
Bob Ross Fanclub
Tomas's Avatar
I like them mucho mucho
bioevolve (03-09-2014), rigor (04-07-2011), wolly6973 (10-25-2011)
 Old 04-06-2011, 06:22 PM   #31
rabble rabble
802MS3's Avatar
Groans: 221
So are the stock springs not stiff enough for you? I don't think I'm getting the point as to why you would need these for the track.
Ha St Mikes huh. What year did you graduate? I went to Champlain, '08. I had a buddy that went there. I partied a handful of times on that campus, but I swear those kids never left their little area. I think I got my buddy to come party downtown maybe once the whole time he was at St. Mikes. But yeah, VT is cool. My job pays for half of my ski pass, and the summers up here are pretty amazing; everything is so green. Just too many fucking cops. Can't wait for my first track days down at NHMS this summer. I've been paranoid about speeding for far too long...
 Old 04-06-2011, 06:39 PM   #32
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
get that raked look hot rod style son
The Following User Says Thank You to rodrigo For This Useful Post:
 Old 04-07-2011, 06:55 PM   #33
rigor's Avatar
Groans: 40
to stop rear squat on take off...
does it help with traction out of the hole?
tuned by nishan
 Old 04-10-2011, 01:42 PM   #34
Bob Ross Fanclub
Tomas's Avatar
The initial reason for getting these is related to the FSDs. They don't have a lot of compression damping in the rear and I rub on 225/40/18 on stock rims. Not much and only when I do laps and the rear is fully compressed riding the bump stops on some high speed drops.
This is what the squatting looks like
They also help with traction when you hit the pedal on corner exit.
I graduated St. Mike late 90's so can't say how the atmosphere is there now. I can tell you however that when I was there if I wanted to party I went to Montreal. Less than 2 hours away IIRC. Club Zona. Used to be open all night till noon on Sunday. Rolling all night. Lots of E everywhere. Then crossing the border with pupils the size of fried egs. Yeah, those were the days. I miss that shit.
Yes they do.
The Following 4 Users Say Thank You to Tomas For This Useful Post:
802MS3 (04-10-2011), bioevolve (03-09-2014), rigor (04-10-2011), wolly6973 (10-25-2011)
 Old 04-22-2011, 05:09 PM   #35
:: Gusto ::'s Avatar
Posts: 1,454   (View Stats)
mm i need these on my ms6.. i hate that my rear end squats...
yea yea - i know i cant spell
 Old 05-16-2011, 08:42 AM   #36
nyghtryder's Avatar
probably the best thing for you would be running each bag independantly with a single air guage with dual needles so you can guage both sides seperately.
if you want to get a little crazy you could get electric valves smc makes great ones. you would have complete control from the cabin. get a little 2 gal air tank with a compressor and you would have all the air and control you could ever need.
NATOR PA
 Old 05-16-2011, 03:34 PM   #37
Bob Ross Fanclub
Tomas's Avatar
individual air valves is what I ended up doing. I always carry compressor and air tank to the track with me. Inboard set up would be kewl but I prefer to keep it simple.
 Old 05-17-2011, 07:15 PM   #38
ManMan's Avatar
Posts: 35   (View Stats)
ManMan is just really niceManMan is just really niceManMan is just really niceManMan is just really niceManMan is just really nice
What's the leak down like on them? I'm really considering this for my ride
2007 MS3 - Koni 4040 FSDs, Cobb SRi, Cobb AP Stage 1+, DIY shifter bushings, CorkSport RMM inserts, Hawk HPS, Slotted rotors, SS Lines.
ManMan is offline   Reply With Quote
The Following User Says Thank You to ManMan For This Useful Post:
 Old 05-18-2011, 06:29 PM   #39
Bob Ross Fanclub
Tomas's Avatar
With 8-12 psi you barely lose a pound in a month. With more pressure it could be the depletion rate is higher but I really only go 20-25 pounds at the track. Street driving at this pressure gets pretty bouncy.
 Old 06-11-2011, 11:07 PM   #40
rigor's Avatar
Groans: 40
ordered mine today joined the club i guess lol
tuned by nishan
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f12/uhhhhh-air-lift-kit-1000-a-26986/
Tein S-tech neuve - Mazda 3 Quebec This thread Refback 02-17-2015 06:35 PM
Where to buy air bags (for towing) for Mazda 3? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 12-22-2014 04:23 PM
Kit air lift 1000 avec compresseur (Universel, Jetta IV entre autres) This thread Refback 10-20-2014 02:14 PM
À vendre : Air Lift 1000 et JBR camber arms - Mazda 3 Quebec This thread Refback 06-30-2014 11:08 AM
How to go about stiffening ride for heavier load? - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Refback 08-04-2013 08:53 AM
Ajustement de suspension et barres de traction pour le drag??? - Mazda 3 Quebec This thread Refback 02-27-2013 01:29 PM
Spy Shots: Face-lift Ferrari 599 GTB Fiorano on its way? Haltech Automotive News 0 04-01-2009 03:00 PM
BMW reveals race-ready S 1000 RR Haltech Automotive News 0 10-11-2008 01:10 PM
Redline hood lift question Zeya MazdaSpeed 3/6 - Appearance 17 09-29-2008 01:21 PM
In the Autoblog Garage: Aprilia RSV 1000 R Haltech Automotive News 0 07-26-2008 10:21 AM
Page generated in 0.67278 seconds with 38 queries
