> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
Like Tree121Likes
 Old 03-07-2015, 08:58 PM   #241
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,787   (View Stats)
The dimples on the balancing shaft ends should point downward like this when at TDC.
MAKE LOVE TO THE CANVAS
Mauro_Penguin (05-11-2015), torquemaniac (03-08-2015)
 Old 03-08-2015, 05:24 AM   #242
torquemaniac's Avatar
Posts: 730   (View Stats)
Originally Posted by Tomas View Post
Hmmmm don't think so. It's not a closed loop circuit. Oil goes into oil galleries and then drops into oil pan. No such thing as air pockets floating around the lube oil system. If there is air in the system it goes out in less than 10 seconds once oil is being scavenged by the oil pump. Unless there is no oil in the pan and the pump just sucks air of course
Then it remains a mystery...
2011 CX-7 AWD 2.3 turbo
Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner
 Old 03-08-2015, 05:35 AM   #243
The dimples on the balnace shaft wheels where down indeed (see post#134)
 Old 04-03-2015, 05:10 PM   #244
The weather was warm and cozy today...and the wife gave me the OK to take the day for modding so I did some test fitting
The engine bay is a real mess...forgot to put the weather strip before winter
Noticed that the weld on the v-band of my modified M2 downpipe was broken...the only thing that keeps the downpipe in place is the alternator heat shield...good thing that piece of crap is coming out
I had bought some 4'' piping for the intake but hopped to be able to run the dryflow filter directly on the turbo, but the filter is somewhat crushed by the valve cover, so I went with the 4'' tubing (had to cut the A/C bracket for the intake pipe and relocate the small fuse box on the passenger side)
The 2.5'' tubing I bought for the hot pipe is too short by a couple inches, so I made a mock-up in high-density foam...hope the mock-up will do the job when I copy with the aluminum tubing
The MAF pipe between the IC and throttle body fits perfectly, but the radiator hose will need to be replace because it comes in contact with the pipe
The wastegate will be a real bitch to position...why are those things so massive
FatSauze and Ozynigma like this.
The Following 11 Users Say Thank You to torquemaniac For This Useful Post:
Code Monkey (04-03-2015), daafisch (04-15-2015), Dano (04-09-2015), KingOfSpades007 (04-07-2015), Mauro_Penguin (05-11-2015), ms3blackmica (04-03-2015), rob ms6gt (04-06-2015), SonicNutrition (04-04-2015), theschrum (04-19-2015), Tomas (04-06-2015), [R]usty (04-10-2015)
 Old 04-15-2015, 09:38 AM   #245
ms33's Avatar
Posts: 16   (View Stats)
ms33 is an unknown quantity at this point
This build looks fking amazing !! I wish i was around you so you could teach me some stuff !!
Mazda CX-7
-HID All Around 8k 55W
ms33 is offline   Reply With Quote
 Old 05-10-2015, 04:29 PM   #246
Hot side pipe and MAF pipe are finished...just need to paint them with VHT platinum silver blue (compressor housing and valve cover will also be painted the same, and the intercooler will be painted with textured black paint...it will look like OEM stuff)
The intercooler was ported on the cold side to give a smooth transition from the 2.60ID to the MAF pipe 2.87ID
Female studs were glued to the intercooler side for support of the meth tank (a stainless bracket was also fabricated to fix the intercooler on the chassis)
Decided to get a compact Tial MV-S 38mm external wastegate so I could position the wastegate like I wanted...this thing is like jewerly
For the oil feed line I opted to go with the stock banjo fitting and some braided stainless line
The only critical part left to fabricate is the oil drain line coming from the turbo (I got some stainless tubing...just need to bend that shit properly so it passes between runner #2 and #3 )
The build will finally be done on the first 2 weeks of June...schedule some off time just for this
adamizme (05-10-2015), cld12pk2go (05-16-2015), Code Monkey (05-10-2015), Easter Bunny (05-11-2015), FatSauze (05-11-2015), KingOfSpades007 (05-16-2015), Mauro_Penguin (05-11-2015), NoRegrets (05-14-2015), Ozynigma (05-10-2015), rob ms6gt (05-30-2015), Zdraveca (05-10-2015)
 Old 05-10-2015, 05:25 PM   #247
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Zdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the world
Groans: 145
Groaned at 80 Times in 77 Posts
You my friend are winning!
2011 MS3"Princess GRU"
GT2876r
AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8,
E85 FREEKTUNE
Zdraveca is offline   Reply With Quote
 Old 05-10-2015, 05:32 PM   #248
LOL...if only it was lotery...would make this thing even more awesome
Zdraveca likes this.
 Old 05-10-2015, 06:57 PM   #249
Ozynigma's Avatar
Posts: 736   (View Stats)
Ozynigma is the leader of the worldOzynigma is the leader of the worldOzynigma is the leader of the worldOzynigma is the leader of the worldOzynigma is the leader of the worldOzynigma is the leader of the worldOzynigma is the leader of the worldOzynigma is the leader of the worldOzynigma is the leader of the worldOzynigma is the leader of the worldOzynigma is the leader of the world
So why the blow through MAF? It seems to add a complication to MAF calibration and tuning.
Great work on the fabrication. Looking forward to seeing this finished.
I have just bought a leak down tester on eBay to check my engine health before considering more mods.
CX7 - The younger, taller and sexier replacement for the MS6.
2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified
Ozynigma is offline   Reply With Quote
 Old 05-11-2015, 06:16 AM   #250
FatSauze's Avatar
Posts: 61   (View Stats)
FatSauze has a spectacular aura aboutFatSauze has a spectacular aura about
Cant wait to hear this beast when shes running.
/CS SRI/CS TIP/CS INTERNALS/CP-E EXHAUST/CP-E TMIC/FORGE BPV V2/AUTOEXE STRUT BAR/VERSATUNE/
FatSauze is offline   Reply With Quote
 Old 05-11-2015, 07:15 AM   #251
Jeff23spl's Avatar
Posts: 1,813   (View Stats)
nice progress! keep going, we want to see that beast running !
Will you make some kind of heat shield for the oil drain tube between runners?
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 05-11-2015, 09:29 AM   #252
reko's Avatar
Posts: 26   (View Stats)
reko is a glorious beacon of lightreko is a glorious beacon of lightreko is a glorious beacon of lightreko is a glorious beacon of lightreko is a glorious beacon of lightreko is a glorious beacon of light
Nice job on this custom project.
Any chances you're a member of m3q?
Cheap, fast, reliable.
Pick two.
reko is offline   Reply With Quote
 Old 05-11-2015, 09:46 AM   #253
I went with blow-thru MAF because :
- the MAF wiring wasnt long enough to get to the intake (didnt want to mess with the wiring)
- 4'' intake can be tricky to calibrate
- will run a BOV (its actualy my Forge V2 BPV vented to ATM)
- other reason I dont remember
The manifold will be heavily wrapped with DEI titanium exhaust wrap, and the drain tube will be covered with a heat protective sleeve
Im a member on m3q, but not an active one
Last edited by torquemaniac; 05-11-2015 at 09:46 AM. Reason: MSF Database - Automerged Doublepost
 Old 05-11-2015, 10:32 AM   #254
sokowoski23's Avatar
Posts: 28   (View Stats)
sokowoski23 is on a distinguished road
This build as absolutely incredible. I just spent the last half hour reading it all. First, major props for being an individual on this build. You did some serious homework when it came to this. Second, your fabrication work is incredible. I've never witnessed someone fab up so many parts for these cars. And last thing, I can not wait to hear this thing scream! Good luck with the rest of your build man.
reko likes this.
sokowoski23 is offline   Reply With Quote
 Old 05-12-2015, 11:38 AM   #255
Fingerlicker's Avatar
Posts: 132   (View Stats)
Fingerlicker has a reputation beyond reputeFingerlicker has a reputation beyond reputeFingerlicker has a reputation beyond reputeFingerlicker has a reputation beyond reputeFingerlicker has a reputation beyond reputeFingerlicker has a reputation beyond reputeFingerlicker has a reputation beyond reputeFingerlicker has a reputation beyond reputeFingerlicker has a reputation beyond reputeFingerlicker has a reputation beyond reputeFingerlicker has a reputation beyond repute
Incredible...Drop the mic, mind BLOWN!!!
Fingerlicker is offline   Reply With Quote
 Old 05-12-2015, 12:09 PM   #256
sh4d0w's Avatar
Posts: 565   (View Stats)
sh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the world
Groans: 45
Groaned at 7 Times in 4 Posts
In cause this shit is amazing!
2010 Black MS3
Cobb AP // Cobb EBCS // Cobb Downpipe // Cobb RMM // JBR Tru 3.5'' Intake // JBR TMM // JBR PMM // JBR RSB // CP-E Cat Back // NGK One step colder plugs // GT 3071r // Azenis 615k // Bilstein PSS B14 Coilovers // Treadstone TR8 FMIC // Bully Stage 4 Clutch // Damon EGR Delete // Autotech HPFP // AEM V1 Meth Kit 50/50 // Freektuned 94 Oct
sh4d0w is offline   Reply With Quote
 Old 05-12-2015, 07:46 PM   #257
Killer95GT302's Avatar
Posts: 198   (View Stats)
Killer95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond reputeKiller95GT302 has a reputation beyond repute
Subbed - Lot of skill and patience exhibited here can't wait to see the outcome
2006 Mazdaspeed6 - Bone Stock!
1995 Mustang GT - Turbocharged / Motor work
Killer95GT302 is offline   Reply With Quote
 Old 05-28-2015, 11:36 AM   #258
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
looks good man. How are you able to get air flow up the intercooler?
Project_dog is offline   Reply With Quote
 Old 05-28-2015, 02:41 PM   #259
Ozynigma's Avatar
See posts 2,7 and 39 on page 1. Its a liquid to air intercooler.
EvilMmotorsports likes this.
The Following User Says Thank You to Ozynigma For This Useful Post:
torquemaniac (05-28-2015)
 Old 05-28-2015, 03:56 PM   #260
For all questions about the build, please contact M.Ozynigma (my assistant)....LOL
The Following User Says Thank You to torquemaniac For This Useful Post:
Code Monkey (05-28-2015)
 Old 05-28-2015, 04:08 PM   #261
Ozynigma's Avatar
Unpaid assistant I might add. Sometimes the global time difference makes it easier for me to answer questions while you have a sleep in....
Actually now I am contemplating a LtA IC too. TMIC and WMI will probably be enough for my hp goals but I will be interested to hear how well LtA performs on yours.
Last edited by Ozynigma; 05-28-2015 at 04:08 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-28-2015, 04:16 PM   #262
Code Monkey's Avatar
Posts: 7,666   (View Stats)
An LTA IC will be fine for daily driving and drag racing. If you plan on road racing your car, go air-to-air IC.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
Mauro_Penguin (05-29-2015)
 Old 05-28-2015, 04:18 PM   #263
I think TMIC are a bad idea, like FWD...lol...the heatsoak is inevitable with the intercooler siting over the engine, especialy in stop and go driving
I will post detail of my LTA setup tonight and show pics of my new stuff (oil drain line, meth injection throttle adapter, coolant overflow tank...)
 Old 05-28-2015, 04:29 PM   #264
Yup...when you have a good air supply up front, air-to-air is best (FMIC)
 Old 05-28-2015, 04:29 PM   #265
Ozynigma's Avatar
Thanks, that sounds like good advice.
So you differentiate between daily driving and drag racing ?
The only race track my CX7 will ever see is about ¼ mile long with no corners and that will just be for fun to see what it can do.
I think part of the poor performance of the CX7 from a standing start in traffic is heatsoak and high BATS leading to the ECU compensating. WMI will help compensate for that. So at the moment I am planning to switch from E30 to WMI for octane boosting.
I don't know how torquemaniac plans to drive his but mine is a lot of fun to drive as a sleeper and give people a shock when the lights turn green and this 1800kg "car" sprints off into the distance (leaving a haze of black smoke from running a bit rich).
 Old 05-28-2015, 04:33 PM   #266
No, I differentiate between drag and road racing.
Ozynigma likes this.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 05-28-2015, 04:47 PM   #267
I also like to drive it hard, but I got used to the extra HP/TQ and am bored now...also, the freakin hybrid boost control setup is not working as planned (poor boost response)...i will go with a simple 3-port with the HY35
I cant wait to push around 30psi of boost...its gonna be real amazing
 Old 05-28-2015, 06:12 PM   #268
LTA setup
Since the system will be filled with vacuum (got a pump that can pull -29in/hg) to prevent air pocket, I decided to put an overflow tank to make space for coolant expansion (the overflow tank is right over the pump suction side...there should be a nice vortex in the tank when the pump is running)
Top port is for the vacuum line
Meth adapter for the throttle body
Stainless compression spring for the valve body upgrade
Parts of the exhaust build kit...Vibrant race cat and bellow for the dump pipe...only thing left to do is the venturi slashcut for the exhaust to PVC line
And finally the dreaded oil drain line...this was a real PITA to bend properly
The fit of the drain line is very close to the manifold runner, but this is the best I can do with the top-mount setup while respecting the Holset specs
Estimated upper and lower drain line mating (rubber hose will be cut to during the fit on the engine)
Super-duper hose...this shit needs to be cut with a saw (metal wire reinforced)
cld12pk2go and Code Monkey like this.
The Following 5 Users Say Thank You to torquemaniac For This Useful Post:
cld12pk2go (05-30-2015), Code Monkey (05-28-2015), Dano (05-28-2015), KingOfSpades007 (05-29-2015), Mauro_Penguin (05-29-2015)
 Old 05-28-2015, 07:10 PM   #269
unijabnx2000's Avatar
Posts: 35   (View Stats)
unijabnx2000 is just really niceunijabnx2000 is just really niceunijabnx2000 is just really niceunijabnx2000 is just really niceunijabnx2000 is just really nice
Groaned at 4 Times in 2 Posts
exhaust wrapping the manifold and the oil drain?
unijabnx2000 is offline   Reply With Quote
 Old 05-28-2015, 07:15 PM   #270
Absolutely...DEI titanium exhaust wrap...
 Old 05-29-2015, 10:21 AM   #271
Jeff23spl's Avatar
Dont forget the weight and the atx tranny but for BAt at iddling, the main cause seem to be the map sensor sit inside the aluminium intake bolted to the engine head. even with a fmic, the air temp rise when there isn't much air flow around the map to cool it down. As soon as you create more air flow around the map, you read the real air temp entering the intake and see the bat droping quickl. It is probably worst with tmic but at iddle, you barely read intake metal temperature. plastic gasket could delay the result but i if someone know about a way to keep bat low at iddle, please tell me...
Wife drive 2010 CX7
Ozynigma (05-29-2015)
 Old 05-29-2015, 03:21 PM   #272
Changing the BAT sensor location could be a good start : Throttle Body Spacer
A real thick and insulating manifold gasket could also help (like 1'' thick Macor ceramic with PTFE on both side for sealing)
 Old 05-29-2015, 04:31 PM   #273
Posts: 9,484   (View Stats)
FWIW I am running one of the JBR or SU 1/4" PTFE IM gaskets and it made a considerable difference in "measured" BATs. I can't imaging you having enough clearance for a 1" thick gasket...at least not with the MS3...the CX7 may have much more room.
again, I have to say very impressive work going on over here. It's always great to see the path less taken being the choice.
Example:
I have a buddy with a low mount GTX3582 on an '02 bugeye (subbie), complete custom build with a larger LAIC core than you have who is having some interesting trouble keeping things cool. roughly 600whp. He is running one of the Cobra heat exchanges (single pass IIRC) with cobra pump, top mount IC wrapped with a ton of insulation. at 80F * AMB temp he sees 140F BATs in a multi gear pull.
He is looking at building a 2 loop ice box system.
couple things here that may be causing the issue: he has an e-bay IC core, and a single pass HE, plus he is top mount. So with about the same investment in trialing the replacement of those he is looking at the modified icebox setup.
Loop 1 is the coolant filled LAIC system that will circulate, via home made copper coils through an igloo cooler filled with ice and rock salt, mounted in the trunk. (don't want to introduce salt to the main system due to corrosion.)
Loop 2 is the icebox with rock salt, ice and water. (IIRC typical ice box systems are 1 loop and only ice/water)
he will have a diverter valve to remove the heat exchanger from the loop when running the ice box (road race/Autox/drag) HE would actually heat things up in this scenario.
he can also use dry ice, although you'd have to be careful not to freeze the main loop at -100F temps of dry ice...lol
should be a cool setup/experimant if all pans out (pun intended)
looking forward to see how your LAIC setup pans out.
 Old 05-29-2015, 05:45 PM   #274
Example:
Does your buddy have a thread I can take a look at...just curious
One of the important thing about LTA setup, is to get rid of air pocket in the system...air trapped in the top part of the IC and heat exchanger can drasticaly affect the system cooling capacity (the Cobra pumps flow is not that great, so air pocket can easily set in)
Flow (gpm) is know to improve cooling capacity, but good pumps for LTA setup are pretty expensive (300$+)
From what I read, single pass vs dual pass heat exchanger performance difference are not that big...its mostly a question of intake and exit port position
If your buddy's build is fully custom, did he take care of air flow management through the engine bay...if the flow is not right, the heat exchanger wont do much...
If the intake is in the engine bay (SRI), the turbo is pumping already hot air, and this can be made worse with bad flow through the engine bay
I can share some link about air flow management if you want....its pretty easy to measure pressure zones in the engine bay with a Magnehelic gauge!
Dano (05-29-2015)
 Old 05-29-2015, 09:30 PM   #275
thanks for the input on the various potential issues...I know zero about LAIC.. I'll pass those along and see where his thread is.
 Old 06-01-2015, 06:48 AM   #276
Jeff23spl's Avatar
I never tried a thickier gasket because i would expect it just delay the time it takes for the IM to reach the same temperature. But if Dano say it help a lot, i will think about it once more...Maybe the air flow can cool the whole IM and the gasket retain enough heat to be beat by air flow cooling...?
The TB spacer with map relocation is a very nice idea. I may try this one first. Peoples that replace the map should probably left the oem one at stock location and use that spacer with the new map and the convertion pigtail...Since it is a pressure and T reading, i don't see any problems of doing it...?
Wife drive 2010 CX7
 Old 06-01-2015, 07:11 AM   #277
CockWarner's Avatar
Posts: 265   (View Stats)
CockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the worldCockWarner is the leader of the world
@torquemaniac; -- @Travisms3; can probably lend a bit of insight. He's been running a custom LTA setup, and is in the process of re-designing it to better perform. One of his main gripes with his current setup is related to the pump -- just not enough flow. The pumps are expensive, yes -- but without a good pump, you're not going to stay cool for long.
2011 MS3
GT3071 EWG | Cobb AP v2 | Autotech Internals | HTP 3.5 | ETS TMIC | CP-E Downpipe | CP-E Triton | DIY PnP Intake Manifold |
Cobb XLE BPV | Grimmspeed EBCS | Bosch 3-Bar MAP | DM OCC | DM PMM | JBR 88 Duro RMM | JBR 88 Duro TMM | Kozmic EGR Delete | JBR TB TIG & Coolant Bypass
CockWarner is offline   Reply With Quote
 Old 06-01-2015, 07:55 AM   #278
Travisms3's Avatar
Posts: 417   (View Stats)
Travisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the worldTravisms3 is the leader of the world
Yes the pump is key!. I got a cx racing pump because it is rated to flow more than the bosch cobra pump (and its cheaper) but it is crap. Here is the one I'm looking to replace it with
http://www.summitracing.com/parts/mez-wp136s
I have the same issue the subbie above has, my BATs climb through out a pull. But 15 seconds later they drop right back down. I believe this is due to lack flow, so the water in the intercooler is not flowing through the system fast enough. I noticed an improvement when I went to larger lines and fittings. @Dano; I would have your friend upgrade his pump and look for choke points in the system before adding all of those complicated ice box loops for marginal improvement.
I have also considered putting additional inlets and out lets on the intercooler because I feel that there are sections of the intercooler that are not flowing water evenly.
Travisms3 is offline   Reply With Quote
 Old 06-01-2015, 09:50 AM   #279
Jeff23spl's Avatar
We had a guy that poster a LTA project for ms3 in our m3qc forum and he started with a small core and had is BAT going too high during long wot pull. According to what he said, he got delta T of abou 45-50F between is IAT and BAT during these long pull and normal pull was more looking for 20-25F. Still using k04.
He swaped for a larger IC and it seem to help him a lot...
I can't link the post because it is in a private section but according to pictures the last one was looking a bit larger than yours. I will give him the link of this post ask him to show up and talk about it...Maybe he will...
Wife drive 2010 CX7
 Old 06-01-2015, 10:01 AM   #280
I find it odd that all LTA intercooler and heat exchanger on the market have crappy end tanks...this probably affect flow through the core like you stated...this I will investigate for the future, but for now its staying as is because im starting the build today
To be on the good side, I use 3/4ID hose with only straight barb fitting (cuz the 90 degree barb will really hinder flow)...the system will also be filled under vacuum prevent air pocket
One of my early inspiration @bnoon; had a LTA setup that was running great...maybe he can chime in!
If you dont want to pay big dollars for the pump, you can use two Bosch pumps (in-series will increase pressure, and in-parallel will increase flow)
JMEngineer (06-01-2015)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f123/big-turbo-build-cx-7-p-168742/
MS3 50,000km sans OCC... This thread Refback 07-19-2015 03:41 PM
Big turbo cx-7 This thread Refback 06-04-2015 01:18 AM
Tuning Mazda cx-7 - Page 2 This thread Refback 04-20-2015 12:05 AM
Cx 7 moteur et turbo scrap This thread Refback 04-09-2015 02:50 PM
Cx-7 vs cx-9 This thread Refback 04-05-2015 10:52 AM
Hose Intercooler This thread Refback 04-04-2015 05:45 PM
Project Q - Another modder's thread - Page 2 - Alfa Romeo Forum This thread Refback 11-17-2014 12:58 AM
HFS3 install on Mazda CX-7 (2.3T) - waterinjection.info This thread Refback 07-01-2014 12:22 AM
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 01:16 PM
Why not another S3 turbo build! taf0422 MazdaSpeed 3/6 - Big Turbo Builds 187 02-21-2013 01:13 AM
MX-5 EFR Turbo Build Andy@Killshot Miata - Forced Induction 40 12-28-2011 03:01 PM
My big turbo build Speedie6 MazdaSpeed 3/6 - Big Turbo Builds 4 12-09-2010 12:54 AM
Big turbo kit, build one or not? ptperformance Mazdaspeed3/6 General Discussion 33 10-12-2008 01:55 PM
Page generated in 0.67378 seconds with 38 queries
