Mazda Platforms
> CX-7 > Turbo Induction & ECU Tuning
Notices
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
 Old 07-20-2012, 12:52 PM   #1
Grocery Getter
RiceBurn2.3T's Avatar
Posts: 61   (View Stats)
RiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to beholdRiceBurn2.3T is a splendid one to behold
Default Cracked turbo waste gate.
Bought a rebuilt OE Turbo from PureTurbos.com via ebay. They have 100% good feedback and decent priced with a 1 year warranty for $475 w/ free ups shipping.
Got it in the mail and wast gate seat is cracked. Looks like from just wear and tear. This is the second one from them. Exchanged the first one because the cracks were a lot worse then this.
Should I send this one back it are these cracked not a big deal?
Thanks in advance!!
RiceBurn2.3T is offline   Reply With Quote
 Old 07-20-2012, 12:53 PM   #2
ZipTie & Duct Tape Master
TWOptSL0W's Avatar
Posts: 3,090   (View Stats)
Groans: 124
Groaned at 82 Times in 49 Posts
send it back, get your money back, and deal with a legitimate company that doesnt send you broken products...twice
The Following 6 Users Say Thank You to TWOptSL0W For This Useful Post:
ASHMS3 (07-20-2012), dereeek (07-20-2012), nighthawk358 (07-21-2012), Raider (07-22-2012), RiceBurn2.3T (07-22-2012), trf5000 (07-20-2012)
 Old 07-20-2012, 12:57 PM   #3
Posts: 9,590   (View Stats)
That's very common on K04 turbo exhaust housings. If the housing has been reused (ie turbo was rebuilt) you are likely to run into this issue.
 Old 07-20-2012, 01:07 PM   #4
Grocery Getter
Do you think Ill run into any problems with this? Time is an issue...My old Turbo is about to go real soon so if these cracks won't cause any problems, ill just install it.
 Old 07-20-2012, 01:09 PM   #5
trf5000's Avatar
Posts: 1,959   (View Stats)
They will cause an issue because they will spread over time as you heat cycle them.
2010 MS3 VRM - Corn Fed PU
CS CBE, CS RP, CS DP, JBR 80/88 Duro Fully Mounted, TS BPV, CPE HPFP, CS SRI/TIP, CPE-FMIC, AP, NGK Iridiums, GS EBCS in 3 Port Int, JMF IM, Hypnotic Tuned, TWM Full Replacement, E4 Weighted Knob, Eibach Prokit, 18x8.5 Konig Milligrams Matte Black with Machined Undercut, 245/40 18 Fuzion ZRi
Best Run: 13.1 @ 109 1.9 60ft Atco
Slow build in progress
The Following 2 Users Say Thank You to trf5000 For This Useful Post:
Lex (07-20-2012), RiceBurn2.3T (07-22-2012)
 Old 07-20-2012, 03:04 PM   #6
All cracks will grow. You can pull your stock turbo, see if it's in better shape and swap over the exhaust housing from your stock turbo to the rebuilt turbo. Chances are you'll find your stocker also has cracks - especially if it is high mileage.
 Old 07-20-2012, 03:12 PM   #7
Garage Queen
Sid3wayS's Avatar
Posts: 4,309   (View Stats)
Groans: 53
Dude stop waisting your money on people that are obviously fucking you over. Spend $25 and donate here, go into the for sale section and get a non smoking low mile turbo from someone that is going bt, at most they are about $200 bucks shipped for a non smoker with LOWWW miles. Your spending less money and no one here will fuck you over. (and god, buddah and Allah help them if they try)
2010 MS3 W/tech pkg Liquid Silver-Still Slower Then An Asthmatic Snail
Cobb:Ap,Sri,Tip//JBR:Egr,Rsb,IM/TB Tigs,Rmm,Tmm//ATP:Catless long DP
ETS:3.25" TMIC//M/D:OCC//Forge:v.2 BPV//AutoTech:FP Internals//PTP:Seals&studs
Bosch:3-Bar//Grimmspeed:3-port EBCS//Stratified:G.A.//KW:Coilovers//RotaGrids:18x9.5
Meth/E85/Nitrous TUNING BY LEX
Sid3wayS is offline   Reply With Quote
 Old 07-20-2012, 06:02 PM   #8
Grocery Getter
Alright, thanks guys. Ill call them tomorrow and see if they will give me a NEW housing. I like that the internals are brand new but if they won't help me further, ill just get my money back and buy one from someone on here.
Thanks and ill let you all know what they say tomorrow.
 Old 07-20-2012, 06:08 PM   #9
ABSpeed3's Avatar
Posts: 639   (View Stats)
ABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the world
Groans: 117
Groaned at 7 Times in 4 Posts
I second this notion but he's on a cx-7 so finding his ko4 might be a little trickier.
08.5 CWP MS3 GT
PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC
ABSpeed3 is offline   Reply With Quote
 Old 07-20-2012, 07:23 PM   #10
Garage Queen
Sid3wayS's Avatar
Groans: 53
Its the same k04 I thought. Raider you have owned both, is it the same?
 Old 07-20-2012, 07:29 PM   #11
Grocery Getter
...donated ; )
The Following 2 Users Say Thank You to RiceBurn2.3T For This Useful Post:
ABSpeed3 (07-20-2012), Sid3wayS (07-20-2012)
 Old 07-20-2012, 07:34 PM   #12
ABSpeed3's Avatar
Groans: 117
I could be wrong, but I was under the impression the cx-7 was designed to output torque differently than the ms3 ko4s
08.5 CWP MS3 GT
The Following 2 Users Say Thank You to ABSpeed3 For This Useful Post:
RiceBurn2.3T (07-22-2012), Sid3wayS (07-20-2012)
 Old 07-21-2012, 05:53 AM   #13
Grocery Getter
Its a K0422-582. Same as MS3?
 Old 07-21-2012, 07:24 AM   #14
indiscretion
leon78's Avatar
Posts: 1,915   (View Stats)
Groaned at 22 Times in 15 Posts
True story...cx-7's k04 shifts the torque curve to the left....so even less high rpm output than our 3's and 6's...so for what ever reason..BNR wont use the cx-7 for the core change...must be diff some how.
2013 Scion FR-S (Whiteout)
White 17x9 Rota Grids w/ 245's_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP.
leon78 is online now   Reply With Quote
The Following 2 Users Say Thank You to leon78 For This Useful Post:
ABSpeed3 (07-22-2012), RiceBurn2.3T (07-22-2012)
 Old 07-22-2012, 05:15 PM   #15
Scammer Hunter
Raider's Avatar
Posts: 14,850   (View Stats)
Groans: 448
Sorry, was out with the birth of my son.
No, cx7 is smaller.
1) Looking to Buy a used Mazdaspeed? Read this!
2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here.
3) Wanna buy and sell here? DONATE for VIP
4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting!
5) Help MSF grow with FAQ threads!?
The Following 2 Users Say Thank You to Raider For This Useful Post:
RiceBurn2.3T (07-22-2012), Sid3wayS (07-22-2012)
 Old 07-22-2012, 08:36 PM   #16
Grocery Getter
Took your word for it and donated $25 from my very limited turbo repair funds and this is all I found. http://www.mazdaspeedforums.org/foru...im-k04-111844/
Was planning on donating anyway but not quite yet. Money is super tight right now.
So what do you guys think about getting this for $90 then buying a new cartridge for about $280?
Or I also found this on Egay. Its listed as new.New Turbo Turbocharger Mazda CX-7 CX7 2.3L K0422-582 2007-2010 1 year warranty | eBay
Thanks guys for the help!
 Old 07-23-2012, 06:48 AM   #17
Grocery Getter
...So I asked the guy who manufactured this new Turbo. He said its manufactured in Wuxi, China by Hosit. It has a 1 year warranty. Should I buy? Does anyone know someone with one of these? I maybe figure since there are so many problems with the kkk/Warner brand, how bad could this be?...Like I said in another thread about our timing chain fails, maybe we should try another brand sine the oe one fail so often.
 Old 07-23-2012, 06:51 AM   #18
Scammer Hunter
Raider's Avatar
Groans: 448
Fuck no. Post a wtb here and get a good used one and avoid eBay shit.
RiceBurn2.3T (07-23-2012)
 Old 07-23-2012, 11:37 AM   #19
Grocery Getter
I wont be getting this. Im giving PureTurbos one last chance to get it right. They apologized and are sending another one today. He said that this hasn't happen before and I believe him because they have nothing but great feedback. I tend to have bad luck with this type of shit anyway lol.
Anyway, about the china made copy-cat turbo...Its visually an exact replica. The only thing different that I can see is that the waste gate looks slightly different, cheaper looking...Attached are the china made K04...
Sorry, forgot to resize.
 Old 07-23-2012, 01:56 PM   #20
The china turbos may look the same but there are usually tolerance and reliability issues galore. It's just asking for trouble in the long run.
 Old 07-30-2012, 11:25 AM   #21
Grocery Getter
Finally got my 3rd turbo and it looks brand new. No cracks at all and they even gave me new studs. Just waiting on the new hoses and gaskets from another store.
turbo timer waste of money? Sniper2606 MazdaSpeed 3/6 - Turbo Induction 23 07-11-2010 03:37 PM
good and bad for running internal waste gate?? mason MazdaSpeed 3/6 - Turbo Induction 6 01-19-2010 04:36 PM
waste gate duty ?? jracer MazdaSpeed 3/6 - ECU Computer Tuning 4 12-05-2009 02:40 AM
Page generated in 0.43248 seconds with 28 queries
