> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
 Old 02-01-2011, 05:55 PM   #1
jdogg's Avatar
Posts: 14   (View Stats)
jdogg is infamous around these parts
Groaned at 27 Times in 7 Posts
Default ETS TMIC
Does anybody have instructions on installing the ETS TMIC? I just got it and haven't got a chance to look at the factory setup yet.
jdogg is offline   Reply With Quote
 Old 02-01-2011, 06:07 PM   #2
PheOniX's Avatar
Posts: 160   (View Stats)
PheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond reputePheOniX has a reputation beyond repute
pretty much plug and play. someone just posted a spark plug how to. pretty much the same thing
____________________
2006 Mazdaspeed 6
Cobb AP Stage 1 Perm // CP-E Xcel Nano SRI // Speedie6 TIP // ETS TMIC // MagnaFlow Cat Back Exhaust // Vei Boost Gauge // BC Coilovers // CP-E RMM // DENSO ITV 22 // TWM Stage 1 Short Shifter w/ Bushings // TWM Desert Eagle // Hawk HPS Brake Pads // Goodyear Eagle GT II Tires
:phillyb:
PheOniX is offline   Reply With Quote
 Old 02-01-2011, 07:22 PM   #3
jdogg's Avatar
Do I have to worry about any fluids?
 Old 02-01-2011, 07:49 PM   #4
PheOniX's Avatar
wow... no. should probably know what you're buying before you buy it. here is the link. it wasnt on msf it was on 6club. i was mistaken How To: Spark Plug Replacement - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum
in addition to these instructions, i'd recommend you remove the bpv from the cold pipe and take the cold pipe out. way easier to reattach the cold pipe to the new IC plus you wont fuck up your bpv or strip your IC bolt holes.
use the search button and read through everything you can find... tend to learn more that way
2006 Mazdaspeed 6
:phillyb:
 Old 02-01-2011, 08:03 PM   #5
jdogg's Avatar
Hey, I new what I was buying!!!!! I just don't know alot about engines.
 Old 02-01-2011, 08:19 PM   #6
PheOniX's Avatar
fluids??? you had no idea
2006 Mazdaspeed 6
:phillyb:
 Old 02-01-2011, 08:21 PM   #7
Burn69's Avatar
Posts: 143   (View Stats)
Burn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to beholdBurn69 is a splendid one to behold
Groaned at 7 Times in 4 Posts
Yes, You must drain and replace your blinker fluid! J/K
2012 Speed3 w/ Tech. / SURE Full3 Aeros & TIP Combo / SURE Shortcut w/ Counterweight / SURE TorqR3 RMM / SURE AGS Shift Knob / COBB AP Programmer / CNT CBE Blue Tip / UR Test Pipe / RallyArmor Flaps / SPC Rear Camber Arms / MORE (coming soon).....
Burn69 is offline   Reply With Quote
The Following User Says Thank You to Burn69 For This Useful Post:
PheOniX (02-01-2011)
 Old 02-02-2011, 08:06 AM   #8
jdogg's Avatar
You must check your brain fluid!!!!!!!!! I just joined this site to get some answers but I guess all I get is a bunch of crap!!!!!!!!
The Following 9 Users Say NO Thank You to jdogg For This Un-useful Post:
8.5MS3 (02-08-2011), ChimmyChong (02-02-2011), faeker (04-03-2011), KusteLokal (04-02-2011), Monotonous ONE (02-08-2011), PheOniX (02-03-2011), thehead (04-03-2011), triplejumper18 (04-02-2011), Zdraveca (02-04-2011)
 Old 02-02-2011, 08:15 AM   #9
MS33SM's Avatar
Posts: 1,821   (View Stats)
MS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the world
Groans: 132
Groaned at 166 Times in 92 Posts
1. you're brown
2. it's knew not new
3. it's a fucking TMIC
4. stop modding your car
5. Mazdas247 ------------------->
6. DECALFX.com! Carbon Fiber Vinyl! Flexible, Stretchable, Low cost, high quality vinyl film overlay sheets! For hoods, custom interior trim moulding! 3M Di-Noc Dinoc wrap
MS33SM is offline   Reply With Quote
The Following 2 Users Say Thank You to MS33SM For This Useful Post:
bewsted (04-02-2011), PheOniX (02-05-2011)
 Old 02-02-2011, 08:20 AM   #10
jdogg's Avatar
You want to meet somewhere and discuss this with my fist to your face.
The Following User Says Thank You to jdogg For This Useful Post:
GoSpeed3Go (04-03-2011)
The Following 10 Users Say NO Thank You to jdogg For This Un-useful Post:
8.5MS3 (02-08-2011), BillsFan (02-09-2011), ChimmyChong (02-02-2011), faeker (04-03-2011), KusteLokal (04-02-2011), Monotonous ONE (02-08-2011), PheOniX (02-03-2011), thehead (04-03-2011), triplejumper18 (04-02-2011), Zdraveca (02-04-2011)
 Old 02-02-2011, 08:23 AM   #11
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
O haz biggest E-Penis
8------------------------------------------------------------->
 Old 02-02-2011, 08:26 AM   #12
5.000000yeah
ridenfish39's Avatar
Posts: 1,269   (View Stats)
ridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the world
Groans: 44
Groaned at 30 Times in 18 Posts
Calm down dude, everyone gets their balls busted here when they're new. Do your time here and you'll be the ball buster eventually.
Use the search, read a lot, and you will learn. TMIC is an easy diy swap that should take 20 minutes.
2012 MUSTANG 5.0 // BBK X_PIPE//FLOWMASTER HUSHPOWER //3.73 REAR//SVE DRIFTS//JLT OIL SEPARATOR//BMR LCAS//J+M PANHARD BAR//STEEDA PANHARD BRACE//AIR RAID//BAMA//CAT DELETES// LOUD AS HELL
ridenfish39 is offline   Reply With Quote
 Old 02-02-2011, 08:34 AM   #13
MS33SM's Avatar
Groans: 132
 Old 02-02-2011, 08:38 AM   #14
jdogg's Avatar
Yeah, whatever. Get a life.
The Following 4 Users Say NO Thank You to jdogg For This Un-useful Post:
8.5MS3 (02-08-2011), PheOniX (02-03-2011), thehead (04-03-2011), triplejumper18 (04-02-2011)
 Old 02-02-2011, 10:15 AM   #15
MS33SM's Avatar
Groans: 132
So if we're going to have this fist in my face meeting is this where I can find you at?
1221 13th Ave E Menomonie, WI 54751-3560 - Google Maps
 Old 02-02-2011, 10:19 AM   #16
ottoblotto's Avatar
Posts: 266   (View Stats)
ottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond repute
i think one of the unspoken rules of MSF is to have thick skin. another newbie joined, was razzed, made an excellent comeback, "blinker fluid is good. previous owner had used some really expensive unobtanium. now answer my fucking question" and his questions were answered.
relax a bit, talk shit, have fun, dont get your panties bunched, quit being a douche to veterans, lucky hal isnt in here or phillyb telling your mother bangs more than a screen door in a trailer park during tornado season, and youll have a blast. else, there are other forums...
tmic is easy money. the cover, a few bolts, clamps on hoses, and pretty much done. dont forget to disconnect your battery to reset ECU, and then find the "disconnected battery and everything is fucked up" thread and fix yo shit.
then get an avatar, donate (your way of showing thanks for help) and talk shit and learn.
2011.75 BMW E90 M3
El-Superbeast-O
ottoblotto is offline   Reply With Quote
The Following User Says Thank You to ottoblotto For This Useful Post:
Raider (02-04-2011)
 Old 02-02-2011, 10:24 AM   #17
5.000000yeah
Groans: 44
Also, check your Nator section and ask for help if you aren't comfortable doing the install. It's amazing how much help will be offered to you if you supply beer and a pizza.
The Following User Says Thank You to ridenfish39 For This Useful Post:
Raider (02-04-2011)
 Old 02-03-2011, 08:26 AM   #18
PheOniX's Avatar
you got good information. go finger blast your mom and jump into oncoming traffic like these bitches
skip to 1:18
2006 Mazdaspeed 6
:phillyb:
 Old 02-04-2011, 01:19 PM   #19
Alpha Wolf's Avatar
Posts: 396   (View Stats)
Alpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the world
Eric do you have your wife's install post on here from the old site?
FYI PM me if you need step by step instructions. It is easy and most here will help you.
Civility will get you more help. Threatening people will not get you help. I had a guy on my bike forum do that to me. Punk changed his tune I road up to his house after he flamed my wife.
2007 Touring CX-7 Liquid Platinum
Kenwood DDX419 DVD/Bluetooth/CD/ Rosen headrest DVD/Game units CP-E CAI ETS 3" Black Powder Coated TMIC
Forge Black Powder Coated BPV Nitto 420 Tires Vogtland Lowering Springs. Tuned with VersaTune
Alpha Wolf is offline   Reply With Quote
 Old 02-04-2011, 01:40 PM   #20
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
My how-to is long gone. I have the pics, but the verbiage is gone.
CX-7 TMIC pictures by raiderms3 - Photobucket
I have not had time to rebuild it.
 Old 02-04-2011, 03:17 PM   #21
Alpha Wolf's Avatar
Post up the pictures in a thread and I will post up the how to verbage
I can use some I took too.
 Old 02-04-2011, 06:51 PM   #22
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Zdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the worldZdraveca is the leader of the world
Groans: 145
Groaned at 80 Times in 77 Posts
wow really?
2011 MS3"Princess GRU"
GT2876r
AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8,
E85 FREEKTUNE
Zdraveca is offline   Reply With Quote
 Old 02-04-2011, 08:15 PM   #23
Raider's Avatar
Groans: 856
Alpha will do!
Alpha Wolf (02-08-2011)
 Old 02-08-2011, 01:45 PM   #24
Raider's Avatar
Groans: 856
to the OP:
http://www.mazdaspeedforums.org/foru...-cx-7-a-71840/
For your CX-7.
The Following 2 Users Say Thank You to Raider For This Useful Post:
Alpha Wolf (02-08-2011), ottoblotto (02-09-2011)
 Old 02-08-2011, 01:49 PM   #25
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
yay its been a while since msf has had some laughs
remember to use a left handed screw driver when taking out the bpv screws
couple buckets of steam to help break the bolts loose wouldnt hurt either
The Following 2 Users Say Thank You to 8.5MS3 For This Useful Post:
Alpha Wolf (02-08-2011), Raider (02-08-2011)
 Old 02-08-2011, 01:57 PM   #26
Alpha Wolf's Avatar
Talking
Double check the muffler bearings too...
 Old 02-09-2011, 12:18 PM   #27
BillsFan's Avatar
Posts: 476   (View Stats)
BillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the world
Psycho: The name's Francis Soyer, but everybody calls me Psycho. Any of you guys call me Francis, and I'll kill you.
Leon: Ooooooh.
Psycho: You just made the list, buddy. And I don't like nobody touching my stuff. So just keep your meat-hooks off. If I catch any of you guys in my stuff, I'll kill you. Also, I don't like nobody touching me. Now, any of you homos touch me, and I'll kill you.
Sergeant Hulka: Lighten up, Francis.
BillsFan is offline   Reply With Quote
 Old 02-09-2011, 12:23 PM   #28
Raider's Avatar
Groans: 856
Nice Stripes reference, BillsFan.
 Old 04-02-2011, 06:27 AM   #29
giordanos4's Avatar
Posts: 233   (View Stats)
giordanos4 is a jewel in the roughgiordanos4 is a jewel in the roughgiordanos4 is a jewel in the rough
Groaned at 14 Times in 8 Posts
hey so on the subject of tmic install...mine was a pain. there was some electrical plug that goes into the engine that was in my way. took me awhile to figure i had to remove it. but when i did the ic slipped right in. but now my turbo is screatching @ me and i dont know why...so yeah its easy to do but w cars ne thing is easy to fck up too.
giordanos4 is offline   Reply With Quote
 Old 04-02-2011, 06:30 AM   #30
Raider's Avatar
Groans: 856
That screech is the turbo spooling. Normal, and awesome!
 Old 04-02-2011, 09:23 AM   #31
giordanos4's Avatar
no def not. ive had the car for 8months and this is the first time it did it. ( i took the ets off b/c some bolts were loose that attach it to the cold pipe and when i reattached everything it started making that noise. its not awesome its scary and loud and it sounds like its telling me to stop. if i hook up a dashhawk to it what should i look for if there is a prob? boost levels?
 Old 04-02-2011, 09:33 AM   #32
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Groaned at 25 Times in 25 Posts
I got an idea.....
google.com
type in the search box "installing a tmic on a mazdaspeed 3"
READ...This will be hard for some of you guys out there I know.
CLick on a website that looks like it might show you how to install your TMIC.
READ again.....
Look at pictures.....
then STFU and install it
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
 Old 04-02-2011, 03:37 PM   #33
PheOniX's Avatar
electical plug? Cant even think what this could be. TMIC is so straight forward. easier than intake to install even. Pics?
dont know what screeching it could be making. what other mods do you have? did you drop something down the boost tube on the hot side of the intercooler? maybe its rattling around in the turbo. You should hear air moving (maybe like a vacuum cleaner type of shhhhhhhhhhhhh sound) when youre accelerating and a chirp noise (a whistling screech maybe) when the bpv fires as you shift gears. This will be louder after a tmic install.
vid of the sound?
vids and pics are essential if you have questions on here.
does the sound happen all the time? on gear changes? during throttle?
2006 Mazdaspeed 6
:phillyb:
 Old 04-03-2011, 01:38 PM   #34
Raider's Avatar
Groans: 856
hi Bewsted,
Thread is old, and there is a fucking how-to on this forum in the CX-7 how-to section. Don't need Google. Fuck Google.
I am thinking a boost tube might be loose or maybe damaged.
A boost gauge is a good start. I run a Prosport Premium in my Speed. But a dash hawk will tell you too. Check all connections.
And the electrical plug is news to me. Pics?
 Old 04-03-2011, 02:08 PM   #35
Speed3eak's Avatar
Posts: 2,290   (View Stats)
Groans: 82
lawl, OP cut and ran right after this post.
Good stuff ms33sm.
Speed3eak is offline   Reply With Quote
 Old 04-03-2011, 02:19 PM   #36
GoSpeed3Go's Avatar
Posts: 493   (View Stats)
GoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the world
Groaned at 27 Times in 8 Posts
oh my god that was hilarious. lol
https://www.facebook.com/NorCalTintZone
instagram: sharpdetails
GoSpeed3Go is offline   Reply With Quote
 Old 04-04-2011, 05:22 PM   #37
giordanos4's Avatar
the sound was a boost leak from the ic to the cold pipe. the screws wouldn't tighten in all the way bc it was stripped. but some lock tight and that gasket maker stuff fixed it up.
as for the electrical plug next to the ic i have a pic ill post it in a bit.... just curious as to what it is.
 Old 04-04-2011, 05:28 PM   #38
giordanos4's Avatar
i kno they are garbage pics so i figure i wont get an answer...im not too worried bc it still works i just broke the clip so the connection could come loose i guess.
thanks for the help though
The Following User Says Thank You to giordanos4 For This Useful Post:
PheOniX (04-20-2011)
 Old 04-04-2011, 05:37 PM   #39
Raider's Avatar
Groans: 856
Wild I don't remember the problem. Stripped threads? Used tmic? If so, take it to get drilled and tapped. Don't want a boost leak. Get a gauge.
 Old 04-05-2011, 07:28 AM   #40
BillsFan's Avatar
Screws from IC to cold pipe? You mean the screw that tightens the ring clamp?
"Most of the time — and this includes naps — I'm an F-18, bro"
TRZ TMIC TRU-BOOST MazdaSpeed 3/6 - Turbo Induction 26 10-03-2008 07:48 AM
Page generated in 0.57335 seconds with 36 queries
