> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
  • 1 Post By MSMS3
 Old 05-16-2019, 05:22 PM   #1
Dropen's Avatar
Posts: 46   (View Stats)
Dropen will become famous soon enoughDropen will become famous soon enough
Default Problem after changing Turbo
Hi,
I had to change my old CX-7 turbo because it was wasting oil to the combustion chamber, so i bought a new K04-882 model (I know thats not the stock model for the car).
All the parts fits very well, but i have a problem in high RPM, when i go around ~2000RPM it works fine, but if i pushed a bit more the error code P300 appears.
This suppose to happen? or theres any other problem that i probably have in my car? Anyone tryed this before and had some issues as me?
After changing the turbo i replace:
- Coils
- Injectors
- Cleaned and measured spark plugs (ok)
I have the versatune Base 93/98 Octane installed in my car.
Greetings.
Dropen is offline   Reply With Quote
 Old 05-16-2019, 05:56 PM   #2
Db09ms3's Avatar
Posts: 436   (View Stats)
Db09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the world
Groans: 89
Turbos are different between the 3/6 speeds and cx7. Contact your tuner with this info.
Stockish
 Old 05-16-2019, 06:02 PM   #3
SSinstaller's Avatar
Posts: 3,964   (View Stats)
Groans: 58
If the plugs aren't really low miles I'd replace them just to be sure.
Soon to be installed:
 Old 05-17-2019, 06:12 AM   #4
MSMS3's Avatar
Posts: 2,595   (View Stats)
Groans: 144
Originally Posted by Dropen View Post
Hi,
- Coils
- Injectors
Greetings.
If those are Iridium plugs, the fine wire is easily damaged by “cleaning.” It is a thin coating, easily scraped off by any abrasive. Also, easily damaged by regapping if you scrape against that wire tip. They may need to be replaced.
Gap should be pretty tight for that turbo and tune. .028” would be a good choice.
 Old 05-17-2019, 07:54 AM   #5
Dropen's Avatar
What do you mean?
 Old 05-17-2019, 08:01 AM   #6
Police - Grammarhead
Vansquish's Avatar
Groans: 1,896
If you are using iridium spark plugs (ITV22/ITV20/NGK6510/etc.) then you need to be careful about cleaning or changing the gap in the plugs, as the iridium coated wire is fragile.
Furthermore, according to Mazda's published specifications from 2010, the plug gap should be between 0.024" and 0.027" (0.61mm - 0.68mm) for this motor.
 Old 05-17-2019, 09:11 AM   #7
Jeff23spl's Avatar
Posts: 2,009   (View Stats)
Was it specified larger previously ? I had in mind Mazda specified larger and sometimes it was too much?
I know at 0.040 it doesn't work at all, it missfire before 10psi....
OP. Have you checked engine compression as missfire may not comes from spark but from low compression also. I ask because the turbo could leak oil but it could also be the result of too much engine blow by...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 05-17-2019, 09:20 AM   #8
Vansquish's Avatar
Groans: 1,896
Yes. The superceded range went up to 0.032", if memory serves .
 Old 05-17-2019, 10:36 AM   #9
MSMS3's Avatar
Groans: 144
What do you mean?
See subsequent response from Vanquish. Mazda OEM plugs have an iridium plating on the center electrode. That is an alloy that is extremely resistant to heat, but is easily damaged if scraped. This is the preferred type plug due to the high heat generated in the combustion chamber of our cars. Platinum does not handle heat quite as well.
Generally speaking, you do not even try to "clean" such plugs, but rather replace them when needed because of the risk of damage. You can gap or regap them, but must be very careful to avoid contacting the fine wire in the center except with something like a wire type gapping tool or feeler gauge. Avoid using the coin type that will scrape against the tip of that wire.
Yes, .028" is probably on the outside of the preferred range but works ok for stock. Closing to .026" will be better. I forgot that.
My guess is that new plugs are in order. NGK iridium in the stock heat range would be a good choice. NGK iridium plugs are OEM, but you can save a little by getting them from antermarket vendors. Their aftermarket part number would be NGK ILTR6A-8G. The part number on the box is 3787.
 Old 05-17-2019, 11:15 AM   #10
Dropen's Avatar
I will check the spark plugs, but they worked fine after changing the turbo (with the old smoky turbo).
If the problem stills, what do you recomend? tunning the car for the turbo's new properties?
 Old 05-17-2019, 04:02 PM   #11
Fstrnyou's Avatar
Posts: 2,457   (View Stats)
Wait, you said you got P0300 after changing turbo, now you're saying it ran fine after changing the turbo. I'm confused.
Also, misfire codes from low compression will happen at idle and will seem to run fine above idle...especially in boost. Ask me how I know.
Since you probably had a good portion of stuff removed, check all electrical connections.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 05-17-2019, 04:34 PM   #12
Dropen's Avatar
Sry, bad translation...
I mean that i "cleaned" the spark plugs before changing the turbo, like 600kms ago and it didnt show me any error, only the oil and smoke were the trigger to had to change the turbo. And now with the new turbo the error appears when i push the rpms.
 Old 05-17-2019, 08:26 PM   #13
MSMS3's Avatar
Groans: 144
I would change the plugs anyway. This seems electrical with a general miss under load. That code suggests multiple misfires on multiple cylinders. Could be the tune, but I think you are already running a K04 tune. Does Cobb even have separate base map tunes for the CX-7? If it does, you might want to load a MS3 specific base map Please state again the specific tune listing/name/map in Cobb nomenclature.
This engine is hard on plugs, even when in stock trim. If your total miles on them, regardless of whether “cleaned” or not is 15,000 or more, get new ones.
You might also, just to be sure, flash back to stock (I think AP called that stage 0) and then reload that Stage 1 basemap.
lazza151 likes this.
 Old 05-18-2019, 01:36 PM   #14
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,975   (View Stats)
Groans: 546
Along with the other recommendations... how's the AFR/LTFT? If it's been running rich it could foul the plugs, and if it's been running lean you might have a leak causing misfires
94 M
06 MS6
 Old 05-22-2019, 06:08 PM   #15
Dropen's Avatar
The car is in the mechanic now... i will load the ms3 table from versatune to see what happens (i hope that it dont blow lol), the sparks was changed by new, but i havent tryied the car yet.
The Following User Says Thank You to Dropen For This Useful Post:
MSMS3 (05-22-2019)
 Old 05-23-2019, 01:24 AM   #16
tomek CX7's Avatar
Posts: 11   (View Stats)
tomek CX7 will become famous soon enoughtomek CX7 will become famous soon enough
- its thrue but only for CX-7 automatic transmission
CX-7 with manual transmission has the same turbo 3/6 speeds K0422-882
I think you cannot load stock table from 3/6 or CX-7 MT because the engine has to work with AT, but ... I may be wrong
tomek CX7 is offline   Reply With Quote
 Old 05-23-2019, 05:41 PM   #17
Dropen's Avatar
Good point... Theres any 3/6 automatic?
 Old 05-24-2019, 06:36 AM   #18
MSMS3's Avatar
Groans: 144
No. All 3 and 6 Speeds have the 6 speed manual.
 Old 05-24-2019, 04:37 PM   #19
Dropen's Avatar
Damn, im screwed then.
 Old 05-25-2019, 01:14 PM   #20
Dropen's Avatar
Well, i have the car back now.
It works fine for now, i had to change the 4 spark plugs. The new turbo works pretty good, no error 300 for now, i will have to use the car for some time if the error happens again.
I didnt change the tunning of the car. Im using the versatuner default tune.
MSMS3 (05-25-2019)
HKS Turbo Timer Problem 4lo2go MazdaSpeed 3/6 - Car Audio & Electronics 14 04-28-2018 12:31 PM
Turbo Air Delivery Problem abm89 CX-7 > Issues & Troubleshooting 4 08-11-2012 07:32 AM
turbo timer problem reconbygod12 Mazdaspeed3/6 General Discussion 6 06-07-2011 05:28 AM
Coolant in Oil, Wiring Problem in Chevy Cobalt, Cruise Control Complaint with Toyota Prius, Changing An O2 Sensor, Heate Haltech Automotive News 0 03-10-2009 02:10 PM
Changing a turbo guestion. SharkDiver MazdaSpeed 3/6 - Turbo Induction 9 08-28-2008 07:57 AM
Page generated in 0.51174 seconds with 28 queries
