> CX-7 > Engine, Transmission & Driveline
 Old 07-11-2018, 09:31 AM   #1
Guitarkidd's Avatar
Posts: 7   (View Stats)
Guitarkidd is an unknown quantity at this point
Default 2011 - 90K Miles - Trans/Shifting Issue - Transmission or TCM
Hello,
I have a 2011 with 90K. This morning was the first time I felt anything wrong with this car and its transmission. From a stop or near stop it appeared to be starting from 2nd gear, and then would down shift into 1st upon acceleration. Not hard down shift, but obviously not normal, and then the car would go through the gears normally with no issues. Only when I cam to a stop or a near stop would it stay in 2nd and then drop into 1st upon accelerating.
When I got to work the AT light eventually came on with no check engine light. There is a very respectable transmission shop within walking distance. When they opened I went to the car to drive it over. My car would not go into reverse but would still go into drive.
I pushed the car out of the parking spot and drove it to the transmission shop. The car went into reverse upon the initial test drive and the issues of shifting were present, but then at another point, the manager lost reverse during the test drive.
The manager was telling me that he believes from just driving it that something internal is wrong and I'm probably looking at a replacement and or rebuild. The manager is going to do some research on potential TSB, customer satisfaction programs from Mazda, etc., but I doubt there is anything he will find.
However, some research has shown that other Mazdas with the same or similar power trains have had the same issues and have only needed the TCM flashed or replaced.
This car has never shown any issues shifting. I am the original owner and have had all maintenance done too.
Thought and suggestions would be appreciated.
Guitarkidd is offline   Reply With Quote
 Old 07-11-2018, 11:07 AM   #2
Db09ms3's Avatar
Posts: 286   (View Stats)
Groans: 65
I'm confused. Your car is a Mazdaspeed 3, correct? If so, is the shifter coming out of 2nd and going into 1st? Easy to see due to it being a manual transmission only car.
From your description it sounds like you're driving an automatic regular Mazda3.
Stockish
 Old 07-11-2018, 12:00 PM   #3
Guitarkidd's Avatar
I'm sorry I'm confused why you're confused LOL... I posted this in the CX-7 forum because I have a 2011 CX-7... I am not sure why you are thinking I have a different vehicle.
 Old 07-11-2018, 01:48 PM   #4
Db09ms3's Avatar
Groans: 65
Ha! I'm dumb. Carry on sir!
Stockish
 Old 07-11-2018, 06:43 PM   #5
Solarsurge's Avatar
Posts: 570   (View Stats)
Db09ms3 (07-11-2018)
 Old 07-11-2018, 06:59 PM   #6
Db09ms3's Avatar
Groans: 65
Ha!
Stockish
 Old 07-12-2018, 02:52 PM   #7
Carskick's Avatar
Posts: 282   (View Stats)
Hello,
I'm no expert on Auto Trannies, so take this with a grain of salt...
If the transmission feels and operates normal except for it's shift logic, then I'd suspect a electronics/computer problem. Rough/Bad shifts are more indicative of a mechanical problem. Loosing reverse could be either...
2009 Mazdaspeed 3 Sport (Original Owner) - 93k miles and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC | SpeedDaddy TP | AT HPFP | Damond RMM | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | Koni STR.T Shocks | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold Fronts | Focal Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: Low Note Additional Horn
Mods Awaitting Install: Bilstein B16 Coilovers (Back Ordered) | Whiteline Bushings, Anti-Lift, & Bump Stops | Whiteline Endlinks | JBR 125 Sway Bars & upgraded bushings/mounts | DM RMM & PMM | JBR TMIC Red Boost Tubes | DM OCC w/VTA
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM
Trans shifting issues.... DareDevilMS6 MazdaSpeed 6 - Engine, Transmission & Driveline 17 08-18-2018 11:18 PM
strange trans shifting pattern ottoblotto CX-7 > Issues & Troubleshooting 5 02-18-2011 10:08 PM
Rough shifting & Slipping Transmission? Circas313 MazdaSpeed 6 - Engine, Transmission & Driveline 12 01-26-2011 02:28 PM
shifting problems.. loose trans mount on an 08? 08_ms3_gt MazdaSpeed 3 - Engine, Transmission & Driveline 41 04-08-2009 08:11 PM
Page generated in 0.29002 seconds with 24 queries
