> CX-7 > Engine, Transmission & Driveline
  • 1 Post By ottoblotto
 Old 11-20-2010, 08:43 AM   #1
ottoblotto's Avatar
Posts: 266   (View Stats)
ottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond repute
Default CX7 AWD System
originally posted by superstretch18:
The CX-7 is equipped with Mazda’s new active torque split all-wheel drive system, which debuted on the MazdaSpeed6, featuring a more aggressive transfer of torque to the rear axle in accordance with driving conditions. This intelligent system achieves a satisfying balance between the interactive control over the vehicle that makes it particularly enjoyable to drive, and confident handling stability necessary for snowy, wet or other uncertain road surfaces/conditions; engine power and torque are faithfully and efficiently transferred to the road surface for maximum performance.
The active torque split AWD system uses real-time data input on steering angle, yaw rate, lateral G-force and engine status to determine road surface and driving conditions. The CX7’s onboard computer then automatically determines which of three different modes of front/rear torque distribution should be engaged: Normal, Sport, or Snow (for slippery surfaces). The active torque coupling mounted in front of the rear differential is electronically controlled in accordance with the data provided by the computer, adjusting front/rear wheel torque distribution between 100:0 and 50:50 to deliver optimum drive power to each axle. The result is that the most power and traction are made available under all conditions; positive acceleration and confident handling are provided regardless of constantly changing road conditions, as well as the ability to fully balance the vehicle in a turn by skilful use of the accelerator pedal.
Unlike many competitor offerings, the torque transfer system in the CX-7 seamlessly integrates the inherent stability of all-wheel drive; because the active torque coupling is controlled electronically, it can react to wheel slippage much more rapidly than conventional gear- or fluid-controlled systems. To ensure consistent power delivery under all weather and driving conditions, the Power Take-Off (PTO) system on the centre differential that distributes torque to the rear axle is fitted with its own liquid-cooled cooling system.
Once the computer has shifted into snow or sport mode it pre-loads the rear axle so you don't have to wait for slippage. As oppossed to the system in the 01-04 Tribute where the wheels had to actually slip before the AWD kicked in.
<On the TCS System>
The braking system works in synergy with the CX-7’s Dynamic Stability Control (DSC), incorporating a traction control system (TCS), to exhibit an outstanding level of active safety. The Dynamic Stability Control system is designed to activate when the vehicle is taking a turn too quickly for the road conditions. DSC compares the driver's intended direction (from the steering wheel angle) to the actual vehicle path; if the system senses
understeer or oversteer, it applies braking force, and reduces engine torque if required, to correct the situation.
Traction control systems generally come in one of two primary systems: an ABS-based system, or an engine management system. Both systems use the ABS wheel speed sensors to determine if there is wheel spin (wheel speed greater than vehicle speed). The CX-7 system uses engine management to reduce the amount of power output by reducing fuel, ignition timing and throttle position to reduce wheel spin. This system is superior to systems that use the ABS brakes to slow down the spinning wheel – ABS systems have a tendency to be very jarring in their operation and can overheat the brakes if used for extended periods of time. The CX-7’s traction control system (TCS) deals with the problem of the engine supplying too much power for road conditions right at the source; when wheel spin is detected, the TCS simply reduces the engine’s power output until the wheel spin stops.
Alpha Wolf likes this.
2011.75 BMW E90 M3
El-Superbeast-O
ottoblotto is offline   Reply With Quote
The Following User Says Thank You to ottoblotto For This Useful Post:
DementedCX (05-08-2012)
 Old 11-20-2010, 08:50 AM   #2
edwhayes's Avatar
Posts: 157   (View Stats)
edwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to all
Seems like a real improvement and the next step might be a real time AWD like is standard on Subarus.
edwhayes is offline   Reply With Quote
 Old 11-20-2010, 12:10 PM   #3
SpeedSixxx's Avatar
Posts: 4,182   (View Stats)
Groans: 778
Groaned at 443 Times in 239 Posts
i'd say active torque split is pretty much a "real time awd..."
in real time it transfers torque=power to whatever wheel needs it.
The Following User Says Thank You to SpeedSixxx For This Useful Post:
Coaststarlight (05-17-2012)
 Old 12-26-2010, 10:03 PM   #4
lvdukerider's Avatar
Posts: 44   (View Stats)
lvdukerider has a spectacular aura aboutlvdukerider has a spectacular aura about
Proably a stupid question but is it even possible to turn a FWD CX7 into a AWD, dollars nonwithstanding? Would it require a entirely diffrent transaxil, CPU,wireing harness?
lvdukerider is offline   Reply With Quote
 Old 12-28-2010, 01:12 AM   #5
Coaststarlight's Avatar
Posts: 296   (View Stats)
Coaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the world
Its got the Tunnel and Exaust Routeing for it, I was looking at the Under Side of a FWD CX7 and Everything underneath the vehicle looks Identical to the AWD version, Literly looks like stuff is Missing like it was removed or stolen
Long Block Built by GPwerks and Loose Screw Motor Sports
https://www.gp-werks.com/
http://www.crossoverauto.com
^Any Parts, Great Prices^
Coaststarlight is offline   Reply With Quote
 Old 12-28-2010, 01:42 AM   #6
ottoblotto's Avatar
anything is possible with the right amount of funding... but my custom exhaust goes through the tunnel area which increased my clearance but if i wanted to go awd, it would require a new exhaust also... but really, if you want awd, trade in your fwd and just buy an awd. prob a shitton easier...
2011.75 BMW E90 M3
El-Superbeast-O
 Old 12-28-2010, 04:17 AM   #7
Posts: 12,649   (View Stats)
There's absolutely not reason to retrofit a FWD CX7 with the AWD system since Mazda already did all that and has sold it for the same model years.
 Old 12-28-2010, 11:18 PM   #8
Thats what I thought but when I purchaced my 2010 GT in pearl white this past July it was almost exactly what I wanted, minus the AWD, in fact I checked Mazdas invintory website while at the deaership and there were no CX7 AWD avalible anywhere near the Las Vegas area and only one CX9. The dealer told me theres just not a large demand for the 2K more expensive AWD model so not as many made and the ones that are are usually sent to dealers in the snow belt. Im very happy with my GT but was just wondering what might be involved. Proably not worth doing, but I was just curious what it would take to make my CX7 into "exactly" what I wanted. Thanks for the replies though.
 Old 12-29-2010, 05:41 PM   #9
bscar's Avatar
Posts: 1,846   (View Stats)
bscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the world
Groans: 46
Hindsight being 20/20 and all, but you couldn't have put in a custom order and waited?
bscar is offline   Reply With Quote
 Old 12-30-2010, 11:16 PM   #10
The problem was I needed a car immidatly, this was back in July, I would have had to wait awhile for the 2011's to come out.
 Old 01-02-2011, 10:34 AM   #11
hartungenator's Avatar
Posts: 25   (View Stats)
hartungenator will become famous soon enoughhartungenator will become famous soon enough
I <3 the CX7 AWD. It has saved my arse on several occassions.
2007 Mazda CX-7
MS6 Cobb SRI
Forge BPV (2nd gen)
Saikou Michi OCC
hartungenator is offline   Reply With Quote
 Old 04-13-2011, 08:07 PM   #12
Neverlift's Avatar
Posts: 4,686   (View Stats)
Groans: 1,136
LOL at this fancy explanation of a torsen lsd. Gotta love marketing BS
Past Mazdas & Speeds
B5 Bimmer Challenge & Street Global Time Attack Project
'99 BMW 328is: 18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C5)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50//KW Variant 3 w/ Vorshlag plates//Turner CTSCC Camber Arms//3 clutch 3.73 LSD//Sparco Ergo II w/ 6 point Schroth Clubman Harness//Bimmerworld Billet Floor Mount//ZSL Aluminum Radiator w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//Active Autowerke GenII Track Pipe & Catback //Condor Speed Shop M3 Offset FCABs, Motor & Trans Mounts, Rear Subframe, & Differential Bushings//Visionary Performance Custom Welded 4 Point Rollbar w/ Harness Bar & Gusseted X Brace//OEM M3 Rear Subframe Reinforcement & Condor Speedshop Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & SSK//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//AKG M3 Adjustable FSB Endlinks w/ 95 M3 FSB
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f124/cx7-awd-system-65242/
Google INTERIA.PL - szukaj: mazda cx 7 2012 dynamic stability control system This thread Refback 01-28-2012 05:46 AM
Suggestions for a new system nynhex 2010 MS3 - Car Audio & Electronics 0 05-08-2010 10:43 PM
GPS Nav system Pornstar 2010 MS3 - Car Audio & Electronics 4 02-16-2010 05:51 AM
Looking at getting a MI system, little help Stan-O MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 7 12-18-2008 08:09 PM
HELP!!! I have Oil in the air system!!!!! CMESCOOT MazdaSpeed 3/6 - Troubleshoot/Diagnostics 19 10-21-2008 08:21 AM
PTP's CAT back exhaust system, soon to be TBE system. ptperformance Mazdaspeed3/6 General Discussion 56 10-05-2008 01:08 PM
Page generated in 0.34459 seconds with 28 queries
