> MazdaSpeed 3/6 - Car Audio & Electronics
MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here.
 Old 03-19-2019, 08:21 AM   #1
DjSinestro's Avatar
Posts: 13   (View Stats)
DjSinestro will become famous soon enough
Default Better headlights
Any suggestions on better headlights to replace the stock ones in the MS6?
Illumination it pretty crappy at night.
DjSinestro is offline   Reply With Quote
 Old 03-19-2019, 08:28 AM   #2
LenSpeed6's Avatar
Posts: 151   (View Stats)
LenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to beholdLenSpeed6 is a splendid one to behold
m6customs.com
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump
 Old 03-19-2019, 10:24 AM   #3
Thor Hammer's Avatar
Posts: 1,845   (View Stats)
Groans: 211
TRS
HID Kit Pros
 Old 03-22-2019, 01:25 PM   #4
Jayzon's Avatar
Posts: 76   (View Stats)
Jayzon has disabled reputation
https://www.theretrofitsource.com/ has some
Back to Stock
Jayzon is offline   Reply With Quote
 Old 03-22-2019, 04:29 PM   #5
Fstrnyou's Avatar
Posts: 2,377   (View Stats)
Originally Posted by Jayzon View Post
= TRS
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 03-23-2019, 09:13 PM   #6
08mzr's Avatar
Posts: 641   (View Stats)
08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world
Originally Posted by Fstrnyou View Post
= TRS
To be fair, one cant assume everyone knows what TRS means. It really should've been given with a link of some sort like the second person did.
2008 Metro Gray Mica Speed 3-SOLD
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
SPC rear camber arms
Hawk HPS pads front and rear
FREEKTUNE OTS+
1998 Civic - SOLD
2011 Speed3 200k+ miles Stock -Daily
08mzr is offline   Reply With Quote
 Old 03-24-2019, 06:56 AM   #7
Fstrnyou's Avatar
First rule of MSF Club: help yourself by searching.
Other rides:
History:
The Following 2 Users Say Thank You to Fstrnyou For This Useful Post:
Db09ms3 (03-25-2019), monkey.bones.007 (03-25-2019)
 Old 03-25-2019, 05:38 AM   #8
LorenzoDM01's Avatar
Posts: 17   (View Stats)
LorenzoDM01 can only hope to improve
Groaned at 4 Times in 2 Posts
It can be easily found with a quick search
LorenzoDM01 is offline   Reply With Quote
 Old 03-25-2019, 09:27 AM   #9
Groans: 211
Sorry dad! LOL. Dude, the OP can do a simple search on google and TRS (oh, excuse me, THE RETROFIT SOURCE) will come up right away.
Maybe I could be really nice and let him know that MS6 customs recommends a different morimoto lens than what TRS (oops, THE RETROFIT SOURC) uses in their kit. Do I get your approval and blessing now? LOL.
OP, if you want to retain your stock D2S bulbs then you can install a set of Morimoto 4TL-R lenses. MS6 Customs makes the brackets to install into your housings. Or you can send him your headlights. I went with these and bought the brackets from him.
https://hidkitpros.com/shop/bi-xenon...-r-projectors/
Seriously.
 Old 06-12-2019, 01:40 PM   #10
Clintb3astwood's Avatar
Posts: 5   (View Stats)
Clintb3astwood will become famous soon enough
If You're comfortable, you can actually open them and swap out the stock projector with something better performing.
Theretrofitsource.com has everything you need.
Clintb3astwood is offline   Reply With Quote
« Eonon Head units | - »
Repacing OEM halogen headlights with OEM HID headlights noidle22 Mazdaspeed3/6 General Discussion 9 06-15-2017 04:05 PM
MS6 headlights are WAY too low Absolut1l MazdaSpeed 3/6 - Car Audio & Electronics 11 05-08-2014 08:16 PM
HID Headlights Afejzic Exterior 7 03-28-2014 07:57 PM
LED Headlights? Mclovin80 Gen2 MS3 General Discussion 8 09-19-2012 05:33 AM
Page generated in 0.30102 seconds with 27 queries
