> MazdaSpeed 3/6 - Car Audio & Electronics
MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here.
  • 1 Post By meelo88
 Old 07-30-2011, 08:58 AM   #1
SuperTrooper169's Avatar
Posts: 323   (View Stats)
SuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the worldSuperTrooper169 is the leader of the world
Groaned at 53 Times in 6 Posts
Default Climate Control Back Light Out - Need Help
Last night I noticed the red back lit light and the text inside the knob (circled in red) are no longer working. I'm assuming there's a bulb specifically for that knob, I just have no clue how to get to it. Can I get to it by pulling the knob off or do I have to take the whole console out? Anyone know what specific bulb # it is? Thanks for any help.
SuperTrooper169 is offline   Reply With Quote
 Old 07-30-2011, 10:51 AM   #2
Frosty-'s Avatar
Posts: 14   (View Stats)
Frosty- is a jewel in the roughFrosty- is a jewel in the roughFrosty- is a jewel in the roughFrosty- is a jewel in the rough
Neutral  -1 score
I believe you can find instructions and a part number here: How-To Replace HVAC Light bulbs - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Frosty- is offline   Reply With Quote
The Following 2 Users Say Thank You to Frosty- For This Useful Post:
bluury13 (09-30-2018), dkapetansky (07-30-2011)
 Old 02-13-2014, 10:00 AM   #3
Douggievee's Avatar
Posts: 71   (View Stats)
Douggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really nice
nice, this was helpful since my light went out today and i need to replace it. probably should replace all 3 while im in there.
Douggievee is offline   Reply With Quote
 Old 02-13-2014, 10:20 AM   #4
ihasmazda's Avatar
Posts: 1,011   (View Stats)
ihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the worldihasmazda is the leader of the world
I did this recently when one bulb went out and replaced the bulbs with red LED's. they are a little brighter than the bulbs though so when it's dimmed down completely they are still lit up a bit but they should last forever in theory...
One thing to note about the writeup on mazda6club - all you have to do is get to the back of the unit and then use a small phillips screwdriver to remove the bulbs from the sockets. There is no need to take apart the button housing whatsoever, I don't know why he did - the last 4 pics where he's taking it apart is not required at all.
Once you remove the trim and see the back side, there are 2 white sockets holding bulbs that have an orange boot (that's the light that shines around the knobs) and the 3 black sockets that hold bulbs with red boots (one for each knob face)
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
ihasmazda is offline   Reply With Quote
The Following User Says Thank You to ihasmazda For This Useful Post:
 Old 02-13-2014, 03:29 PM   #5
Douggievee's Avatar
Thats good to know. Would you happen to know the bulb part numbers for the LED's that you used? Were they a direct fit or did they need some modification to work?
 Old 02-13-2014, 05:53 PM   #6
ihasmazda's Avatar
I got some from superbrightLEDS.com but i ordered the wrong base type so I pulled the bulbs out and re-used the factory sockets.
I ordered 5 ea of the neo wedge p/n "NEO5-R 5mm NEO5-x Red" and shipped it was under $10.. not bad.
But again these are the wrong base type, they were too large, so go with the size smaller and i would think it should fit, unless you don't mind the tedious work of transferring the bulbs to the factory sockets. it was kind of a pain because they're so small but it worked fine.
TiGraySpeed6 (05-29-2014)
 Old 05-29-2014, 11:10 AM   #7
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
necro-bump to say thanks for the LED part numbers and also the heads up on the sizing- Just ordered a set of NEO4-R:4mm, which is the next smaller. I'll post back here with fitment results when I'm done.
Oh, and cost is still under $10 shipped for five LED's.
340hp / 371tq
 Old 06-23-2014, 10:53 AM   #8
Reporting back on the bulb size- fit perfect, direct drop in replacement
NEO4-R 4mm NEO4-x Red - need 5 of them, shipped for under $10.
NEOx LED Bulb - Instrument Panel LED | Instrument Cluster & Gauge LED Lights | LED Car Bulbs | Super Bright LEDs
Choose 4mm and red color and it's a twenty minute swap to get working ac lights again. Plug in small connection to test, and if any don't light up just pull em out & rotate em 180 degrees to swap connection polarity.
Stock bulbs & their condoms -vs- LED's. Clear, but light up red as can be
340hp / 371tq
The Following 3 Users Say Thank You to TiGraySpeed6 For This Useful Post:
bluury13 (09-30-2018), silvapain (03-21-2016), Zoomer_Esiason (11-01-2015)
 Old 03-21-2016, 10:28 AM   #9
Zoomer_Esiason's Avatar
Posts: 140   (View Stats)
Zoomer_Esiason has a reputation beyond reputeZoomer_Esiason has a reputation beyond reputeZoomer_Esiason has a reputation beyond reputeZoomer_Esiason has a reputation beyond reputeZoomer_Esiason has a reputation beyond reputeZoomer_Esiason has a reputation beyond reputeZoomer_Esiason has a reputation beyond reputeZoomer_Esiason has a reputation beyond reputeZoomer_Esiason has a reputation beyond reputeZoomer_Esiason has a reputation beyond reputeZoomer_Esiason has a reputation beyond repute
Hi guys -- resurrecting this old thread to hopefully help the next speed owner who may run into the same issue. The recommended LEDs above are now discontinued. I had a light out and recently ordered the version below which worked perfectly in my speed 6.
Hope this helps someone like this thread recently helped me! Photo attached to see the results.
https://www.superbrightleds.com/more...-led/221/1000/
2007 MS6 GT
Autotech Internals | BC Racing BR Type CO Kit | CS Power Series SRI & TIP | CS Power Series 3" CBE | 3" Test Pipe | CS Catless DP | TR8 FMIC | Custom 20 psi Freektune | GFB Respons BPV | CS RMM | CS Injector Seals | CS Rear Diff Mount | Grimspeed EBCS
Zoomer_Esiason is offline   Reply With Quote
The Following 3 Users Say Thank You to Zoomer_Esiason For This Useful Post:
meelo88 (03-21-2016), silvapain (03-21-2016), TiGraySpeed6 (03-21-2016)
 Old 03-21-2016, 10:42 AM   #10
meelo88's Avatar
Posts: 557   (View Stats)
meelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the world
Just some added info, I bought these LEDs and when it's dark and you don't use the illumation setting at full bright these LEDs will be at least 2x brighter than the rest of your dash.
"If I can't fix it, it was meant to be broken"
[SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey
TUNED BY NISHAN
POWER
SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG
COSMETIC AND AUDIO
Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4
meelo88 is offline   Reply With Quote
The Following 3 Users Say Thank You to meelo88 For This Useful Post:
silvapain (03-21-2016), TiGraySpeed6 (03-21-2016), Zoomer_Esiason (03-21-2016)
 Old 03-21-2016, 10:54 AM   #11
Thanks. I wonder how difficult it would be to just swap out every bulb behind the Radio and clock display...I started to pull my radio apart today and realized there's 229393 screws overlapping each other, holding it in, and said F it.
2007 MS6 GT
 Old 03-21-2016, 11:13 AM   #12
meelo88's Avatar
I imagine it would be a PITA...i would much rather lower the current output of these LED's than go thru replacing those. Odds are they are soldered in as well.
Zoomer_Esiason likes this.
TUNED BY NISHAN
POWER
COSMETIC AND AUDIO
 Old 03-19-2019, 06:38 PM   #13
GennadiyClafe's Avatar
Posts: 1   (View Stats)
GennadiyClafe is an unknown quantity at this point
, . : https://www.digitbox.net/ . . !
, . : https://www.digitbox.net/ . - . !
, -. : https://www.digitbox.net/ . . !
, -. : https://www.digitbox.net/ . - . !
Last edited by GennadiyClafe; 03-19-2019 at 06:38 PM. Reason: MSF Database - Automerged Doublepost
GennadiyClafe is offline   Reply With Quote
 Old Yesterday, 02:48 PM   #14
EvanTem's Avatar
Posts: 2   (View Stats)
EvanTem is an unknown quantity at this point
Default buy allegra d
where to buy allegra d over the counter
buy allegra d online canada
can i buy allegra over the counter
buy allegra antihistamine
age to buy allegra d
buy allegro 2
where to buy allegra in japan
buy allegra in canada
buy allegra d 24 hour online
allegra buy online uk
buy allegra 180 mg
can you buy allegra under 18
allegra 120 buy
purchase allegra-d
buy allegra 180 mg
buy allegra d cheap
can you buy allegra with fsa
buy allegra d cheap
where to buy allegra in hong kong
where to buy allegra uk
allegra 120 buy online india
buy allegra uk
where to buy allegra d online
buy allegro 2
buy kookai allegra dress
where can i buy allegra antihistamine
buy allegro 2 reformer australia
can you buy allegra over the counter
where to buy allegra cream
buy allegra d
buy allegra 180 mg
buy raquel allegra
buy allegra otc
can i buy allegra online
buy allegra 180 mg
buy allegra
where to buy alegria shoes
can you buy allegra in canada
buy allegra uk
can i buy allegra with my hsa
purchase allegra d online
allegra 120 buy
where to buy generic allegra d
Buy Allegra (Fexofenadine) 120 mg pills online, Cheap Allegra
purchase allegra-d
buy allegro 2
buy allegra
buy raquel allegra
buy allegra tablets
allegra 120 buy
where to buy allegra 60 mg
buy allegra tablets
purchase allegra-d
buy allegra otc
allegra 120 buy
where to buy cheap allegra
buy allegra uk
buy allegra otc
buy allegra d
buy generic allegra online
www.healthrpose.com/allegra/
purchase allegra-d
allegra to buy
buy allegra tablets
buy allegra 180 mg
buy allegra medicine
buy allegro 2 reformer uk
buy allegra in bulk
buy allegra
buy allegra 120 mg
buy allegra in bulk
buy allegra 120 mg
buy allegra
allegra 120 buy
purchase allegra-d
buy allegra tablets
can i buy allegra d online
allegra 120 buy
allegra to buy
can you buy allegra d online
buy allegra in bulk
allegra 120 buy
buy allegra otc
buy allegra in bulk
buy allegra tablets
buy allegra otc
buy allegra 180 mg
buy allegra d
buy allegra
allegra to buy
buy allegra otc
buy allegra
buy allegra 180 mg
buy allegra tablets
buy allegra in bulk
buy allegra d cheap
purchase allegra-d
buy allegro 2
buy raquel allegra
buy allegra 120 mg
buy allegra otc
purchase allegra-d
buy allegra in bulk
allegra to buy
buy allegra in bulk
buy allegra uk
buy allegra uk
allegra to buy
purchase allegra-d
buy allegra tablets
buy allegra australia
buy allegra in bulk
buy allegra otc
buy allegra uk
purchase allegra-d
buy allegra 120 mg
allegra 120 buy
buy allegra otc
allegra 120 buy
buy allegra
buy allegra otc
buy allegra in bulk
buy allegra
buy allegra tablets
allegra 120 buy
buy allegra online
buy raquel allegra
buy allegra d cheap
allegra 120 buy
buy allegra 120 mg
buy allegra
allegra to buy
allegra 120 buy
buy allegra
allegra to buy
buy allegra 180 mg
buy raquel allegra
allegra 120 buy
buy allegra d cheap
Last edited by EvanTem; Yesterday at 02:48 PM. Reason: MSF Database - Automerged Doublepost
EvanTem is offline   Reply With Quote
 Old Yesterday, 05:33 PM   #15
AidanTem's Avatar
AidanTem is an unknown quantity at this point
Default buy kookai allegra dress
buy allegra
buy allegra d
buy allegra d cheap
buy allegra in bulk
allegra to buy
buy allegra online
buy allegro 2
buy allegra
buy allegra in bulk
allegra 120 buy
buy allegro 2
buy allegra tablets
buy allegra
buy allegra 180 mg
buy allegra in bulk
buy allegra
buy allegra 180 mg
allegra to buy
buy allegra 120 mg
buy allegra uk
buy allegra tablets
buy allegra 180 mg
buy allegra d cheap
buy allegra tablets
buy allegra uk
buy allegro 2
allegra to buy
buy allegra d cheap
buy allegra 120 mg
buy allegra tablets
buy allegra 120 mg
buy allegra in bulk
purchase allegra-d
buy allegra otc
buy raquel allegra
buy allegra in bulk
buy allegra online
buy allegra d cheap
buy allegra in bulk
allegra 120 buy
allegra to buy
buy allegra d
purchase allegra-d
purchase allegra-d
buy allegra 120 mg
allegra 120 buy
buy allegra uk
allegra 120 buy
purchase allegra-d
buy allegra 120 mg
allegra to buy
buy allegra
buy allegra online
purchase allegra-d
purchase allegra-d
buy allegra d cheap
buy allegra otc
buy allegra otc
allegra to buy
buy allegra 120 mg
buy allegra 180 mg
buy raquel allegra
buy allegro 2
buy allegra d
buy raquel allegra
buy allegra tablets
purchase allegra-d
buy allegro 2
buy allegra 120 mg
buy allegra d
buy allegra otc
buy allegra tablets
buy allegra d cheap
buy raquel allegra
purchase allegra-d
allegra 120 buy
buy allegra online
buy allegra 180 mg
allegra 120 buy
buy allegra d
buy allegra 180 mg
buy allegra otc
buy allegra d cheap
buy allegra otc
allegra 120 buy
buy allegro 2
buy allegra online
buy allegra d
allegra to buy
buy allegra in bulk
buy allegra d
buy raquel allegra
buy allegro 2
buy raquel allegra
buy allegra 180 mg
buy allegra otc
buy allegra uk
allegra to buy
buy allegra d cheap
buy raquel allegra
buy allegra 180 mg
buy allegra otc
buy allegra d
buy allegra 120 mg
buy allegra
buy allegra in bulk
buy allegra 120 mg
buy allegra online
buy allegra
buy allegra 180 mg
Last edited by AidanTem; Yesterday at 05:33 PM. Reason: MSF Database - Automerged Doublepost
AidanTem is offline   Reply With Quote
 Old Today, 01:00 AM   #16
EvanTem's Avatar
Default buy allegro 2 reformer
buy allegra online
buy allegra uk
buy allegra 180 mg
allegra 120 buy
buy allegra online
buy allegra 180 mg
buy allegra d
buy raquel allegra
purchase allegra-d
buy allegra 180 mg
buy allegra uk
buy allegra 180 mg
allegra 120 buy
buy allegra d cheap
buy allegra 180 mg
buy allegra in bulk
buy allegra uk
buy allegra 180 mg
buy allegra tablets
buy allegra in bulk
buy allegra in bulk
buy allegra in bulk
buy allegra in bulk
buy allegra
buy allegro 2
buy allegra in bulk
buy allegra uk
buy allegra tablets
allegra 120 buy
buy allegro 2
buy allegra in bulk
allegra to buy
buy allegra tablets
buy allegra 180 mg
buy allegra d
allegra 120 buy
buy allegra otc
buy allegra
buy allegro 2
buy raquel allegra
buy allegra 180 mg
buy allegra d
allegra to buy
buy allegra online
buy allegra
buy allegra 180 mg
buy allegra 180 mg
allegra to buy
buy allegro 2
buy allegra online
buy allegra d cheap
buy allegro 2
buy allegra d cheap
buy allegra 180 mg
buy allegra 120 mg
buy allegra in bulk
allegra to buy
buy raquel allegra
buy allegra 120 mg
buy allegra 180 mg
buy allegro 2
buy allegra d cheap
buy allegra d
buy allegra in bulk
buy allegra d cheap
buy allegro 2
allegra 120 buy
buy allegra online
buy allegra otc
buy allegra 120 mg
buy raquel allegra
buy allegra
buy allegra online
buy raquel allegra
buy allegra in bulk
purchase allegra-d
buy allegra 120 mg
buy allegra
buy allegra d
buy allegra otc
buy allegra uk
buy allegra d
buy allegra tablets
buy allegro 2
allegra to buy
buy raquel allegra
buy allegra tablets
buy allegra d
buy raquel allegra
buy allegra
buy allegra tablets
buy allegra
buy allegra d cheap
buy allegra 120 mg
buy allegro 2
buy allegra otc
allegra to buy
buy allegra
purchase allegra-d
buy allegra tablets
buy allegra 120 mg
buy allegra otc
purchase allegra-d
buy allegra d
buy allegra online
buy allegra uk
purchase allegra-d
buy allegra d
allegra to buy
buy allegro 2
buy allegra in bulk
buy allegra otc
buy allegra 180 mg
buy allegra
buy allegra online
buy allegra in bulk
allegra to buy
buy allegra d
buy allegra tablets
purchase allegra-d
buy raquel allegra
allegra to buy
buy raquel allegra
buy raquel allegra
buy allegra d cheap
buy allegra uk
buy allegro 2
buy allegra in bulk
allegra to buy
buy allegra uk
buy allegra otc
buy allegra tablets
buy allegra 120 mg
buy allegro 2
buy allegra uk
buy allegra in bulk
buy allegra d
buy allegra online
allegra 120 buy
buy allegra online
buy allegra 120 mg
buy allegra d
allegra 120 buy
buy allegra 180 mg
buy allegro 2
allegra to buy
buy allegra d
allegra to buy
buy allegra
buy allegra 180 mg
buy allegra in bulk
buy allegra
buy allegra 180 mg
buy allegra in bulk
buy allegra in bulk
allegra to buy
buy allegro 2
allegra 120 buy
buy allegra in bulk
buy allegra otc
buy allegra d
buy allegra tablets
allegra to buy
buy allegra online
purchase allegra-d
buy allegra 120 mg
buy allegra d cheap
buy allegra
buy allegra 120 mg
buy allegra d cheap
buy allegra d
buy allegra 120 mg
buy allegra in bulk
allegra 120 buy
buy allegra 180 mg
buy allegra d
buy allegra d
purchase allegra-d
purchase allegra-d
healthrpose.com
buy allegra tablets
buy allegra online
buy raquel allegra
buy allegra in bulk
allegra 120 buy
buy allegro 2
buy allegra in bulk
buy raquel allegra
buy allegra d cheap
buy allegra d
allegra to buy
buy allegra in bulk
allegra 120 buy
Last edited by EvanTem; Today at 01:00 AM. Reason: MSF Database - Automerged Doublepost
« Better headlights | - »
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f13/climate-control-back-light-out-need-help-87435/
???? ????? - ???????? ? ??? ?????? - ?????? ????????? ???????? ?? ???????? ?? ????????? This thread Refback 12-13-2015 01:48 PM
Interior Climate Control Buttons - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 07-08-2014 11:44 AM
Climate Control Light Out - How to fix? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 07-07-2014 02:32 PM
Auto Climate Control Turning off countzero2k9 2010 MS3 - Troubleshoot/Diagnostics 10 07-23-2011 01:40 PM
climate control imaguju 2010 MS3 - Troubleshoot/Diagnostics 3 01-05-2011 04:04 PM
Climate Control - AC Always on fermentj Mazdaspeed3/6 General Discussion 24 11-25-2010 11:21 AM
Visteon expands climate control operations in China Haltech Automotive News 0 06-22-2010 09:10 PM
Automatic Climate Control Question needforspeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 8 10-18-2009 01:23 PM
Page generated in 0.35526 seconds with 30 queries
