> MazdaSpeed 3/6 - Car Audio & Electronics
MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here.
  • 1 Post By danb
 Old 10-01-2018, 12:53 PM   #1
ncgbrown@yahoo.com's Avatar
Posts: 4   (View Stats)
ncgbrown@yahoo.com is an unknown quantity at this point
Default Harness for tapping speaker outputs
Hello folks, I just bought my son a 2009 Mazdaspeed 3 so we are looking to mod some things. I have looked in the forums but maybe I'm missing it -
I want to keep the OEM head unit but replace the Bose amp and speakers. I need the speaker outputs coming from the head unit at the amp under the seat to connect to an amp with high level inputs. Is there a female harness for the male coming from the head unit (the one that plugs into the bose amp) so I do not have to cut into the speaker wires to get at those speaker outputs?
Thanks - I'm sure I'll have more questions as we start looking into more stuff.
ncgbrown@yahoo.com is offline   Reply With Quote
 Old 10-01-2018, 01:12 PM   #2
Jeff23spl's Avatar
Posts: 1,698   (View Stats)
you can just skin the plastic armor off the wire without cutting the copper part and tap it there.
there you will find the wiring.
RADIO PINOUTS
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 10-03-2018, 10:02 AM   #3
shamie's Avatar
Posts: 924   (View Stats)
The inputs to the BOSE amp are low level.
I made my own harness years ago but can't find the thread. There is a Metra connector that will fit where the BOSE amp connects but I don't have that number either. So basically I'm useless.
2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, 51R Battery Box & Raider's AD / StopTech Brakes
 Old 10-03-2018, 12:34 PM   #4
So you made a harness with RCA's on the opposite end?
 Old 10-04-2018, 07:11 AM   #5
shamie's Avatar
Yes. Harness to RCAs and remote turn on I believe.
I posted on another Mazda3 forum years ago but can't find the link. I can't even remember which forum (it wasn't 247). The title of the thread was "BOSE blows no mo". If you can find it please post the link. I'll try to dig up my documentation tonight and post it here. I lost my hard drive at home last week so let's hope its in the backups.
 Old 10-04-2018, 12:00 PM   #6
Yep - here it is -
https://www.mazda3forums.com/70-2004...ows-no-mo.html
And yes, that is exactly what I had in my head to accomplish. So when you bought those Metra connectors, you didn't have any problem removing the individual pins and reusing them? or did you have to butcher them and buy new pins? Also on the wiring diagram you posted there, I am assuming that Pin B (RCA) A(spk) is referring to the top and bottom row of pins.
Looks great man - I may try to make this if I can get some free time.
 Old 10-04-2018, 05:28 PM   #7
shamie's Avatar
I didn't butcher them - just de-pinned them, un-soldered them, and re-soldered them. The PAC ADD-GM24A adapter mentioned toward the end of the thread would have been my first choice if I had known.
A & B do refer to top and bottom - or bottom and top, I can't recall it was 9 years ago. One thing I do remember is the remote turn on turns on with the car not the radio.
Good luck with your install.
 Old 10-04-2018, 05:34 PM   #8
shamie's Avatar
BTW how the hell did you find it? I wrote it and couldn't find it!
 Old 10-05-2018, 05:20 AM   #9
danb's Avatar
Posts: 151   (View Stats)
danb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud of
google search of "blows no mo" comes up with pics of my ex wife
RazoE likes this.
2007 speed3 GT. cobb rmm, JbR pmm, twm solid shifter bushings, AP3, Autotech, corksport turbo, HTP 3.5, Depo catless dp, Turbosmart Kompact bpv, Corksport 3port, cpe BlockD, Guardian Angel V3, DO DVC-30, SU TMIC Freektune 93 and e85 maps
2011 mazda 6 95k. wifes ride
danb is offline   Reply With Quote
2019 BMW Z4: Two inline-6 engine outputs being tested Haltech Automotive News 0 10-09-2017 11:10 AM
GPS Navigation Unit with AV Outputs. theurgy MazdaSpeed 3/6 - Car Audio & Electronics 2 01-17-2014 03:24 PM
needed: gen1 bose amp outputs tddvrrn MazdaSpeed 3/6 - Car Audio & Electronics 6 08-20-2012 05:09 PM
help identifying speaker wiring at harness evilgrin 2010 MS3 - Car Audio & Electronics 3 03-21-2012 05:34 PM
Vanns.com Klipsch Synergy Series Speaker Sale (Klipsch Tower Speaker $129.88) Haltech Hot Deals Section 0 04-08-2008 01:21 PM
Page generated in 0.29501 seconds with 23 queries
