> MazdaSpeed 3/6 - Car Audio & Electronics
MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here.
 Old 08-18-2009, 08:13 PM   #1
pugzsigmapi's Avatar
Posts: 7   (View Stats)
pugzsigmapi is an unknown quantity at this point
Default how many watts can the stock alternator handle?
i have a Speed3 GT so i have the bose system and i want to add a subwoofer and have been thinking about one Rockford Fosgate P3 (500 watts rms) or one Rockford T1 (600 watts rms) can our car/alternator handle this much power added to it? (i know it would depend on the amp.. which would be around 400-500 watts rms)
I wonder because my previous car was a 2000 V6 cougar and i have 2 older P2's which together was only 400rms 800max and at one point i had problems with the battery not getting charged as quickly as it should and sometimes would die...
so how much power can our car/alternator handle before its too much?
any help would be helpful.. but please only respond if u actually know what ur talking about THANKS!
pugzsigmapi is offline   Reply With Quote
 Old 08-18-2009, 08:25 PM   #2
JMEngineer's Avatar
Posts: 2,122   (View Stats)
JMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the worldJMEngineer is the leader of the world
Groans: 32
Groaned at 19 Times in 15 Posts
I'm not sure how it is with the 3, but I know the MS6 has a more powerful alternator than the regular 6. When I have both of my subs in I'm running well over 1000W RMS and I've never had any problems - just a slight dimming of the lights on the big hits if I turn it way up. I don't see 5-600 being a problem.
2006 MS6 GT - Built engine, twin scroll GT3076R, dual MV-S wastegates dumped to atmosphere, TR1035 FMIC, too many parts to list...
2009 MS3 GT - Built engine, JBR intake/TIP and short shifter, all engine mounts, Autotech HPFP internals, ETS TMIC, Custom AP tune, Pauter rods, CP pistons, and 6-puck ACT clutch
-GTX2867R Coming Soon
JMEngineer is offline   Reply With Quote
 Old 08-19-2009, 06:43 AM   #3
ataraxia's Avatar
Posts: 119   (View Stats)
ataraxia has much to be proud ofataraxia has much to be proud ofataraxia has much to be proud ofataraxia has much to be proud ofataraxia has much to be proud ofataraxia has much to be proud ofataraxia has much to be proud ofataraxia has much to be proud ofataraxia has much to be proud ofataraxia has much to be proud of
The 2007-2008 Speed3 and the 2006-2007 Speed6 have a 110 amp alternator, although I understand they are limited to 80amps by the ECU. I've got two amps and nine speakers using the stock alternator and have no dimming/starting issues although I'm going to pick up a yellow top Optima this weekend (D35) as a starting point toward prevention.
ataraxia is offline   Reply With Quote
The Following User Says Thank You to ataraxia For This Useful Post:
802MS3 (08-19-2009)
 Old 08-19-2009, 09:10 AM   #4
SSinstaller's Avatar
Posts: 3,826   (View Stats)
Groans: 51
I have a Memphis MOJO 2500D, and a Memphis MC5004 amp running on the stock alternator and haven't had any charging issues. I do run two tiny optima pc680 batteries in the trunk, but that was done to get the battery out from under the hood, not because of the stereo..
You won't have any problems.
Soon to be installed:
ST manifold w/ port injection : Raduim Engineering PCV Plate : Radium Engineering PCV valve : Radium Engineering Fuel filter : Aeromotive FPR : DCR VVT : TI Automotive F90000262 Fuel Pump : NX 15718 : Split Second AIC
 Old 08-20-2009, 09:03 AM   #5
sweet thanks!
Honda Accord Radio Doesn't Work, Hood Release Won't Catch, Manifold Gasket Leaks, Running A Vehicle On The Alternator, T Haltech Automotive News 0 01-23-2009 12:50 PM
anyone put a HO alternator on their ms3? builthatch MazdaSpeed 3/6 - Car Audio & Electronics 40 01-10-2009 11:26 AM
Cyl pressure questions... DI can it handle it? ptperformance MazdaSpeed 3/6 - ECU Computer Tuning 28 05-22-2008 08:41 PM
how much can our pistons handle? CMESCOOT MazdaSpeed 3 - Engine, Transmission & Driveline 40 04-26-2008 06:02 PM
Logitech G51 155 watts RMS 5.1 Surround Sound Speakers $119.99 Haltech Hot Deals Section 0 04-06-2008 08:02 AM
Page generated in 0.26077 seconds with 23 queries
