> MazdaSpeed 3/6 - Car Audio & Electronics
MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here.
 Old 11-13-2010, 04:48 PM   #1
Qtip's Avatar
Posts: 410   (View Stats)
Qtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond repute
Default Need ignition source to tap
My car is in pieces right now trying to fix the cowl rattle and figured I'd fix my wiring as well...
Anyone know of a ignition source that I can tap that is in the driver footwell area? I want this source to only have power when the key is in the ON position.
Did a search but couldn't find any post with clear information.
Tnx
Qtip is offline   Reply With Quote
 Old 11-13-2010, 04:55 PM   #2
taf0422's Avatar
Posts: 4,687   (View Stats)
Groans: 192
Did you try the cigarette plug wires? That has some pretty easy access
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 11-13-2010, 04:59 PM   #3
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Pull the steering column cover and use those wires - you can find the right one by searching for a turbo timer install write up...
Or use the cigarette lighter power wire in the fuse block harness..
 Old 11-13-2010, 05:03 PM   #4
Qtip's Avatar
Wow, that was fast! This forum rocks.
So I want the Green/Yellow wire(Ignition) at the column correct?
http://www.mazdaspeedforums.org/foru...eed-3-a-18264/
 Old 11-13-2010, 05:22 PM   #5
hnda etr's Avatar
Groans: 90
Looks like it... Use test light to confirm - if you have one...
 Old 11-13-2010, 05:31 PM   #6
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
or if you want to not cut your factory wires use an add a fuse over on the fuse panel on the passenger side and just run a wire over
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following User Says Thank You to cpolly69 For This Useful Post:
FreeFlyFreak (11-14-2010)
 Old 11-13-2010, 05:32 PM   #7
hnda etr's Avatar
Groans: 90
+1
The Following User Says Thank You to hnda etr For This Useful Post:
cpolly69 (11-13-2010)
 Old 11-14-2010, 12:49 AM   #8
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,155   (View Stats)
Groans: 754
Add a fuse every time for me, fucking with factory wiring often leads to endless future problems. Problems which are often hard to troubleshoot.
Suspension:
 Old 11-14-2010, 04:52 AM   #9
Eatin' Your Tuna
Haltech's Avatar
Groans: 243
Theres an unused fuse in the engine fuse cover. Use.a.15amp add a fuse and you have switched ignition on power in virvin state.
 Old 11-14-2010, 03:28 PM   #10
Qtip's Avatar
I think lazyness got me this time, I didn't want to run the wire all the way to the passenger side so I just used the ignition wire everyone mentioned.
Are you talking about the unused slot at the upper front of the fuse box? If so, that one has some demons. It'll power-up by itself out of nowhere once it a while.
I've attached a picture of the ignition wire so anyone else who needs it can figure it out. This wire is a lot heavier gauge than I expected.
The Following User Says Thank You to Qtip For This Useful Post:
Captainobvious (05-31-2014)
 Old 11-17-2010, 11:02 AM   #11
dreamspeed's Avatar
Posts: 39   (View Stats)
dreamspeed is just really nicedreamspeed is just really nicedreamspeed is just really nicedreamspeed is just really nicedreamspeed is just really nice
Try to avoid using test light. It should be okay for what you were looking for but using a test light with change the resistance on the wire and depending on the wire could lead to damaging components. Use a multimeter... even if its just a cheap one.
dreamspeed is offline   Reply With Quote
Headlights On/Off with ignition prenedo MazdaSpeed 3 - How-To's 13 12-07-2014 01:29 PM
Car won't start even with key in ignition diablo900t MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 06-29-2010 12:22 PM
Headlights on/off w/ ignition prenedo MazdaSpeed 3/6 - Car Audio & Electronics 7 12-03-2009 06:23 AM
Ignition tables Trader
Cobb ATR Support
7 08-22-2009 10:40 AM
HKS Ignition Amplifier Laloosh MazdaSpeed 3/6 - ECU Computer Tuning 25 09-29-2008 04:31 PM
Page generated in 0.31201 seconds with 27 queries
