> MazdaSpeed 3/6 - Car Audio & Electronics
MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here.
 Old 12-06-2017, 03:56 PM   #1
BoostedRide's Avatar
Posts: 169   (View Stats)
BoostedRide has disabled reputation
Question Reverse light wire for backup cam install? (Speed6)
Going to be installing a backup camera in my Speed6. Does anyone know which wire going to the reverse bulbs has power?
BoostedRide is offline   Reply With Quote
The Following User Says NO Thank You to BoostedRide For This Un-useful Post:
5doorsoffury (12-07-2017)
 Old 12-07-2017, 02:26 AM   #2
5doorsoffury's Avatar
Posts: 966   (View Stats)
Groans: 72
Groaned at 7 Times in 6 Posts
https://www.google.com/search?q=mazd...obile&ie=UTF-8
Try this first then post.
MECP
2012 BM
Rfinkle tune in progress
The Following User Says NO Thank You to 5doorsoffury For This Un-useful Post:
BoostedRide (12-07-2017)
 Old 12-07-2017, 04:49 AM   #3
Originally Posted by 5doorsoffury View Post
Thanks for trolling. Googled before I posted.
The Following 2 Users Say NO Thank You to BoostedRide For This Un-useful Post:
5doorsoffury (12-10-2017), MSMS3 (12-10-2017)
 Old 12-07-2017, 01:31 PM   #4
Groans: 72
Np. I was just going to say dont be a lazy faggot and use a volt meter to figure it out your self. Then i googled it and found the answer in 4 diffrent places and realized your not a faggot your just fucking retarted so i spoon fed you with the link. Just look for yellow loom and tap into any wire in there or try some black wires in that area.
MECP
2012 BM
The Following User Says Thank You to 5doorsoffury For This Useful Post:
MSMS3 (12-10-2017)
 Old 12-07-2017, 04:50 PM   #5
Same shit I found. For Mazda3 or later gen 6, but thanks. It's you're btw
 Old 12-08-2017, 07:47 PM   #6
SSinstaller's Avatar
Posts: 3,827   (View Stats)
Groans: 51
Should be red/yellow.
For future reference....
https://www.scribd.com/mobile/docume...Wiring-Diagram
Soon to be installed:
ST manifold w/ port injection : Raduim Engineering PCV Plate : Radium Engineering PCV valve : Radium Engineering Fuel filter : Aeromotive FPR : DCR VVT : TI Automotive F90000262 Fuel Pump : NX 15718 : Split Second AIC
BoostedRide (12-09-2017)
 Old 12-10-2017, 11:53 AM   #7
Groans: 72
like i said... retarded ..... 4th post down on google...
and i quote,
"putting it into reverse, and using a multimeter to check if you're getting +12v between the RED/YEL wires and ground" so red yellow was the reverse wire but dont worry about it since some one just told you.
try not to get to much food on the bib while being spoon fed.....
MECP
2012 BM
MSMS3 (12-10-2017)
BoostedRide (12-13-2017)
 Old 12-10-2017, 01:51 PM   #8
MSMS3's Avatar
Posts: 2,196   (View Stats)
Groans: 112
OP has proven two things:
1. He is lazy and expects everyone to do his work for him. Recipe for real life failure.
2. Even when spoon fed, he can't read far enough down the list to discern the answer. ADHD.
When one is lazy, has attention deficit, and is impatient with those offering help, there's not much incentive to offer any help in the future.
5doorsoffury (12-11-2017)
The Following User Says NO Thank You to MSMS3 For This Un-useful Post:
 Old 12-10-2017, 08:42 PM   #9
Groans: 51
People like you two are the reason this forum isnt 1/10th as busy as it used to be. If the thread isnt worth the time to answer why waste the fucking time to berate the OP. Just move along.
The Following 3 Users Say Thank You to SSinstaller For This Useful Post:
dolbouck7 (12-21-2017), SaveMelMac (12-10-2017), Spectrix (12-10-2017)
The Following User Says NO Thank You to SSinstaller For This Un-useful Post:
 Old 12-11-2017, 05:22 AM   #10
MSMS3's Avatar
Groans: 112
Because we don't need to be enablers. This forum is a gold mine of tech info on this platform. Just about everything that can or will happen to these cars has been identified and discussed in detail.
New users should learn to use the resources and not expect others to do it for them.
The problem is not just here. It is endemic in America and reflected in the low academic achievement on standardized tests compared to other countries against whom we compete.
It's not that these people are of lower intelligence than their peers in more competitive countries, its that they are lazy and we enable that behavior. I will not. This must stop. Tough love.
Backup camera in Speed6? BoostedRide Mazdaspeed3/6 General Discussion 4 11-27-2017 02:09 PM
Backup camera install jasonb0816 CX-7 > Car Audio & Electronics 19 11-14-2016 05:23 AM
How to install a Reverse Light HID Kit nyghtryder MazdaSpeed 3 - How-To's 67 06-27-2013 02:37 AM
Backup wire and speed sensor wire? Fozzy MazdaSpeed 3/6 - Car Audio & Electronics 4 06-01-2013 04:43 AM
Reverse light question/help. campbell MazdaSpeed 3/6 - Car Audio & Electronics 4 03-16-2010 12:41 PM
Page generated in 0.31435 seconds with 23 queries
