> MazdaSpeed 3/6 - Car Audio & Electronics
Notices
MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here.
Like Tree7Likes
 Old 10-08-2012, 05:48 PM   #1
brandon3212's Avatar
Posts: 7   (View Stats)
brandon3212 is an unknown quantity at this point
Default Speed 3 custom stereo
Here is where I will be posting the progress on the stereo that I'm putting in my car
Enjoy!
Includes:
Hertz High Energy 6.5" components
Hertz Mille 10" sub
Dayton 15" referance series sub
Phoenix Gold MS2250 for front speakers
Hertz EP1D Monoblock for rear sub
Audison LRX 2 for front seat sub
Audison Bit 10 (to hook up to OEM headunit, should have pics of it by the end of the week)
B-Quite sound deadening in the doors
Running the power wire to the back.
The beginning of the fiberglass box to fit under the glove box. Right now it's just Styrofome wrapped in tuck tape, soon it will get glassed.
Dayton Referance 15" sub
Hertz ML2500 sub
Some new wheels and tires to go with the stereo
 Old 10-08-2012, 05:56 PM   #2
Mi06Speed6's Avatar
Posts: 109   (View Stats)
Mi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond repute
So you don't plan on having a passenger? Never seen a box in the passenger side foot well. Curious to see what you have in mind.
'06 Mazdaspeed 6|| Cobb SF & AP Stage 1 | RPM Street Springs | SPC Ball Joints | SU Rear MM | SURE Dread | Whiteline RSB |18x8 Enkei EKM3 w/ 225/40 | JBR SSP & SURE Anchors | Rotora Blanks w/ EBC Red Stuff | 6K HID lights/fogs | V2 Pre-amp |
Mi06Speed6 is offline   Reply With Quote
 Old 10-08-2012, 05:59 PM   #3
Well as you can see there is still foot space, not allot mind you.
Having the sub in the front sounds better than anything you have ever heard in a vehicle. The bass blends so well the the front speakers it's almost like it's all coming from one source.
 Old 10-08-2012, 06:35 PM   #4
SLOWHATCH's Avatar
Posts: 2,116   (View Stats)
Groans: 203
Groaned at 33 Times in 18 Posts
2010 CBM W/ Tech, Cobb AP Tuned by rfinkle2, PTP HPFP, Ported IM,
HTP 3.5" Intake, CS DP, CS TP w/QTP E Cut out, ETS TMIC, D.O WMI D07,
NGK Iridium Ix, JBR EGR Delete, Coolant Bypass, JBR IM TIG, GS EBC 3 Port Mode
JBR TMM 70, JBR RMM 88, JBR SSB, JBR AP Holder, Sure SSP
Swift Springs, Koni Yellows, GC Bump Stops, CS RSB, Ebay Adj. Camber Arms, Sonic Tuning ST8'S 18x8.5 on 245/40/18 NT-05
 Old 10-08-2012, 07:02 PM   #5
Posts: 5,721   (View Stats)
Groans: 121
Looks like a lot of used eBay shit components and hacked-up installs.
The Following 5 Users Say Thank You to silvapain For This Useful Post:
aggierandy (10-09-2012), bstover17 (10-08-2012), Deldran (10-08-2012), faeker (03-19-2013), radioflyer (10-09-2012)
 Old 10-08-2012, 07:10 PM   #6
Actually it's all out of my Sentra, none of its new. Sentra quit so a bought a MS3 instead.
 Old 10-08-2012, 07:15 PM   #7
Unicorn Farts
Deldran's Avatar
Posts: 2,189   (View Stats)
Groans: 99
Groaned at 35 Times in 28 Posts
I have seen a lot of jank ass installs before but that sucks. I am all for big stereos and used to complete in meca but you are ruining your car.
You do realize with the box there every time u blow a fuse your gona have to take the box out.
My advice sell all that crappy the only decent name there was that audison amp. Buy some decent components and simple sub setup these cars don't need anything huge. You are just making your car slower
Sent from galaxy Nexus vis CM10
Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms
Deldran is online now   Reply With Quote
 Old 10-08-2012, 07:18 PM   #8
To each his own
I have had this stuff for a number of years now and really like it, so I'm going to re-use it.
 Old 10-08-2012, 07:38 PM   #9
greenespeed's Avatar
Posts: 1,321   (View Stats)
greenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the world
Groaned at 6 Times in 3 Posts
I foresee you hearing alot of cone noise with the sub facing toward you and in the front like that. There is a reason subs are generally in the back of a vehicle. Plus bass is omnidirectional so I doubt it will sound any better there than it would in the hatch as far as volume goes.
2006 Mazdaspeed6 BCM GT
MODS : Cobb AP // Cobb SF // Sure TIP // JBR RMM // JBR SSB // JBR SSP // Magnaflow CBE // MSR 045 18 X 8 +35 // ACT ZX5-HDG6 // M2 3" catless DP // AT HPFP Internals // NGK's -- FREEKTUNE in progress
Having a 12 second Honda is just like coming out of the closet; You're going to surprise a bunch of people, but in the end you're still gay.
greenespeed is offline   Reply With Quote
The Following 2 Users Say Thank You to greenespeed For This Useful Post:
Big_Burd (10-09-2012), radioflyer (10-09-2012)
 Old 10-08-2012, 07:40 PM   #10
Spec's Avatar
Posts: 1,287   (View Stats)
Spec has disabled reputation
You must not live near thieves. Have you priced a window and regulator yet?
What about people with big feet? Ex: A man.
You say to each his own but, with this logic I doubt you'll be owning a floorboard sub for long. Some cracky is going to bust your shit wide open and jack your shit. They tend to go for a sure deal, not bust windows and snoop around and hope for a find.
Anyways, it is a different, bit unpractical but defiantly different. Good luck.
Spec is online now   Reply With Quote
 Old 10-08-2012, 07:46 PM   #11
Unicorn Farts
Deldran's Avatar
Groans: 99
I did a lot of testing with hatchbacks like ours and sportier hatches. For hatches like ours we found to get the most SPL facing toward the hatch as close as you can. Ever car is different but I would at least put the sub in the hatch you will get much better sound quality that way and wont annoy your passengers
 Old 10-08-2012, 08:27 PM   #12
tymoto21's Avatar
Posts: 35   (View Stats)
tymoto21 is just really nicetymoto21 is just really nicetymoto21 is just really nicetymoto21 is just really nice
Op put the sub in the back, like said before sub bass frequencies are not directional so wherever you put it it will fill what space it can.
Also don't run the 10" and the 15" sub.....
Not to mention you need to give the sound waves room to "expand" so to speak. Everyone knows most times you face the subs toward the back of the car, this is to help lower the peak frequency of the cabin to something closer to what the subwoofer naturally plays. (Like 30-50hz)
If you are concerned about the "distant" sound of the sub you can model an enclosure in winisd just google it and try to keep your group delay below 10ms. But the biggest way to make your stereo sound good is just tuning. Get your gains set properly so there is no audible distortion, set your crossovers appropriately and get a sub enclosure to fit your listening needs.
If you are looking for tight bass kicks look into a sealed enclosure or loud low bass look into a ported.
Iirc that Dayton sub is not meant for ported enclosures but its been a while.
tymoto21 is offline   Reply With Quote
 Old 10-08-2012, 08:43 PM   #13
Unicorn Farts
Deldran's Avatar
Groans: 99
Yes do not run a 10 and 15 at the same time if you thought that sounded good you have never heard a good system.
The reason behind this is say a 10 and a 15 are trying to play a 30hz tone. Even though they are replicating the same tone do to the larger cone area the 15 does not have to work as hard to create it. But the 10 does. It will sound extremely muddy because they in a way cancel each other out
The Following User Says Thank You to Deldran For This Useful Post:
 Old 10-08-2012, 08:53 PM   #14
bstover17's Avatar
Posts: 405   (View Stats)
bstover17 is the leader of the worldbstover17 is the leader of the worldbstover17 is the leader of the worldbstover17 is the leader of the worldbstover17 is the leader of the worldbstover17 is the leader of the worldbstover17 is the leader of the worldbstover17 is the leader of the worldbstover17 is the leader of the worldbstover17 is the leader of the worldbstover17 is the leader of the world
Groans: 166
Do it right once.....
Mods to be installed:
2010 MAZDASPEED 3
COBB ACCESSPORT // ETS TMIC // AUTOTECH INTERNALS // HTP 3" GOLD INTAKE // JBR 88 DURO RMM // JBR EGR DELETE // SURE ANCHORS // SURE COUNTERSHIFT // SURE SHORTCUT
TB PERFORMANCE TRACTION BAR V 2.0 // TB PERFORMANCE CHASSIS BRACE // BOOST TUBES // JBR BYPASS HOSE // DDM TUNING 5k HID // STREETUNIT TURBOSMART BPV
PROSPORT BOOST GAUGE // CNT CATLESS DP // ZOOM ZOOM BOX // JL Audio 10w3 // HEADLIGHT ARMOR YELLOW FOGS
bstover17 is offline   Reply With Quote
 Old 10-09-2012, 07:22 AM   #15
6262ms3's Avatar
Posts: 103   (View Stats)
6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute
Lol, tough crowd here. Just my 2 cents, I would also do away with the 10 up-front. The Dayton HF is a great sub with a low-distortion motor, in the right box with the right power it should still sound clean and tight. HF series need HUGE boxes though. MS3's have solid plastic inner-door cards which require only a little extra sealing to get good mid-bass from your door speakers, again reducing the need for a front sub. If you absolutely want to run the front sub, make sure it and the 15 are crossed over separately to play different frequencies (ie: 15" 40hz-down, 10" 40hz-90hz) and time-align the 10 on your processor. But you have a 15 that can play high, and with good mid-basses and tuning you really don't need the front sub.
'07 MS3. Cosmic Blue, CPE 60-duro rmm, Cobb Accessport, Corksport sri, Corksport tmic, TWM shifter base bushings, JBR adjustable short shift plate, Koni FSD-4045 Struts, RX-8 Rims.
6262ms3 is offline   Reply With Quote
The Following User Says Thank You to 6262ms3 For This Useful Post:
Captainobvious (03-19-2013)
 Old 10-09-2012, 08:09 AM   #16
Mi06Speed6's Avatar
You have a hatch. That's one of the best car setups you can ask for in terms of putting subs in the "trunk". Point them towards the back and let the sound waves reverberate off the back hatch.
Personally, I prefer my chick in the seat next to me instead of subs.
The Following 2 Users Say Thank You to Mi06Speed6 For This Useful Post:
Atlanta (11-15-2012), radioflyer (10-09-2012)
 Old 10-09-2012, 08:18 AM   #17
deadlandxtreme's Avatar
Posts: 1,010   (View Stats)
deadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the world
Groans: 82
This seems like something that should be closed and moved to Mazda247. I agree with the fact that everyone has a right to express themselves with what they think is right for their car. However, if you were to look in the vast expanse on other custom installs on here, you would see a solid and proven knowledge base.
Not all of us can afford new system parts, so I applaud you for trying to use what you can. However, if a stereo is import, make sure you start to save for better audio gear and upgrade as you go.
2010 Mazdaspeed3- Installed Mods: - TWM Performance Full Replacement Short Shifter Kit, CP-E TMIC, COBB TIP, AEM CAI, Forge V2 BPV, Corksport boost and recir hoses, Corksport coolant hoses, Denso ITV-22, COBB AP, CNT DP, Corksport hangers,JBR EGR block off, Autotech HPFP internals. Glowshift triple gauge pod, Aeroforce Interceptor dual gauges, STRI Imperial boost gauge.Grimmspeed EBCS.RSB and Rear Camber Arms ( JBR ). Tein EDFC kit - Tein Super Street Coilovers . Enkei Racing RPF1 .Corksport FSB..StopTech SS Brake Lines-SportStop Cross Drilled and Slotted Rotors-StopTech Street Performance Brake Pads.
deadlandxtreme is offline   Reply With Quote
The Following 2 Users Say Thank You to deadlandxtreme For This Useful Post:
 Old 10-09-2012, 08:32 AM   #18
hung380's Avatar
Posts: 119   (View Stats)
hung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond reputehung380 has a reputation beyond repute
Good choice on the hertz high energy component set.
I'll be installing a set in my evo
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
hung380 is online now   Reply With Quote
 Old 10-09-2012, 08:59 AM   #19
radioflyer's Avatar
Posts: 447   (View Stats)
radioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the world
Groans: 28
2 things with audio you only want to do once. Speakers, and wiring. Everything else is pretty easy to access. Skimping on these will make your life suck.
Power: // K&N SRI // Cobb TIH // ETS TMIC // CNT Catted Turbo-Back // AT Internals // ITV-22's
Tuning & Fuel: Cobb AP // 25% e85/91oct // Cobb EBCS // Stratified Tuned
Suspension: Koni Yellows // Swift Spec R Springs // Hotchkis FSB // JBR RSB
Mounts: CPE Stage 2 RMM // CPE PMM // CPE TMM
Shifting: Corksport SSP // Corksport Shifter Assembly Bushings
Wheels & Rubber: XXR 527 // Some crappy free tires at the moment
How to make your car BSOD:
http://www.mazdaspeedforums.org/forum/f13/carputer-105207
radioflyer is online now   Reply With Quote
 Old 10-09-2012, 04:04 PM   #20
I will keep this thread updated for those who actually care. For those of you who don't care you can say what you wish, doesn't bother me.
You can hate my choices in amps and speakers all you wan't. You can hate the fact that I'm putting a sub under the glovebox, I have done this a few times before and I have personally listened to many other cars with the same front sub setup. I love the way it sounds, you just can't get the same presentation of midbass from a sub in the trunk.
The front speakers, front sub and rear sub will all be crossed over seperatley with an Audison Bit 10.
 Old 10-09-2012, 04:28 PM   #21
radioflyer's Avatar
Groans: 28
Welp. When you're ready to do a professional installation, you know where to find us.
 Old 10-09-2012, 04:56 PM   #22
Unicorn Farts
Deldran's Avatar
Groans: 99
What exactly do you call mid bass.
Anything above 70 to 80hz should be played by your mids. Aka 6.5" components. Then those will be crossed so only the highs are handled by the tweeters. Subs do do not play mid bass they play bass.
We are trying to help you you are just to ignorant to listen.
Have fun listening to mud
 Old 10-09-2012, 05:05 PM   #23
Rokusek's Avatar
Posts: 4,036   (View Stats)
Groans: 71
Groaned at 31 Times in 24 Posts
Hmm interestingly suspicious I once had an NA 3 hatch with a SQ setup... If you knew anything about car audio, as others have said running two different size subwoofers is retarded, your destroying the sound and you physically can't tune the system properly running it this way. As for all your equipment... Even though you have had it for a while and like it, there are a million different components subs and amps out there that you can buy new for less than the cost of a new set of wheels, and they will sound 10 times better than what you have now without being tuned... But good work I guess I'd just do some
More research on what you has and the capabilities of this car with a SQ set up
SMH
Sub'd for later and more detailed response...
Roku Built / RichTune In progress
275FWHP/299FWTQ MUSTANG DYNO 4/7/13
Wiseco Pistons - K1 Connecting Rods
SPONSORED BY JAMES BARONE RACING
JBR-3"WP/SBB/SSP/SSB/RSB/BSD/VTA-OCC/BPV HOSE/SSK
MUD FLAPS/TIGS/EGR B-O/CAMBER ARMS/88 TRILOGY/AP MOUNT/OPB
Turbo XS-DP/TP;Forge-V2 BPV;BC-BR TYPE COILS;TR MOTOR SPORT-C3 17x9 +32F +40R; DUNLOP ZII 255/40/17;NGK-IRIDIUM X's;GT SPEC-REAR TIE BRACE; COBB-ACCESS PORT; PG-IC PIPING;TREADSTONE-TR8;CPE-HPFP;ACT-PROLITE SPRUNG 6 PUCK; PTP SEALS
[06:36 AM] Rokusek: cody dont be jelly of codys success
[06:25 AM] BlueDmnSpeed: makes me want it more now
[06:25 AM] BlueDmnSpeed: lol awesome
[06:24 AM] mghtymouse380: you wouldnt even be able to penetrate before boom
[06:22 AM] BlueDmnSpeed: ???
[06:22 AM] BlueDmnSpeed: so what your saying is just sticking the tip in would finish me
[06:22 AM] BlueDmnSpeed: hahaha
[06:21 AM] mghtymouse380: no you dont been in there its too good for you
[06:21 AM] BlueDmnSpeed: paul is sexy i wanna make love to his butt!
radioflyer (10-10-2012)
 Old 10-09-2012, 05:47 PM   #24
helmetface's Avatar
Posts: 4,586   (View Stats)
Groans: 142
Install is fail.
That sub is a great sub, however it needs a shit-load of air space. I'll never understand people's concept of "bigger is better"... with a proper box you can make any driver sound proper.
I also don't get why someone would invest their time(as obviously money isn't involved here with used equipment) and not invest in a good HU...
I won't even comment on the bass location(s)
Rokusek likes this.
helmetface is online now   Reply With Quote
The Following 3 Users Say Thank You to helmetface For This Useful Post:
PartiAudiMazdarati (10-09-2012), radioflyer (10-10-2012), Rokusek (10-09-2012)
 Old 10-09-2012, 06:22 PM   #25
Unicorn Farts
Deldran's Avatar
Groans: 99
Originally Posted by helmetface View Post
Install is fail.
Thank you!!! Someone who understands what a box can do.
The Following 2 Users Say Thank You to Deldran For This Useful Post:
 Old 10-09-2012, 07:06 PM   #26
GODspeed7's Avatar
Posts: 2,736   (View Stats)
Groaned at 48 Times in 33 Posts
Neutral  -1 score
I think you should just go to mazdas247>>> I don't think anyone here wants you to update anymore...
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
HYPNOTIC TUNED, HTP full 3" intake system, HKS SSQV 4 full VTA, Corksport 65mm Racepipe, Cobb AP, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 70duro PMM, JBR cylindrical shift knob, DDM tuning HID's lows and fogs, Resonator Delete.
GODspeed7 is online now   Reply With Quote
The Following 2 Users Say Thank You to GODspeed7 For This Useful Post:
bstover17 (10-09-2012), radioflyer (10-10-2012)
 Old 10-23-2012, 05:26 PM   #27
Ihatepufferfish's Avatar
Posts: 42   (View Stats)
Ihatepufferfish has disabled reputation
I'm glad I looked at this post I needed a good laugh
Ihatepufferfish is offline   Reply With Quote
 Old 10-23-2012, 06:29 PM   #28
JosephM's Avatar
Posts: 65   (View Stats)
JosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud ofJosephM has much to be proud of
Groaned at 61 Times in 15 Posts
Wow... Just wow... This sounds like a horrible idea....Sell that 10 on Car Audio at CarAudio.com, get some legit 6.5'' and they will sound way better than that 10 in your glove box.. Better yet.. Trade it... While your on caraudio.com... read...a lot to learn there..
JosephM is offline   Reply With Quote
 Old 10-23-2012, 07:03 PM   #29
Mclovin80's Avatar
Posts: 232   (View Stats)
Mclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the worldMclovin80 is the leader of the world
Go ahead and mount all of your amps to the FMIC for maximum airflow....oh and don't forget the neons....
Sent from Cloud 9
spitfire6977 likes this.
Mclovin80 is online now   Reply With Quote
 Old 10-23-2012, 07:19 PM   #30
500WHP INC
Nitr0EngiE's Avatar
Posts: 1,573   (View Stats)
Groans: 31
Groaned at 51 Times in 36 Posts
I am running Memphis 6 x 8 on all 4 doors and seperate tweeters on all 4 doors all running off a 1000 watt Quantum Audio Amp, and I got 2x JL W1 12" subs in a 4 cubic sealed box facing the hatch powered by a JL G1700 700W Monoblock amp. 5 Farad cap. and yes my subs are in the trunk lawl.
2008.5 White Pearl MS3
474HP/453TQ http://imageshack.us/a/img4/1726/virtualdyno129124thgear.jpg(with CF 1.01 it was more like 425HP)
Mods: 3.5 Bar MAP,Wisecos 9:5:1,Pauter Rods,BSD,balanced rotational assembly, ARP Studs,Devils Own Meth Kit DO7 100%, Garret 3076R T3 w/Titanium turbo blanket, CP-E Safe Seals,CP-E FMIC,CP-E CDFP,Cobb AP,DCR VVT,ITTV24,Grounding Kit,Custom 3.5" Intake and MAF, Custom T3 Manifold w/38MM Tial EWG black cermaic coated with Titanium heat wrap,Custom 3" V-Band DP Titanium heat wrapped,Borla Catback,Fidanza 11LB Flywheel,Spec 3+ Clutch,cometic head gasket,ceramic heat barrier on IM, Sure TIG,V.C.T.S. Welded, Kenne Bell BAS,CP-e Triple gauge pod, Prosport Boost Gauge,Glowshift Wideband AFR gauge, Glowshift EGT gauge,Streetunit Engine Mounts ALL 3,PTP BSD-Windage Tray, So Many Little things i cant remember.
 Old 10-23-2012, 07:29 PM   #31
Boatcop1's Avatar
Posts: 267   (View Stats)
Boatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the world
Neutral  -1 score
Jesus Christ what a moron!
Boatcop1 is offline   Reply With Quote
The Following User Says Thank You to Boatcop1 For This Useful Post:
radioflyer (10-23-2012)
 Old 11-13-2012, 07:34 PM   #32
greatFox's Avatar
greatFox will become famous soon enough
I think you guys have made your point.
However the OP is correct with the bass imaging and integration with the front speakers. I had a Smartcar and I had Focal Polyglas components in the front with a custom JL 8" box under/inside the dashboard. It really DID sound great, the bass was not separated from the mid-bass in the doors. It sounded more like a set of nice tower speakers. By comparison, a sub way in back suffers from phase problems and a hell of a lot of delay problems and reverberation coming from way back there. The bass just never meshes when it comes from way back.
2007 Mazdaspeed 3
www.greatfoxmusic.com
greatFox is offline   Reply With Quote
 Old 11-13-2012, 07:49 PM   #33
radioflyer's Avatar
Groans: 28
I wont groan you because it's your first post.
This is not a smart car, you did what you had to do.
The OP lacks any and all logic in the design of his system, ignores the advise of other more experienced installers, and has abandoned all common sense. Unlike the OP many of us have lots of experience and have spent many hours researching testing different setups. A hatchback is probably the most optimal bass cannon anyone could ask for and the OP has decided that he is not going to take advantage of that and aggravate any passenger that gets in his car.
I strongly suggest you make a proper introduction in the off topic lounge and walk away from your position on this.
GODspeed7 and Deldran like this.
The Following 4 Users Say Thank You to radioflyer For This Useful Post:
Deldran (11-13-2012), GODspeed7 (11-13-2012), Mase (11-15-2012), tddvrrn (11-15-2012)
 Old 11-13-2012, 08:18 PM   #34
GODspeed7's Avatar
I stopped giving a fuck and you lost all credibility as soon as you mentioned, smartcar. Also I don't think your first post should be telling us that " we have made our point" I don't think you understand how this forum works. OP says or does dumb shit, we attack and don't stop until either OP gets banned, or takes it like a man and lets the animals (us) lose interest. I suggest you do less posting and more reading so you know how this forum operates. This site isn't all rainbows, sunshine, sugar cookies and handjobs. Blood is shed on a daily basis.
Hey OP good news! You're off the hook. Feel free to install any shitty system you want. greatFox; is our new bitch now. UNLEASH THE HOUNDS!!!
Last edited by GODspeed7; 11-13-2012 at 08:18 PM. Reason: MSF Database - Automerged Doublepost
silvapain (11-13-2012), tddvrrn (11-15-2012)
 Old 11-13-2012, 08:26 PM   #35
Spec's Avatar
op is an idiot and I had gay sex in a smart car.
Fixed.
The Following User Says Thank You to Spec For This Useful Post:
 Old 11-13-2012, 10:47 PM   #36
Groans: 121
I stopped reading at "Smartcar".
Anyone who buys, owns, drives, sits in, stands near, or looks at a SmartCar immediately looses all credibility with me.
Rokusek and deadlandxtreme like this.
The Following 7 Users Say Thank You to silvapain For This Useful Post:
deadlandxtreme (11-14-2012), Deldran (11-14-2012), GODspeed7 (11-14-2012), radioflyer (11-14-2012), Rokusek (11-14-2012), Spec (11-14-2012), tddvrrn (11-15-2012)
 Old 11-14-2012, 06:24 PM   #37
greatFox's Avatar
Wow.
This is like High School.
Sorry guys but High School was 20 years ago. I'm done with flame wars.
Next time I want to post something I think might be useful, I will refrain.
2007 Mazdaspeed 3
The Following User Says NO Thank You to greatFox For This Un-useful Post:
Mase (11-15-2012)
 Old 11-14-2012, 06:37 PM   #38
radioflyer's Avatar
Groans: 28
The Following 3 Users Say Thank You to radioflyer For This Useful Post:
Deldran (11-14-2012), Kamaril (11-14-2012), tddvrrn (11-15-2012)
 Old 11-14-2012, 06:47 PM   #39
greatFox's Avatar
OOOO! FORCE LIGHTNING COCKS!
2007 Mazdaspeed 3
Mase (11-15-2012)
 Old 11-14-2012, 06:49 PM   #40
ericdebruyn1's Avatar
Posts: 335   (View Stats)
Wow.
if someone is being gay towards you you just gotta out gay them, they grab your butt, you grab their penis and they will stop.
if someone is being a dick to you, dont fight back, just bend over, pull pants down, and spread cheeks. and and say "give it to me" and stay in that position tell they are done... do these things and you will be fine on this forum, i got it the hard way
2008 cosmic blue, h&r lowering springs, koni struts,HKS intake, rally armor mudflaps, rx8 wheals, stock everything els
Looking at a MS3, stereo issues etc?? Cameron MazdaSpeed 3/6 - Car Audio & Electronics 4 01-04-2011 04:13 PM
WTF Stereo?!?!? OgCoda MazdaSpeed 3/6 - Car Audio & Electronics 0 01-02-2011 12:38 PM
New Stereo Install ataraxia MazdaSpeed 3/6 - Car Audio & Electronics 71 12-28-2009 08:30 AM
my stereo enhancements builthatch MazdaSpeed 3/6 - Car Audio & Electronics 6 08-10-2008 12:53 PM
Page generated in 0.63143 seconds with 42 queries
