| MazdaSpeed 3/6 - Car Audio & Electronics MazdaSpeed 3/6 - Car Audio & Electronics - Tired of that stock stereo? Installing Nav units or mods to your current system? Come talk about it here. |
![]() | | | LinkBack | Thread Tools | Display Modes | ![]() |
![]() | | #1 | ![]() |
| Infidel ![]() Join Date: Aug 2009 Location: FL Panhandle
Rep Power: 376 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,001
| Not Ranked : 0 score
Last weekend, I installed a new Prosport boost gauge. Install was pretty easy, I used threads from here as a guide, thanks guys for posting those how-to's. I mounted the gauge, purchased from SU, in a vent pod purchased from the RPM Store. I used the piggy back double fuse adaptors for the fuse box hook up. The first and fourth pics show the daytime color setting of white. The second and third pics show the color setting of amber which activates when I turn on my parking lights/headlights. Here are a couple pics, you pic whores. Last edited by SW160; 11-01-2009 at 04:02 PM. | ||||||||
| The Following User Says Thank You to SW160 For This Useful Post: | thanox2 (10-29-2009) |
![]() Join Date: Aug 2008
Rep Power: 44 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
Nice,i have same gauge and set-up
| The Following User Says Thank You to slo4now For This Useful Post: | SW160 (10-30-2009) |
Rep Power: 181 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,159
Groans: 436
Groaned at 34 Times in 24 Posts
sooooooooooooooooooooooooooooooooooooooooooooooooo oooo nice, can't wait to get mine!!
__________________ I Forgot if my car was modded.
| The Following User Says Thank You to thanox2 For This Useful Post: | SW160 (10-30-2009) |
![]() | | #4 | ![]() |
| Mazda N00b ![]() Join Date: Aug 2009 Location: NJ/NYC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 7 Times in 2 Posts
is that the bright red? that what i'm using. i find it to be too bright. the refection in my driver side mirror and window annoy me. i'm going to rewire this weekend and use the less bright red for night.
![]() | | #5 | ![]() |
All the info I received with the gauge said it was amber. I didn't know there was another option color according to the wiring, only white or amber. let me know if you can re-wire it, I am interested in seeing what it looks like (post a pic). I will take some night time pics and get them on here over the weekend so you can see the color better.
![]() | | #6 | ![]() |
| Sox & Lox Bitch ![]() ![]() Join Date: Apr 2009 Location: NJ
Rep Power: 253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
i have the pod - was lookin into gauges where did you pick yours up
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. CPE Catted DownPipe | Res Delete | CPE Nano Intake | CPE Turbo Inlet | Forge BPV | TRZ Dogbone RMM | TRZ Tranny Mount | TWM Short Shifter | Street Unit Bushings | E4 Weighted Shift Knob & Shifter Weight | Full HID | Shaved,Tinted & Blacked Out | Hankook V4's | Other Sh1t coming soon... | ||||||||
![]() | | #7 | ![]() |
Street Unit Prosport Premium Boost Gauge, here is the link to the one I bought. ProSport Premium Amber/White Electronic Boost Warning & Peak Hold - 52mm | ||||||||
![]() | | #8 | ![]() |
| GO BLUE ![]() Join Date: Sep 2009 Location: Surburban Detroit Michigan
Rep Power: 600 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,166
![]() | Not Ranked : 0 score
Got the same thing. Very clean. Also bought mine from the same places!
__________________ CPE RMM - MS CAI with Straightener - Forge BPV - Cobb TIP- Custom Vibrant 3" exhaust - Turbo XS TP - JBarone SSP - Prosport boost gauge in vent - DashHawk w/JBarone mount - Valentine 1 - 20% tint - NKG 1 step colder- CP-E HPFP - Cobb AP w/NATOR AFcadet tune-Cobb RSB - Alpine w900 w/Boomin' Sound system | ||||||||
![]() | | #9 | ![]() |
I agree Bud. I went with this setup because it was very clean. I am not taking away anything from people with other setups, I just prefer this one.
![]() | | #10 | ![]() |
![]() ![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 50 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23
anybody know if this works in the ms6?
__________________ 2006 MAZDASPEED6 Go-fast bits: cobb sf, pg tp, ets tmic, cobb ap, cpe catted dp Bob-n-weave: h&r springs, goodyear eagle f1's Recon: Prosport premium boost, oil temp, oil press, lotek pod, spin-on filter conversion Reinforcements: tt diff mount, awr rear&tranny mounts Snickitty-snick: twm m1, custom shift counterweight, ams severe gear tranny/pto/diff oil Look@me: speedline badgeless grille, shorty antenna, drl leds Don't look@me: 35% tint, jdm visors, redline hood lifts Free mods: independent fogs, brighter fogs, 3rd brake light 1999 MAZDA MX-5 ebc green stuff /// brembo rotors /// tein s-techs | ||||||||
![]() | | #11 | ![]() |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
Where did you get the actual vent from? And how much?
![]() | | #12 | ![]() |
| Not Ranked : 0 score VentPod Single Gauge Pod for Mazda 3 / Mazdaspeed 3 - Revolution Performance Motorsports! use this PDF to remove the vent. i had to use a pair of pliers to turn the inside duct. http://www.showyourmedia.com/files/1252972295.pdf | ||||||||
![]() | | #13 | ![]() |
| Mexican MS3 ![]() ![]() Join Date: Dec 2009 Location: Mexico
Rep Power: 678 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 781
__________________ MS3 GT 2009 - COBB TIP // COBB SRI // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella yellow fog bulbs // Eonon 7" screen // AutoGauge Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // Hypertech Sport Programmer // COBB Downpipe // Ingalls Torque Damper // Denso ITV22 // GV style front lip // -- 294 whp - 342 tq - Probably fastest Mexican MS3 Coming soon: Street Unit Reinforced RMM // Wotbox 2-step & Launch control // PG/Godspeed FMIC Vids: MAZDASPEED 3 vs FOCUS RS ---> To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. MS3 vs MS3 (2nd Gen) vs STI ---> To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. MS3 slow-motion burnout (210 fps) ---> To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | |||||||||
![]() | | #14 | ![]() |
RapidShare: 1-CLICK Web hosting - Easy Filehosting | |||||||||
![]() | | #15 | ![]() |
![]() ![]() Join Date: Mar 2009 Location: Cincinnati, Ohio
Rep Power: 22 ![]() ![]() ![]() ![]() Thanks: 12
Now we need one for the MS6!
__________________ 1989 Mustang LX Notchback Mods: A few bolt ons........ Mazdaspeed 6 Black Mica Pearl Mods: CP-E CAI | ||||||||
![]() | | #16 | ![]() |
![]() ![]() Join Date: Oct 2009 Location: Andersen AFB, Guam
Rep Power: 670 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 697
Groans: 118
Groaned at 24 Times in 18 Posts
I like it and want one for the 2010!!!
![]() | | #17 | ![]() |
Finally got mine installed ![]()
![]() | | #18 | ![]() |
![]() Join Date: Jan 2010
Rep Power: 0 ![]() Thanks: 0
I always notice that, for some reason that vent is always closed. Looks like it was made for the gauge ! Nice install. | ||||||||
| The Following User Says Thank You to Snakery For This Useful Post: | ganque (02-24-2010) |
![]() | | #19 | ![]() |
![]() Join Date: Dec 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 10
I just ordered a vent pod as well as an Aeroforce Scan Gauge. Hopefully I will be installing them this weekend!
![]() | | #20 | ![]() |
![]() Join Date: May 2008 Location: Louisiana
Rep Power: 63 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 55
Can this vent pod be used with a mechanical gauge? Is there enough room and a way to get the boost line inside the vents?
![]() | | #21 | ![]() |
![]() Join Date: Jul 2009 Location: San Antonio, TX
Rep Power: 0 ![]() Thanks: 6
I have Prosport Mechanical boost guage and the tubing plus the 4 wires fit Note... be sure your carefull when pressing the vent pod in that you don't pinch the boost line, make sure the lines stay in the slit.
__________________ <Cobb SRI-Cobb inlet tube-Cobb AP-vent boost gauge-TurboXS TBE(catted RP)-TRZ RMM&TMM-PTP pill-PTP intake screen> | |||||||||
![]() | | #22 | ![]() |
![]() ![]() Join Date: Jul 2009 Location: Hampton Roads, VA
Rep Power: 40 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
I was wondering, if you turn on your headlights/parking lights, THEN turn on the car, does it stayed lit white? No matter whether you turn the headlights on and off afterwards? Mine does this and it's VERY annoying, I have the exact same setup...
__________________ '09 Speed3 Sport Metro Gray, cp-e Xcel™ CAI, Viper 5701 Remote Start/Alarm with tilt sensor/backup battery/audio glass break sensor, AVIC-F700BT, Polk Momo 6.5" Components, Alpine Type-R 12" Sub, Alpine MRD-M605 Mono @ 2 Ohm's, Alpine MRV-F540 Bridged to 2 CH's, No Mouldings, DDM 35W 4300K HID's, 35% tint all around w/eyebrow 13.8828 @ 102.48 MPH | ||||||||
![]() | | #23 | ![]() |
![]() ![]() Join Date: Apr 2010 Location: Northern VA
Rep Power: 49 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51
| Not Ranked : 0 score for all of you that have installed them... does the inner part of the vent just pop out...? I am under the impression it does, but I dotn want to break it while attempting to pull it out.Thanks fellaaaaaz
__________________ ---Stupid kid can haz car. | ||||||||
![]() | | #24 | ![]() |
![]() Don't be scared
| Thread Tools | |
| Install a boost gauge. | Demi | MazdaSpeed 3 - How-To's | 58 | 06-16-2010 08:10 PM |
| Installed CPE Defrost Vent Pod and Maddad Ultra Clarity "Basic" Boost Gauge | Addikted To Boost | MazdaSpeed 3/6 - Turbo Induction | 19 | 05-15-2010 01:47 PM |
| Vent Pod Boost gauge install | Katfish6913 | MazdaSpeed 3/6 - Car Audio & Electronics | 6 | 09-15-2009 09:04 AM |
| Vent pod boost gauge install question | uoftguy | MazdaSpeed 3/6 - Car Audio & Electronics | 1 | 05-10-2009 06:59 AM |
| boost gauge install? | bombdotcom | MazdaSpeed 3/6 - Turbo Induction | 5 | 06-06-2008 07:59 PM |
