Miata MX-5
> Miata - Forced Induction
 Old 01-27-2011, 03:13 PM   #1
Andy@Killshot's Avatar
Posts: 17   (View Stats)
Andy@Killshot has much to be proud ofAndy@Killshot has much to be proud ofAndy@Killshot has much to be proud ofAndy@Killshot has much to be proud ofAndy@Killshot has much to be proud ofAndy@Killshot has much to be proud ofAndy@Killshot has much to be proud ofAndy@Killshot has much to be proud ofAndy@Killshot has much to be proud ofAndy@Killshot has much to be proud of
Default MX-5 EFR Turbo Build
I figured I would share these pictures of my latest projects for one of my Miata customers.
Andy@Killshot is offline   Reply With Quote
The Following 17 Users Say Thank You to Andy@Killshot For This Useful Post:
Alpha (01-28-2011), DaleNixon (01-28-2011), Fobio (02-03-2011), FreeFlyFreak (01-28-2011), Hoangy (03-25-2011), kilik2 (02-24-2011), kmac (03-23-2011), madvillain (02-08-2011), mike8748 (01-28-2011), MPSdriver (02-03-2011), mr_mazda329 (01-31-2011), MS3-a(sore)ASS-rex (01-28-2011), PunjabiPlaya (01-28-2011), rodrigo (01-28-2011), Scoobs (05-14-2012), speed23 (04-27-2011), triplejumper18 (03-28-2011)
 Old 01-27-2011, 06:46 PM   #2
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
Nice... become a vendor.
Past Mazdas & Speeds
 Old 01-28-2011, 06:04 AM   #3
How do I do that?????
 Old 01-28-2011, 07:34 AM   #4
mike8748's Avatar
Posts: 396   (View Stats)
mike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the world
Nice work...
07'MazdaSpeed3 Stage2+SF 93 FMIC Custom Map
Current Mods: COBB AP, COBB SRI, COBB Inlet, COBB Cold Air Box, COBB Shift Weight, COBB STS, COBB PCV Catch Can, COBB Rear Sway Bar, M3M FMIC, TWM Shifter Bushings, FORGE BPV, Nator Rear MM, TurboXS DP, TurboXS RP, TB BYPASS MOD, MSD Dash Hawk, Denso 2-Step Colder plugs, Eibach Springs, BSD, KMD ver2 internals, EGR delete, PTP intake cooler kit, CNT Racing CBE, PG Exhaust Manifold
mike8748 is offline   Reply With Quote
The Following User Says Thank You to mike8748 For This Useful Post:
Andy@Killshot (01-28-2011)
 Old 01-28-2011, 10:28 AM   #5
SSinstaller's Avatar
Posts: 3,953   (View Stats)
Groans: 58
PM Haltech
Soon to be installed:
 Old 01-28-2011, 10:34 AM   #6
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
Is that an NC?
The Following User Says Thank You to DaleNixon For This Useful Post:
 Old 01-28-2011, 11:01 AM   #7
Yes
 Old 01-28-2011, 12:22 PM   #8
DaleNixon's Avatar
Groans: 91
Looks like a bad ass build. I'm starting to like the NC more and more.
The Following User Says NO Thank You to DaleNixon For This Un-useful Post:
 Old 01-28-2011, 12:23 PM   #9
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
pm haltech, understand that this forum is unique, and kudos to you for showing engine bay shots that actually dont look so queer like
The Following 3 Users Say Thank You to rodrigo For This Useful Post:
Andy@Killshot (01-28-2011), DaleNixon (01-29-2011), FreeFlyFreak (01-28-2011)
 Old 01-28-2011, 02:34 PM   #10
Got it, I will PM him as soon as I get back to my office and off this G D iPhone, these things suck to do anything but look on.
 Old 01-28-2011, 02:54 PM   #11
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
That collector, you didnt happen to get it from ProFabrication did you?
 Old 01-28-2011, 02:58 PM   #12
No sir.
I bought the form and bullets separate from my stainless distributor then assembled it as I built the header.
Last edited by Andy@Killshot; 01-28-2011 at 02:58 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-28-2011, 03:00 PM   #13
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i gotta say, if there was even the slightest chance one of my buttcheeks could even fit inside this miata i might drive it with an engine bay like that
The Following 4 Users Say Thank You to rodrigo For This Useful Post:
Andy@Killshot (01-28-2011), DaleNixon (01-29-2011), Fobio (02-03-2011), FreeFlyFreak (01-29-2011)
 Old 01-28-2011, 03:04 PM   #14
Thanks guys for the kind words, y'all are awesome!
 Old 01-28-2011, 03:29 PM   #15
Neverlift's Avatar
Groans: 1,143
 Old 01-29-2011, 12:29 AM   #16
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,155   (View Stats)
Groans: 754
Which EFR are you using?
Suspension:
 Old 01-29-2011, 06:39 PM   #17
The Following User Says Thank You to Andy@Killshot For This Useful Post:
FreeFlyFreak (03-23-2011)
 Old 02-02-2011, 10:18 PM   #18
The Runner
M4Nathan's Avatar
Posts: 229   (View Stats)
M4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant futureM4Nathan has a brilliant future
Groaned at 11 Times in 6 Posts
Good, well think the same until you screw up. Then youll get eaten alive. Just a forewarning haha, but welcome!
'09 Black Mica [MURDERED] MS3- HyperTech Tuned, CPE rear and side motor mounts, COBB TIP, JBarone Short Shifter Plate and Heavy Shift knob, SU Shifter Bushings, CPE Nano SRI, AWR End Links.
WANTED- Radar Detector, Down Pipe, DashHawk, Forge BPV.
M4Nathan is offline   Reply With Quote
 Old 02-03-2011, 12:16 PM   #19
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
6758
during my research, this seemed to be the ideal upgrade/GT30 replacement...is it considered a big(ger) turbo for the MX5? And would you say the 70xx would be more suited to the MS3? From your experience, how do the EFR's compare to the GT turbo's?
Thanks for pics.
-- Mario Andretti --
 Old 02-03-2011, 03:26 PM   #20
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
Damn i want an efr for my car so bad. Maybe I'll be the first ms3 with one... We'll have to see what the tax fairy brings me. Cuz i got lots to do before mine is bt worthy. Awesome build btw
TRADED : 07 MS3 GT Silver... fully bolted w/K04
CURRENT : 06 MS6 GT Silver....
KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6
The Following User Says Thank You to Fatguy729 For This Useful Post:
Andy@Killshot (02-03-2011)
 Old 02-03-2011, 05:25 PM   #21
Thanks for pics.
I believe the 7064 EFR would work great on a MS3. As far as the GT vs. EFR in my opinion, there is no comparison. Keep posted I should have more pics soon and some dyno numbers in a week or two.
Fobio (02-03-2011)
 Old 02-06-2011, 10:07 AM   #22
I really need a better camera, anyway here are some more pics.
The Following 2 Users Say Thank You to Andy@Killshot For This Useful Post:
Cataphract_40 (02-06-2011), DaleNixon (02-07-2011)
 Old 02-06-2011, 02:15 PM   #23
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
Ugh so much fucking win.
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 02-06-2011, 06:19 PM   #24
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
u actually might be the first non faggot driving a miata on this forum.
come to think of it.... u are still a fag. but at least u will be flying to your boyfriends house nightly.
congrats!!!
The Following User Says Thank You to rodrigo For This Useful Post:
 Old 02-07-2011, 12:02 PM   #25
Neverlift's Avatar
Groans: 1,143
Lenny... this gentleman is doing this work for a Miata owner out of a shop.
I know reading is a task only a few people should be good at... but please try to apply yourself in this section of the forum.
The Following 2 Users Say Thank You to Neverlift For This Useful Post:
CosmicArkie (03-27-2011), M4Nathan (02-10-2011)
 Old 02-07-2011, 12:08 PM   #26
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
tony..... shouldnt u be at GMR instead of posting on here?
andy and I are old friends, ive known him for almost a decade.
 Old 02-07-2011, 12:45 PM   #27
Neverlift's Avatar
Groans: 1,143
Rodrigo, I should be, but alas... @ work. I pass the time by trolling this moderation staff like it were a treacherous canyon.
PS... fsb isnt big enough.
 Old 03-23-2011, 04:51 PM   #28
Sorry for not updating lately, the customer went ahead and approved the engine build.
Miata block, Speed 6 crank (heavy mods made in house), proprietary rods and Speed6 pistons.
Here is a pics of the rods, I will get some pics of the crank up when I am done with it.
The Following 4 Users Say Thank You to Andy@Killshot For This Useful Post:
bigx5murf (12-28-2011), DaleNixon (03-24-2011), FreeFlyFreak (03-23-2011), Hoangy (03-25-2011)
 Old 03-24-2011, 07:07 AM   #29
DaleNixon's Avatar
Groans: 91
Damn that's a serious build!
 Old 03-24-2011, 03:24 PM   #30
Looking to make 500 at the crank, at least that is what I am shooting for. I will for sure post up the dyno and shit when I am done.
 Old 03-25-2011, 07:19 AM   #31
Hoangy's Avatar
Posts: 344   (View Stats)
Hoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the worldHoangy is the leader of the world
this build reminds me of builds from d-series.org, using various parts from other Mazda's to make it work. Quite awesome if you ask me!
Hoangy is offline   Reply With Quote
 Old 03-25-2011, 12:22 PM   #32
Neverlift's Avatar
Groans: 1,143
Dseries/Onecamonly members know their shit and build amazing cars.
 Old 03-27-2011, 10:50 AM   #33
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
is this a street car or a race car?
how are aluminum rods these days for daily drivers?.... in my days we never had success running them on the street because they would always stretch over time and leave u with the piston knocking a valve eventually
for drag racing they are the shit but running time between cool downs is minimal obviously.
keep posting shit man, looks good. interesting build
 Old 03-28-2011, 09:00 AM   #34
Smile
They have come a long way, now dont get me wrong they are no 100,000 mile rod or anything but I have them in a few 4G63's that are daily driven, and they are doing great. I also have them in several subbies, Mustangs, Camaro's, Vette's and various other engines. To answer the other part of your question, yes this miata will be driven on the street as well as the track. Quick tech note, I have them made slightly shorter to compensate for growth in warm up. The trick to making an aluminum rod live is to let the engine warm to operating temp. before ever touching the throttle.
 Old 03-28-2011, 09:03 AM   #35
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
haha , makes sense. variable compression ftw !!! good work man
 Old 03-28-2011, 09:06 AM   #36
Yes, you could say that. We are only talking about .010-.015" though, and Thank You.
 Old 04-27-2011, 04:01 AM   #37
GAMISTAD's Avatar
Posts: 25   (View Stats)
GAMISTAD is on a distinguished road
I like to get one of these!
We need a vendor to step up and lay a set of cards on the table.
Down time sucks, I am aiming but, I am not trigger happy.
MS6
GAMISTAD is offline   Reply With Quote
 Old 05-11-2011, 02:24 PM   #38
hope to have some final results here in the next week. Break in tune is done, just have to get the time to get it tuned.
DaleNixon (05-11-2011)
 Old 05-11-2011, 02:33 PM   #39
MS6
I would like to become a vendor on here, and what kind of card we talkin bout here?
 Old 12-15-2011, 09:34 AM   #40
Sorry it has been a minute, 18psi car blew through the clutch and kinda hovered around 330whp. currently having a clutch setup made so we can turn up the boost, the car as built to run 25 to 27 psi. I will tell yall something though, that son of a bitch will fly at 18psi. I rode around Road Atlanta with the owner WOW! that is all I have to say about that!
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f15/mx-5-efr-turbo-build-70812/
Stroked-n-turboed NC - Miata Turbo Forum - Turbo Kitten is watching you test compression. This thread Refback 06-03-2015 01:28 PM
Stroked-n-turboed NC - Miata Turbo Forum - Home to the Turbo Miata This thread Refback 08-25-2011 06:01 PM
GTK-450 turbo build matgod MazdaSpeed 3/6 - Big Turbo Builds 18 09-09-2013 07:00 PM
essejkcamraw's big turbo build essejkcamraw MazdaSpeed 3/6 - Big Turbo Builds 163 10-07-2011 09:13 AM
My big turbo build Speedie6 MazdaSpeed 3/6 - Big Turbo Builds 4 12-09-2010 12:54 AM
Big turbo kit, build one or not? ptperformance Mazdaspeed3/6 General Discussion 33 10-12-2008 01:55 PM
Page generated in 0.55839 seconds with 34 queries
