Miata MX-5
> Miata - Suspension & Brakes
 Old 07-13-2010, 02:43 AM   #1
mr_mazda329's Avatar
Posts: 795   (View Stats)
mr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the worldmr_mazda329 is the leader of the world
Groans: 55
Default Ohlins coilovers review
Year 97
My old suspension (AGX/ Eibach) was good, but just wasn't good enough. A little too bumpy on the streets and not stiff enough (yeah I know). Let me say that just it a shame that you can't leave them off the car because the quality of their product is fantastical.
Installing was way easier than any shock and spring setup (no spring compressor needed) and was very straight forward. Took about 3 hours including adjusting ride height, which is set to 12.5 fr 13r for now until it settles but I expect it not to do much of that because how much stiffer the rates are 8kg fr 6kg r or 450lbs fr 336lbs r . Dampers are set to about 6 fr 3 r , for street use and 24 f, 12 r for autoX/track use. These coilovers have a range of 32 for adjustment. Will anyone use them all.. prolly not.
Intial Driving Impression: Holy SXXX. The Ride is much stiffer yet way more comfortable than older setup (boo..bumpstop).Railroad track are much more pleasant, small bumps are invisible, but pothole still let you know they are there. Steering response is strong and crisp. Squat and dive are practically zero and can feel what the brakes are doing better. Took an insterstate loop at higher than normal speed and theres no more rear tail wagging. Body-roll is about gone but slight. Cornering is great and gives the driver more confidence. I would definately recommend this setup or even the PCV's for anyone who does lots of autoXing/ track, but still wants a good ride for the streets.
My current alignment specs are as follow: (variation of Lanny's)
Front: -1.2* camber 1/16'' total toe-in (1/32'' per side) 5.0* Caster
Rear: -1.8* camber 1/16'' total toe-in (1/32'' per side)
this gave my car more mechanical grip than I did with Icehawks specs that had toe-out and more camber.
I give Ohlins 2 thumbs up
Here are some pictures For your enjoyment and if you have any questions, just ask.
Ohlins in a box:
Fronts installed:
End-link clearance at droop(bulky RB's):
Front Adjuster on pillowball mounts:
Fronts at full droop total est 2in:
Rears installed:
09 MS3 CWP BNR-S3 GFB Respons BPV, HTP 3.5in whalepenis , CXRacing/TR8L Core FMIC CorkSport CBE CNT Catless long DP, NGK Plugs, DM Trilogy, Cobb AP VEGA Tuned, CP-e HPFP CP-e Injector Seals
97 Miata Daily Driver
04' Mazdaspeed Miata Track Car
Road Racing > Autocross > Spirited Driving > Sitting in Traffic > Mowing Lawns > Drag Racing
mr_mazda329 is offline   Reply With Quote
The Following 10 Users Say Thank You to mr_mazda329 For This Useful Post:
Ambulare (12-26-2014), bigx5murf (01-10-2013), CorkSport (07-13-2010), DaleNixon (07-13-2010), fastdreams (07-13-2010), JS + MS3 (03-27-2011), redneck4Christ (08-15-2016), rodrigo (07-13-2010), Tomas (08-27-2013), xcoldricex (07-13-2010)
 Old 07-13-2010, 04:22 PM   #2
CorkSport's Avatar
Posts: 3,416   (View Stats)
CorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the world
Ohlins are so badass.
WWW.CORKSPORT.COM
CorkSport is offline   Reply With Quote
 Old 07-29-2010, 10:24 AM   #3
BLURSPORTS's Avatar
Posts: 51   (View Stats)
BLURSPORTS is a glorious beacon of lightBLURSPORTS is a glorious beacon of lightBLURSPORTS is a glorious beacon of lightBLURSPORTS is a glorious beacon of lightBLURSPORTS is a glorious beacon of light
OHLINS FTW.
My next mod for my ZX10!
BLURSPORTS is offline   Reply With Quote
The Following User Says Thank You to BLURSPORTS For This Useful Post:
mr_mazda329 (07-29-2010)
 Old 08-03-2010, 06:40 PM   #4
martyxattack's Avatar
Posts: 924   (View Stats)
martyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the world
Groaned at 37 Times in 27 Posts
mr has big pockets!
know your roll
martyxattack is offline   Reply With Quote
The Following User Says Thank You to martyxattack For This Useful Post:
PreyStayShun (01-13-2013)
 Old 01-10-2013, 07:11 PM   #5
bigx5murf's Avatar
Posts: 235   (View Stats)
bigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond repute
Groaned at 20 Times in 10 Posts
hey, just realized I've jinxed this car's radiator before
bigx5murf is offline   Reply With Quote
 Old 01-16-2013, 02:15 PM   #6
AustinK's Avatar
Posts: 175   (View Stats)
AustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the world
I absolutely love the feel of My Ohlins, SOLID choice on a suspension upgrade!
AustinK is offline   Reply With Quote
The Following User Says Thank You to AustinK For This Useful Post:
mr_mazda329 (06-06-2013)
 Old 08-27-2013, 03:57 PM   #7
Andrade67's Avatar
Posts: 4   (View Stats)
Andrade67 will become famous soon enoughAndrade67 will become famous soon enough
one day......
Andrade67 is offline   Reply With Quote
The Following User Says Thank You to Andrade67 For This Useful Post:
mr_mazda329 (08-30-2013)
 Old 08-27-2013, 04:05 PM   #8
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,774   (View Stats)
Fuuuuuck you got them new!
How much? Shit was prolly worth more than the car.
MAKE LOVE TO THE CANVAS
 Old 08-30-2013, 12:42 AM   #9
Groans: 55
Well, I bought them back in 08' new for $2500 before Ohlins USA jacked their prices up. No.. not worth more than the car. car was worth 6k back then with its super low mileage. Today.. prolly about 4k. I can make up almost 4k if I part out.
The Following User Says Thank You to mr_mazda329 For This Useful Post:
Tomas (08-30-2013)
 Old 08-30-2013, 05:13 PM   #10
Bob Ross Fanclub
Tomas's Avatar
$2500 for those Ohlins is a solid price if they are at least 3 way adjustable
BC Racing Coilovers 2010 MS3 Review Daddy 2010 MS3 - Suspension & Brakes 26 06-16-2012 08:12 AM
HR coilovers shaneS MazdaSpeed 3/6 - Suspension & Brakes 6 05-27-2009 12:45 PM
Page generated in 0.57502 seconds with 27 queries
