> MazdaSpeed 3/6 - Appearance
Notices
MazdaSpeed 3/6 - Appearance MazdaSpeed 3/6 - Appearance - Show off pics of your ride, including after market body enhancements!
Like Tree5Likes
  • 1 Post By Macedawg
  • 1 Post By greenespeed
  • 1 Post By :: Gusto ::
  • 1 Post By 6ixof1
  • 1 Post By jmhinkle
 Old 07-08-2012, 07:43 AM   #1
ESB Jiu JItsu's Avatar
Posts: 494   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
Groaned at 4 Times in 2 Posts
Default MS6 Low Beam Hella Projector Fog Lights
So I found two Low beam hella projector light housings in my spare parts bin and i decided since i had the bumper off for my FMIC install i would check to see if they would fit.....and guess what i found out They will! and look amazing! Just a few pics to start with, Im mid process of modifying the stock mount to fit these housings but not much dremiling should need to be done!!! Very excited. Will post more soon. Here are a few teaser pics!
I have the hella projectors evevated, so they look bigger but really they are only slightly bigger at 90mm in dia
By just removing the stock fog the new assembly basically just lines right up minus a few spots to be trimmed
What it looks like from the good side
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline   Reply With Quote
The Following 15 Users Say Thank You to ESB Jiu JItsu For This Useful Post:
06Speed6 (07-08-2012), Alpha (07-31-2012), daztdMS6 (07-11-2012), Downmented (10-15-2012), greenespeed (07-31-2012), I<3Groceries (07-08-2012), Jh8909 (07-08-2012), jrlms6 (07-08-2012), lilred (07-08-2012), LMB77 (07-22-2012), Monotonous ONE (10-14-2012), Pointless (10-14-2012), Stormtrooper6 (07-08-2012), Tenchix (07-08-2012), triplejumper18 (07-08-2012)
 Old 07-08-2012, 09:53 AM   #2
lowspeed
TiGraySpeed6's Avatar
Posts: 2,663   (View Stats)
Nifty find!
I'm not a lighting person, so from the position of total ignorance I'm wondering about
-power supply being sufficient to drive them & do so without melting wires, blowing fuses and the like
-about heat & if they put out more heat or too much heat
-about the cut-off, which might actually be a good thing
Looking forward to seeing how this works out!
Mazdaspeed6 GT #3476 TiGray slicktop
Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete
M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, TB Coolant Bypass, SU Billet RMM
TWM Stage II STS & JBR SSB, Prosport Mech Boost
RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff
Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued
405/394 AWD - cf1.01 e38 BNRs3
315/372 AWD - cf1.01 e38 k04
TiGraySpeed6 is online now   Reply With Quote
ESB Jiu JItsu (07-09-2012)
 Old 07-08-2012, 10:30 AM   #3
Speed_j23's Avatar
Posts: 571   (View Stats)
Speed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the worldSpeed_j23 is the leader of the world
Please make DIY! I've been wanting to do something like this for some time now, can't wait to see how it turns out.
06 LPM MS6: The Essentials
Speed_j23 is offline   Reply With Quote
The Following 2 Users Say Thank You to Speed_j23 For This Useful Post:
Alpha (07-31-2012), ESB Jiu JItsu (07-09-2012)
 Old 07-08-2012, 04:32 PM   #4
Stormtrooper6's Avatar
Posts: 18   (View Stats)
Stormtrooper6 will become famous soon enoughStormtrooper6 will become famous soon enough
Subbed for intense fog light brightness action!!!
Sent from the Death Star as it rebuilds....
Stormtrooper6 is online now   Reply With Quote
The Following User Says Thank You to Stormtrooper6 For This Useful Post:
 Old 07-08-2012, 06:11 PM   #5
Kdawg207's Avatar
Posts: 1,831   (View Stats)
Sweet
~~~NatorNJfoLyf~~~
2012 Crystal White Pearl w Tech Pkg ~ On Dat Hypnotic Finkle Lyfe
Kdawg207 is offline   Reply With Quote
The Following User Says Thank You to Kdawg207 For This Useful Post:
 Old 07-08-2012, 06:39 PM   #6
jrlms6's Avatar
Posts: 1,173   (View Stats)
jrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the world
Nice! I'd like to see a picture of the actual lighting at night when all said and done.
My neighbor has a bugeye, and decided to mount his Hella's from his Jeep (one OEM fog light was broken anyway). Looks pretty cool, and unique.
2006 Mazdaspeed6 GT - SOLD
Titanium Gray Metallic
SURE Aeros | SURE Sidewinder
Forge V1 | CPE TMIC
Magnaflow CBE | Corksport DP | TXS RP
COBB AP | Autotech Internals
JBR SSP | JBR Shift Weight | JBR Knob
Denso ITV22
2010 MB C300 Sport 4Matic
jrlms6 is offline   Reply With Quote
The Following User Says Thank You to jrlms6 For This Useful Post:
 Old 07-08-2012, 06:49 PM   #7
DiGi Faggot's Avatar
Posts: 1,082   (View Stats)
DiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the world
Groaned at 86 Times in 49 Posts
Subbed, I wanna see where this goes! Hurry up! Before you put in the passenger maybe you should test and take pics to show light improvement?
GET US SOME PART NUMBURRRRRRS!! Please.
DiGi Faggot is offline   Reply With Quote
The Following User Says Thank You to DiGi Faggot For This Useful Post:
 Old 07-08-2012, 07:13 PM   #8
Macedawg's Avatar
Posts: 1,156   (View Stats)
Macedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the worldMacedawg is the leader of the world
hmm I have some old Hella's I know have a better pattern than my stock fogs..u may have inspired me
ESB Jiu JItsu likes this.
Ferg: ive been inside so many deep dark loose holes even ron jeremy would be impressed.
Macedawg is offline   Reply With Quote
The Following User Says Thank You to Macedawg For This Useful Post:
 Old 07-08-2012, 07:22 PM   #9
Tenchix's Avatar
Posts: 369   (View Stats)
Tenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the world
good job! I've wanted to do this to my ride. i just need to know the part name and number please.
Tenchix is offline   Reply With Quote
The Following User Says Thank You to Tenchix For This Useful Post:
 Old 07-08-2012, 08:55 PM   #10
Sixxer's Avatar
Posts: 20   (View Stats)
Sixxer is a splendid one to beholdSixxer is a splendid one to beholdSixxer is a splendid one to beholdSixxer is a splendid one to beholdSixxer is a splendid one to beholdSixxer is a splendid one to beholdSixxer is a splendid one to beholdSixxer is a splendid one to behold
awesome the lighting is decent. they aren't expensive projectors. I had them in my old headlight conversion on my old car.
I'll have to pick up another pair i think
Sixxer is offline   Reply With Quote
The Following User Says Thank You to Sixxer For This Useful Post:
 Old 07-08-2012, 09:08 PM   #11
Would the hella housing be able to use the stock light bulb plug piece? Meaning could we just pop out the old housing, and insert bulb using the same twist lock mechanism?
 Old 07-09-2012, 06:07 AM   #12
Guys this was so simple its mind blowing.... the only thing i need to do now is aim them a bit better. All in all though I had to drill one hole and take out the stock fog light and that was it. I can post up specs of the hella lights when i get home tonight, but until then here are a few pictures!
Also fyi I know nothing about lighting, I just read that people were modifying their stock fog light plugs to match the bulbs that just happen to be in the low beam hella projectors i had, so i figured why not just see if the entire thing works instead.....and sure enough it did!!! Also did not come in contact with my new FMIC piping i cut and installed all of yesterday!!! So i picked up two mods
Thank you for all the kind words guys. Once i complete the setup by actually working out a way to level them or aim them then Ill post all the diy info, but it was incredibly simple, it just worked so perfectly with minimal thought
Aiming needed obviously but not bad for one really quick mod, and free at that
Part info:
Hella 90mm Projectors (low beam) H9 Bulbs
DIY to make your H9 bulbs work in place of the H11, but the cool thing is the H11 bulbs fit in the hella housings so really you could still go with the stock bulbs if you wish
H11 to H9 fog light conversion - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
Last edited by ESB Jiu JItsu; 07-09-2012 at 06:07 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-10-2012, 06:59 PM   #13
Any chance of a write up with pics on what you had drill/dremel to get the housing to mount?
 Old 07-11-2012, 11:17 AM   #14
Once Im finished with the project ill post up some pictures and a description of what to do Im currently also venting the fog lights to allow air through to cool the IC pipes and will be trying to figure out a way of adding an aiming screw to my setup.
The Following User Says Thank You to ESB Jiu JItsu For This Useful Post:
Alpha (07-31-2012)
 Old 07-17-2012, 07:42 AM   #15
a few new pics of the cut out i added to the fog light bezel to allow for FMIC pipe cooling. still not completed but just some new pictures to show progress. I love these lights~!
 Old 07-31-2012, 08:55 AM   #16
some pics of the backside
 Old 07-31-2012, 09:28 AM   #17
I've got a question, I can't tell from the pics, but on the front of the foglights, is there any glass or plastic that seals the light housing and protects it from road debris, or is it completely open?
 Old 07-31-2012, 09:34 AM   #18
greenespeed's Avatar
Posts: 1,310   (View Stats)
greenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the world
Groaned at 6 Times in 3 Posts
Once again great work man. Adding things I must do to my list again.
2006 Mazdaspeed6 BCM GT
MODS : Cobb AP // Cobb SF // Sure TIP // JBR RMM // JBR SSB // JBR SSP // Magnaflow CBE // MSR 045 18 X 8 +35 // ACT ZX5-HDG6 // M2 3" catless DP // AT HPFP Internals // NGK's -- FREEKTUNE in progress
Having a 12 second Honda is just like coming out of the closet; You're going to surprise a bunch of people, but in the end you're still gay.
greenespeed is online now   Reply With Quote
The Following User Says Thank You to greenespeed For This Useful Post:
ESB Jiu JItsu (07-31-2012)
 Old 07-31-2012, 11:12 AM   #19
the hella lights are in a footlight housing with back mounting plate and a front glass dome. Very nice construction! I just want to change out the bulds to match my low beams up top the ones on the btm are not quite as white and bright
 Old 09-15-2012, 07:58 PM   #20
:: Gusto ::'s Avatar
Posts: 1,093   (View Stats)
damn man..
do you have a part number for the HELLA light housing.. or kit.. or whatever??
Car looks dope...
how's the hood cooling vent holding up?
I remember you did that write up a while ago...
:: Gusto ::
::: Mazdaspeed6 :::
yea yea - i know i cant spell
http://www.mazdaspeedforums.org/forum/signaturepics/sigpic2297_1.gif
ESB Jiu JItsu (09-17-2012)
 Old 09-17-2012, 05:29 AM   #21
Im sorry man all i have is the part number listed but its super easy to do they line up better then one would think but adjustability is meeehhhh.... but im sure someone could do it better.
Hood is holding up nicely. Barely sees any rain in there and even if it does it falls in okay places. The amount of cooling i see is remarkable. Plus i think it adds to the lines of the car nicely!
than kyou for the comments!!!
 Old 10-14-2012, 01:44 AM   #22
TrePaul86's Avatar
Posts: 138   (View Stats)
TrePaul86 has disabled reputation
Groaned at 11 Times in 6 Posts
Thanks for this man, really interested in how much better over stock these things put out, lighting wise! Definitely on my list
06 MS6 - Sport LP Silver
Exterior: Thule roof racks, CS LED Foglight kit, CS LED DRL, CS LP LED tag lights, 20% tint, JBR SSP.
Interior: CS door LEDs, CS map LED's, STRI boost gauge, A-Pillar sound bar, 4ch amp powering Focal components, Fosgate 2ch sub amp, JBR knob.
Engine: Cobb AP (Modified Stage 2 OTS for now) CS intake, CS MAF, CS TIP, CS 3" catless downpipe to CS TBE, ETS TMIC, Autotech HPFP, Denso plugs.
Suspension - CS Front Strut Bar, AutoEXE Rear Strut Bar, Lowered on Eibach's, RMM, TMM, CS Front Sway Bar
TrePaul86 is offline   Reply With Quote
 Old 10-14-2012, 07:01 AM   #23
<span style="text-shadow:2px 2px 4px purple; "><span style="color:#6B6B6B; "><span style="text-shadow: 0px 0px 0.2em red, 0px 0px 0.2em red, 0px 0px 0.2em red; ">Axle Breaker</span></span></span>
jmhinkle's Avatar
Posts: 3,942   (View Stats)
jmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the world
Groans: 152
I'm assuming you used the Hella low beam projector. That part number is HL68137. Here's good info on them and a decent price too.
jmhinkle is offline   Reply With Quote
The Following 3 Users Say Thank You to jmhinkle For This Useful Post:
Speed_j23 (10-14-2012), TiGraySpeed6 (10-14-2012), triplejumper18 (10-14-2012)
 Old 10-14-2012, 10:39 AM   #24
Speed_j23's Avatar
Is that price for a pair or just single projectors?
 Old 10-14-2012, 11:59 AM   #25
TrePaul86's Avatar
Pretty sure that's an "each" price. Still a great deal!
 Old 10-14-2012, 03:41 PM   #26
jmhinkle's Avatar
Groans: 152
Price is each, but seems to be on the low end of the spectrum.
ESB Jiu JItsu is the depth on these longer or shorter than the stock projector housings?
Last edited by jmhinkle; 10-14-2012 at 03:41 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to jmhinkle For This Useful Post:
TrePaul86 (10-14-2012)
 Old 10-15-2012, 05:32 AM   #27
longer.... its the only dimension that gave me a bit of an issue due to my fmic but still works like a charm. Just trim to fit. Once you place it against the open fog light bezel everything will come together. Its as simple as some dremel work and 2 screws from your parts bin Well worth the small amount of work! Sorry i didnt get to do a step by step but its really just cut and test fit sort of scenario.
 Old 10-15-2012, 06:15 AM   #28
1/2 dozen of the other...
6ixof1's Avatar
Posts: 379   (View Stats)
6ixof1 is the leader of the world6ixof1 is the leader of the world6ixof1 is the leader of the world6ixof1 is the leader of the world6ixof1 is the leader of the world6ixof1 is the leader of the world6ixof1 is the leader of the world6ixof1 is the leader of the world6ixof1 is the leader of the world6ixof1 is the leader of the world6ixof1 is the leader of the world
Groaned at 6 Times in 4 Posts
Nice job man!
Black Mica Mazdaspeed 6
NJSpeed P&P IM, KMD internals, SU TMIC, BNR STG 1
The Mad Scientist Tunings
6ixof1 is offline   Reply With Quote
The Following User Says Thank You to 6ixof1 For This Useful Post:
ESB Jiu JItsu (10-16-2012)
 Old 10-15-2012, 06:51 AM   #29
jmhinkle's Avatar
Groans: 152
I'm changing to a bigger FMIC so I was hoping these were a little shorter to buy some room with over the stockers. Guess I'll have to do FMIC first and see if there is room for these after. They do look good.
HID High Beam jkspeed06 MazdaSpeed 3/6 - Car Audio & Electronics 8 07-02-2012 07:42 PM
High Beam Lights Deldran MazdaSpeed 3/6 - Car Audio & Electronics 5 03-17-2012 12:56 PM
HIDs, Reverse lights, Liscence Plate lights Franconemo Exterior 31 06-12-2010 02:25 AM
Mitsubishi PK20 SVGA Pocket Projector DLP Projector $399.99 Free Shipping Haltech Hot Deals Section 0 03-26-2008 11:10 AM
Page generated in 0.98227 seconds with 34 queries
