> MazdaSpeed 3/6 - Appearance
MazdaSpeed 3/6 - Appearance MazdaSpeed 3/6 - Appearance - Show off pics of your ride, including after market body enhancements!
Like Tree25Likes
 Old 03-09-2016, 02:16 PM   #121
thrisnospork's Avatar
Posts: 245   (View Stats)
thrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond reputethrisnospork has a reputation beyond repute
Originally Posted by Jega View Post
It would look better if you got a stack of wider washers and stacked them on the plastic ring under the boot, plus one on top of the boot. Use enough washers so that the adapter base clamps it all down when tightened. You can see an example of the washer size I'm talking about under my knob here:
Thanks for the tip! I was considering stacking washers on the outside of the boot, didn't even cross my mind to stack them under instead. Unfortunately Ace didn't have any wide washers, should have just went to the Fastenall right next to it but I only wanted one washer at the time. I'll probably end up doing that down the road though, did the washers make a big difference in weight for you?
thrisnospork is online now   Reply With Quote
 Old 03-10-2016, 01:50 PM   #122
Jega's Avatar
Posts: 112   (View Stats)
Jega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud ofJega has much to be proud of
Groaned at 39 Times in 10 Posts
No noticeable difference. The weight of the washers is insignificant compared to he weight of the shift knob. Just makes it look way better.
2007 Mazdaspeed3
Jega is offline   Reply With Quote
The Following User Says Thank You to Jega For This Useful Post:
thrisnospork (03-10-2016)
 Old 03-25-2016, 06:39 AM   #123
hollar1211's Avatar
Posts: 495   (View Stats)
hollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond repute
so, i was checking out some Mustang GT350 images the other day and noticed the shift knob. it has the same shift pattern, and upon further investigating, the same thread pitch as mazda, 10 x 1.25. i might have to pull the trigger on one. i see prices vary from around $70-$100 depending on site.
if anyone does feel like grabbing one make sure it is FOR THE GT350. the S550's (4 cyl, 6 cyl, GT's...) have a 12 x 1.25 thread pitch and won't fit without some modification.
SO MAKE SURE YOU GET THE ONE SPECIFICALLY FOR THE GT350. sorry for yelling.
2008.5 Speed3 GT
Freek Tuned e33: Cobb AP, Autotech Internals, UR Test Pipe, CPE TMIC, JBR Power Path Stage 2 SRI-TIP/ Short Shifter/ Solid Shifter Bushings/ Heavy Shift Knob/ 88 Duro RMM/ EGR Delete & Block Off Plate/ Throttle Body TIG, NGK IX 6510, 18x8 +35 Drag DR-49
hollar1211 is offline   Reply With Quote
 Old 03-29-2016, 12:16 PM   #124
DavidWolfe's Avatar
Posts: 15   (View Stats)
DavidWolfe is a jewel in the roughDavidWolfe is a jewel in the roughDavidWolfe is a jewel in the rough
That's not a bad idea, it's the right shape and size too. Very similar to the OEM knob. I wonder how the weight is...
Ryan1926 likes this.
DavidWolfe is offline   Reply With Quote
 Old 04-01-2016, 09:26 PM   #125
Dezine's Avatar
Posts: 49   (View Stats)
Dezine is a glorious beacon of lightDezine is a glorious beacon of lightDezine is a glorious beacon of lightDezine is a glorious beacon of lightDezine is a glorious beacon of lightDezine is a glorious beacon of light
That GT350 knob is a pretty good replacement.
2009 Black MS3 GT
Cobb SRI, Short Shifter, TSW Rotary Forged Wheels, Corksport shocks and struts, Corksport lowering springs, Corksport mud flaps, LED fog lights, yellow fog overlays
Dezine is offline   Reply With Quote
 Old 04-12-2016, 04:55 PM   #126
Ryan1926's Avatar
Posts: 22   (View Stats)
Ryan1926 is a splendid one to beholdRyan1926 is a splendid one to beholdRyan1926 is a splendid one to beholdRyan1926 is a splendid one to beholdRyan1926 is a splendid one to beholdRyan1926 is a splendid one to beholdRyan1926 is a splendid one to beholdRyan1926 is a splendid one to behold
Has anybody made the jump to purchase this knob for their Speed3? If so, how does it feel?
2008 Mazdaspeed3 (Cosmic Blue Mica)
Stratified Tuned (91 oct and E30), BNR S3, CPE Xcel Intake 3.25, HTP Inlet Pipe, CPE Downpipe, COBB AP, HKS Hi-Power Exhaust, Forge BPV, Treadstone TR8c FMIC, CPE Motor Mounts, CPE Safe Seals, JBR Thermal Gaskets, COBB 3 port ECBS, Autotech HPFP Internals, Guardian Angel, 18x8 Rays Gram Lights Optimize in Shining Silver, Koni Sports, Seift Springs, JBR Rear Sway Bar, SPC Rear Camber Arms, Whiteline Rear Endlinks
1995 Acura NSX
Fully Bolted and Comptech Supercharged Garage Queen
Ryan1926 is offline   Reply With Quote
 Old 04-14-2016, 04:07 PM   #127
DavidWolfe's Avatar
I just ordered one, should be here in a few days. We'll see...
The Following User Says Thank You to DavidWolfe For This Useful Post:
Ryan1926 (04-14-2016)
 Old 04-14-2016, 04:24 PM   #128
macdiesel's Avatar
Posts: 824   (View Stats)
macdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the worldmacdiesel is the leader of the world
The gt350 knob looks padded, which would be nice
Sent from my iPhone using my stinky little fingers
2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts//
Coming up: Corksport injector seals
macdiesel is offline   Reply With Quote
 Old 04-18-2016, 01:51 PM   #129
kpeezy188's Avatar
Posts: 110   (View Stats)
kpeezy188 is a glorious beacon of lightkpeezy188 is a glorious beacon of lightkpeezy188 is a glorious beacon of lightkpeezy188 is a glorious beacon of lightkpeezy188 is a glorious beacon of light
Rocking the 4 star dragon ball. I'm sorry the thumbnail pic is sideways. I can't figure out how to change that. I rotated the pic to its upside down position and still comes out like this.
SeeMeGovan, RazoE and Db09ms3 like this.
kpeezy188 is offline   Reply With Quote
 Old 04-18-2016, 02:55 PM   #130
DavidWolfe's Avatar
Here's the GT350 knob installed. In think it looks great! It goes with the red accents in the interior nicely. It is a bit lighter than the stock knob, so take that into consideration. It also requires you to put a bunch of washers under the shift boot to raise it up to meet the lower bottom on the new knob.
The Following 3 Users Say Thank You to DavidWolfe For This Useful Post:
iggypop (07-02-2016), redneck4Christ (08-18-2016), Ryan1926 (04-18-2016)
 Old 04-18-2016, 03:07 PM   #131
Gribbs1469's Avatar
Gribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to all
gt350 looks nice!
2007 MS6 FMIC, Garrett turbo, 3" Magna Flow TBE, 4" Intake, HP Fuel pump, COBB AP V3
Gribbs1469 is offline   Reply With Quote
 Old 04-18-2016, 03:34 PM   #132
Ryan1926's Avatar
Originally Posted by DavidWolfe View Post
Attachment 224268Attachment 224269
Looks good! Thanks for the pics!
1995 Acura NSX
 Old 04-20-2016, 07:59 AM   #133
hollar1211's Avatar
that looks great davidwolfe.
2008.5 Speed3 GT
 Old 06-24-2016, 12:05 PM   #134
chuy's Avatar
Posts: 1   (View Stats)
chuy is an unknown quantity at this point
Default @daafisch
where did you get your shift knob?
chuy is offline   Reply With Quote
 Old 06-24-2016, 12:06 PM   #135
DavidWolfe's Avatar
I got it off eBay. $65 shipped.
Sent from my Nexus 5X using Tapatalk
 Old 07-02-2016, 11:05 AM   #136
iggypop's Avatar
Posts: 31   (View Stats)
iggypop is just really niceiggypop is just really niceiggypop is just really niceiggypop is just really niceiggypop is just really nice
Thanks for the pics!!
Here is another GT350 knob installed.
Some Cobra venom injected into CorkSport short throw shifter. It didn't require any washers because STS.
2013 Mazdaspeed3
FREEKTUNE: finished(upgrade to a full tune at a discounted price with purchase of the Accessport.)
Cobb: AP v3, SF Intake (AEM Dry Flow filter), TIH
CS: internals, TP(stock flange), sts, rsb
RACING BEAT: Power Pulse 3" cbe
Damond: RMM
BBS: OEM Toyota Avalon 18x8 BBS CK wheels(bored professionally to 67.1) with 235/40/18 Michelin PSS rubber
Future mods: suspension(KW v3) or some decent coil+spring combo
2014 Mazda6 Sport 6MT (trade in)
1998 Honda Civic HX (sold)
1989 Mazda MX6 (sold )
_______________________________
iggypop is offline   Reply With Quote
 Old 07-02-2016, 12:21 PM   #137
mituc's Avatar
Posts: 3,191   (View Stats)
Groaned at 15 Times in 12 Posts
OEM FTW! Illuminated MX5 NC knob. Am I the only one?
mazdaspeedmyk and tomazws like this.
2008 Cosmic Blue Mazda 3MPS
Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PSS 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend ENduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit
JBR Tru-3" + CS CAI Box, SU TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071, CS 3.5BAR, Guardian Angel, CoolingMist WMI
StratiVersaTuned FTW
 Old 08-16-2016, 07:19 PM   #138
dogmower's Avatar
Posts: 17   (View Stats)
dogmower has a spectacular aura aboutdogmower has a spectacular aura about
I think you are, but not for long! I need more info on this - Where'd you get the knob, and how difficult was wiring it up?
2007 Mazdaspeed3 Sport | Cobb SRI | Cobb OTS 1/93 | JBR 88d RMM/ Efocus RMM | ebay test pipe | Kosei K1 TS 17x7.5
1997 Mazda Miata | race car, too many parts
dogmower is offline   Reply With Quote
 Old 08-16-2016, 11:17 PM   #139
mituc's Avatar
I've got mine from the dealer, it's an OEM part for the MX5 NC.
The installation was not horrible, I had to tap into the heated seats button to get power for the lighting..
First Romanian BT MS3
 Old 08-17-2016, 04:27 AM   #140
anavrinIV's Avatar
Posts: 4,481   (View Stats)
Groans: 63
US spec MS3s don't have a heated seat option.
That said there are power ports in the dash so it shouldn't be hard either way. I like it.
Blue Pu.
 Old 08-17-2016, 06:42 AM   #141
mituc's Avatar
Basically any 12V wire will do as long as it's interrupted. Ideally you should get a wire from a light or something that already has dimming because you may not want it at maximum brightness all time.
 Old 09-06-2016, 05:11 PM   #142
Garrettcx's Avatar
Posts: 4   (View Stats)
Garrettcx has a little shameless behaviour in the past
Mazda MX5 NC illuminated shift knob on a 3 MPS/Mazdaspeed3 2008 - YouTube
How did you find this through your dealer, and are you in the US?
Garrettcx is offline   Reply With Quote
 Old 09-06-2016, 09:08 PM   #143
mituc's Avatar
No, I'm not in the US, you can see my location by looking at my profile.
It's not important how I found it, it's important that I did
 Old 09-08-2016, 06:20 PM   #144
CamShaft's Avatar
Posts: 28   (View Stats)
CamShaft will become famous soon enoughCamShaft will become famous soon enough
The boot's seen better days, but zero fucks in that regard. "Go" before "Show" for this guy.
CamShaft is offline   Reply With Quote
 Old 11-13-2016, 06:27 PM   #145
Wcdfmt510's Avatar
Posts: 21   (View Stats)
Wcdfmt510 is on a distinguished road
Snapon pry bar handle
Sent from my XT1585 using Tapatalk
Wcdfmt510 is offline   Reply With Quote
 Old 11-17-2016, 09:27 PM   #146
Jega's Avatar
Shit I thought it was a butt plug and was almost ready to give you some props
2007 Mazdaspeed3
 Old 11-30-2016, 07:07 PM   #147
whitedevil's Avatar
Posts: 35   (View Stats)
whitedevil has a spectacular aura aboutwhitedevil has a spectacular aura aboutwhitedevil has a spectacular aura about
best one yet by far my friend...would've used a MAC handle instead that way Id know it wont break
Wcdfmt510 likes this.
'12 tech package
corksport TBE
turbosmart supersonic
xxr 530 gold 18x8.75 +20
235/40 BFG g-force a/s
whitedevil is offline   Reply With Quote
 Old 11-30-2016, 07:11 PM   #148
Wcdfmt510's Avatar
Lol. I'm not a fan of Mac tools. Even tho I have a couple things in my box. Always loved Snapon tools. Kinda grew up with them
 Old 12-01-2016, 03:23 PM   #149
whitedevil's Avatar
ya I was just fuckin with ya I got alittle of everything theyre all more or less equivalent...just bought a snapon lime green 1/2" impact today only cause he threw in a $100 visa card with it
but I know theyre damn good guns
'12 tech package
corksport TBE
 Old 12-01-2016, 03:24 PM   #150
Wcdfmt510's Avatar
I know bro... Damn that's Kool.
 Old 12-01-2016, 03:36 PM   #151
whitedevil's Avatar
i might have to take your idea tho that's sweet...did you just drill and glue it or did you tap it?
'12 tech package
corksport TBE
 Old 12-01-2016, 03:46 PM   #152
Wcdfmt510's Avatar
No. Luckily the hole in the handle was smaller than the shifter. and the Snapon handle is plastic I just used some pressure and pushed down so it made its own threads. Threaded it all the way down to the boot. And its tight. Not loose at all.. I'll check the part number on the handle when I go to my car. I wish it was black tho or red.
 Old 12-01-2016, 04:04 PM   #153
whitedevil's Avatar
damn well its meant to be if it was that easy and ya red would look pretty trick...i think they recently redesigned theyre hand tools not forsure tho
'12 tech package
corksport TBE
 Old 12-02-2016, 12:53 PM   #154
Anthony1982's Avatar
Posts: 139   (View Stats)
Anthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond reputeAnthony1982 has a reputation beyond repute
Groaned at 4 Times in 2 Posts
Perm knob with extension
2011 Silver MS3
JBR-EGR block off/delete, Stage 2 OCC, 3.5 SRI, Short Shifter, PMM/TMM, rear sway bar
Corksport-TP, Axle back, battery box, hood scoop
Auto tech internals, NGK plugs, ETS TMIC, Sure TB/IM TIG
CPE stage 2 RMM, Gaurdian Angel, perm tuning butt plug
AP V2 with RICH TUNE on 93.
Forge V1 BPV-SHIIING!
Anthony1982 is offline   Reply With Quote
 Old 03-27-2017, 04:57 PM   #155
Franky-5-Fingaz's Avatar
Posts: 25   (View Stats)
Franky-5-Fingaz is a jewel in the roughFranky-5-Fingaz is a jewel in the roughFranky-5-Fingaz is a jewel in the roughFranky-5-Fingaz is a jewel in the rough
Billetworkz weighted(500g) Piston in Gloss black.
thrisnospork likes this.
Franky-5-Fingaz is offline   Reply With Quote
The Following User Says Thank You to Franky-5-Fingaz For This Useful Post:
thrisnospork (03-27-2017)
 Old 05-22-2017, 01:34 AM   #156
jdspeed's Avatar
Posts: 57   (View Stats)
jdspeed is a glorious beacon of lightjdspeed is a glorious beacon of lightjdspeed is a glorious beacon of lightjdspeed is a glorious beacon of lightjdspeed is a glorious beacon of lightjdspeed is a glorious beacon of light
Playing around on the lathe the other day at work and made this form some old scrap shaft. Need to bore it out abother 1/4 inch to get it to sit flush against the boot. Heavier than stock and feels nice in the hand. Gets hot though.
jdspeed is offline   Reply With Quote
 Old 10-12-2017, 04:20 PM   #157
Db09ms3's Avatar
Db09ms3 will become famous soon enough
Six star Dragonball for me.
Db09ms3 is online now   Reply With Quote
« Rice of the Day | - »
Shift knob thread pitch? zoom1&zoom2 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 07-22-2016 10:38 PM
'11 MS3 shift knob thread size? Pelotonracer2 2010 MS3 - Torque Specs & information 1 11-24-2011 07:47 AM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Page generated in 0.47755 seconds with 42 queries
