-   -   Drag racing BS thread (http://www.mazdaspeedforums.org/forum/f232/drag-racing-bs-thread-163419/)
Realgib3 03-31-2014 08:49 AM
Originally Posted by MZRSPEED (Post 2519946)
I was just wanting to try a different setup. I haven't had a chance to try the 26" tires since I've had the spring bags installed, prob try that next.
I mean this setup is obviously working for you! I was just curious. I still haven't had a chance to try out my slicks yet, but I need every bit of height I can possibly get with this setup, so I can ride out 4th.
Boostman07 03-31-2014 09:18 AM
Originally Posted by mxlplx71 (Post 2514683)
m & h have a new 26/8.5/17
8.5/26.0-17 New Tire!
makes me want to sell the 15"rims and spacers to try the 17s out
Those look like a decent option for pretty much bolt up slick setup. May not be a whole lot of sidewall but I'm sure will do the trick.
Sent from my SCH-I545 using Tapatalk
dtrackstar 04-03-2014 01:45 PM
With an MS6 - stock clutch, Has anyone used the handbrake to pre-load the drivetrain before launching?
Adam is so pro 04-25-2014 09:58 AM
What are you guys doing about springrates for the rear?
p.s. who's launching in 2nd?
86AmishMs3 04-25-2014 10:04 AM
Footballs.
Diddo, i think i might try a 27" tire.
Realgib3 04-25-2014 10:42 AM
Originally Posted by 86AmishMs3 (Post 2558201)
Footballs.
A 27" definitely will not fit on a Gen1. Found out the hard way that my 26's wouldn't even fit without rubbing the bumper if I turned the wheel even a little bit. Hence me running at ENM with no front bumper.
86AmishMs3 04-25-2014 10:59 AM
What were you running?
Realgib3 04-25-2014 11:03 AM
26x8.5x15 M&H Racemasters with the vision wheels on 25mm spacers.
I adjusted the front height all over the place and that didn't matter at all. As so as I would turn in some, hit the font bumper. Gotta modify it somehow so I can start running with my bumper on.
86AmishMs3 04-25-2014 11:05 AM
Are you lower then stock?
Realgib3 04-25-2014 11:07 AM
Nope, and I even went up quite a bit higher than stock to test, but it really wasn't the height that was the problem.
86AmishMs3 04-25-2014 11:15 AM
Rain on my parade...
I know the M&H RM have a:
8.3" Tread W
10.5" Section W
26" diameter
Where the hoosier's I was looking at 27/10.5 - 15
9" Tread W
10.1" SW
27" diameter.
Current 245/40/18
9.1" TW
9.8" SW
25.8" diameter
I figured there may be a chance. Guess I'll just do regular qtp and 16" rim. Sigh.
Realgib3 04-25-2014 11:26 AM
8.3" Tread W
10.5" Section W
26" diameter
9" Tread W
10.1" SW
27" diameter.
Current 245/40/18
9.1" TW
9.8" SW
25.8" diameter
I'll be trying to set them on a smaller spacer first to see if that clears it up. I'll let you know once I try it.
86AmishMs3 04-25-2014 12:23 PM
Yeah biggest thing is not to get a wheel that pokes so much...but hard to fit a 15" wheel on the front.
AlsChopShop 05-09-2014 04:24 PM
for the guys running slicks... what are you guys setting LC at if at all? i have a set of 26x10.50x15 MT streets ready to go. previous owner (only made 2 passes on them) was dumping the clutch in the 5-6k range to keep from bogging down. suggestions on where to start?
Al
doubleflusher 05-09-2014 07:27 PM
5250 and go up/down by 100 rpm depending on track conditions, until you find the sweet spot.
MZRSPEED 05-10-2014 09:00 PM
Al
Have you test fit them yet? Could you post pix of them on the car when you get a chance please, that's some serious tire.
AlsChopShop 05-10-2014 09:07 PM
here is a test fit with h&r springs. i'm switching back to stock springs next week so i have more room.
https://fbcdn-sphotos-a-a.akamaihd.n...75404107_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.n...24840631_n.jpg
Al
MZRSPEED 05-10-2014 09:16 PM
Al
@LumberJack;
LumberJack 05-10-2014 09:27 PM
Originally Posted by MZRSPEED (Post 2578009)
The reason those ET Streets fit so well is because actual tread width is only 8.3" measuring according to the MT site, section width is 10.5" huge difference. They're fitting very similar to the MT ET Drag of 26x8.5x15 because the actual tread width is only 0.2" different at 8.3" tread width.
AlsChopShop 05-11-2014 12:23 AM
interesting. i just put a tape across the tread and came up with ~8.5". gotta love inconsistency of tire measurements, even within the same manufacturer.
Al
rodrigo 05-19-2014 12:12 AM
My 2 cents .... Fuck drag radials and fuck 16 diameter QTPs
Get at least a 26 tall tire on a 15 .... This is drag racing , sidewall height > tire width
M&H 26x8.5x15 are worth .100-.150 on the 60 FT alone over it's QTP 16 inch wheel counterpart ..... We were cutting low 1.7s at a no prep track with 330-340whp on a 28xx ms3 .... To me shaving calipers is WELL worth what u get in return .... More consistent and better launches
This is Julio (JCMS07) on m&h at Fontana which is an absolute horror to launch on since prepping isn't on the budget .... Car on this pass was mid 2800s lbs and around 330-340whp .... No LC ... No FFS program ... Just hold rpm on launch and powershift the fucker old skool
dtrackstar 06-14-2014 07:11 AM
Anyone running QTPs on an MS6?
Sent from my Nexus 4 using Tapatalk
Page generated in 0.20819 seconds with 11 queries
