![]() | | #41 | ![]() |
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,747
| Not Ranked : 0 score
__________________ 2013 CWP - HPFP - 80d RMM - 3.5" INTAKE - CAT LESS EXTENDED DOWN PIPE - 3PORT - METH/WATER INJ D03 [SIGPIC][/SIGPIC] First 11 sec stock turbo MS3: 1.688, 7.676 @ 91.71 11.977 @ 113.85 |
| The Following User Says Thank You to MZRSPEED For This Useful Post: | He Hate Me (02-23-2014) |
![]() | | #42 | ![]() |
![]() Join Date: Jul 2011 Location: Bowling Green, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 140
| Not Ranked : 0 score Looking for some quick advise from a few drag masters. I am starting to read up more and more after getting addicted this weekend (my first time ever at the drag strip). I was only at an 1/8 mile track but I was mostly concerned about practicing my launch and getting a feel for the car at the track. My quickest 60' was a 2.03 and my quickest 1/8 was only a 9.2 with a 2.1 60'. I was launching around 4k and let the clutch slip a little. I currently have the full face ACT clutch with a streetlite flywheel. After a few runs I really felt like the clutch wasn't grabbing as hard as it could. Maybe I was feathering the clutch too much? Is that the correct way to do it? I was spinning all four out of the gate until I was at about 25 mph. I could tell because of the logs I took during the run. The vehicle speed was bouncing everywhere. I am currently on all seasons and stock wheels. Is this affecting my time much?? Other than weight reduction and a custom tune, is there anything else that should be improved before I head back out and try again? I did make 10 passes without breaking anything, and that includes a rear end that isn't mounted yet. I feel my luck running out though lol I know that I need to work on upgrading my cooling if I want to make solid passes back to back so that is also in the future.
__________________ ![]() JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers Sponsored By: JamesBaroneRacing.com ![]() |
![]() | | #43 | ![]() |
![]() Join Date: Aug 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,823
| Not Ranked : 0 score Fully mounted and still wheel hopping. Should I give it more power coming off the line? I usually take off at around 3kand feather the clutch slightly before letting off. I was going to try Friday but, someone hit the wall at 120 and I was at the end of the line.
__________________ |
![]() | | #44 | ![]() |
![]() Join Date: Jun 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 143
| Not Ranked : 0 score Yo guys, made goal today. Went faster this time so I was able to post: Full weight 12 second pass sub 12.988 on 93 driver tuned on the factory tire. Only had 1/32 left and it was nearly the same DA I had 1107 on 12/21 and today 1071. Only changes: Modded stock airbox and revised midpipe to remove a restriction wtih a re-tune. Thanks guys! SDG, Michael tire_1294_slip | Flickr - Photo Sharing!
__________________ SDG:Racing/Intertune Tv - Videographer/Driver 2013 MS3: 1.954 12.943@108.94 full weight, factory tire on 93 octane. modded intake and updated mid pipe only changes since 12.988. Best 60' - 1.91 on factory 2050 tire, Best MPH - 110.35 @ ENM '14 AT LEAST +10WHP OVER STOCK SETTING FROM SPARK PLUG MOD EXPLAINED: https://vimeo.com/85412223 reserve your set! |
| The Following 6 Users Say Thank You to Livingframe For This Useful Post: | allmotor95pgt (03-19-2014), doubleflusher (03-03-2014), Easter Bunny (03-08-2014), Elwood617 (03-02-2014), mxlplx71 (03-02-2014), MZRSPEED (03-02-2014) |
![]() | | #45 | ![]() |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Neutral : +1 score dang good job. how the heck you get under 2 sec 60 fts so you gutted second cat?
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
| The Following 2 Users Say Thank You to mxlplx71 For This Useful Post: | Livingframe (03-02-2014), MZRSPEED (03-02-2014) |
![]() | | #46 | ![]() |
| Not Ranked : 0 score thanks brother, I have a vid in my sig that shows how I did it. this latest pass was full weight, the pipe is revised to remove a restriction and I added a short cai stack to my stock intake box. 78 degrees and seeing about 265g/s I trapped with about 17.99 psi which really helped on the top end. car is making about 285-290 in the daytime now, it actually runs hotter in the 1000-1500 density altitude range now. there's more in the car, I didn't quite drive its wheels off on saturday but I did on 12/21/13 I could not have gone any faster and it was enough... really pleased to have seen 4 passes 1.96-1.953 down to the wire on the factory tire. the last day it ran it was during the day with more track temp and that really helped... as soon as it got cooler for first elimination round... hop/spin. time for something new! haha I got to get back at that Mustang! DANG IT
__________________ SDG:Racing/Intertune Tv - Videographer/Driver 2013 MS3: 1.954 12.943@108.94 full weight, factory tire on 93 octane. modded intake and updated mid pipe only changes since 12.988. Best 60' - 1.91 on factory 2050 tire, Best MPH - 110.35 @ ENM '14 AT LEAST +10WHP OVER STOCK SETTING FROM SPARK PLUG MOD EXPLAINED: https://vimeo.com/85412223 reserve your set! Last edited by Livingframe; 03-02-2014 at 11:45 PM. Reason: vid |
| The Following 3 Users Say Thank You to Livingframe For This Useful Post: |
![]() | | #47 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score I've seen clearer video's watching porn through static channels.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
| The Following 3 Users Say Thank You to 86AmishMs3 For This Useful Post: |
![]() | | #48 | ![]() |
| Not Ranked : 0 score yup. my go pro had seen finer days. it eventually took a dive off of a 572 chevelle.
| The Following User Says Thank You to Livingframe For This Useful Post: | allmotor95pgt (03-19-2014) |
![]() | | #49 | ![]() |
| Not Ranked : 0 score So close... wanted to say I was really happy I got to run with MZRSPEED tonight, he did awesome. Trifecta 12.1s on my home track in the 1.85 60' range, then belted out a 1.70 at the end of the night which was an incomplete run. I'll let him say more about it if he likes but from my end was awesome to have him back. Last time he was here and we met we were both running 14s haha. He was a full second faster than my car tonight. Much respect. |
| The Following 2 Users Say Thank You to Livingframe For This Useful Post: | allmotor95pgt (03-19-2014), mxlplx71 (03-08-2014) |
![]() | | #50 | ![]() |
| Not Ranked : 0 score Who cuts a 1.70 sixty on the last pass and then misses 3rd like a rookie...me, that's who. Ran three 12.1@114 with 1.8xx sixties, adjusted air pressure, lowered LC and ripped a 1.70 sixty to only miss FUCKING 3rd gear, still managed a 12.2...fuck me 11's are soooo close. ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk
| The Following 12 Users Say Thank You to MZRSPEED For This Useful Post: | 12blkms3 (03-08-2014), 802MS3 (03-09-2014), allmotor95pgt (03-19-2014), doubleflusher (03-10-2014), Elwood617 (03-08-2014), guitarzan134 (03-08-2014), He Hate Me (03-08-2014), killer-ms3 (03-27-2014), lilred (03-08-2014), Livingframe (03-10-2014), mxlplx71 (03-08-2014), snailD (03-08-2014) |
![]() | | #51 | ![]() |
![]() Join Date: Jan 2013 Location: OC, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 633
| Not Ranked : 0 score Really great times! Goes to show, practice pays off. Can't imagine what you would do with a bigger turbo ![]() P.S. Update your sig |
| The Following User Says Thank You to He Hate Me For This Useful Post: | Livingframe (03-10-2014) |
![]() | | #52 | ![]() |
![]() Join Date: Jan 2013 Location: Spring,Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 788
Groaned at 119 Times in 22 Posts
| Not Ranked : 0 score Subing. Shoot. I went first time couple weeks ago. I hit 13.6 @ 111mph. My 60 was awful at 2.6. Get my 60 down to 2 or less I should be twelves easily. Not bad for my first time. It was a fudging adrenaline rush. I'm hooked
__________________ [SIGPIC][/SIGPIC] 2013 Tech Package // NVS tuned // 35% e85 DYNOCOM eddy current chassis dyno @ 332hp 400lbft ![]() |
| The Following User Says Thank You to Ireland For This Useful Post: | Livingframe (03-10-2014) |
![]() | | #53 | ![]() |
![]() Join Date: May 2012 Location: fontana, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 893
Groans: 68
Groaned at 62 Times in 29 Posts
| Not Ranked : 0 score I've been practicing my Launching and it's useless, I just sit there and spin! I'm hitting the track tomorrow and the only thing that's keeping my hopes alive is that I'll be able to lower my tire pressure.
__________________ [SIGPIC][/SIGPIC]2012 Black Mica JBR WP intake// JBR RMM 80 duro// JBR Heavy knob// JBR Boost tubes + Recirc Hose// JBR Spacers// ETS Tmic// UR catless Dp// UR catless Tp// Custom 3in Catback// Go Fast Bits BOV 50/50// Autotechs// NGK one step colder// Megan Coilovers 324whp 368tq Vdyno CF 1.01 268whp 300tq AWD Mustang Dyno 3 GAL. E85 mix STRATIFIED 13.10 @ 108.1 (Nt05's) Auto Club Speedway |
| The Following User Says Thank You to 12blkms3 For This Useful Post: | Livingframe (03-10-2014) |
![]() | | #54 | ![]() |
![]() Join Date: Jan 2014 Location: Camp Lejeune, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,079
![]() Again, that is some great driving!
__________________ It's all about the PMA | |
| The Following User Says Thank You to Elwood617 For This Useful Post: | Livingframe (03-10-2014) |
![]() | | #55 | ![]() |
![]() Join Date: Jun 2008 Location: Moncton, NB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
| Not Ranked : 0 score À prepped track must make a nice difference compared to back road launching
__________________ : )-~ CS 3inch intake, CS FP internals, CS Test pipe, Forge V2, AP v3, JBR 88a RMM and mud flops |
| The Following User Says Thank You to Gr33ntumb For This Useful Post: | Livingframe (03-10-2014) |
![]() | | #56 | ![]() |
Groans: 68
| Not Ranked : 0 score It's at the auto club speed way in fontana. I don't think they've ever heard of track prep!
| The Following User Says Thank You to 12blkms3 For This Useful Post: | DevinS (07-03-2015) |
![]() | | #57 | ![]() |
| Not Ranked : 0 score First pass, Grand Sport Vette, stock I think, he ran a 12.281@115.96 with a 1.96 sixty. I went 12.118@114.57 on a 1.86 sixty. Second pass against the vw, lost the slip. Third pass, LS3 maro, cam'd I believe, street tires. He went 13.108@119.37 with a 2.19 sixty. I went 12.158@114.31 on a 1.82 sixty. Last pass, cut a 1.70 sixty, then missed 3rd. Still managed a 12.246@113.65 Sent from my iPhone using Tapatalk
| The Following 8 Users Say Thank You to MZRSPEED For This Useful Post: | 12blkms3 (03-08-2014), 802MS3 (03-09-2014), btstarcher (03-08-2014), dmeadors (07-04-2015), doctavus (03-09-2014), Elwood617 (03-08-2014), Livingframe (03-10-2014), snailD (03-08-2014) |
![]() | | #58 | ![]() |
| Raiders Bitch ![]() Join Date: Aug 2013 Location: Flagler Beach, FL
Rep Power: 377 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 464
__________________ ![]() '13 CWP Mazdaspeed 3 w/ Technology Package: Cobb Tuning Accessport V3, Autotech HPFP Internals, HTP 3in Intake, Turbosmart Dual Port, Ultimate Racing Test Pipe, CP-e TMIC, Ultimate Racing Catback, DM RMM, DM PMM, CPE Trans Mount, JBR Shifter Bushings, OCC Rice: LED's, Black emblems, Rally Armor mudflaps, OEM Rain Visors, OEM Cargo Tray, Weathertech Floor mats, S204 lip (RIP), PERM shift knob, Cobb Exhaust hangers, Blue Evo X GSR wheels Fluids/other shit: Rotella T6, NGK 1 step colder plugs 235/40 Pilot Super Sports Tuned by Nishan 25% E85 |
| The Following User Says Thank You to Shampu For This Useful Post: | Livingframe (03-10-2014) |
![]() | | #59 | ![]() |
| Not Ranked : 0 score Yeah man, I launched in reverse my first time at the track in a ms3, so you're not doing THAT bad, lol. Sent from my iPhone using Tapatalk
__________________ 2013 CWP - HPFP - 80d RMM - 3.5" INTAKE - CAT LESS EXTENDED DOWN PIPE - 3PORT - METH/WATER INJ D03 [SIGPIC][/SIGPIC] First 11 sec stock turbo MS3: 1.688, 7.676 @ 91.71 11.977 @ 113.85 | |
| The Following User Says Thank You to MZRSPEED For This Useful Post: | Livingframe (03-10-2014) |
![]() | | #60 | ![]() |
| Not Ranked : 0 score Heres a crappy video of me running down a cummins
![]() | | #61 | ![]() |
![]() Join Date: Jan 2012 Location: Mesa, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 620
Groaned at 29 Times in 23 Posts
| Not Ranked : 0 score And no reason to get an upgraded tmic either if you can trap those speeds on a stock one. Good job as always. Wish you were around when i started modifying. |
![]() | | #62 | ![]() |
Groans: 68
| Not Ranked : 0 score First time at the strip, on street tires.
| The Following 2 Users Say Thank You to 12blkms3 For This Useful Post: | Ireland (03-09-2014), Livingframe (03-10-2014) |
![]() | | #63 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Neutral : +1 score Solid work. 12s are close.
__________________ '08 CWP MS3 w/ T3 3071r |
![]() | | #64 | ![]() |
| Not Ranked : 0 score wkd of 3/1 I entered a NHRA bracket race because I got so close the night before to see 12s again in my factory tire car with all the furniture in place @ 3450lbs on 93. I had made some changes to the setup (minor, my new V2 SDG Racing eco midpipe and modified stock airbox, retune) and wanted to see a deeper time than my weight reduced time of 12.988. wasnt able to back it up that session, just not enough runs but I was able to see 1.954/12.943@108.94 which is my personal best at 1071 DA, my 12.988 run was at 1107 DA ;D tire_1294_slip | Flickr - Photo Sharing! Last edited by Livingframe; 03-10-2014 at 01:00 PM. Reason: typo |
| The Following 2 Users Say Thank You to Livingframe For This Useful Post: | allmotor95pgt (03-19-2014), MZRSPEED (03-10-2014) |
![]() | | #65 | ![]() |
Groans: 68
| Not Ranked : 0 score So first time at the strip was a blast, hoping to dip into the 12's with slicks. I've noticed a lot of people running Hoosiers, I'm looking to pick up some DR soon. What do you guys recommend as far as - brand, size, rim, etc? My budget is about $600.
![]() | | #66 | ![]() |
$600 could get you damn close to a 15" wheel/slick setup man, do it right te first time if you're gonna be serious about it. Two 15" wheels will run about $260 Two slicks will be roughly $400 Spacers about $100. And that's close to full price on everything, shop around for some used wheels, and I went with eibach spacers, so I'm sure a no name brand set would be much cheaper. Sent from my iPhone using Tapatalk
| The Following 2 Users Say Thank You to MZRSPEED For This Useful Post: | 12blkms3 (03-27-2014), doubleflusher (03-27-2014) |
![]() | | #67 | ![]() |
Groans: 68
__________________ [SIGPIC][/SIGPIC]2012 Black Mica JBR WP intake// JBR RMM 80 duro// JBR Heavy knob// JBR Boost tubes + Recirc Hose// JBR Spacers// ETS Tmic// UR catless Dp// UR catless Tp// Custom 3in Catback// Go Fast Bits BOV 50/50// Autotechs// NGK one step colder// Megan Coilovers 324whp 368tq Vdyno CF 1.01 268whp 300tq AWD Mustang Dyno 3 GAL. E85 mix STRATIFIED 13.10 @ 108.1 (Nt05's) Auto Club Speedway | |
![]() | | #68 | ![]() |
| Not Ranked : 0 score VW521- 5865P0 is the part # McCormack Racing : Vision Wheels-Sports Star 8.5/24.5-15 As far as the spacers, you can find them on amazon, just look for an off brand. One more thing, DONATE BROWNIE
![]() | | #69 | ![]() |
Groans: 128
| Not Ranked : 0 score m & h have a new 26/8.5/17 8.5/26.0-17 New Tire! makes me want to sell the 15"rims and spacers to try the 17s out
| The Following 2 Users Say Thank You to mxlplx71 For This Useful Post: | Boostman07 (03-31-2014), MZRSPEED (03-27-2014) |
![]() | | #70 | ![]() |
Rep Power: 151849 ![]() Thanks: 55,993
Groans: 1,443
(Thread Starter) | Not Ranked : 0 score The 17's are tempting, but not enough sidewall.
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan |
| The Following User Says Thank You to doubleflusher For This Useful Post: | MZRSPEED (03-27-2014) |
![]() | | #71 | ![]() |
![]() Join Date: Apr 2011 Location: Boynton Beach FL/Flanders, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,007
Groaned at 64 Times in 49 Posts
| Not Ranked : 0 score Ohhhhh I ran a superslow.superslow at superslow mph. My 60' was forever and a half. Wassup? Seriously though best pass to date was 12.7@119. Wherever the hell the time slip is. Time to run real times with real tires this year
__________________ Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq. #HAR Hidden Agendas Racing |
![]() | | #72 | ![]() |
![]() Join Date: Mar 2014 Location: ardmore, ok
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score anybody actually make less power going from a stock TMIC to a FMIC? I had no idea that my old bag'O ice trick would be more efficient at the dragstrip than my new FMIC setup. now on the street fooling around its MUCH BETTER but at the track I cant seem to get the bats down to where they used to be without being a moron and boosting around the return road then hauling ass to the staging lanes and hoping the cool air stays in the car. btw, this is in a ms6 at the 1/8th mile instead of the QTR mile so I don't have as much time to suck up cool air while going down the track. its all about the launch at the 1.8th mile and im going slower now that ive gone FMIC and its killing me..... ugh! |
![]() | | #73 | ![]() |
Groans: 128
Maybe spray some methanol. Post a slip.
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. | |
![]() | | #74 | ![]() |
I have absolutely no experience with meth on disi cars, what are some good kits? lemme see if I can find a slip that doesn't suck. last Thursday I ran a 8.7sumthing with a 1.85 60ft at 81mph but I cant find the slip anywhere. my goal is to eventually run a 12.99 at the 1/4mile or a time equivalent to it at the 1/8th mile. | |
![]() | | #75 | ![]() |
Groans: 128
Big difference.
| The Following User Says Thank You to mxlplx71 For This Useful Post: | Mulenax (03-29-2014) |
![]() | | #76 | ![]() |
| Not Ranked : 0 score thanks, I REALLY hope you aren't screwing with me, ive seen these kind of "gizmo's" on mustangs and other cars and they never seem to work. but I will trust you and order em next time I get some cash. I think I will do at least 2 of both to make them as thick as possible. has anyone done that? or has every one just done 1 of each? jbr says you can do up to 4... |
![]() | | #77 | ![]() |
Groans: 128
| The Following User Says Thank You to mxlplx71 For This Useful Post: | Mulenax (03-30-2014) |
![]() | | #78 | ![]() |
| Not Ranked : 0 score |
![]() | | #79 | ![]() |
![]() Join Date: Jan 2009 Location: Cleveland, OH
Rep Power: 3292 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,280
Groans: 52
| The Following User Says Thank You to Realgib3 For This Useful Post: | MZRSPEED (03-31-2014) |
![]() | | #80 | ![]() |
I was just wanting to try a different setup. I haven't had a chance to try the 26" tires since I've had the spring bags installed, prob try that next. Sent from my iPhone using Tapatalk
| Drag Racing! | Haltech | Drag Racing | 10 | 10-31-2013 09:15 AM |
| drag racing a Gen Coupe 3.8 | ahskeetz | Drag Racing | 88 | 10-03-2011 09:55 AM |
