Autosports Area
> Drag Racing
Like Tree4Likes
 Old 08-28-2011, 03:20 PM   #41
ahskeetz's Avatar
Posts: 431   (View Stats)
ahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the worldahskeetz is the leader of the world
Groaned at 7 Times in 5 Posts
I found my problem with my shifting. I uninstalled my JB SSP and it feels so much better. I can FFS completely fine, and my shifts are smoother. I undoubtedly will get a 14.X run this Friday!
2010 Black Mica MS3 |CP-E Nano.TIP.TMIC.RMM|1G DSM BPV|UR DP.TP|H&R springs|eBay camber arms|ITV-22|Ford XT-M5-QS|Sure Shortcut|PG shift weight|JBR Bushings|Maisonvi Chode Knob|MD OCC|Cobb AP tuned by me
2013 Kawasaki Ninja 300|15T sprocket|Yoshimura R77 full system| Area-P Tune
ahskeetz is offline   Reply With Quote
 Old 08-28-2011, 04:06 PM   #42
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groans: 98
Groaned at 72 Times in 51 Posts
JB SSP has nothing to do with shifting imo. Mine's been perfectly fine for the past +10k miles.
In fact, I grinded and missed 2nd -> 3rd shifts a lot before I installed JBR SSP + aluminum bushing + RMM. After those, I rarely or never missed 3rd gear during WOT runs.
And I'm still on my stock transmission fluid.
Practice more on street. :2cents:
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline   Reply With Quote
The Following User Says Thank You to JS + MS3 For This Useful Post:
breakfstincluded (11-15-2011)
 Old 08-28-2011, 04:17 PM   #43
TRex's Avatar
Posts: 3,139   (View Stats)
TRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the world
Groaned at 106 Times in 69 Posts
did you have your shifter properly adjusted after installed the jbr plate? if not that was probably your problem...also mt-90 and a heavy shift knob will clear up a lot of the notchiness it adds
TRex is offline   Reply With Quote
 Old 08-28-2011, 04:31 PM   #44
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I didn't bother reading all the posts. But you definitely want a degree of wheel slip. Traction control isn't launch control. It applies the brakes and bogs you down.
Just modulate the throttle better through first and half way through second and shift at 5500. Don't miss a gate either.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 08-28-2011, 04:37 PM   #45
Wolfgang5884's Avatar
Posts: 236   (View Stats)
Wolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond reputeWolfgang5884 has a reputation beyond repute
good words of advice.
Wolfgang5884 is offline   Reply With Quote
 Old 08-28-2011, 05:52 PM   #46
jlink38's Avatar
Posts: 330   (View Stats)
jlink38 is the leader of the worldjlink38 is the leader of the worldjlink38 is the leader of the worldjlink38 is the leader of the worldjlink38 is the leader of the worldjlink38 is the leader of the worldjlink38 is the leader of the worldjlink38 is the leader of the worldjlink38 is the leader of the worldjlink38 is the leader of the worldjlink38 is the leader of the world
I respectfully disagree. My third gear grinds got 30 to 50 percent worse after the SSP install. There just isn't enough space in the gate for third it seems, and the SSP accentuates the problem. I still keep mine on because around town it feels so much better than stock, but when I do go to the track I will definitely be uninstalling the SSP. Also, this is regarding grinding third, not missing it altogether. My car will block out out third altogether if you shift into third after running second til 5k rpms. As always this is IMO and YMMV.
Tapatalk
jlink38 is offline   Reply With Quote
 Old 08-28-2011, 07:11 PM   #47
ahskeetz's Avatar
Yes, i had fine-tuned my shifter. I also have aluminum bushings and RMM, as well as synth tranny fluid. Like others have mentioned, the JBR SSP may not work the best for every gen2, including myself.
Tapatalk
Exactly! Same experience with me, except instead of keeping the SSP, I decided to post it for sale. If I start missing the feeling of a shorter throw, I may give the SURE Shortcut a try.
 Old 08-28-2011, 07:12 PM   #48
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
why not go with an actual short shifter, instead of a shortshift plate?
if you have issues with one, you'll likely have issues with the other.
The Following User Says Thank You to socks For This Useful Post:
Broxer (08-30-2011)
 Old 08-28-2011, 07:16 PM   #49
ahskeetz's Avatar
good point, but i don't think the shorter shift justifies the price of a full short shifter kit. I'll keep that money and save up for an AP and internals
 Old 08-28-2011, 08:01 PM   #50
RevolverRob's Avatar
Posts: 423   (View Stats)
RevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the worldRevolverRob is the leader of the world
Groaned at 22 Times in 13 Posts
I would turn all of the systems off, stage it and launch at 2.5k in first, short shift 2nd at 4500-5k, and then run it out to 5500 in 2nd, 5500 in 3rd, and run the track out in 4th.
Concentrate on being SMOOTH. Remember, SMOOTHER is faster (always). Don't try and drive it "fast", try and drive it smooth. Imagine you are driving this car to impress the most beautiful woman in the world and that she is holding a $1000 glass of champagne. If you get to the end of the track and you have been so smooth she hasn't spilled a drop, you can take her (and your win) home.
SMOOTH. On the gas, on the clutch, and on the shifter.
-Rob
2010 Mazdaspeed 3 - Celestial Blue - Stock'ish - Driver Mod
In honor of: PTE. Andrew Miller, 2 Field Ambulance, 1 RCR Battle group, gave the ultimate sacrifice for the ultimate cause of freedom, June 26, 2010.
RevolverRob is offline   Reply With Quote
The Following User Says Thank You to RevolverRob For This Useful Post:
JohnMS3 (09-21-2011)
 Old 08-28-2011, 09:07 PM   #51
ahskeetz's Avatar
-Rob
Can you elaborate on being SMOOTH? I feel like I'd have to slip the clutch more to make it smooth, and shift slower to be smooth. What is this smooth fast you are talking about?
 Old 08-28-2011, 09:42 PM   #52
It just means try and be fluid in your movements. You would rather be slower and smoother, than grind a gear, right? When the pressure is on, it's better to be very deliberate and precise with your movements than waste time trying to go fast and screw up.
This week, try launching from lights and minimizing wheel spin using your right foot and with the TCS and DSC off, get on the throttle and shift gears, focus on smoothly pushing the clutch in (not jamming it to the floor) letting the shifter go into the gate, rather than cramming it there. Roll off the clutch and onto the throttle, trying to get your transitions as smooth as possible (hint if you feel it you're dumping the clutch and not getting on the gas soon enough).
Smooth fast is basically when you are minimizing your movements and maximizing their efficiency. You can only really achieve this through a lot of practice, but you can practice it everyday while driving.
When the time comes, just work the pedals and levers with efficiency and don't focus on being fast or beating the other guy, focus on running the cleanest and best run you can. I can almost guarantee your bud will miss a shift or otherwise blow it and you'll win from driver mod alone.
Good luck dude!
-Rob
The Following 3 Users Say Thank You to RevolverRob For This Useful Post:
ahskeetz (08-28-2011), Broxer (08-30-2011), kjs9471 (11-01-2011)
 Old 08-29-2011, 09:11 PM   #53
ahskeetz's Avatar
Flat-foot shift or no?
 Old 08-29-2011, 09:12 PM   #54
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
One must learn how to walk before he can run grasshopper.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 08-29-2011, 09:18 PM   #55
ahskeetz's Avatar
BUT i was practicing tonightttt!! I took off my JBR ssp, fine tuned my shifter, and now it shifts like a dream. I never could FFS until now, and it pretty much spun through almost all of 2nd (maybe loss of traction not so good). I was watching @DingoDave 's drag videos on Youtube and he doesn't FFS.. not sure which is better at the drag strip
 Old 08-30-2011, 04:32 PM   #56
DingoDave's Avatar
Posts: 764   (View Stats)
DingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the world
Groans: 43
Groaned at 8 Times in 4 Posts
Believe it or not.. I do FFS (or try to lol). Although 90% of those videos were before the FFS/LC addition to the AP. I currently have my LC set to 3000, and FFS set to 5500 on Stage 1 93 oct OTS tune (This is on Hankook tires. Stock dunlops prob need 2500 LC). IMHO, FFS every gear if you can. Just practice getting the left foot and right hand synced up. Good luck.
2013 Black Mica Mazdaspeed 3 - Current daily
2006 WWP Mazdaspeed 6 - Soon to be daily
2006 BCM Mazdaspeed 6 - Project
Tuned with by
DingoDave is offline   Reply With Quote
The Following User Says Thank You to DingoDave For This Useful Post:
ahskeetz (08-31-2011)
 Old 08-30-2011, 09:37 PM   #57
Dahouse702's Avatar
Posts: 487   (View Stats)
Dahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the world
-Rob
LOL ill be thinking about this next time i goto the track!
2007 MS3 Black Mica-Totaled @98500 on 09/2014
Current Car...
2009 MS3 Black Mica GT JBR TRU 3.0 Widepath full intake, BNR S3 v1, GS EBCS, 3 BAR , Forge BPV V2, Autotech internals , Denso Itv22, CNT Downpipe, CX-Racing piping with Cobb v2 core, Cobb AP v2, JBR RMM, JBR PMM, JBR TMM, JBR Oil Catch Can, EGR Delete, JBR TIG, Toyota Seals, HTP battery tray, DashHAWK
Zoom Zoom
Dahouse702 is offline   Reply With Quote
 Old 08-30-2011, 09:43 PM   #58
NCZ13's Avatar
Posts: 1,268   (View Stats)
Groaned at 44 Times in 32 Posts
I wouldnt recommend FFS anything except 3-4th gear.
2008 Cosmic Blue Mazdaspeed3
1986 Mazda RX7
The Following User Says Thank You to NCZ13 For This Useful Post:
 Old 09-03-2011, 11:29 AM   #59
harryclay's Avatar
Posts: 685   (View Stats)
harryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the world
when I was stock a roll raced a 3.8 on the highway from a 4th gear pull and we were dead even. Im car was a turd then too, stock tune stock intake. Should be a easyish kill
2010 super smiley Red MS3
- Corksport SRI/TIP
- ETS TMIC
- CNT hiflow catted long DP
- Sure boost tubes
- SURE motorsports anchors
- SU RMM
- Greddy Type S BPV
- KMD HPFP Internals
- harryclay tune
- Semi-flat black wheels (painted stockers)
- Eibach pro springs ftw
- Michelin Pilot Super Sports 235/40/18
- Yellow 55v fogs
13.69 @ 106 (4g eth mix, intake/tune)
13.67 @106 (intake,dp,tmic, 50/50 eth)
harryclay is offline   Reply With Quote
 Old 09-03-2011, 11:43 AM   #60
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
results??
'08 CWP MS3 w/ T3 3071r
 Old 09-04-2011, 05:01 PM   #61
ahskeetz's Avatar
If you're dead even with a 3.8 genesis at stock from a roll, wouldn't you lose from a dig?
And the track was closed this Friday because of the hurricane , so we will have to do it probably next Friday.
 Old 09-04-2011, 05:14 PM   #62
booo! I was looking forward to see who won!
The Following User Says Thank You to Wolfgang5884 For This Useful Post:
tddvrrn (09-04-2011)
 Old 09-05-2011, 08:31 PM   #63
ahskeetz's Avatar
Well you'll just have to wait
P.S. I'm getting a COBB Accessport this week so I'll be running a Stage 1 map for the race!
 Old 09-05-2011, 08:47 PM   #64
nindoja's Avatar
Posts: 2,395   (View Stats)
Make sure you get a proper MAF cal in before you go thrash it on the drag strip.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 09-06-2011, 01:01 PM   #65
ahskeetz's Avatar
Ok, since I'm a total noob to the AP, what do u mean by that? You're saying I have to make sure that I have the right OTS MAP? or do I actually have to calibrate the MAF sensor?
 Old 09-06-2011, 01:08 PM   #66
cplhoney1228's Avatar
Posts: 25   (View Stats)
cplhoney1228 has a little shameless behaviour in the past
I smoked one before I had my hypertech but we were even till forth
cplhoney1228 is offline   Reply With Quote
 Old 09-06-2011, 02:27 PM   #67
ahskeetz's Avatar
So if you were even til 4th, did you use NOS to smoke it in 4th and 5th?
 Old 09-06-2011, 02:48 PM   #68
warlord's Avatar
Posts: 756   (View Stats)
warlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the worldwarlord is the leader of the world
Groaned at 60 Times in 18 Posts
Flash the OTS map that is most appropiate for your mods. Drive fifty miles. Then follow Chapter 4 in Abilors Tooning guide. You MAF will now be calibrated. Once your MAF is calibrated you can move on to getting fast by leaning out your fuel tables, tweaking boost and then timing. Calibrating the MAF, fuel tables and boost aren't that hard if you follow Abilors Guide. You'd probably want to get help with the timing though.
2018 Audi S6 Prestige. APR Tuned 575 AWHP (current)
2017 Audi A4 APR tuned 315 AWHP (sold)
2014 IS350 (sold)
2013 MS3 Stage2 E85 (sold)
2011 MS3 Stage2 (sold)
warlord is offline   Reply With Quote
The Following User Says Thank You to warlord For This Useful Post:
ahskeetz (09-06-2011)
 Old 09-06-2011, 03:03 PM   #69
nindoja's Avatar
HOW TO CALIBRATE YOUR MAF! With An Example has a great description of exactly what you need to do.
True Red 2009 MS3
Critical Stats:
// 305whp/352tq
The Following 2 Users Say Thank You to nindoja For This Useful Post:
ahskeetz (09-06-2011), DingoDave (09-06-2011)
 Old 09-06-2011, 06:20 PM   #70
ahskeetz's Avatar
Thanks for the link and guide, I'll take a look at it so I can properly tune
 Old 09-06-2011, 06:56 PM   #71
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
With all the hype this thread is getting you would think its the race of the centery.
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
 Old 09-06-2011, 06:57 PM   #72
PunjabiPlaya's Avatar
Posts: 5,131   (View Stats)
PunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the worldPunjabiPlaya is the leader of the world
Groans: 131
Groaned at 45 Times in 17 Posts
it's already been done: Comparison Test : 2010 Mazdaspeed 3 vs. 2010 Hyundai Genesis Coupe 3.8
Cobb SRI
CPE 75 duro RMM
AP - tune in progress
broke ass college student
PunjabiPlaya is offline   Reply With Quote
 Old 09-06-2011, 10:45 PM   #73
ahskeetz's Avatar
Originally Posted by PunjabiPlaya View Post
Haha my buddy got a kick out of this video. He couldn't believe that they rated chose the MS3 over his car lol.. But this race is as much about our cars as it is about our dignity. I win, I talk to shit to him for the next x months. He wins, the odds favored him anyways (he thinks)
 Old 09-18-2011, 01:12 PM   #74
BobbleHead's Avatar
Posts: 2,237   (View Stats)
BobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the world
Groans: 186
Groaned at 33 Times in 25 Posts
is this still going down? BTW i flat foot 3-4 and 4-5. I launch with DSC off around 2900 and go about 1/2 - 3/4 throttle through third. I ran 13.8 for a best. Most runs were low 14s though
2012 BM MS3 w/ tech. Cobb AP V2b: Autotech CDFP internals: JBR 88d RMM: SURE 3" Aeros full intake: Ebay test pipe: Corksport TMIC: Turbosmart BPV: Bridgestone Potenza 235/40 tires: self tuned
BobbleHead is offline   Reply With Quote
 Old 09-18-2011, 04:34 PM   #75
ahskeetz's Avatar
Yep it's still going down, just waiting for a good day that fits both our schedules. I'll definitely update when it happens. Thanks for the advice, I'll experiment with FFS. Just got an AP and could tune it to FFS and use LC, but prob won't have time to do so before the race.
 Old 09-20-2011, 11:22 PM   #76
Lurkers
runswithscissors's Avatar
Posts: 223   (View Stats)
runswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond reputerunswithscissors has a reputation beyond repute
Groaned at 350 Times in 103 Posts
That Gen Coupe is going to wax that ass. They got VTEC and a 9000rpm redline.
runswithscissors is offline   Reply With Quote
The Following 3 Users Say NO Thank You to runswithscissors For This Un-useful Post:
adlpb (09-22-2011), BobbleHead (09-21-2011), Easter Bunny (09-21-2011)
 Old 09-21-2011, 03:45 AM   #77
Tokay444's Avatar
Groans: 793
Your still a faggot that doesn't have a clue what the fuck it's talking about, even in this thread.
We're talking about a Hyundai. Not an S2000, which even with vtec and 9000 rpm redline, even that other faggot who runs 15's and starts in second gear and thinks the ms3 is better suited to rally racing could smoke.
Demodded.
The Seals
 Old 09-21-2011, 03:29 PM   #78
Lurkers
I was joking douche boy!
Cry baby cry.. You're still butt hurt following me around like a sick puppy. I wasn't wrong about anything I stated in that other thread.
Get a life douche boy.
The Following 2 Users Say NO Thank You to runswithscissors For This Un-useful Post:
adlpb (09-22-2011), breakfstincluded (11-15-2011)
 Old 09-21-2011, 05:33 PM   #79
Manny's Avatar
Posts: 1,185   (View Stats)
Manny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the worldManny is the leader of the world
Groans: 320
Groaned at 78 Times in 45 Posts
troll some more breh
Manny is offline   Reply With Quote
 Old 09-21-2011, 05:48 PM   #80
BobbleHead's Avatar
Groans: 186
STFU and donate or GTFO
Drag Racing! Haltech Drag Racing 10 10-31-2013 09:15 AM
Drag Racing 2010 MS3 9900rpm 2010 MS3 - Dyno Sheets/Discussions 176 06-12-2010 10:36 PM
Page generated in 0.57155 seconds with 42 queries
